Can you temporarily disable ISA
All Forums >> [ISA Server 2004 General ] >> ISA 2004 SBS >> Can you temporarily disable ISA Page: [1]
Can you temporarily disable ISA - 4.Aug.2009 6:10:34 PM
Zani
I know ISA isn't like you standard consumer firewall but is it possible
RE: Can you temporarily disable ISA - 4.Aug.2009 8:40:56 PM
richardhicks
Sure, it's possible.  Go to a command prompt and type the following command:
net stop fweng /y
That will completely disable the firewall.  Careful though...if you have network interfaces connected to untrusted networks (e.g. the Internet) you are exposed and potentially vulnerable, depending on the configuration of the base operating system.
Richard Hicks - Forefront MVP
(in reply to Zani)
RE: Can you temporarily disable ISA - 5.Aug.2009 2:05:29 AM
jpdw
Thanks as I have also been wanting to know how to disable the firewall.
Will this command disable the proxy as well?
also what would be the commands to start the firewall again or would one have to restart the Actual server with ISA on it?
(in reply to richardhicks)
RE: Can you temporarily disable ISA - 5.Aug.2009 11:02:35 AM
Zani
Thanks Richard I found this forum thread which also mentions some great tips on disabling ISA o4
http://social.technet.microsoft.com/Forums/en-US/Forefrontedgesetup/thread/4d2a9c6e-e548-41e7-9da8-5fba82632820
(in reply to jpdw)
RE: Can you temporarily disable ISA - 5.Aug.2009 11:30:06 AM
DEVLAVI
Stopping the Firewall Engine driver (by using net stop fweng /y at the command prompt) also stops the other firewall components, which opens the computer to all network traffic and its highly not recommended
But instead you can stop the Firewall service (net stop fwsrv) which puts the ISA Server computer in lockdown mode and allows only a limited set of protocols to and from the ISA Server computer itself.
Use net start to start the services manually or a reboot of the ISA box should start all the stopped services
DEV
(in reply to jpdw)
