ISA Single NIC question
All Forums >> [ISA 2006 Web Proxy] >> Unihomed >> ISA Single NIC question Page: [1]
ISA Single NIC question - 25.Nov.2009 10:54:15 AM
clwoodmac
Hi, first off apologies if this has been covered many times but i'm pretty new to ISA 2006.
I am trying to resolve a 'discussion' with my manager regarding single NIC ISA deployed as a web proxy.
I have depployed ISA with single NIC many times using MS technet article and i am aware that single NIC server doesnt have concept of External Network object. The issue i have is that whenever thier is an apparent 'issue' with ISA my colleague wants to change my FW rules and add in external network object.
The weird thing i cant understand is why some of the rules are working with external configured as the destination; for example internet access rule is Internal & Local Host > Internal. He will come along and change destination to external and internet access will still work.
The only thing i can think of is that the IP addresses assgined to the Internal Network adapter arent correct.
Any ideas or how can i understand this better?
RE: ISA Single NIC question - 25.Nov.2009 11:16:41 AM
What addresses do you have on the addresses tab of the internal network object?
You should only need to use the Internal network object in all rules, as this should include all possible addresses. Hence external is the inverse of everything, which equals nothing
(in reply to clwoodmac)
RE: ISA Single NIC question - 25.Nov.2009 11:25:39 AM
clwoodmac
Hi Jason, thanks for quick response. Your comments definately make sense to me.
On the ISA Internal Network object the IP addresses are defined as:
10.0.0.1 > 10.255.255.255
50.0.0.1 > 50.0.0.255
192.168.0.1 > 192.168.255.255
so as you say this doesn't include all possible addresses.
Is the reason that the external network object will work?
If i add the Adapter this will cover all IP addreses and negate the use of external network object?
Colin.
RE: ISA Single NIC question - 25.Nov.2009 4:55:52 PM
If you only have one NIC, the IP addresses you have defined are incorrect; so yes, this is why you need to add external.
If you remove the existing addresses and click the 'add adapter' option and select your internal NIC, you will get the correct settings. They should include all default A, B, C and D class addresses but exclude localhost IIRC.
RE: ISA Single NIC question - 27.Nov.2009 9:24:42 AM
clwoodmac
Hi jason, yes this is what i would normally do but my colleague thinks differently without actually reading anything!
Thanks for confirming!
Colin.
