Hi all, I have developed scripts for backup isa settings and dhcp as well. I merged these scripts in a simple and smart application . it will make exported .xml well-organized by date . "day.month.year"
just one-click will export your isa settings and give it a date mark. and with another click importing will be done as well. if any one need an especial edition , just post it here , will be pleasure to help. read "Read Me.txt" file . Download
this forum gave me alot , and this is a simple way to say thanks. ;) i have mailed info@isaserver.org to test this program , but i didn't get the answer yet . But it was tested by me and others, it works fine as well as it should . i hope it help you .
what if i dont have 2 paritions disk ? and only C. would this mean that i will not be able to use your app !!
not all ppl will go and change their drive letters just to run an app.
Anyway, i think i have found the xml file. If you do not have a D drive, then a folder inside C:\Program Files\Backup Manager will be created and the xml file will be stored there.
actually i found a 640 kb xml file : ISA-Backup-15.08.2008.xml
and it has my configurations.
as a test, you can remove the drive letter on your D drive, so that you have only 1 parition , C. and then test your tool. You will find your backup xml file inside the c:\program files\backup manager\ISA-Backup-15.08.2008.xml
i will take this file and try to restore it on another ISA Server late this night.
