RE: Install ISA 2006 on DC
All Forums >> [ISA 2006 General] >> Installation and Planning >> RE: Install ISA 2006 on DC Page: <<   < prev  1 2 3 4 [5]
RE: Install ISA 2006 on DC - 29.May2009 10:24:14 AM
OTO_777
First I've joined Client in domain and then I've changed NIC settings. Isn't it correct?
I start the web proxy listener,but the same result.
BTW how can I configure client1 in the same network ID,If my ISA's Internal NIC is in 192.168.0.100 subnet?
When I change Client1's NIC setting to 192.168.1.50(For Example. Also I have DC in this subnet.) and set the DG to 192.168.0.100(ISA Servers Internal NIC IP), I got the message that they are in different subnets.
I am confused.
Can you tell me exactly what configuration I need to set for Client1?
< Message edited by OTO_777 -- 29.May2009 10:31:59 AM >
Post #: 81
RE: Install ISA 2006 on DC - 1.Jun.2009 10:02:43 AM
OTO_777
Hey Tom.
Can't you help me what configuration I need exactly to set for Client1?
(in reply to OTO_777)
Post #: 82
RE: Install ISA 2006 on DC - 1.Jun.2009 10:19:50 AM
The Internal interface of the ISA firewall, the DC and the client all need to be on the same network ID, which sounds like it should be 192.168.0.0/24
Post #: 83
RE: Install ISA 2006 on DC - 1.Jun.2009 1:16:03 PM
OTO_777
You said me that ISA Firewall's internal Interface will be on the same network ID where the host is,but isn't SteveMoffat's post correct?
you will need to give the external ISA nic an ip address in the same network as the host.
http://forums.isaserver.org/fb.aspx?m=2002086771
If I'll configure ISA server Internal NIC with 192.168.1.X/24(It's my Internal network.I did 192.168.0.0/24 just for example),and I'll configure External NIC with for example 192.168.2.X(Not Internal Subnet),then what default gateway do I need to set for external NIC? 192.168.1.1(It's my Default Gateway).
If I'll do that,I'll got the message that DG and IP address are not on the same network.
Please answer to this question.
Thanks.
< Message edited by OTO_777 -- 1.Jun.2009 1:20:31 PM >
Post #: 84
RE: Install ISA 2006 on DC - 2.Jun.2009 10:08:46 AM
OTO_777
Hey Tom.
Can't you help me?
< Message edited by OTO_777 -- 2.Jun.2009 10:10:18 AM >
Post #: 85
RE: Install ISA 2006 on DC - 5.Jun.2009 8:41:07 AM
My System:
Host: 192.168.1.1\24
ISA VM:
External: 192.168.1.2/24 Bridged
Internal: 10.0.0.1/24 VMNet2
DC: 10.0.0.2/24
default gateway: 10.0.0.1 VMNet2
Client: 10.0.0.3/24
Post #: 86
RE: Install ISA 2006 on DC - 8.Jul.2009 5:33:11 AM
OTO_777
Thanks Tom.
I've just finished reading your book.
It's just fantastic.
If I'll have the questions,I'll post in appropriate sections.
Post #: 87
RE: Install ISA 2006 on DC - 8.Jul.2009 8:28:16 AM
Post #: 88
Page:   <<   < prev  1 2 3 4 [5] << Older Topic    Newer Topic >>
