New install with Vlans
All Forums >> [ISA 2006 General] >> Installation and Planning >> New install with Vlans Page: [1]
New install with Vlans - 15.Sep.2009 5:35:09 PM
unkyjojo
Greetings all, newbie here with ISA 2006.
I have a Netgear Layer 3 Switch with 3 Vlans -1 for management
V-Lan2 - 192.168.1.0 subnet
V-Lan3 - 192.168.2.0 subnet
Currently I have the default gateway pointing to 192.168.1-2.250 as the default gateway on the workstations-servers. This then points to a Linksys router with access to the internet at 192.168.1.254. It also has RIP enabled to keep the routing table updated.
What I want to do is replace the Linksys router with the ISA server for both subnets. The address of the ISA server will be 192.168.2.254 and would end up being the router to the internet for boths subnets.
Would I first configure the ISA for the .2.0 subnet, make sure it works properly, and then do a route add for the .1.0 subnet?
Thanks in advance for the help.
RE: New install with Vlans - 15.Sep.2009 5:43:05 PM
paulo.oliveira
you need to add all your network ranges to ISA Internal Network object and point Netgear Layer 3 swtich to ISA.
It will be something like this:
                                       Vlan2
Internet----ISA----Netgear
                                        Vlan3
Paulo Oliveira.
(in reply to unkyjojo)
RE: New install with Vlans - 15.Sep.2009 9:02:39 PM
unkyjojo
Paulo,
Thanks for the reply.
Now to check a few things.
ISA Server is member server of domain.
On the ISA server, for the NIC connected to the LAN I have the following.
IP: 192.168.2.254
SM:255.255.255.0
Gateway: NONE
DNS: Points to DNS on domain controller 192.168.2.1
For the external nic on ISA 2006 server
IP: 216.45.xxx.xx
SM: 255.255.255.192
Gateway: 216.45.xxx.xx
DNS Points to 208.67.220.220 Open DNS
For now the servers and workstations have the following config.
IP: 192.168.2.?
SM: 255.255.255.0
Gateway: 192.168.2.254
This seems to be working, I am able to get out to the net, and I can see the clients in the sessions screen on ISA 2006, but I wanted to make sure the settings on the ISA server are correct before proceeding.
Once someone tells me this is OK I will then tackle the routing for the other Subnets and test them.
(in reply to paulo.oliveira)
RE: New install with Vlans - 16.Sep.2009 5:47:41 AM
Nearly...
You should not define DNS on the external interface as this is know to cuase problems. You should configure your internal DNS to use forwarder instead.
These may help:
http://blog.msfirewall.org.uk/2008/06/isa-servers-recommeded-network-card.html
http://blogs.technet.com/isablog/archive/2009/08/27/side-effects-of-incorrect-dns-configuration-on-isa-server-10060-connection-timeout-scenario.aspx
http://technet.microsoft.com/en-us/library/cc302590.aspx (still relevant)
RE: New install with Vlans - 16.Sep.2009 6:45:02 PM
unkyjojo
Jason,
Thanks for those great links, that is exactly what I was looking for :)
I will impliment these changes and then come back with more questions I am sure.
I will need some help getting my layer 3 switch to route between subnets next, but I want to get the ISA configuration stuff out of the way first.
RE: New install with Vlans - 16.Sep.2009 7:07:02 PM
unkyjojo
What is the best book to buy on configuring ISA 2006?
Should I get the 2004 book or the ISA 2006 Migration Guide.
I want in depth and simple explanations for configuration.
RE: New install with Vlans - 17.Sep.2009 4:17:17 AM
Cool, good luck!
This book is a good starting point:
http://www.amazon.com/Shinders-Server-2006-Migration-Guide/dp/1597491993
as are the following online tech docs:
http://www.microsoft.com/forefront/edgesecurity/isaserver/en/us/product-documentation.aspx
Also, search the articles on this site...
RE: New install with Vlans - 17.Sep.2009 11:52:52 AM
unkyjojo
Ok, now the fun part.
