HTTPS login problem
All Forums >> [ISA 2006 Firewall] >> Access Policies >> HTTPS login problem Page: [1]
HTTPS login problem - 25.May2009 3:00:55 PM
isa_rooky
Hi again everybody,
I have another little problem. Everytime a user try to make a login in the internet with this type of address: https://internetaddress:2542/web/home.pl
They cannot login. How can I allow them to login with my ISA Server 2006?
RE: HTTPS login problem - 25.May2009 3:48:23 PM
paulo.oliveira
by default ISA only allow the default HTTPS (443) and NNTPS (563) ports.
Check this article to extend ISA tunnel port range:
Extending the ISA Firewall’s SSL Tunnel Port Range (2004)
Paulo Oliveira.
(in reply to isa_rooky)
RE: HTTPS login problem - 25.May2009 4:18:35 PM
isa_rooky
This .js file also works for ISA server 2006?
(in reply to paulo.oliveira)
RE: HTTPS login problem - 25.May2009 4:49:42 PM
paulo.oliveira
Never tested.
RE: HTTPS login problem - 25.May2009 6:38:32 PM
Pretty sure it's the same for 2k6, if not look at this one:
http://www.isatools.org/tools/isa_tpr.js
RE: HTTPS login problem - 25.May2009 9:50:17 PM
isa_rooky
Ok, I'm going to try that one.
Thanks a lot guys for your help!
RE: HTTPS login problem - 25.May2009 10:08:12 PM
SteveMoffat
Works fine in 2006
Steve
www.isaserver.bm
RE: HTTPS login problem - 26.May2009 2:19:18 PM
isa_rooky
Hi guys,
I try the application to open a new tunnel to be able to navigate websites with a different port, but I'm still not able to go in. I alse checked if the application created the new tunnel and is there already.
(in reply to SteveMoffat)
RE: HTTPS login problem - 26.May2009 4:03:33 PM
paulo.oliveira
what´s the error message? What does ISA real-time monitoring log tells you?
Paulo Oliveira.
RE: HTTPS login problem - 26.May2009 4:42:22 PM
SteveMoffat
Did you restart the FW service?
Steve
www.isaserver.bm
RE: HTTPS login problem - 27.May2009 11:11:54 AM
isa_rooky
Hi guys and sorry for the delay.
After I created the new tunnel, I didn't start any service. What service is that Steve? Can you guys help on starting this service? Maybe that's why I'm not able to dogo in.
RE: HTTPS login problem - 27.May2009 1:23:05 PM
paulo.oliveira
just reboot your machine.
Paulo Oliveira.
RE: HTTPS login problem - 27.May2009 2:44:49 PM
isa_rooky
Oh, I see. I did that this morning, but I didn't try it.
Ok, let's see....nope still not working. The're maybe something else blocking me.
Do I need to add a rule to allow the users to use this port? Something like: 1) This rule apply to - selected protocol.
Then I can create a new protocol with the port number, right?
