RSS |
Problems with Hostlogger, ISA server 2004, service wont start
Problems with Hostlogger, ISA server 2004, service wont... - 21.Jan.2008 4:40:27 AM
The ISA Newbie
As the topic says, my service wont start after ive registered the HostLogger.dll What have i done wrong? Event Viewer says: Cannot load an application filter Web Proxy Filter ({4CB7513E-220E-4C20-815A-B67BAA295FF4}). FilterInit failed with code 0x8007007e
< Message edited by The ISA Newbie -- 21.Jan.2008 4:55:48 AM >
RE: Problems with Hostlogger, ISA server 2004, service ... - 21.Jan.2008 5:12:12 AM
The ISA Newbie
Solved
RE: Problems with Hostlogger, ISA server 2004, service ... - 21.Jan.2008 5:27:00 AM
Have u deleted the dll file after u have registered it ?
_____________________________ Tarek Majdalani Windows Expert - IT Pro MVP Facebook : https://www.facebook.com/ElMajdal.Net
RE: Problems with Hostlogger, ISA server 2004, service ... - 21.Jan.2008 5:46:55 AM
The ISA Newbie
No i didnt But the problem is solved, i just read in a thread that you said it should be in %SystemRoot%\System32\ But the .dll file needs to be in the ISA directory according to the Error logged in the Event Viewer. But its solved
RE: Problems with Hostlogger, ISA server 2004, service ... - 22.Jan.2008 2:09:19 PM
Yah, as it is said : quote: Copy HostLogger.dll to the ISA Server installation folder. in the readme file that come with it , and as it is also stated on my site : http://www.elmajdal.net/ISAServer/HostLogger.aspx Glad that you sorted out and thanks for the follow up. Tarek
RE: Problems with Hostlogger, ISA server 2004, service ... - 24.Jan.2008 9:00:16 AM
azfar
Should I just copy it in isa install dir or also in system32. And after registerign the dll should I only need to restart firewall service or i have to enable it in addons.
New Messages
No New Messages
Hot Topic w/ New Messages
Hot Topic w/o New Messages
Locked w/ New Messages
Locked w/o New Messages
Post New Thread Reply to Message Post New Poll Submit Vote Delete My Own Post Delete My Own Thread Rate Posts
