Local User Authentication
All Forums >> [ISA 2006 Firewall] >> Access Policies >> Local User Authentication Page: [1]
Local User Authentication - 15.Jan.2008 11:19:40 PM
daz618
We have a number of sites with local PC user accounts that are not members of the internet users group however are still allowed to access a short list of valid sites. This works fine. However when they enter a url that is not allowed they get prompted for a username/password to access the internet.
I have another access rule that allows domain users who are members of the internet users group full internet access.
I would like local users to get the redirect rule saying they are not a member of the internet users group contact the Helpdesk etc rather then just getting an authentication prompt. Any help would be appreciated.
RE: Local User Authentication - 16.Jan.2008 9:01:44 AM
abqtech
You can do this by creating a DENY rule based upon the following criteria:
Action: Deny (redirect HTTP requests to this web page) provide the URL to a webpage that indicates "they are not a member of the internet users group contact the Helpdesk".
Protocols: All outbound traffic (or just web protocols HTTP, HTTPS, if that's what your requirements are based upon)
To: External
Users: All Users | Exceptions: the User Set you've created for domain\internet users group.
And make sure that you account for the excess logging on your ISA Server if you chose to enable logging for this rule.  Obviosly you should enable logging until you ensure that the rule is working as expected.
Also make sure that you place this rule above all other access rules that require authentication, and below any rules that all the anonymous proxy access your environment requires.
(in reply to daz618)
RE: Local User Authentication - 16.Jan.2008 5:52:06 PM
daz618
Thanks for the info, unfortuantely still the same authentication prompt when trying to go to a non valid site rather then the access denied page.
A little more information the local users are local administrators with blank passwords a no no i know but that what i have been given to work with. When the local administrator password is set to the same as the isa server this rule works fine. My problem is i cant reset the local admin password for all these users and in the short term they will have to stay blank. The isa servers local admin password cannot be set to blank.
Any other ideas for a work around? Thanks in advance.
(in reply to abqtech)
RE: Local User Authentication - 16.Jan.2008 9:43:14 PM
abqtech
my apologies I totally glossed over the fact that these are local users, rather than domain users...
Are these local users which are allowed to access the short list of sites are hitting an Access Rule that is configured for All Users?  If not, how is this Access rule configured?
RE: Local User Authentication - 16.Jan.2008 10:09:19 PM
daz618
Yes these are local administrator/users set to access the valid sites url list using the access rule for 'All Users'.
RE: Local User Authentication - 16.Jan.2008 10:20:13 PM
abqtech
Okay.  Are all your clients web proxy clients, or do you have any SecureNAT or Firewall cleints?
RE: Local User Authentication - 16.Jan.2008 10:22:03 PM
daz618
All local users are anonymous/web proxy users other domain users are SecureNAT and Firewall.
RE: Local User Authentication - 16.Jan.2008 10:23:36 PM
abqtech
Also are you clients going to bypass ISA for the URL you want them re-directed to, or will that request be proxied by ISA?
RE: Local User Authentication - 16.Jan.2008 10:26:23 PM
daz618
Request proxied if possible, either way is ok if we can get it to work.
RE: Local User Authentication - 16.Jan.2008 10:36:43 PM
abqtech
I have not tried this, but it makes sense to me at the moment.  You'll need two Access rules:
First the Deny Rule:
Deny_Anonymous_HTTP
Action: Deny (redirect HTTP requests to the Helpdesk URL)
To: External (execptions - add the small list of sites, either by adding them to a domain name set or URL Set)
Users: All Users
Next create the Allow rule, below the Deny Rule:
Allow_Anonymous_HTTP
Action: Allow
Protocols: HTTP, HTTPS (others if needed)
To: (the small list of sites, added to the domain name set or URL Set mentioned in the Deny exception list above.)
Users: All Users.
Try this and let me know... but please be aware of where this fits in your policy, it will need to be above any authenticated rules, and depending on where it's placed and what your secureNAT clients are doing may interfere with them.
RE: Local User Authentication - 16.Jan.2008 11:08:23 PM
daz618
This works however blocks the internet users group access to all web sites.
Adding the Internet Users Group to the Exceptions of the deny rule causes the prompt to pop again for local users access non valid sites.
RE: Local User Authentication - 17.Jan.2008 9:58:15 AM
abqtech
If you can identify the anonymous web proxy users by their IP address.  You could create a computer set and add each client IP into that computer set, and then use that computer set in the Rules:
Deny_Anonymous_HTTP
Protocols: All outbound (or just the protocols used in the Allow Rule)
Users: All Users
Action: Allow
Users: All Users.
Let me know if that does the trick.  Otherwise you may be better off going with a 3rd party plug-in capable of authorization and content filtering, such as Websense.
< Message edited by abqtech -- 17.Jan.2008 10:00:38 AM >
RE: Local User Authentication - 17.Jan.2008 5:33:48 PM
daz618
Ahh that seems to have fixed it. Thanks alot for you help much appreciated.
RE: Local User Authentication - 17.Jan.2008 5:59:45 PM
abqtech
daz618
glad I could help....
cheers!
