I am useing isa server 2006 sp1 and its working fine. all users have limited access. they can open only 5-6 sites. Everything is ok but now users try to search in google they getting this error.
We're sorry... ... but your query looks similar to automated requests from a computer virus or spyware application. To protect our users, we can't process your request right now. We'll restore your access as quickly as possible, so try again soon. In the meantime, if you suspect that your computer or network has been infected, you might want to run a virus checker or spyware remover to make sure that your systems are free of viruses and other spurious software. If you're continually receiving this error, you may be able to resolve the problem by deleting your Google cookie and revisiting Google. For browser-specific instructions, please consult your browser's online support center. If your entire network is affected, more information is available in the Google Web Search Help Center. We apologize for the inconvenience, and hope we'll see you again on Google.
To continue searching, please type the characters you see below:
When i have save it, it use 403 Forbidden name for file. What could be problame.and other sites working fine. it is only with google.Plz give me any solution.
Hi, Thanks for reply all sites working but its only with google but now its ok now google also working fine. some users have full access and some users have access only for google and two more sites all working fine but when they search in google anyting they got mssege To continue searching, please type the characters you see below: then google work fine. but now all ok, i just want what is the reason for it ?i didn't make any change.its only with google.
No it isn't ISA related but google related. If you make a bit of an advanced query or there are a lot of queries at once google might block them. It also might be if your want to see more results per page then default.
< Message edited by Dumber1 -- 14.Jan.2009 8:32:23 AM >
Marcel Netherlands
MCTS, MCITP (SA,EA) MCP, MCSA:Security, MCSE:Security, CCNA, CCSA, CCSE, CCSE+ No matter how secure, there is always the human factor. http://www.phetios.com/
