RSS |
filtering sites and messengers
filtering sites and messengers - 21.Feb.2008 6:30:40 AM
gaurav.agr
Hi Need help on blocking web sites and messengers on ISA 2006. I have a Windows 2003 server without a domain and with ISA 2006. Installed the firewall client application on a XP machine. I tried disabling the "Proxy Filter" in HTTP protocol so that users don't need to be under proxy but should still not be able to use blocked sites and messengers. It didn't work as the HTTP blocking goes away from the access rule. Can someone help bypassing proxy but still be able to block content.
RE: filtering sites and messengers - 22.Feb.2008 1:42:25 AM
ofeefee
I'm having a similiar problem. I would like to block, www.playboy.com , so I have a domain set with: *.playboy.com However, in ISA, this doesn't handle playboy.com by itself, so do I need to add this as well, or is there a tweak to make *.site.com include site.com. This is causing me major grief using urlblacklists I download. Thanks, Derek
_____________________________ Google is your friend!
RE: filtering sites and messengers - 22.Feb.2008 2:44:08 AM
Hi, use this format : *playboy.com HTH, Tarek
_____________________________ Tarek Majdalani Windows Expert - IT Pro MVP Facebook : https://www.facebook.com/ElMajdal.Net
RE: filtering sites and messengers - 25.Feb.2008 4:11:13 PM
ofeefee
that worked, thank you.
RE: filtering sites and messengers - 25.Feb.2008 6:22:28 PM
Great ! Thanks for the follow up. Tarek.
RE: filtering sites and messengers - 26.Feb.2008 1:16:48 PM
ofeefee
another followup. I have multiple domains I'm blocking: pandora.com, pandora.net, pandora.tv I tried *pandora* for a domain set, but this did not work. How would I do this, would *pandora.* work, I haven't tried this yet.
RE: filtering sites and messengers - 26.Feb.2008 1:18:25 PM
ofeefee
went ahead and tried it after I posted, and *site.* doesn't work.
RE: filtering sites and messengers - 26.Feb.2008 1:55:40 PM
Hi, You will have to block each individually.
RE: filtering sites and messengers - 27.Aug.2008 7:26:17 PM
jgarcia
Hi Elan, Is there a "default" or "suggested" list of sites one can use when blocking sites?
New Messages
No New Messages
Hot Topic w/ New Messages
Hot Topic w/o New Messages
Locked w/ New Messages
Locked w/o New Messages
Post New Thread Reply to Message Post New Poll Submit Vote Delete My Own Post Delete My Own Thread Rate Posts
