fwsrv stopped responding & Faulting application wspsrv.exe
All Forums >> [ISA 2006 Firewall] >> General >> fwsrv stopped responding & Faulting application wspsrv.exe Page: [1]
fwsrv stopped responding & Faulting application wspsrv.exe - 6.Dec.2007 11:40:49 AM
ogsi
ISA 2006 Std, Win2003 R2, GFI WebMonitor 4
my connection to the WAN interface broke this morning, these are the errors I see:
Event Type: Error
Event Source: Microsoft ISA Server Control
Event Category: None
Event ID: 14079
Date:  12/6/2007
Time:  9:34:18 AM
User:  N/A
Computer: OGISA06
Description:
Due to an unexpected error, the service fwsrv stopped responding to all requests. Stop the service or the corresponding process if it does not respond, and then start it again. Check for related error messages.
Event Type: Error
Event Source: Microsoft ISA Server 2006
Event ID: 1000
Date:  12/6/2007
Time:  9:37:01 AM
User:  N/A
Computer: OGISA06
Description:
Faulting application wspsrv.exe, version 5.0.5721.240, stamp 46da7812, faulting module unknown, version 0.0.0.0, stamp 00000000, debug? 0, fault address 0x00000000.
from the network I can get to the ISA LAN interface but not to teh WAN interface
from the ISA server I could get to teh WAN and outside
ISA Firewall service showed as started and restarting it didn't change anything
same with WebMonitor's service
had to reboot the machine to get it fixed
one thing I left and you'll ask: Internet Security and Acceleration (ISA) Server 2006 Supportability Update package is loaded on my machine
< Message edited by ogsi -- 6.Dec.2007 11:48:28 AM >
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 3:32:28 AM
If you uninstalled GFI WM4, would this happen also ?
Windows Expert - IT Pro MVP
(in reply to ogsi)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 8:17:17 AM
ogsi
ORIGINAL: elmajdal
isn't it going to the extream?
I want to make sure it is WM4 before doing something like this
and remember - it is a production environment that need protection!
(in reply to elmajdal)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 9:00:38 AM
check these :
http://forums.gfi.com/Gfi_stop_ISA_%3f!%3f/m_900756887/tm.htm
http://forums.gfi.com/Problem_with_files%2c_wrong_or_expired_request%25/m_900756773/tm.htm
You may post also on GFI Forums to check with their support team if you issue is related to ISA Server.
(in reply to ogsi)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 9:09:21 AM
ogsi
this is not even close to my problem and for some reason GFI moved that issue to email support and left the post unanswered
did that but got nothing useful
thanks
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 11:08:45 AM
Which Build do u have ?
FIXED: Microsoft Firewall Service crashed when a custom content-type is blocked
Source : http://forums.gfi.com/Version_and_Build_Information_-_GFI_WebMonitor_4/m_900753333/tm.htm
(in reply to ogsi)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 11:20:53 AM
ogsi
GFI WebMonitor Version 4 Build 20070817
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 11:27:22 AM
ITEngineer
had this issue also with GFI Web Monitor 4.
I ended up uninstalling it. I believe GFI didnt have the required time to seriously test the product before putting it to public.
In the Manually its written that supported platforms: Windows 2000 / Windows 2003, and when i tried installing it on a windows 2000 server ( our isa server is installed on it  ) , i could not install it and had errors, reported this to GFI and lately they published a KB article that GFI Can not be installed on a Win 2000
(in reply to ogsi)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 11:30:33 AM
ogsi
so you're saying go back to WM3?
(in reply to ITEngineer)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 11:34:25 AM
ITEngineer
Before going back to WM3, try uninstalling  v4.
Did u have such errors before installing GFI ?
(in reply to ogsi)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 11:36:31 AM
ogsi
I've upgraded from v3 which require uninstalling v3 then installing v4
if I just remove it I get no protection at all!
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 11:38:57 AM
ITEngineer
Ok keep you Server crashing .
At least start helping your self so that we be able to assist you.
If you do not desire to troubleshoot your issue, then why you posted it here ?
(in reply to ogsi)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 11:43:39 AM
ITEngineer
ORIGINAL: ogsi
also you didnt answer my question , did u have this issue before installing gfi wm4 ?
(in reply to ogsi)
RE: fwsrv stopped responding & Faulting application wsp... - 7.Dec.2007 12:00:19 PM
ogsi
don't get mad!
I had no such issues before WM4
my problems started only this week while WM4 is running smoothly for over a month
if I new it is definitly WM4 I would go back but I'm not sure at all
RE: fwsrv stopped responding & Faulting application wsp... - 19.Dec.2007 1:07:53 PM
Wu
I am getting these exact smae errors without any of the GFI stuff being installed...  Not sure if that pushes the conversation in another direction on not, but I may be inlisting the help of MS if I don't get it resolved soon.
(in reply to ogsi)
RE: fwsrv stopped responding & Faulting application wsp... - 2.Jan.2008 8:52:59 AM
ogsi
I didn't find a solution yet but if it's not GFI related maybe someone from Microsoft (Thomas, you might help here) can take a look
(in reply to Wu)
