Isa2006 FPC AlertAction enabling problem
All Forums >> [ISA 2006 Misc.] >> ISA 2006 Programming >> Isa2006 FPC AlertAction enabling problem Page: [1]
Isa2006 FPC AlertAction enabling problem - 13.Aug.2009 8:48:53 AM
longair
Question: Does anyone know how to programically enable the sendmail action?
I'm trying to use a VBscript to enable the SendMail AlertAction for specific Alerts. But if the AlertAction SendMail has never been enabled the SendMail AlertAction does not appear in the collection of AlertActions
the script below will help demonstrate the issue, chose two alerts  that have never had the sendmail action enabled set one manually and run the script after editing the line (If  alert.name = "Service Started" Then) to reflect the name of the alert (note case sensitive)
run the script and you will get the output
'LogEvent
True
0
SendMail
True
2
Done!
now disable the sendmail action for that alert manually and run the script again
this is the output (you can see the sendmail action as False, disabled)
'LogEvent
True
0
SendMail
False
2
Done!
If you then run the script against an alert that has never had the sendmail action enabled you only get
'LogEvent
True
0
This mean I can't programically enable the sendmail action for alerts that have never been enabled.
Sub ConfigureAlerts()
   ' Create the root obect.
   Dim root  ' The FPCLib.FPC root object
   Set root = CreateObject("FPC.Root")
   ' Declare the other objects needed.
   Dim array   ' An FPCArray object
   Dim alerts  ' An FPCAlerts collection
   Dim alert   ' An FPCAlert object
Dim Action   ' An FPCAlert.actions Collection
   ' Get references to the array object
   ' and the alerts collection.
   Set array = root.GetContainingArray()
   Set alerts = array.Alerts
   On Error Resume Next
   For Each alert In alerts
   ' wscript.Echo alert.name
    For Each action In alert.actions
      WScript.Echo action.name & VbCrLf  & action.enabled & VbCrLf & action.type
    Next
        '' alert.Actions.SetSendMail "SendMail", "MailServer", "firewall", "mike@northwindtraders.com"
      'CheckError
      'alert.Actions.Save
      'CheckError
   End If
   Next
   WScript.Echo "Done!"
   WScript.Sleep 60000
End Sub
Sub CheckError()
   If Err.Number <> 0 Then
       WScript.Echo "An error occurred: 0x" & Hex(Err.Number) & " " & Err.Description
       Err.Clear
   End If
End Sub
ConfigureAlerts
Thanks for looking
Paul
