Importing plain text to isa via isacripts.org script help !
All Forums >> [ISA 2006 Firewall] >> HTTP Filtering >> Importing plain text to isa via isacripts.org script help ! Page: [1]
Importing plain text to isa via isacripts.org script he... - 28.Aug.2008 9:15:15 AM
CJJ
I have been trying to get the script ISA_Fill_Domain_Name_Set.vbs to work from ISAscripts.org but cant figure out where you define the paremeters for domainnameset and filename.txt. I have tried several places as well as using the set parameter but with my knowlege of vb very little I have been unsuccesful and need some help figuring this out. Here is the top half of the script where I believe is the portion where you define these paremeters.
' Script Name: ISA_Fill_Domain_Name_Set.vbs
'     Version: 1.2
'      Author: Jason Fossen (
www.ISAscripts.org )
' Last Updated: 18.Feb.2008
'     Purpose: Automatically update an ISA Server Domain Name Set with domains; for example,
'              these could be domains of spammers, pornographers, hacking sites, etc.
'   Arguments: First arg is name of Domain Name Set, in double-quotes if necessary.  The
'              second arg is the HTTP URL, local full path, or file name (if in same
'              folder as script) of a text file containing the domain data.  This file,
'              if it contains comments, must use #-marks or semicolons to denote comments.
'              Each line must be just a domain name, but if IP addresses are in the list, they
'              will be ignored automatically.  This script is compatible with, but does not
'              require or depend on, the lists at:
http://urlblacklist.com
'                   http://www.squidguard.org/blacklists/
'              It also works if a listed domain begins or ends with a period, or begins
'              with "*." as a wildcard.  The file with the domains can use either
'              Windows-style or UNIX-style newlines, it's compatible with both.  Note that
'              each domain will be added twice: once with a prepended "*." and another
'              without the leading "*." wildcard, since ISA won't match on just the plain
'              domain name in a URL if the domain has "*." prepended to it in the set.
'        Note: Depending on the speed of the ISA box, importing a 10MB file with 500,000
'              domains can take between two and four hours.  This is a bottleneck imposed
'              by ISA, not the Windows Script Host or VBScript.  Hence, schedule your
'              imports during off-peak hours and run the script with the Start command
'              to launch it with a lower multi-tasking priority; for example, like this:
'                    "start /belownormal cscript.exe ImportBlacklist.vbs Bad-Sites domains"
'        Note: The fastest way to see that the Domain Name Set had been filled correctly
'              is to close and open the ISA MMC console again, not by refreshing.
'              Works on both ISA Standard and Enterprise.
'       Legal: Public Domain.  Modify and redistribute freely.  No rights reserved.
'              SCRIPT PROVIDED "AS IS" WITHOUT WARRANTIES OR GUARANTEES OF ANY KIND.
'              USE AT YOUR OWN RISK.  Test on non-production servers first!
Option Explicit
On Error Resume Next
ReDim aDomainsArray(0)      'Array of Domains to be added to the Domain Name Set.
Dim sDomainNameSetName      'Name of Domain Name Set to be created and/or updated.
Dim bUseLocalDomainsFile    'If true, use local file.  If false, get domains from http URL.
Dim sDomainsFilePath        'An HTTP URL or a local filesystem path to a file of domains.
Dim oFPC                    'See MakeIsaObjects()
Dim oIsaArray               'See MakeIsaObjects()
Dim oFileSystem :  Set oFileSystem = WScript.CreateObject("Scripting.FileSystemObject")
Call CatchAnyErrorsAndQuit("Problems creating the FileSystemObject.")
' Main()
Call ProcessCommandLineArguments()
Call CreateIsaObjects()
Call MakeArrayOfDomains()
Call CreateDomainNameSet()
Call EmptyTheDomainNameSet()
Call CreateNewDomains()
' Procedures
Sub ProcessCommandLineArguments()
  ' First arg...
  sDomainNameSetName = WScript.Arguments.Item(0)
  Dim sArg  : sArg  = LCase(sDomainNameSetName)
  If (WScript.Arguments.Count = 0) Or (WScript.Arguments.Count => 3) Or (sArg = "/?")_
      Or (sArg = "-?") Or (sArg = "/h") Or (sArg = "/help") Or (sArg = "--help") Then
      Call ShowHelpAndQuit()
  End If
  ' Second arg...
  sDomainsFilePath = WScript.Arguments.Item(1)
  If InStr(LCase(sDomainsFilePath), "http://") = 0 Then
      bUseLocalDomainsFile = True   'Use a local text file.
  Else
      bUseLocalDomainsFile = False  'Use an http URL.
  End If
  On Error Goto 0
End Sub
Sub CreateIsaObjects()
  'This sub is just a placeholder for something to add later on...
  Set oFPC = CreateObject("FPC.Root")
  Set oIsaArray = oFPC.GetContainingArray
  Call CatchAnyErrorsAndQuit("Problems connecting to ISA Server or ISA Array.")
End Sub
< Message edited by CJJ -- 28.Aug.2008 9:16:49 AM >
RE: Importing plain text to isa via isacripts.org scrip... - 28.Aug.2008 1:18:40 PM
paulo.oliveira
check this: http://sync-io.net/ISATools.aspx
MalwareDomains.com ISA Import
Paulo Oliveira.
(in reply to CJJ)
RE: Importing plain text to isa via isacripts.org scrip... - 29.Aug.2008 8:00:41 AM
CJJ
< Message edited by CJJ -- 10.Sep.2008 10:30:00 AM >
(in reply to CJJ)
RE: Importing plain text to isa via isacripts.org scrip... - 10.Sep.2008 10:35:19 AM
CJJ
I have created a text file urlset.txt and copied the list of urls from urlblacklist.com however using the software from sync-io.net I keep getting the error "Unable to validate domains.txt format - Import Aborted" and have been unable to get it to work. Any ideas fore I thought this program read standard url formats ?
(in reply to CJJ)
