WPAD in single domain with multiple DNS and ISA servers in different sites
All Forums >> [ISA 2006 General] >> General >> WPAD in single domain with multiple DNS and ISA servers in different sites Page: [1]
WPAD in single domain with multiple DNS and ISA servers... - 4.Jun.2008 3:48:46 AM
mit_3990
We are facing problem with WPAD configuration in ISA. We have installed the multiple ISA in different sites. All ISA servers are member of single domain. We have configured multiple DNS in single domain.
Now we have to enable WPAD configuration for internal networks of ISA server. The internal network should get respective site ISA server as proxy address. But in our scenario it gets sometimes different site ISA server as proxy address.
Is it necessory to keep WPAD alies name in DNS or else alies name can we keep.
Any suggestions will be appricated.
HTH
Mitesh Patel
RE: WPAD in single domain with multiple DNS and ISA ser... - 4.Jun.2008 4:24:16 AM
FYI - I have removed your original post as this one appears to be a duplicate...
(in reply to mit_3990)
RE: WPAD in single domain with multiple DNS and ISA ser... - 4.Jun.2008 8:03:25 AM
paulo.oliveira
have you tried to take a look at Tomīs article?
http://www.isaserver.org/tutorials/Configuring-WPAD-Support-ISA-Firewall-Web-Proxy-Firewall-Clients.html
Regards.
RE: WPAD in single domain with multiple DNS and ISA ser... - 5.Jun.2008 1:10:00 AM
mit_3990
Thanks for the reply.
I have been gone through the given link. WPAD is working but i need respective ISA Server would be available for Internal network of respective sites. In my scenario there is single domain with multiple DNS so i could not make more than one WPAD alies for different ISA server so sometimes it takes different site ISA server for its local site also.
Mitesh Patel
(in reply to paulo.oliveira)
RE: WPAD in single domain with multiple DNS and ISA ser... - 5.Jun.2008 2:58:29 AM
HePa
The solution is DHCP, if you have local DHCP server on the remote locations(?). You can also use netmask ordering but easiest is to use DHCP.
HePa
RE: WPAD in single domain with multiple DNS and ISA ser... - 5.Jun.2008 3:00:40 AM
HePa
Copy and paste from http://www.isaserver.org/tutorials/Configuring-WPAD-Support-ISA-Firewall-Web-Proxy-Firewall-Clients.html, which paulo referd to:
Another method that can be used to deliver autodiscovery information to Web Proxy and Firewall clients is DNS. You can create a wpad alias entry in DNS and allow browser clients to use this information to automatically configure themselves. DNS is a viable option, but you have to be aware that if you have multiple networks, each with itís own ISA Firewall, then youíll need to have different wpad entries for each network. While you can support multiple networks and multiple ISA Firewalls using DNS by taking advantage of netmask ordering, most companies perform to use DHCP wpad to support local networks, since they need to use local DHCP server anyway to assign local clients addressing information.
HePa
(in reply to HePa)
RE: WPAD in single domain with multiple DNS and ISA ser... - 5.Jun.2008 4:16:15 AM
mit_3990
Thank you Henrik Parkkinen ...
I will check and revert back with the status.
Thanks & Regards
Mitesh patel
RE: WPAD in single domain with multiple DNS and ISA ser... - 5.Jun.2008 8:58:04 AM
HePa
No problems!
Give some feedback when you've tested your configurations.
Good luck and have fun!
Best regards
Henrik Parkkinen
HePa
RE: WPAD in single domain with multiple DNS and ISA ser... - 9.Jun.2008 9:44:27 AM
Hey guys,
Just to reinforce the point that Henrik made, you can use either DNS with netmask ordering or DHCP.
(in reply to HePa)
RE: WPAD in single domain with multiple DNS and ISA ser... - 10.Jun.2008 12:51:51 AM
mit_3990
Dear Henrik Parkkinen and Toms
As per your guideline, WPAD working in single domain with multiple DNS using DHCP. But we are not using DHCP in all network and in some network DHCP configured in router and it is handled by third party.
Can we configure the same DHCP scope for WPAD in router, HOW ??
Can we do the same WPAD configuration in single domain with multiple DNS and multiple ISA using different way ???
I dont know how to configure DNS netmask order for WPAD.
Thanks & Warm Regards
Mitesh Patel
RE: WPAD in single domain with multiple DNS and ISA ser... - 10.Jun.2008 11:23:37 AM
Read up on DNS netmask ordering over at the MS Technet site. It's very easy to configure and works will within the constraints presented by the feature.
RE: WPAD in single domain with multiple DNS and ISA ser... - 11.Jun.2008 2:19:16 AM
HePa
A KB article of what we discussed:
http://support.microsoft.com/kb/842197
HePa
RE: WPAD in single domain with multiple DNS and ISA ser... - 11.Jun.2008 10:34:18 AM
Hi Henrik,
Good one!
(in reply to HePa)
RE: WPAD in single domain with multiple DNS and ISA ser... - 13.Jun.2008 1:47:51 AM
HePa
No problems!'
Thx for the feedback.
BR
Henrik Parkkinen
HePa
