Help!! Slow Login after intsalling ISA 2006
All Forums >> [ISA 2006 General] >> Installation and Planning >> Help!! Slow Login after intsalling ISA 2006 Page: [1]
Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 6:23:41 AM
andrees
Hello,
Can anyone help me with my problem.  I have recently installed ISA 2006 on a Windows Server 2003 R2 64bit machine, and now everytime I try to log into Windows it takes a very long time to log in.  When ISA is not installed it logs in fine.  I thought it might be a DNS issue but my DNS settings are fine.  Has anyone else experienced this problem before and if so can you help?
Many Thanks
S Andree
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 8:40:40 AM
have u installed ISA on a DC ?
Windows Expert - IT Pro MVP
(in reply to andrees)
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 10:15:42 AM
andrees
Sorry, do you mean a Domain Controller?  If so then the answer is no, it is installed on a separate server.
(in reply to elmajdal)
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 10:21:54 AM
have u installed ISA Server Supportability Update package http://support.microsoft.com/?kbid=939455 ?
Whats is your NICs setting on both the client and ISA Server.
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 10:42:46 AM
andrees
Hello,
Yes I have installed the ISA patch.
My NIC settings are as follows.  IP's are issued by DHCP from domain controller.
Client:
IP Address: 192.168.1.10
Subnet Mask: 255.255.255.0
Default Gateway: None
ISA Server:
Internal NIC:
IP Address: 192.168.1.2
Primary DNS: 192.168.1.1
Secondary DNS: 192.168.1.2
External NIC:
IP Address: 172.0.1.1
Subnet Mask: 255.255.0.0
Default Gateway: 172.0.1.254
Secondary DNS: 172.0.1.254
Hope this helps.
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 11:06:02 AM
Never put any DNS Entry on the External NIC,
only your Internal NIC should have a DNS Entry pointing your ur Internal DNS Server, and your Internal DNS Server should be able to forward external requests to your ISP DNS Servers.
check this article : http://www.elmajdal.net/ISAServer/Internal_DNS_Forwarding.aspx
RE: Help!! Slow Login after intsalling ISA 2006 - 26.Oct.2007 11:38:09 AM
andrees
Thanks for the advice, I have changed these settings, however the original problem is still occurring.  Any other ideas would be appreciated?
RE: Help!! Slow Login after intsalling ISA 2006 - 27.Oct.2007 8:01:17 AM
Install this hotfix : http://support.microsoft.com/kb/936594/
RE: Help!! Slow Login after intsalling ISA 2006 - 27.Oct.2007 9:53:09 AM
andrees
Thanks for this, have installed the fix, however problem is still occuring.  ANy more ideas?
RE: Help!! Slow Login after intsalling ISA 2006 - 10.Nov.2007 2:06:31 AM
Heinz
Andree
ISA 2006 or any other version is not supported on 64bit!!!
Try a block standard 32 bit win2003.
Cheers, H
RE: Help!! Slow Login after intsalling ISA 2006 - 10.Nov.2007 2:08:30 AM
Heinz
Andree
only hope you don't have a Dell 1950. I am having lots of fun with a box like this at the moment.
Cheers, H
RE: Help!! Slow Login after intsalling ISA 2006 - 11.Nov.2007 2:15:21 AM
Heinz
Hey
I just fixed my problem, by turning RSS off, on the internal lan card. I bet you have the same issue.
Good luck
H
RE: Help!! Slow Login after intsalling ISA 2006 - 28.Oct.2009 7:41:41 AM
Ramy Kelany
Hi all Please I have the same problem, Is turning RSS off is the solutions?
If yes, how can I do that?
(in reply to Heinz)
