Could Not Install ISA Server 2000 Firewall Client
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> Could Not Install ISA Server 2000 Firewall Client Page: [1]
Could Not Install ISA Server 2000 Firewall Client - 12.Nov.2007 5:14:23 AM
tanvir
Hi Everyone,
I'am trying to installing ISA Server 2000 Firewall Client, but the installer failed with this error.
Also, Event 11708 Source MsiInstaller is also generated.
I try almost everything. Any help will be appreciated.
My environment is,
Server: ISA 2000 w/SP2 on Windows 2003 R2 w SP2
Client: Windows XP Pro w/ SP2 (all critical and security updates are installed)
Tanvir
RE: Could Not Install ISA Server 2000 Firewall Client - 12.Nov.2007 6:04:37 AM
hi,
Are you Trying to install FWC on a 64bit Machine ?
Windows Expert - IT Pro MVP
(in reply to tanvir)
RE: Could Not Install ISA Server 2000 Firewall Client - 12.Nov.2007 7:25:11 AM
tanvir
Its a 32bit machine...
(in reply to elmajdal)
RE: Could Not Install ISA Server 2000 Firewall Client - 12.Nov.2007 5:24:12 PM
any antivirus software installed on the client machine ? maybe u can uninstall it and try .
RE: Could Not Install ISA Server 2000 Firewall Client - 12.Nov.2007 5:54:14 PM
AHIT
8.3 filename limitations have been known to generate this error - see http://support.microsoft.com/kb/M294409
Additionally you may want to consider 'the lastest version' of the firewall client- particularly if a Vista machine - http://support.microsoft.com/kb/929556
http://www.ahit.com.au/isa
(Previous nick: Tolk)
RE: Could Not Install ISA Server 2000 Firewall Client - 12.Nov.2007 11:01:54 PM
tanvir
Thanks elmajdal and AHIT,
By the way i check uninstalling the mcafee v8.0.i but the same.
AHIT, i download the firewall client you mention and it installed successfully and detect my isa.
Will it require any more settings on isa server ?
How do i deploy it on another workstations, execute from local machine. How can it detect the firewall client settings on isa server, because firewall client are need to install from the share \\isaservername\mspclnt.
Please clarify.
Thanks for helping me guys...
Tanvir
(in reply to AHIT)
RE: Could Not Install ISA Server 2000 Firewall Client - 12.Nov.2007 11:17:26 PM
AHIT
Great to hear it worked!
Once you've installed the client and 'pointed it' to your IS server, no additional settigns are required as the client retrieves LAT and other details fromt eh IS server itself.
This MS knowedge base article is about the ISA2004 firewall client so you should be able to use the same principles/options etc with your newly downloaded client - http://support.microsoft.com/kb/838122
RE: Could Not Install ISA Server 2000 Firewall Client - 13.Nov.2007 7:03:47 AM
tanvir
Thanks for your valuable time AHIT...
Tanvir
(in reply to AHIT)
RE: Could Not Install ISA Server 2000 Firewall Client - 14.Nov.2007 6:41:28 AM
AHIT
Valuable? Only if I charge for it!!!