I have made the changes to DNS and binding order, and disabled the file and print sharing per the instructions.
Now I am trying to route between the subnets. I always have trouble getting my head around this part.
ISA Server = 192.168.2.254
Vlan 2=192.168.2.0
Vlan 3=192.168.1.0
I have on the netgear managed switch a default route of 0.0.0.0 to 192.168.2.254
I had previously created the following learned routes
192.168.1.0 - 192.168.1.250
192.168.2.0 - 192.168.2.250
This is per the Netgear setup instructions for VLANS and routing.
On the pc and server in the 2.0 subnet I have the default gateway as 192.168.2.250 which is the netgear switch, I can ping the 2.0 subnet, I can get out to the web and I can see it going though the ISA server without issues.
I added the following to the ISA server route add -p 192.168.1.0 MASK 255.255.255.0 192.168.2.254 and I have tried 192.168.2.250 but still cant ping the 1.0 subnet from any workstation or server on the 2.0 subnet.
I hope this makes sense, I have pics of the configuration but don't know how to post them.
Thanks in advance.
RE: New install with Vlans - 17.Sep.2009 1:10:04 PM
unkyjojo
P.S. Bought the book :) This I am sure will help me configure the rest.
I still need help with setting up the routing between subnets if anyone can lend a hand.
RE: New install with Vlans - 17.Sep.2009 2:09:23 PM
unkyjojo
Update:
Had a routing guru friend of mine verify that the Netgear switch and the Vlans are configured properly.
I have also verfied that I can go out to the internet on the 2.0 subnet.
I have added the following route
route add -p 192.168.1.0 MASK 255.255.255.0 192.168.2.250 "IP of Netgear" the Netgear has a default route of 192.168.2.254 pointing to the ISA server
However when I ping the 1.0 subnet the packets are dropped after the 2.250 Netgear using tracert.
Is there something else in ISA I need to configure to make this work?
RE: New install with Vlans - 17.Sep.2009 6:27:10 PM
What is the gateway of machines in the 1.0 subnet?
RE: New install with Vlans - 18.Sep.2009 10:29:01 AM
unkyjojo
Jason,
The gateway for the machines in the 1.0 subnet is 192.168.1.250
Which is a virtual IP on the Netgear switch.
The gateway for the 2.0 subnet is 192.168.2.250, and it works as the DF Gateway on the Netgear points to 1.254 for the default route.
Hope this explains it.
RE: New install with Vlans - 18.Sep.2009 11:02:57 AM
So traffic between the 1.0 and 2.0 subnets has nothing to do with ISA then - back to the NetGear me thinks
You should only hit ISA if you use and address which is unrouteable by the NetGear; it then should forward to the ISA on .254
RE: New install with Vlans - 18.Sep.2009 11:49:05 AM
unkyjojo
Actually no.
The netgear handles the routing between the subnets and it works when a router is placed at the 192.168.1.254 subnet with a route back to the 1.0 and 2.0 subnets.
The default gateway on the Netgear points back to the ISA at 192.168.2.254 and this is where the packets are being dropped as diagnosed with tracert.
The ISA server is dropping the packets in spite of adding a static route into its routing table.
Again, when I hook back up the Linksys router in place of the ISA server the packets are routed properly, so it must be a setting with the ISA server.
RE: New install with Vlans - 19.Sep.2009 2:45:06 PM
unkyjojo
Jason, you were correct.
I moved ISA from the 2.0 subnet to the 1.0 subnet as well as the test network.
Now it is working properly, I am able to ping computers on both the 1.0 and 2.0 subnets.
I don't have a clue as to why the Netgear switch wont route properly when using the 2.0 instead of the 1.0 subnet, but I will cross that bridge later, for now it is working and I am able to continue to configure and test ISA, so thanks for all of your assitance.
Can't wait for the book to arrive :)
RE: New install with Vlans - 19.Sep.2009 8:50:40 PM
ORIGINAL: unkyjojo
Cool, enjoy the book!
