slow browsing
All Forums >> [ISA 2006 Firewall] >> General >> slow browsing Page: [1]
slow browsing - 13.Apr.2009 6:06:45 AM
Ejukated
Hi all,
Hope someone here can help me. I have ISA 2006 on a windows server 2003 thats the domain controller. ISA has been working perfectly since january, in the last few weeks the internet browsing has been slow (think dialup speeds). Its not the ISP, ive plugged a computer back into the modem and the internet is normal, i uninstalled ISA 2006 and the internet is normal on the server. After reinstalling the speed was good for a few hours then went back to being slow again.
In the logging there are a few "Failed Connection" logs from my unrestricted internet rule that I cant seem to resolve.
Does anyone have any suggestions?
RE: slow browsing - 13.Apr.2009 6:18:59 AM
SteveMoffat
Remove ISA from your DC. Very stupid way to apply ISA & not supported.
You have opened up your domain to attack. Swiss cheese firewall.
Steve
www.isaserver.bm
(in reply to Ejukated)
RE: slow browsing - 13.Apr.2009 9:49:52 AM
paulo.oliveira
totally agree with Steve. Make sure to install ISA firewall on a separate machine and properly configure ISA NICs.
Check this article: http://blog.msfirewall.org.uk/2008/06/isa-servers-recommeded-network-card.html
Paulo Oliveira.
(in reply to SteveMoffat)
RE: slow browsing - 14.Apr.2009 4:49:11 AM
Ejukated
ok, ive moved isa off the DC. However the performance is still super slow. The two NIC's in are configured as per Paulo link.
I've run ISA2000, ISA2004 and recently ISA 2006 all without problems untill a few weeks ago, and nothing has changed on the systems apart from regular windows updates.
Could this be a routing issue as when I uninstalled both NIC and installed them everything was fine for a few hours (I understand this recreates the routing tables?)
(in reply to paulo.oliveira)
RE: slow browsing - 14.Apr.2009 1:55:15 PM
paulo.oliveira
is your internal DNS server configured to forward DNS requests to ISP DNS server?
Paulo Oliveira.
RE: slow browsing - 15.Apr.2009 8:50:43 AM
Ejukated
Yes, I've configured DNS settings as per "Drawing 3" from this site: http://www.isaserver.org/tutorials/DNS_for_ISA_Server.html
RE: slow browsing - 15.Apr.2009 2:50:13 PM
paulo.oliveira
do you have a AV software or backup client software installed on ISA?
Paulo Oliveira.
RE: slow browsing - 15.Apr.2009 8:19:30 PM
Ejukated
Symantec Antivirus V10
No thirdparty backup software.
RE: slow browsing - 16.Apr.2009 8:27:11 AM
paulo.oliveira
is this host-based AV or HTTP filtering? If itīs host-based, disable it and see if your browsing itīs still slow.
Paulo Oliveira.
RE: slow browsing - 18.Apr.2009 3:54:40 AM
Ejukated
Hi Paulo,
thanks for the suggestion. Its not host based. I disabled the auto protects anyway with no change in performance :(
RE: slow browsing - 18.Apr.2009 7:56:03 AM
Enable the option Use HTTP 1.1 through proxy connections
Have you enabled cache ?
Windows Expert - IT Pro MVP
RE: slow browsing - 18.Apr.2009 10:56:31 AM
Ejukated
Thanks for the suggestions Tarek. The "HTTP 1.1 through proxy connections" is already set as is cache.
I think it may be a DNS or routing misconfiguration. Can anyone suggest how I should go about testing this conclusively?
(in reply to elmajdal)
RE: slow browsing - 18.Apr.2009 2:02:39 PM
SteveMoffat
Are you allowing access out for DNS requests from your DNS server?
Steve
www.isaserver.bm
RE: slow browsing - 18.Apr.2009 5:01:48 PM
For configuring ISA Server Network Cards, check this article : Configuring ISA Server Interface Settings.
As for the Internal DNS Server, check this article : Internal DNS Forwarding Through ISA Server 2004/2006
RE: slow browsing - 18.Apr.2009 7:34:05 PM
Ejukated
Hi Steve, yes my there is already a rule to allowing traffic from my internal DNS. It's configured exactly like the links in Tareks post.
Tarek, its been configured exactly like those links (found them on google a while ago)
