ISA 2000 to ISA 2006
All Forums >> [ISA 2006 General] >> Installation and Planning >> ISA 2000 to ISA 2006 Page: [1] 2   next >   >>
ISA 2000 to ISA 2006 - 8.Jul.2008 5:33:32 AM
Syntel
We use still ISA 2000. But we want to upgrade. Better, we want a NEW server and an brand new installation of ISA 2006 (or later). Is there a possibility (a workout) how to export and import the rules from ISA 2000 to ISA 2006. ISA 2006 has the possibility to export/import rules by Backup. ISA 2000 has not this function. Is there a way or do I have to import the rules (and protocols and packets etc.) by hand
Hans
RE: ISA 2000 to ISA 2006 - 8.Jul.2008 7:51:48 AM
Syntel
Supplement:
ISA 2000 has BIF as extension for backup. ISA 2006 XML. Is there a conversion tool?
Hans
(in reply to Syntel)
RE: ISA 2000 to ISA 2006 - 8.Jul.2008 8:06:19 AM
paulo.oliveira
Hi Hans,
not sure if this can help you, but you can give a shot:
Migrating an ISA Server 2000 Configuration to a Clean ISA Server 2004 Server Upgrading to Microsoft Internet Security and Acceleration (ISA) Server 2004 Enterprise Edition
http://www.isatools.org/tools/isaexportimport.zip
Paulo Oliveira.
RE: ISA 2000 to ISA 2006 - 8.Jul.2008 8:24:37 AM
Syntel
Paulo,
Thanks. When I run the export vbs I have to answer some "y" questions. After that I get a vbs script error. This maybe has to do with the Windows 2003 version. But, thereis a import vbs file. When I install this file on the new isa 2006 (test server), nothing happens when i doubleclick. No config is changed. Is the tool also for ISA 2006 or only for ISA 2004 (as I read in the documents)?
Hans
(in reply to paulo.oliveira)
RE: ISA 2000 to ISA 2006 - 8.Jul.2008 1:34:35 PM
There is no direct path to upgrade from ISA 2000 to ISA 2006.
What you can do is to upgrade first to from ISA 2000 to ISA 2004 and then from ISA 2004 to ISA 2006.
ISA 2004 CD has a tool to upgrade isa 2000 configuration to isa 2004 which can then be directly imported into isa 2006.
else.
check these articles :
http://www.isaserver.org/tutorials/Offline-Rule-Bases-Objects.html
http://www.isaserver.org/tutorials/Exporting-Importing-Troublesome-ISA-Server-Rule-bases-2004-2006.html
http://www.isaserver.org/tutorials/Exporting-ISA-objects-2000-2004-2006.html
RE: ISA 2000 to ISA 2006 - 8.Jul.2008 3:56:53 PM
Budmaas
ORIGINAL: Syntel
Paulo,
Hans
It failed for me ..... & i'm still looking for the solution........ . nothing works as good as win 2000 & ISA 2000 .......
2004/2006  or not so user freindly to play with it as 2000.
RE: ISA 2000 to ISA 2006 - 9.Jul.2008 1:35:16 AM
Syntel
@Tarek Majdalani
Thanks, but I don't want a upgrade I want a new install. Therefore is it possible to use the ISA 2004 migration tool for making the xml-file and then use this file for import this in ISA 2006? Will this work? And how do I get this "migration tool"? Can I download it somewhere? Otherwise I have to buy first ISA 2004 and then ISA 2006 ($$)
Hans
RE: ISA 2000 to ISA 2006 - 9.Jul.2008 4:07:08 AM
Yes, this is what i was saying. You can export the xml file and then use it on a new server to import it into ISA 2006.
The tool is only available in the ISA 2004 CD.
RE: ISA 2000 to ISA 2006 - 9.Jul.2008 4:42:06 AM
Syntel
But then I have to buy first ISA 2004 for only the migration tool. Then throw away the CD's and buy ISA 2006 CD's. Isn't that grazy? Why can I not download this tool? Is there anybody who wants to give me a download link or email me this tool?
Hans
RE: ISA 2000 to ISA 2006 - 9.Jul.2008 5:20:38 AM
Syntel
And, is ISA 2004 still available? If not, I never can upgrade to ISA 2006
RE: ISA 2000 to ISA 2006 - 9.Jul.2008 8:52:32 AM
Budmaas
I have ISA 2000 -2004-2006-2008;) .
All r not working for me as I want.......if anybody wants just PM me or let me know how do you want it . . . . .. ?
for your help  ......
RE: ISA 2000 to ISA 2006 - 9.Jul.2008 9:08:54 AM
Syntel
Thats not an answer, thats frustation. Wrong topic.
RE: ISA 2000 to ISA 2006 - 9.Jul.2008 9:47:10 AM
Budmaas
ORIGINAL: Syntel
You requested below
Hans
It's not frustation sir .......... I told you that just for your help.
I'm trying to find the time to work on it  ... . .. I  have 2000/2004/2006 all. If you want take it.
rest upto you
< Message edited by Budmaas -- 9.Jul.2008 9:48:32 AM >
RE: ISA 2000 to ISA 2006 - 10.Jul.2008 1:32:47 AM
Syntel
Sorry by that, I misunderstood
I just want the ISA2KEPORT.EXE, thats all. So I can test my update. So if you can give/send me only that tool I'll be happy
Hans
RE: ISA 2000 to ISA 2006 - 10.Jul.2008 2:47:14 AM
Budmaas
ORIGINAL: Syntel
Hans
If u have FTP access or any  other way to transfer this file online.
I cannot mail  it to you as you requested in PM.
sorry sir
RE: ISA 2000 to ISA 2006 - 10.Jul.2008 5:03:10 AM
Syntel
Sorry no FTP, not allowed. What's wrong with email?
RE: ISA 2000 to ISA 2006 - 10.Jul.2008 11:19:02 AM
Budmaas
ORIGINAL: Syntel
PM me your Email . .let me try to attach  it for you ... !!!
RE: ISA 2000 to ISA 2006 - 15.Jul.2008 8:21:44 AM
Syntel
Anyone? Who can help me out with sending me ISA2EXPORT (please)
Hans
(in reply to Budmaas)
RE: ISA 2000 to ISA 2006 - 15.Jul.2008 9:32:03 AM
rm_knight
Hi Hans,
I have sent you an email with a url for you to be able to download the export tool.
You may still have some work to do afterwards as the XML file will still be in the ISA 2004 format.
I am sure Tom has talked about this somewhere but I can not find it at the moment..
Rich.
Post #: 19
RE: ISA 2000 to ISA 2006 - 16.Jul.2008 1:27:15 AM
Syntel
Rich.
Thanks, I received the tool. And no, Tom (?) has not told me about some conversion of the exported xml file to ISA 2006 format. Is there a document of how to convert the ISA 2004 xml output to ISA 2006 format?
Hans
(in reply to rm_knight)
Post #: 20
