HTTP but not HTTPS on Most Machines
All Forums >> [ISA 2006 Firewall] >> General >> HTTP but not HTTPS on Most Machines Page: [1]
HTTP but not HTTPS on Most Machines - 8.Apr.2008 9:25:43 PM
wstrong
Most client machines on internal network can get HTTP information from Internet but not HTTPS. There is one machine that CAN get HTTPS data.
Setup: New Dell1950 Quad x64 4 MB 2 NICs running Windows Server 2008, Domain controller, DNS Server, Hyper-V Roles.
Have one Virtual Machine running Win Server 2003 R2 SP2 with ISA Server 2006 installed configured as edge firewall successfully routing requests from internal to external network - all clients can Ping through.
All clients are Windows XP SP2 and appear to have same configuration (Internet Options --> Connections --> LAN Settings all options unchecked).
Requesting HTTPS page from most client machines results in "Denied Connection" on ISA Server log.
One client machine can connect through with an Alowed Connection message.
I've been looking and looking but I can't find any differences between the client machines and I can't find any reason that ISA would be treating requests from one machine differently. (One note is that the machine that works was turned on when the ISA Server SW was being installed but that doesn't seem at all important).
Any suggestions where to look or what to try next?
RE: HTTP but not HTTPS on Most Machines - 29.May2008 6:50:27 PM
cptsternn
I loaded (and reloaded) ISA 2006 in a Hyper-V machine a few times last night.  I had a problem with SMTP passing through.  I found an obscure blog entry that said ISA has a problem with the the NIC's the Hyper-V uses and will drop packets.  In my case the issue showed up right after I would load ISA and reboot: it would take 15 minutes to log in.
The solution in my case was simple:  change the NICs to the Legacy Nic, redo the IP info and you are all set.   To save some clean up change the existing nics to DHCP before you remove them.
(in reply to wstrong)
