Disable all Flood mitigation
All Forums >> [ISA 2006 Firewall] >> General >> Disable all Flood mitigation Page: [1]
Disable all Flood mitigation - 25.May2008 4:33:25 AM
xAyiDe
Is it possible to disbale all flood mitigation so I can run Nessus against it?
RE: Disable all Flood mitigation - 25.May2008 8:08:22 AM
You can disable it by click on the General node from the left pane, and then click on Configure Flood Mitigation Settings, then untick the checkbox Mitigate flood attacks and worms propagation
Windows Expert - IT Pro MVP
(in reply to xAyiDe)
RE: Disable all Flood mitigation - 27.May2008 12:56:32 PM
NGS
Hello
You can disable Floog Mitigation. It is OK if you scan the isa interface but if you do some scan(nmap) to another external host, the isa server you will block the scan, no matter if the Flood Mitigation is disable or not.
                                    routing
(internal host)scan ----> | ISA | ------> External Host.
                             Flood Mitigation
                                   Disable
The ISA server seen to have the SYN attack protection enable by default and is not configurable.
See my post: ISA Server Flood Mitigation
(in reply to elmajdal)
