Publishing Web site driveing me nutz
All Forums >> [ISA 2006 Firewall] >> General >> Publishing Web site driveing me nutz Page: [1]
Publishing Web site driveing me nutz - 13.Aug.2007 7:19:00 PM
wolverine99219
I've been trying this now for 24 hours solid and getting nowhere.
I have a web publishing rule (number 1 in the firewall policy) it was created using the web publishing wizard link in ISA 2006.
The rule is as follows:
Allow from Anywhere to 172.16.5.56
for http
Path /*
I have a web listener on port 80
When I try to browse to the web site externally this rule is ignored.
If I add a rule to allow http from external and internal to the external IP address of the ISA machine - this rule is picked up and I get the under contruction page from the ISA Server NOT the web site.
Any one got any ideas what I am doing wrong?
RE: Publishing Web site driveing me nutz - 14.Aug.2007 11:18:39 AM
NEVER allow connections to the ISA Firewall's Local Host Network unless you really know what you're doing.
From an external client, do you see the connection attempts in the ISA Firewall's firewall logs?
(in reply to wolverine99219)
RE: Publishing Web site driveing me nutz - 14.Aug.2007 12:54:40 PM
wolverine99219
If I remove the localhost from the protocol rule then I get a denied in the log.
It completely ignores the web publishing rule.
If I allow localhost then I see the client requesting access which appears to resolve as the external ip address of the ISA server and therefore loads the local IIS construction page.
I know this is the case because I edited the construction page to prove it.
My question is why is the web publishing rule being ignored? It doesn't figure in the log at all even though it is number one in the processing rules and the protocol rule is around number 8.
This firewall is behind others that are outside of our control. It has a chaining rule to point to the upstream server, and a rule before that telling it to access the internal network directly.
There is an OWA rule which works perfectly. (that's number 2 in the list)
RE: Publishing Web site driveing me nutz - 16.Aug.2007 9:46:46 AM
Chaining Rules?
Local Host Rules?
This ISA Firewall sounds like a nightmare!
I'd crater it ASAP because it's likely be misconfigured to the point of compromise.
BTW -- GET IIS OFF THE FIREWALL.
