which Antivirus realtime scanner to use for filesystem
All Forums >> [ISA Server 2004 Misc.] >> Tom's ISA Firewall Blog Discussion >> which Antivirus realtime scanner to use for filesystem Page: [1]
which Antivirus realtime scanner to use for filesystem - 20.Jun.2008 2:43:30 PM
jens@compcond.com
Which antivirus realtime scanner for the file system do you guys use on ISA
I'm not talking about an ISA plug-in to do gateway antivirus, bbut standard file system protection of ISA itself
A lot of the newer AV's (even corporate ones) are implementing restrictions on your newtwork connections (Trend Micro now has a web filter built in to their realrime scanner)
I really would not like to interefere with the network connections on the ISA, so does anyone know of an antivirus that works well
Jens Madsen
PS Using ISA 2004 Standard Ed
RE: which Antivirus realtime scanner to use for filesystem - 23.Jun.2008 8:44:13 AM
Hi Jens,
I never install a host scanning AV scanner on the ISA firewall, since it's not required. If you manage the ISA firewall correctly, there is no way for malware to get onto the firewall. I don't install AV on PIX or ASA, and I don't install it on the firewall.
(in reply to jens@compcond.com)
RE: which Antivirus realtime scanner to use for filesystem - 29.Jun.2008 5:32:19 AM
Hi Jens,
Check Toms Blog here : Do Not Install a Host AV Program on the ISA Firewall!
Forefront MVP
Website : http://www.elmajdal.net
Covering ISA Server/TMG, Windows Server 2008 & Windows 7,Windows 8, Exchange Server 2010,2013
Twitter : @elmajdal
RE: which Antivirus realtime scanner to use for filesystem - 29.Jun.2008 12:12:53 PM
Hi Tarek,
Good one!
(in reply to elmajdal)
RE: which Antivirus realtime scanner to use for filesystem - 29.Jun.2008 8:59:44 PM
You Bet , I remember all your posts
Forefront MVP
Twitter : @elmajdal
RE: which Antivirus realtime scanner to use for filesystem - 30.Jun.2008 9:13:29 AM
I wish I could :)
