RSS |
block java
block java - 9.Apr.2009 9:40:04 AM
yasserkgl
Dears i want to make a rule to block all java sites plz help me
RE: block java - 9.Apr.2009 1:37:12 PM
paulo.oliveira
Hi, create a deny access rule and use the Content Type tab to do it. Regards, Paulo Oliveira.
RE: block java - 9.Apr.2009 5:16:04 PM
quote: ORIGINAL: yasserkgl i want to make a rule to block all java sites you want to block chat sites ?
_____________________________ Tarek Majdalani Windows Expert - IT Pro MVP Facebook : https://www.facebook.com/ElMajdal.Net
RE: block java - 9.Apr.2009 5:27:46 PM
yasserkgl
quote: ORIGINAL: elmajdal quote: ORIGINAL: yasserkgl i want to make a rule to block all java sites you want to block chat sites ? yes i want to block all chat sites
RE: block java - 9.Apr.2009 5:39:57 PM
I can understand this, but some impportant sites ( such as bank website ) do have Java applets in them as well ! what are you going to do about this ?? I remember i have managed to block java applets by blocking the jar extension. check this article to know how to add this extension to the block list : Blocking Desired Extensions & Content Types
RE: block java - 9.Apr.2009 5:43:52 PM
yasserkgl
Dear elmajdal i want to block sites like this site www.ebuddy.com which contain java , that is what i mean . thanks
RE: block java - 9.Apr.2009 5:55:32 PM
Why don't you use GFI Web Monitor. It will save your time by blocking sites with Categories. Anyway, I dont see any java applet loading on the site you refered previously , did you try blocking jar extension, did it work for you ? if not, then its because there is no java applet !!
RE: block java - 9.Apr.2009 5:59:41 PM
yasserkgl
thanks for your help Regards
RE: block java - 9.Apr.2009 6:01:55 PM
You are welcome . Thanks, Tarek
New Messages
No New Messages
Hot Topic w/ New Messages
Hot Topic w/o New Messages
Locked w/ New Messages
Locked w/o New Messages
Post New Thread Reply to Message Post New Poll Submit Vote Delete My Own Post Delete My Own Thread Rate Posts
