502 proxy error
All Forums >> [ISA 2006 Web Proxy] >> Web Proxy Client >> 502 proxy error Page: [1]
502 proxy error - 30.Aug.2008 4:31:05 AM
aamir.khamkar
Error Code: 502 Proxy Error. Connection refused(10061)
IP Address: 10.10.2.5
Source: proxy
10.10.2.5 is my additional domain controller
I could not open the link.arriyadhholding.com.sa:8443
help thanks2 all
RE: 502 proxy error - 30.Aug.2008 9:32:51 PM
paulo.oliveira
by default ISA only allow the 443 port for SSL connections, if you need to use an specified port to SSL connections, check this article: http://www.isaserver.org/articles/2004tunnelportrange.html
Paulo Oliveira.
(in reply to aamir.khamkar)
RE: 502 proxy error - 31.Aug.2008 1:16:12 AM
aamir.khamkar
thanks for ur reply,
i had created ssl tunnel port range 8443 but isa is still blocking the site .
Error Code: 502 Proxy Error. The ISA Server denied the specified Uniform Resource Locator (URL). (12202)
RE: 502 proxy error - 1.Sep.2008 3:49:25 PM
paulo.oliveira
how´s is configured your access rule?
Paulo Oliveira.
RE: 502 proxy error - 2.Sep.2008 3:54:36 AM
aamir.khamkar
i had created allow internal to external rule for https1 but in vain.
my http is allowing outbound traffic for port 443 it is not allowing me to edit .
RE: 502 proxy error - 2.Sep.2008 8:43:17 AM
paulo.oliveira
you can´t edit the default protocols that comes with ISA. In your case, you need to create a new protocol allowing the 8443 port and add to your rule.
Note: The http and https protocols, allow respectivitly the 80 and 443 port.
Paulo Oliveira.
RE: 502 proxy error - 2.Sep.2008 9:26:41 AM
aamir.khamkar
hi paulo,
i had created new protocol and add it to my rule(allow outbound traffic from anywhere to anywhere) but still same problem
isa is still blocking my site.https://plesk.domain.com:8443
regards,
Aamir
(in reply to paulo.oliveira)
RE: 502 proxy error - 2.Sep.2008 10:46:27 AM
paulo.oliveira
what does ISA logs tells you?
Paulo Oliveira.
RE: 502 proxy error - 8.Sep.2008 4:54:26 AM
aamir.khamkar
hi paulo,
isa log information is as follows:
log type:web proxy(forward)
status:407 proxy authentication required
rule:outbound
source: internal
dest:external(10.10.2.7:8443)
request:arriyadhholding.com.sa:8443
filter information:req id:oba127b1;compression:client=no;compres rate=0%;compres:client=no,compress rate=0%,decompress rate=0%
protocol:ssl tunnel
plz help
RE: 502 proxy error - 8.Sep.2008 4:58:20 AM
aamir.khamkar
initiated connection
lof type:firewall service
status:
rule:
source:local host 1674
destination internal:10.10.2.5:8443
protocol:plesk
these two type of logs i get
Aamir
RE: 502 proxy error - 8.Sep.2008 9:37:41 AM
paulo.oliveira
Hi Aamir,
hi paulo,
rule:outbound
source: internal
protocol:ssl tunnel
plz help
try to disable authentication on your ISA server. The logs are telling ISA is requiring authentication and not blocking the 8443 port.
Paulo Oliveira.
RE: 502 proxy error - 9.Sep.2008 6:26:43 AM
aamir.khamkar
hi paulo,
can u plz help me how to disable authentication.i am having A.D.S
Aamir
RE: 502 proxy error - 6.Jun.2011 11:52:26 AM
THX
I have a question regarding allowing TCP Port 8443 outbound via running the ISA Tools script.
Once you execute the script I understand that you are now allowing port 8443 to be allowed outbound.
Is 8443 then considered part of the HTTP protocol or part of the HTTPS protocol?
Is it possible to limit access to a website that utilizes port 8443?
Or, is that now impossible once you run the script to allow 8443 outbound?
