Unable to connect to Web Proxy server address on array
All Forums >> [ISA 2006 General] >> Installation and Planning >> Unable to connect to Web Proxy server address on array Page: [1]
Unable to connect to Web Proxy server address on array - 7.Jul.2009 11:18:30 AM
nickcleary
Hi All
I've created a ISA 2006 Array on Vmware ESX 3.5.0.
The array is on a 10.70.x.x subnet and the majority of our users are on a 10.22.x.x.
All users on the 10.70 section can connect to the Proxy address without problems however those on the 10.22 cannot. They can however connect to each individual ISA server address and browse through those.
I have added a persistant route to each server for the other subnet but there I'm still unable to connect. The DNS entry has been added accordingly.
Apologies if more info is needed,
Thanks in Advance
RE: Unable to connect to Web Proxy server address on array - 7.Jul.2009 9:50:52 PM
varun25
On the ISA, is10.22.X.X subnet specified as internal or external network?
Without adding the persistant route are you able to ping between the 2 subnets?
(in reply to nickcleary)
RE: Unable to connect to Web Proxy server address on array - 8.Jul.2009 4:57:28 AM
nickcleary
The Internal network is set to 10.0.0.0- 10.255.255.255 and yes i can ping between them.
Nick
< Message edited by nickcleary -- 8.Jul.2009 5:53:47 AM >
(in reply to varun25)
RE: Unable to connect to Web Proxy server address on array - 8.Jul.2009 11:48:02 AM
Boedus
The way I understand your problem is that both those IP are on the same network actually.
Really NIC/IP should be on a different network.
Make sure you are using a 8 bits mask in that case,such as below:
10.70.0.0/255.0.0.0
10.20.0.0/255.0.0.0
In that case they are on a different network.
Also ideally routes should be set before ISA is installed. Nothing is preventing you from installing them afterwards, but usually doing it initially will help you avoiding to have IP issues.
Make sure the routes are working fine as well, before you install ISA. It is difficult to troubleshoot routing issues on a firewall.
HTH
ORIGINAL: nickcleary
Nick
< Message edited by Boedus -- 8.Jul.2009 11:50:44 AM >
RE: Unable to connect to Web Proxy server address on array - 8.Jul.2009 12:12:14 PM
richardhicks
You mentioned that users from the 10.20.x.x network can communicate with each array member individually, but not with the array as a whole. Do you have NLB enabled?
Richard Hicks - Forefront MVP
RE: Unable to connect to Web Proxy server address on array - 9.Jul.2009 5:35:28 AM
nickcleary
Yes, NLB is enabled on the internal NIC w\ Multicast as they are on VMware.
Nick
(in reply to richardhicks)
RE: Unable to connect to Web Proxy server address on array - 9.Jul.2009 6:11:12 AM
ORIGINAL: Boedus
10.70.0.0/255.0.0.0
10.20.0.0/255.0.0.0
Surely with an 8 bit mask, those subnets are actually on the same network?
If you want to differentiate them as different networks, you would need a 16 bit mark - no?
(in reply to Boedus)
RE: Unable to connect to Web Proxy server address on array - 9.Jul.2009 6:14:04 AM
Hi All
Thanks in Advance
If you are using multicast NLB and you have clients on remote networks, you will need to add static ARP entries on the router.
This is discussed in more detail in Question 10 from here:
http://blog.msfirewall.org.uk/2008/10/resource-guide-for-using-microsoft-nlb.html
P.S. Mentioning multicast NLB in your original post would have helped
< Message edited by Jason Jones -- 9.Jul.2009 6:15:41 AM >
RE: Unable to connect to Web Proxy server address on array - 9.Jul.2009 6:53:32 AM
Boedus
ORIGINAL: Jason Jones
ORIGINAL: Boedus
10.70.0.0/255.0.0.0
10.20.0.0/255.0.0.0
Yep I meant to write 16 initially :-)
Thanks for correcting me.
RE: Unable to connect to Web Proxy server address on array - 9.Jul.2009 6:57:32 AM
nickcleary
Thanks for your help guys, I'll attempt to add the static ARP entries today and let you know
Nick
RE: Unable to connect to Web Proxy server address on array - 13.Jul.2009 9:23:31 AM
nickcleary
I think the issue may be down to the Virtual IP having a different MAC address on each server. I was under the impression ISA changed this accordingly, how can i do this manually?
RE: Unable to connect to Web Proxy server address on array - 13.Jul.2009 11:23:24 AM
richardhicks
In multicast mode each host retains it's original MAC address.  The MAC address is overwritten when NLB is in unicast mode (default).  Regardless, you may still need a static ARP entry with VMWare, but I'm not sure.  I've never configured NLB on VMWare myself, so perhaps others might have more insight to this.
RE: Unable to connect to Web Proxy server address on array - 15.Jul.2009 6:42:34 PM
No, you need static ARPs!
