Traffic data from the logs, reports and ISP are completely different
All Forums >> [ISA 2006 Firewall] >> Logging and Reporting >> Traffic data from the logs, reports and ISP are completely different Page: [1]
Traffic data from the logs, reports and ISP are complet... - 13.Feb.2009 10:01:55 AM
max_e
Hello everyone!
Our customer has ISA 2006 SE. Most of the clients are SecureNAT, but there is WebProxy filter in place.
The management is worried about internet connection usage so they would like to have some sort of traffic reports - by protocols and by machines.
There are two problems:
1. ISA Reports show only a few megabytes of traffic although there were probably ten times more of for example, HTTP traffic according to logs. The ISP is also reporting a much bigger amount of traffic.
Why can this happen?
2. ISA firewall logs show about 30-40% more traffic than ISP. I investigated this and found that there are some records with ZERO bytes sent like:
ISASRV  2/11/2009  17:00:46  TCP  z.z.z.z:35234  y.y.y.y:80  z.z.z.z  Terminate  0x80074e24 HTTP  - 0 1807769
These sessions are not logged by the ISP. What do these records mean?
Best Regards,
Max
RE: Traffic data from the logs, reports and ISP are com... - 13.Feb.2009 11:21:54 AM
richardhicks
Hi Max,
Is caching enabled?  Perhaps that could explain some of the discrepancy?
Richard Hicks - Forefront MVP
(in reply to max_e)
RE: Traffic data from the logs, reports and ISP are com... - 14.Feb.2009 12:57:39 PM
max_e
Hi richardhicks,
Yes, caching is enabled. But I tought if there is a record in a Firewall log than the object was not returned from cache. Is that correct?
(in reply to richardhicks)
RE: Traffic data from the logs, reports and ISP are com... - 14.Feb.2009 1:00:08 PM
richardhicks
There will be records in your logs for each request made of the ISA firewall, regardless where the request was ultimately served from.  Remember, this is true for requests that are denied as well, as long as you haven't disabled logging for denied requests.
(in reply to max_e)
RE: Traffic data from the logs, reports and ISP are com... - 16.Feb.2009 2:22:19 AM
max_e
This can explain the difference.
Is there any way not to log the requests returned from the cache?
RE: Traffic data from the logs, reports and ISP are com... - 16.Feb.2009 12:32:24 PM
richardhicks
Not to my knowledge, but you should see an indication in the log records that the request was returned from cache.
(in reply to max_e)
RE: Traffic data from the logs, reports and ISP are com... - 17.Feb.2009 3:41:46 AM
max_e
And what about the ISA reports?
They are not completely empty, but show very small amount of traffic, about 5% of the total.
RE: Traffic data from the logs, reports and ISP are com... - 17.Feb.2009 12:34:13 PM
richardhicks
The ISA reports should also indicate how many requests were satisfied out of cache...
(in reply to max_e)
RE: Traffic data from the logs, reports and ISP are com... - 19.Mar.2009 8:11:26 AM
NickSS
Hello All!
It seems that I have a similar problem. My ISA reports do not include Symantec Live Update traffic. I can see this traffic in logs, but it does not appear in reports. Symantec Antivirus connects to akamai network servers via FireWall Client. I've got in logs following records:
3/14/2009 10:34:22 PM 92.122.213.81 80 192.168.1.3 Internal External 0 Firewall
3/14/2009 10:34:22 PM 92.122.213.81 80 192.168.0.254 Local Host External 0 Firewall
3/14/2009 10:40:58 PM 92.122.213.81 80 192.168.1.3 Internal External 48780868 Firewall
3/14/2009 10:44:45 PM 92.122.213.81 80 192.168.0.254 Local Host External 50118806 Firewall
It shows traffic twice somehow (why?) and no one of this appears in the reports. How is it possible?
Cachig is off on my ISA.
NS
RE: Traffic data from the logs, reports and ISP are com... - 19.Mar.2009 12:28:36 PM
SteveMoffat
ISA reporting is basic at best. Use webmonitor from GFI or something similar.
Steve
www.isaserver.bm
(in reply to NickSS)
RE: Traffic data from the logs, reports and ISP are com... - 19.Mar.2009 3:41:19 PM
NickSS
Thanks Steve for advice! :)
But does it mean that ISA reports are not correct by design? What are they for at all if I can not trust to them?
(in reply to SteveMoffat)
