ISA 2006 Access Rule Issue - Blocking Anonymous User
All Forums >> [ISA 2006 Firewall] >> Access Policies >> ISA 2006 Access Rule Issue - Blocking Anonymous User Page: [1]
ISA 2006 Access Rule Issue - Blocking Anonymous User - 29.Dec.2008 1:59:28 AM
sgraham977
I'm hoping someone can help me...we currently have an ISA 2006 server which is protecting our network from the outside world and have got a number of different rules in place on the firewall for this purpose.
One of the rules is to block a group called 'Blocked Users' from accessing anything externally.  This group has only got a few people in this group and the rule is to block only these people.  I have however, recently discovered that this rule is also blocking 'Anonymous' user somehow even though I haven't specified it to block the 'Anonymous' user.
This is causing some issues for us in that there are a couple of sites which use Java and use anonymous user to connect to it that are being blocked which is causing issues as we need to connect to these sites.  One of the sites is the VodaFone site (Australia) which is for mobile phones etc.
When I disable this particular rule it works fine but when I don't disable it just keeps displaying an isa 'authentication' dialog box and just doesn't work.
Any help would be appreciated.
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 29.Dec.2008 5:46:09 PM
inderjeet
The reason why you are seeing ISA authentication prompt is that you are trying to access the website using local user credentials though you have selected the Integrated authentication on ISA web proxy. This requires you to login with Domain user to use it.
you Java issue which is sending annonymous requests can be resolved (Hopefully) by Allowing "Require All users to authenticate" on web proxy tab for internal interface
Remember, this will require all your client machines to be either Web proxy clients or Firewall Clients. You can not have SecureNAT clients accessing internet using this rule....
Inderjeet (MSFT)
(in reply to sgraham977)
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 29.Dec.2008 8:12:23 PM
sgraham977
The reason we've got integrated authentication is because we want users to be able to browse the web without having to enter in their login details all the time.
I tried setting the option for 'Require all users to authenticate' but this didn't resolve the Java issue.
Is there anything else that I'm missing here for the Java site to work?  Do I need to change anything to allow Anonymous user?
(in reply to inderjeet)
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 30.Dec.2008 9:17:13 AM
inderjeet
ORIGINAL: sgraham977
I was able to re-produce the same issue in my test lab. Let me find a workaround
Inderjeet (MSFT)
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 30.Dec.2008 2:44:34 PM
inderjeet
Run the ISA BPA in the following manner and send me the CAB file at isaissues@yahoo.com
ISA BPA can be downloaded and installed from the following location:
http://www.microsoft.com/downloads/details.aspx?FamilyID=d22ec2b9-4cd3-4bb6-91ec-0829e5f84063&DisplayLang=en
After installing this please run the ISA Data Packager from the Start, Programs, ISA Server, ISA Tools menu Select the ‘Collect data from one of the following repro scenarios’ radio button and select the ‘Basic Repro and Static Configuration’ option, select ‘Next’ and then ‘Start Data Collection’.
When the ISA Data Packager has initialized the various data captures you will be asked to press the Spacebar to start capturing data. This is going to capture a number of data outputs from a repro of the issue (Network traces, ISA tracing output, ISA logs) so before running this and pressing the spacebar please get set-up to repro the issue.
When you are ready to repro the issue press the spacebar, repro the issue and then press the spacebar again to stop the captures. If you can try to keep this the time you are capturing quite short that will help our analysis of the data.
The BPA will also gather config data from the ISA server that will help us understand your set-up and will output all the data captures to a file on the desktop called isapackage.cab.
Inderjeet (MSFT)
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 31.Dec.2008 2:36:52 PM
inderjeet
Workaround:
You can add it to your bypass rule by going to Configuration > Networks > Internal > properties > web browser and add the *.vodafone.com.au to the "Directly access these servers or domains"
But still run the trace and send it to me before you apply the above workaround....
Inderjeet (MSFT)
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 8.Jan.2009 1:31:19 AM
sgraham977
I'm a bit reluctant to send the information collected through the data collector for security purposes as I don't really want to be sending sensitive information around on the internet.
Will it function sufficiently using the workaround you suggested?
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 8.Jan.2009 11:25:57 AM
inderjeet
Workaround is a workaround......so, you may try it and see if it works. Moreover, i understand ur concern. It's fine if you are not comfortable sending the data...
Contact Microsoft PSS to open a case for log analysis....
It might land up to me :)
Inderjeet (MSFT)
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 8.Jan.2009 12:52:52 PM
Check this : An ISA server or Forefront Threat Management Gateway server requests credentials when client computers in the same domain use Internet Explorer to access Web sites that contain Java programs
Windows Expert - IT Pro MVP
RE: ISA 2006 Access Rule Issue - Blocking Anonymous User - 8.Jan.2009 1:52:09 PM
inderjeet
It's also doing the kind of same thing. The end goal is to allow access to the Java without getting user authenticated. When you used "All Users" in the users tab, ISA bypass the authentication
You may try using both and see which one works for you....
Hope that helps
Inderjeet (MSFT)
(in reply to elmajdal)
