rules between DMZ and LOCAL
All Forums >> [ISA Server 2004 Firewall] >> DMZ >> rules between DMZ and LOCAL Page: [1]
rules between DMZ and LOCAL - 8.Jan.2009 4:04:22 AM
isashnik
Good day!
I created a dmz setup with our ISA 2004 Std /Win2k3.
I'm running ISA2004 SP3 on Win2K3 SP2.
My network configured as:
The external NIC is configured as follows: (which is connected to my modem/router)
IP: 212.1.1.x
Sub: 255.255.x.x
GW: 212.1.1.1
The internal NIC is configured as follows:
IP: 192.168.0.1
Sub: 255.255.255.0
GW: None
The DMZ NIC is configured as follows:
IP: 172.16.0.1
Sub: 255.255.255.0
GW: None
Network Rules as following:
   Name                                     Relation        Source Networks  Destination Network
1     Local Host Acces               Route             Local Host             All Networks (and Local Host)
2     Perimeter Configuration     Route             Internal                   Perimeter
3    Perimter  Access                  NAT               Perimeter                External
4    Internet Access                   NAT                Internal                  External
Everything is work fine but rules between Perimeter and Internal does not work.
For example ping from 172.16.0.1 to 192.168.0.1
but not work from 172.16.0.1 to 192.168.0 to local
I doesn't config anything on Windows. Must I congif RRAS?
What I need to know to config or modify?
Must i add route:
route add 172.16.0.0 mask 255.255.255.0 192.168.0.1?????????????
ALso i note that in my registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
DataValue:0
Must i change this value to 1????????????????????/
If anyone is able to help, that would be greatly appreciated.
Best Regards,
Den
< Message edited by isashnik -- 9.Jan.2009 10:19:43 PM >
RE: rules between DMZ and LOCAL - 13.Jan.2009 3:38:29 AM
isashnik
Hi everyone.
I have solved my problem.
The problem was :
computer in DMZ was configured right, but computer in local subnet configured with a wrong defaul gateway.(not 192.168.0.1)
Please close this post.
Good luck.
(in reply to isashnik)
