ISA server - configuration question
All Forums >> [ISA 2006 Firewall] >> HTTP Filtering >> ISA server - configuration question Page: [1]
ISA server - configuration question - 10.Aug.2009 5:59:03 AM
jigzden
Hi All,
I am seeking for the solution for my below mentioned design:
-- I have Cisco Layer-3 switch with multiple VLANs
-- I have ISA server with two NIC cards - One NIC with 'Internal' IP and second NIC with 'DMZ' IP
-- I want all VLAN should forward http(s) traffic to ISA server and then ISA will forward the traffic to DMZ network configured on Cisco ASA
-- ASA will do the PAT between DMZ and Outside traffic
Questions:
-- Will ISA work if I forward all VLAN traffic to ISA server without specifying ISA ip in browser
-- Will ISA control Http(s) traffic base on the policies
Thanks for any help in advance,
Jigzden
RE: ISA server - configuration question - 11.Aug.2009 7:59:27 AM
paulo.oliveira
yes, it will. You just have to put all VLANs range into ISA Internal Network definition. Also, make sure layer-3 switch is pointing to ISA internal IP as default gateway.
You also, have to create a static route on Windows routing table using route add CLI.
Paulo Oliveira.
(in reply to jigzden)
