Error Code 502 : Not enough storage is available to process this command.
I am getting above error after 2 0r 3 days then i can not browse any sites for this I will have to restart the server everytime whenever i got the error. I kindly request you to please provide me the solution.
I have search on google also and make some changes in registry but no use still getting the same error.
I've run into the same error twice now since early July. I'm running 2006 SP1, supportability update, etc.
My server has 4GB of ram, a 20GB cache and had a 6GB page file (split to two 4GB files now). Plenty of free space on both drives.
When I opened ISA Management and went to cache, it told me the size of the drive/size of the cache was unavailable. I refreshed and it displayed correctly - browsing worked for a short while, then right back to 502.
I created the IRPStackSize reg key and set it at 18 and rebooted. We'll see how that holds up - once the issue is resolved it takes a while to reappear. Previously I disabled caching, deleted the cache file and reenabled it. The service restart could have been the fix, and not this action.
I'm using MSDE logging (was using 1.7GB before reboot). I have two web filters installed - GFI webmon w/norman+bitdefender and ClearTunnel. I've used webmon for a while - with 2004 standard and did not have this problem.
I only have 85 web browsing users (this is just a firewall/proxy for web browsing) and it's sitting on a 6mbit DSL connection.
Well folks,
I haven't had this trouble on an ISA, but have had on other machines.
Check the Value of this registry entry. Try a value somewhere between 6 and 11. Just remember what it was at to start with so if this doesn't work you can put it back where it was.
I *think* I've pinned it down to a memory leak in GFI WebMon, but I'm not 100% sure. I disabled/reenabled the web filter and the problem disappeared/reappeared. Since rebooting the machine it hasn't reoccurred. I've enabled debugging for webmon.
I'm not sure about the lanmanserver parameter - that's for the server service (network shares), and the ISA server isn't sharing any files to clients.
