RE: User Access Check tool
All Forums >> [ISA 2006 Misc.] >> ISA Firewall Tools >> RE: User Access Check tool Page: <<   < prev  1 [2]
RE: User Access Check tool - 4.May2008 6:54:56 AM
ITEngineer
ORIGINAL: fixitchris
Of course I can develop more software.
Did you check out my MalwareDomains.com Import Tool?
http://sync-io.net/MD2ISA.aspx
Actually I was thinking of writing an IDS plug-in to ISA, but Snort3.0 is coming out at the end of the year and it would be pointless for me to compete with that.
Also an asp.net web page based on the Access Check Tool would be nice so that each domain user can check their own Internet access without having to ask the admin for a list of allowed domains.
Hi Fix again,
is this tool really working ? when i try to surf to http://www.malwaredomains.com/files/domain.txt it gives me page can not be displayed.
can you double check please.
(in reply to fixitchris)
Post #: 21
RE: User Access Check tool - 4.May2008 9:25:00 AM
dglosser
www.malwaredomains.com/files/domains.txt
< Message edited by dglosser -- 4.May2008 2:09:53 PM >
(in reply to ITEngineer)
Post #: 22
RE: User Access Check tool - 4.May2008 9:48:21 AM
ITEngineer
have you tried the link ? its giving page not found
(in reply to dglosser)
Post #: 23
RE: User Access Check tool - 4.May2008 11:35:49 AM
fixitchris
ITENG I answered your post  regarding MalwareDomains here http://forums.isaserver.org/m_2002065825/mpage_1/key_/tm.htm#2002066342
Post #: 24
RE: User Access Check tool - 4.May2008 11:42:48 AM
ITEngineer
Thanks.
Will check it there.
Post #: 25
RE: User Access Check tool - 4.May2008 2:10:58 PM
dglosser
domains.txt, plural. somehow the display was good but the link was bad. My bad.
Also, lines with a comment (#) in the first column are NOT active:  false positives,  inactive domains, or duplicates....
< Message edited by dglosser -- 4.May2008 2:13:44 PM >
Post #: 26
RE: User Access Check tool - 6.May2008 11:46:05 AM
paulo.oliveira
Hi fixitchris,
I´m currently using ISA 2006 and my clients are webproxys or secureNAT. Do you have or know a free software to check what websites are they visiting? The original ISA reports does not show this essencial information in nowdays!!
Thanks and congratulations on your software it´s really great!!
PS: Maybe you can add this feature to your software... what do you think?
Post #: 27
RE: User Access Check tool - 7.May2008 3:37:28 PM
Hi Paulo,
check my article here : Creating Detailed Reports Using ISA Server 2006 & Excel
Tarek
(in reply to paulo.oliveira)
Post #: 28
RE: User Access Check tool - 7.May2008 3:49:35 PM
Hi Chris,
i just tried you latest build and i think the result for the deny rule is wrong.
i have a rule for example:
Deny >Http/Https >  From a Computer Set > To External Except mail.company.com > AD Group
The result under the deny tab is as follows :
Protocols :
Http    Allowed
Https  Allowed
Computers/Url Set/ Domains
mail.company.com Denied
Post #: 29
RE: User Access Check tool - 7.May2008 4:52:26 PM
fixitchris
UPDATE: http://www.sync-io.net/Files/ISA_UserAccessChk_Binary.zip
Binary updated to show correct rule action for denied and disabled rules.
You're right... I created a rule:
DENY > HTTP/HTTPS > FROM COMPUTER1 > TO EXTERNAL EXCEPT DOMAIN.COM > AD USER
and I get
External is Allowed
Http/Https is Allowed
DOMAIN.COM is Denied
This is how the data is represented by ISA.  I think the logic is that -1 * -1 = 1, in other words:
DENY RULE * ALLOW HTTP = DENY HTTP
DENY RULE * DENY domain.com = ALLOW domain.com
< Message edited by fixitchris -- 7.May2008 5:31:40 PM >
(in reply to elmajdal)
Post #: 30
RE: User Access Check tool - 9.May2008 3:49:26 AM
Hi Chris,
Denies rules Reports are accurate now.
Thanks.
By the way, i think you should remove the : NOTE: Report does not include disabled or denied rules.
and can you please the default text GATEWAY.
Post #: 31
RE: User Access Check tool - 9.May2008 12:21:14 PM
fixitchris
done.
Post #: 32
