Help with publishing several RDPs
All Forums >> [ISA Server 2000 General] >> Server Publishing >> Help with publishing several RDPs Page: [1]
Help with publishing several RDPs - 15.Oct.2007 7:56:39 AM
bl_bl
Hi!
Today I have RDP running on my ISA 2000 Server. From that I can connect from the outside to my ISA Server and to other servers on the inside (via RDP) as well. Now I thought I would make it a step less when connecting and thus I want to directly connect to a specific server on the inside with RDP from the outside.
As said, I have RDP working on the inside and if I connect to one server internally that works. I've changed the registry to set one server on a different port and that is working as well (port 1234).
My idea was that I would connect from the outside specifying the new port (e.g mstsc.exe /v:mydomain.com:1234) and make a forward in the ISA Server but I can't get it to work.
So, is there anything special that I need to know to make it work?
Any good ideas?
TIA!
RE: Help with publishing several RDPs - 17.Oct.2007 2:41:33 AM
Its been ages since i last worked with ISA 2000.
but the idea is that you need to publish your RDP Server.
so creating a publishing rule. not an access rule.
Tarek
Windows Expert - IT Pro MVP
(in reply to bl_bl)
RE: Help with publishing several RDPs - 17.Oct.2007 2:43:16 AM
Hi again,
this article might help you : http://www.isaserver.org/tutorials/Publishing_Windows_2000_Terminal_Services_to_a_NonStandard_Port_.html
(in reply to elmajdal)
