Allow internet to Branch office alredy connected VPN - using head office ISA
All Forums >> [ISA 2006 Firewall] >> Branch Office >> Allow internet to Branch office alredy connected VPN - using head office ISA Page: [1]
Allow internet to Branch office alredy connected VPN - ... - 16.Dec.2009 5:44:45 AM
palitha
Our head office LAN is use 192.168.2.0 /24 and Gateway is 192.168.2.1.Branch 1 use 192.168.1.0/24 Gateway is 192.168.1.1. Branch 2 use 192.168.3.0/24 Gateway is 192.168.3.1. It is connected with Branch offices located at remote locations through VPN supplied by service provider. Every branches and Head office connected through routers which is supplied by VPN service provider.
There is a ISA Server on Head office with firewall and proxy. There are two interfaces one is External (Internet Service Provider) and Other one is for Internal network (192.168.2.9). Now I have supplied internet through ISA within Head office users. Now I need to give internet to VPN client (Branch Users) using Head office Internet facility (Using ISA server).What are the configuration should I do for This ? http://www.freeimagehosting.net/image.php?bb4ff8b8e8.jpg
Please check diagram for more details.
< Message edited by palitha -- 16.Dec.2009 5:54:53 AM >
RE: Allow internet to Branch office alredy connected VP... - 16.Dec.2009 7:44:45 AM
paulo.oliveira
this is a tipical scenario of network behind network:
http://www.isaserver.org/tutorials/Advanced-ISA-Firewall-Configuration-Network-Behind-Network-Scenarios.html
http://isaserver.org/articles/2004netinnet.html
The short answer is: since the traffic is comming from behind ISA internal NIC, you have to add 192.168.1.0/25 and 192.168.3.0/24 ranges on ISA Internal Network definition.
Paulo Oliveira.
(in reply to palitha)
RE: Allow internet to Branch office alredy connected VP... - 16.Dec.2009 3:42:26 PM
pwindell
Hi, guys,
Also be aware of secondary routing issues cause by a broken "connection state" that ISA will interpret as spoofing.  The symptoms are this:
1. Hosts on main LAN can initiate and successfully connect to Hosts on the Remote LANs.
2. But Hosts on Remote LANs cannot initiate connections to hosts on the Main LAN.
See:
The Official SBS Blog : Network Behind a Network
http://blogs.technet.com/sbs/archive/2007/11/29/network-behind-a-network.aspx
To avoid this the VPN Device on the Main LAN has to be treated as a "LAN Router" and will become the Default Gateway of all hosts on the Main LAN,...the Device will then use the ISA as it's Default Gateway.  However, changine the VPN Device's Defialt Gateway will knock down the VPN Tunnel,...so Static Routing on the VPN Device must be in place to support the VPN Tunnel to its termination point at the opposite end.
This same scenario would have to be repeated at each Remote Site if these remote sites use the same design layout for their LANs.
A different solution for this would be to add a second "internal" Nic with a new subnet to the ISA and move the VPN Device to that.  Then the ISA remains the Default Gateway and the ISA can also then use Access Rule to regulate traffic between the Sites.
Here are digrams of both solutions.  You should be able to easily see which is which.
Phillip Windell
(in reply to paulo.oliveira)
RE: Allow internet to Branch office alredy connected VP... - 17.Dec.2009 2:40:04 AM
palitha
Thanks all for reply. I followed your reference article http://isaserver.org/articles/2004netinnet.html http://isaserver.org/articles/2004netinnet.html  and try with it. I am using ISA 2006 enterprise edition. I create following things
Enterprise Network
Enterprise > Enterprise networks  > Internal  - Address Range 192.168.0.0 - 192.168.255.255
Arrays > Configuration > Networks > Internal  - Add Enterprise Internal Netwok into it.
And created a subnet as 192.168.1.0 /24 for Branch
And created a subnet as 192.168.2.0 /24 for Head Office
I checked ISA Log.
Initiated Connection
ISA-SERVER 12/17/2009 12:39:42 PM
Log type: Firewall service
Status:
Rule:
Source: Internal (192.168.1.2:1116)
Destination: Local Host (192.168.2.9:1745)
Protocol: Microsoft Firewall Client (TCP)
User:
result code :0x0 ERROR_SUCCESS
Closed Connection
ISA-SERVER 12/17/2009 12:40:52 PM
Status:
Rule:
User:
result Code : 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN
When I ping to ISA 192.168.2.9 (Main Office) Computer from branch side it is Request timed out.But I can ping to main office other PCs. except ISA.
When I ping to Branch Office Computer from ISA (192.168.2.9) it is Request timed out.But I can ping to branch office from other Main office PCs. except ISA.
Is this way suit for my architecture.
I cant access internet from branch office yet.
When I tried to tracret command from ISA Computer as 'tracert 192.168.1.2'. It is route through 192.168.1.1 (it is external gateway). It is not correct and it should be route through Internal VPN router (192.168.2.1).
< Message edited by palitha -- 17.Dec.2009 3:55:59 AM >
RE: Allow internet to Branch office alredy connected VP... - 18.Dec.2009 1:33:49 AM
palitha
Thanks ur replies. Now I can access ISA Machine from branch. Problem was routing configuration.
< Message edited by palitha -- 18.Dec.2009 1:35:30 AM >
