Listening on Mutlple IP Addresses
All Forums >> [ISA Server 2004 General ] >> Server Publishing >> Listening on Mutlple IP Addresses Page: [1]
Listening on Mutlple IP Addresses - 15.Mar.2008 3:41:25 PM
Puffin
Howdy,
I've been using Microsoft ISA Server since it was known as Microsoft Proxy Server and love the product to bits, however I'm in danger of having to ditch it internally due to a line of business vendor ("ConnectWise PSA") saying that ISA Server is known to cause problems due to caching of transaction information.
Although I've had multiple IP addresses on my DSL connection since I had it installed, up until today I was only using the router address.  I went out and got myself a nice Cisco 857W to replace my existing one because ConnectWise needs it's own IP address.
To meet the vendor requirements, I need to be able to publish ports 80, 443 and 3389 on the ConnectWise server to the Internet, however 443 and 3389 are already published to our main server.  This means that we're going to have to use 11.22.33.149 as the SBS box and 11.22.33.148 as the ConnectWise box - the Cisco router is already set up to map 11.22.33.149 to 192.168.1.100 and 11.22.33.150 to 192.168.1.101 however I can't find a way of setting up ISA Server to add an additional external IP address on which to listen or assign that address to a publishing rule
I'm running ISA Server 2004 Standard on SBS 2003, however due to the complexity of the setup I'm not using the SBS wizards to alter the firewall config.  Is it even possible to have multiple static IP addresses on an ISA Server?  I don't want to spend another 2 or 3 hours playing around trying to get something to work that simply won't due to a limitation and will have to say 'goodbye' to ISA after all these years.
Regards, Ade.
RE: Listening on Mutlple IP Addresses - 15.Mar.2008 3:49:44 PM
Rotorblade
Ok, so don't cache it! Create a non-caching rule.
HTH
RB
David Melvin
Ohio
(in reply to Puffin)
RE: Listening on Mutlple IP Addresses - 15.Mar.2008 3:53:37 PM
Rotorblade
Are you saying that you are trying to configure multiple gateways?
RB
David Melvin
Ohio
RE: Listening on Mutlple IP Addresses - 15.Mar.2008 4:01:45 PM
Rotorblade
As far as adding an additional IP; assign a secondary IP to the External NIC and then create a new Web listener that is bound to the secondary IP. With ISA 2004, you will need to bind a new SSL certificate for the new web listener. As you mentioned, the issue will be with 3389 port access because the you already have a server publishing rule bound to that port.
HTH
RB
David Melvin
Ohio
(in reply to Rotorblade)
RE: Listening on Mutlple IP Addresses - 15.Mar.2008 4:54:33 PM
Puffin
No, I want ISA Server to listen to 11.22.33.149 (default) and 11.22.33.148 (additional) and then to be able to setup publishing rules (or a 'allow everything rule') to forward requests to 11.22.33.148 to 192.168.192.4.
RE: Listening on Mutlple IP Addresses - 15.Mar.2008 4:56:08 PM
Puffin
Okay, sounds good as far as HTTP/HTTPS publishing goes, but are you saying that it's not possible to create unique rules for a secondary IP address bound to the external NIC?
RE: Listening on Mutlple IP Addresses - 15.Mar.2008 6:28:58 PM
Rotorblade
Sorry, I should have been a little clearer. You should be able to publish to the separate servers as long as you create the server publishing rule to listen to their respective assigned IP on the external NIC.
HTH
RB
David Melvin
Ohio
