Can't access RWW remotely
All Forums >> [ISA Server 2004 General ] >> ISA 2004 SBS >> Can't access RWW remotely Page: [1]
Can't access RWW remotely - 28.Jan.2009 10:12:25 AM
GiganticDays
Single server (2 NICs) Network running SBS 2003 Premium with ISA 2004 installed.
I have run the CIECW & Remote Access Wizard and successfully setup internet and RWW. I can access RWW via a workstation using hxxps://domainname.local/Remote and successfully connect to desktops or the server, so it's running.
Problem is, I can't do the same from a remote location which suggests that it's a firewall issue.
The server connects to the web via a BT Voyager 240 ADSL Modem/Router, but I've disabled NAT on this, although I did try re-enabling it and forwarding ports 4125 and 443. Neither configuration has worked.
The error I get is as follows:-
Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address.
If I try to access it locally but using the external IP hxxps://IP/Remote, I get the following error:-
Technical information (for support personnel)
Error Code : 502 Proxy error. Connection refused(10061)
IP Address: IP
Date :
Server : Server name
Source : Proxy
Anyone have any idea what I've done wrong?
RE: Can't access RWW remotely - 31.Jan.2009 3:23:05 PM
itauthority
with the NAT enabled - if you run ISA logging do you see anything hitting the server?
(in reply to GiganticDays)
RE: Can't access RWW remotely - 31.Jan.2009 3:41:17 PM
GiganticDays
Thanks for the reply. I actually got it sorted myself; it was the BT Voyager 240 router after all. I had misconfigured it - could have sworn I'd turned off NAT
Never under any circumstances take a sleeping pill and a laxative on the same night.
