ISA Server 2004 on SBS 2003 premium
All Forums >> [ISA Server 2004 General ] >> ISA 2004 SBS >> ISA Server 2004 on SBS 2003 premium Page: [1]
ISA Server 2004 on SBS 2003 premium - 13.Nov.2008 11:24:47 AM
vikramsokhi
I have installed ISA Server 2004 on my SBS 2003 server which is also my domain controller with exchange server installed. After finishing installation and restart of the server, my other computers on the network lost connection with the server. All the shared drives and shared short cuts stops working. machines start taking lot of time to loggon. I have to uninstall the ISA Server 2004 from the server and every thing start working normal.
Could some body advice me what I have dont wrong. what should be the steps to follow to implement ISA Server on sbs 2003 premium edition.
Hope to hear from you guys soon.
Mnay thanks
Vikram
RE: ISA Server 2004 on SBS 2003 premium - 13.Nov.2008 1:17:52 PM
Rotorblade
It's a danggumm firewall dude! The default installation is secure – NO ACCESS until you create access rules to allow traffic, or modify the ISA system policy for intra-domain access. SBS servers have a purpose but you should reconsider adding ISA to the mix. Best option is to have running as a domain member on it’s own box.
HTH
RB
David Melvin
Ohio
(in reply to vikramsokhi)
RE: ISA Server 2004 on SBS 2003 premium - 13.Nov.2008 1:52:19 PM
SteveMoffat
One should read the post. It's SBS 2003 Premium. It includes ISA.
Use the connect to the internet wizard after you have installed ISA.
You are using the install wizard to install ISA?
Steve
www.isaserver.bm
(in reply to Rotorblade)
RE: ISA Server 2004 on SBS 2003 premium - 14.Nov.2008 9:48:07 AM
Rotorblade
Steve, I’m not a complete idiot! I know that it includes ISA! I was simply trying to make a point!
David Melvin
Ohio
(in reply to SteveMoffat)
RE: ISA Server 2004 on SBS 2003 premium - 14.Nov.2008 9:53:14 AM
SteveMoffat
Your post was irrelevent to the OP's post. He wanted an answer, not a rant.
Steve
www.isaserver.bm
RE: ISA Server 2004 on SBS 2003 premium - 14.Nov.2008 11:17:41 AM
Rotorblade
Thanks, next time I'll try to keep my rants to a minimum and answer the full question!
The OP wanted to know what he did wrong, so I told him what I thought, and in my opinion,  that he should not even try to go down the wrong road of trying to install ISA (activate it because it is included in SBS 2003 Premium) because it’s not an recommended practice!
Dave
David Melvin
Ohio
RE: ISA Server 2004 on SBS 2003 premium - 14.Nov.2008 12:59:18 PM
SteveMoffat
Note the subject line of the post, and this snippit from the original.
"Could some body advice me what I have dont wrong. what should be the steps to follow to implement ISA Server on sbs 2003 premium edition. "
And the correct answer...use the connect to the internet wizard.
HTH
S..:)
Steve
www.isaserver.bm
RE: ISA Server 2004 on SBS 2003 premium - 15.Nov.2008 10:45:20 AM
Rotorblade
Ok Steve, you are right,  but remember; “people that live in glass houses should not throw stones”
:) touché
Hope he get's it worked out.
http://forums.isaserver.org/m_2002075843/mpage_1/key_/tm.htm#2002075898
My point was, TS troubleshooting aside, and even that's dodgy, it's a FIREWALL.
Allowing F&P sharing from an edge security device? That's good security..
David Melvin
Ohio
RE: ISA Server 2004 on SBS 2003 premium - 15.Nov.2008 10:49:48 AM
SteveMoffat
You're still not getting the point.
SBS is a one server solution. Exchange server, SQL Server, F& P Serbver. That's what it's designed to be. It is "NOT" Server 2003. The SBS team spent many many hours, tweaking it and locking it down. That is what the various wizards do.
As you are probably aware. There have been no documented compromises of a properly deployed ISA 2004 yet, and that includes SBS 2003.
Steve
www.isaserver.bm
RE: ISA Server 2004 on SBS 2003 premium - 21.May2009 9:59:54 AM
vikramsokhi
Hi Guys.....
I am back here again... Good to see u all again.... Guys I am still struggling with my old problem and now my IT Manager has given me a dead line to install & configure ISA Server because we face lot of problem if users abusing internet. So guys i am asking for your help again. I tried to install ISA server again on my SBS 2003 R2 and i face 2 errors first it keep on asking me for the certificate (i don’t understand which one to connect to internet) and second I cant configure it because after installing ISA all te computers on my network disconnect from the server all the shares and every thing stops working and after uninstalling the ISA everything is back to normal.... Cant figure out what shall I do to make it work. Please guys help me with this please....
Many thanks
Vikram
RE: ISA Server 2004 on SBS 2003 premium - 21.May2009 10:19:34 AM
SteveMoffat
Have you installed ISA from the SBS 2003 Premium disk?
Steve
www.isaserver.bm
RE: ISA Server 2004 on SBS 2003 premium - 21.May2009 10:25:14 AM
vikramsokhi
Yes I have.... But cant figure out what to do next bec It keep on asking me about the Internet Connection Certificate
RE: ISA Server 2004 on SBS 2003 premium - 21.May2009 11:57:48 AM
SteveMoffat
Doesn't sound to me like it's the premium disk...It should install ISA and allow your file & print traffic.
The SBS ISA is not like ordinary ISA. There are scripts that run to configure it when you runt the connect to the internet wizard. You have done this?
Steve
www.isaserver.bm
RE: ISA Server 2004 on SBS 2003 premium - 21.May2009 12:01:32 PM
vikramsokhi
Thanks for the reply...Trust me mate it is Premium ISA Disk comes with SBS. I have tried to run the OWA wizard so many time every time it say either create a new certificate or import. I dont understand which certificate it is asking me and keep on going me error msgs...
Please help me with that I cant understand what I am doing wrong
RE: ISA Server 2004 on SBS 2003 premium - 21.May2009 12:15:08 PM
SteveMoffat
It's looking to create the certtificate for OWA...basic stuff. Just follow the prompts.
Steve
www.isaserver.bm
