Email Notification - Message is not RFC compliant
All Forums >> [ISA 2006 General] >> General >> Email Notification - Message is not RFC compliant Page: [1]
Email Notification - Message is not RFC compliant - 30.Oct.2008 2:42:22 PM
artemgassan
I am having very strange issue with alerts and report. When I simulate test email it is not going out. My rule works and when I monitor mails server here is what I get: Message is not RFC compliant
Thu 2008-10-30 14:24:53: Session 2078; child 2; thread 3064
Thu 2008-10-30 14:24:53: Accepting SMTP connection from [123.123.123.123:54299]
Thu 2008-10-30 14:24:53: --> 220-mail.domainname.com ESMTP MDaemon 9.6.6; Thu, 30 Oct 2008 14:24:53 -0400
Thu 2008-10-30 14:24:53: --> 220----------------------------------------------------------------------
Thu 2008-10-30 14:24:53: --> 220-Company Name (www.domainname.com) and its affiliated companies
Thu 2008-10-30 14:24:53: --> 220-do not authorize the use of its proprietary computers and
Thu 2008-10-30 14:24:53: --> 220-computer networks to accept, transmit, or distribute
Thu 2008-10-30 14:24:53: --> 220-unsolicited bulk e-mail sent from the internet.
Thu 2008-10-30 14:24:53: --> 220-Effective immediately: Company Name may no longer accept connections
Thu 2008-10-30 14:24:53: --> 220-from IP addresses which have no reverse-DNS (PTR record) assigned.
Thu 2008-10-30 14:24:53: --> 220 ---------------------------------------------------------------------
Thu 2008-10-30 14:24:53: <-- HELO firewallserver
Thu 2008-10-30 14:24:53: --> 250 mail.domainname.com Hello ymir, pleased to meet you
Thu 2008-10-30 14:24:53: <-- MAIL FROM:<firewallalerts@domainname.com>
Thu 2008-10-30 14:24:53: --> 250 <firewallalerts@domainname.com>, Sender ok
Thu 2008-10-30 14:24:53: <-- RCPT TO:<firewallalerts@domainname.com>
Thu 2008-10-30 14:24:53: --> 250 <firewallalerts@domainname.com>, Recipient ok
Thu 2008-10-30 14:24:53: <-- DATA
Thu 2008-10-30 14:24:53: Creating temp file (SMTP): c:\mdaemon\queues\temp\md50000000903.tmp
Thu 2008-10-30 14:24:53: --> 354 Enter mail, end with <CRLF>.<CRLF>
Thu 2008-10-30 14:24:53: Message size: 234 bytes
Thu 2008-10-30 14:24:53: --> 554 Message is not RFC compliant
Thu 2008-10-30 14:24:53: <-- QUIT
Thu 2008-10-30 14:24:53: --> 221 See ya in cyberspace
Thu 2008-10-30 14:24:53: SMTP session terminated (Bytes in/out: 348/884)
RE: Email Notification - Message is not RFC compliant - 30.Oct.2008 4:07:28 PM
artemgassan
Ok it was setting on my NEW version mails server:
Found how to fix it: http://lists.altn.com/WebX?14@803.iUTIauSHQ5j@.eedcd5e
Setup | Miscellaneous Options, Servers tab about 1/2 way down the dialog
is the line 'SMTP server checks __ message __ parameters for RFC
compliance'. Turn off the message check since the problem is with the
message itself. Then MDaemon should let the messages pass. Once you
have a few messages, you can then look to see what makes them non-RFC
compliant. From the 9.56 Release notes about this feature:
o [4980] Added SMTP parameter RFC compliance checking. The SMTP server
   will now reject parameters which contain control or 8-bit characters.
   This check has been combined with the existing basic body compliance
   check and can be toggled on/off via a switch in Misc. Options|Servers
   which was relabeled to reflect this new functionality. Compliance
   checks on SMTP parms and body content are now ENABLED by default which
   is a departure from older versions. Disable if you must receive mail
   from non-compliant sources.
(in reply to artemgassan)
RE: Email Notification - Message is not RFC compliant - 4.Nov.2008 7:55:08 AM
Nice tip!
