Why can't I do this??
All Forums >> [ISA 2006 General] >> Installation and Planning >> Why can't I do this?? Page: [1]
Why can't I do this?? - 18.Feb.2010 3:07:08 PM
sduffey
Hi there I am new to ISA and have been testing it out in a lab environment for a couple weeks.  I have been stumped by how ISA seems to be blocking access when it shouldn't be.
I have been trying to do a simple ping rule.  I am trying to ping from a network that I have defined as a perimeter network to a computer on the other side of the ISA server which is defined as being on the Internal network.
I set up my ping rule to allow access from the perimeter network to the Internal network.  However the test fails and I see the attempt being blocked in the log.
If I make no other change but to move the ip range of the perimeter network and include it as part of the Internal network, I am able to ping.
I am stumped.  I'm sure I am overlooking something obvious here but for the life of me I don't know what.
RE: Why can't I do this?? - 18.Feb.2010 3:23:39 PM
sduffey
This is what I see in the log when it is blocked.
Original Client IP Client Agent Authenticated Client Service Server Name Referring Server Destination Host Name Transport MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload GMT Log Time Source Port Processing Time Bytes Sent Bytes Received Result Code HTTP Status Code Cache Information Error Information Log Record Type Authentication Server Log Time Destination IP Destination Port Protocol Action Rule Client IP Client Username Source Network Destination Network HTTP Method URL
192.168.31.51    CCTCFW -  ICMP -      -    2/18/2010 8:21:48 PM 8 0 0 0 0xc0040014 FWX_E_FWE_SPOOFING_PACKET_DROPPED  0x0 0x0 Firewall - 2/18/2010 3:21:48 PM 192.168.150.100 0 PING Denied Connection  192.168.31.51  Outside Internal - -
(in reply to sduffey)
RE: Why can't I do this?? - 18.Feb.2010 3:23:41 PM
SteveMoffat
3 nic ISA? Route relation ship between Perimeter & internal?
Steve
www.isaserver.bm
RE: Why can't I do this?? - 18.Feb.2010 3:25:15 PM
sduffey
I have 2 NICS defined in ISA.  I have a route between perimeter and internal defined both in ISA under network rules as well as a static route in the Windows Server OS.
(in reply to SteveMoffat)
RE: Why can't I do this?? - 18.Feb.2010 3:27:13 PM
SteveMoffat
so you don't actually have a perimeter network then. It's external.
Steve
www.isaserver.bm
RE: Why can't I do this?? - 18.Feb.2010 3:29:11 PM
sduffey
Ok I apologize for the improper definintion.  Any ideas why this won't fly?
Test set up is laid out like this:
192.168.31.50 workstation1 ip-192.168.31.0 router in between 192.168.30.0 -192.168.30.2 isa nic1 - isa nic 2 192.168.150.1 - workstation2 ip 192.168.150.100
I am trying to ping from a workstation on the 192.168.31.0 network to a machine on the 192.168.150.0 network.
If I tell ISA that 192.168.31.0 is an Internal network it allows the ping.  If I define 192.168.31.0 as it's own network and explicitly allow it to ping to Internal it fails.
< Message edited by sduffey -- 18.Feb.2010 3:57:24 PM >
RE: Why can't I do this?? - 18.Feb.2010 3:55:56 PM
sduffey
A picture always works better for me
http://dl.dropbox.com/u/2357341/Drawing1.jpg
RE: Why can't I do this?? - 18.Feb.2010 6:42:02 PM
SteveMoffat
ahh...because the ping is coming from the .31 subnet, you have to add that subnet to the isa internal nic
Steve
www.isaserver.bm
RE: Why can't I do this?? - 19.Feb.2010 7:44:26 AM
sduffey
Hmmm I don't follow the reasoning.  Why does a network have to be included in the Internal group to allow pings?
RE: Why can't I do this?? - 19.Feb.2010 12:50:11 PM
SteveMoffat
Because if you have a rule for ping it will only allow it from the networks that you specify....ie the ping is coming from a non local subnet...therefore it's not allowed. That's what firewalls do....
Steve
www.isaserver.bm
RE: Why can't I do this?? - 19.Feb.2010 1:08:29 PM
sduffey
Yes but in ISA I created a new network for 192.168.31.0 and specifically granted it permission to ping the Internal newtwork, doesn't work.
More pictures on the way.
< Message edited by sduffey -- 19.Feb.2010 1:11:56 PM >
RE: Why can't I do this?? - 19.Feb.2010 1:16:14 PM
SteveMoffat
no, don't do that. Add the subnet into the internal network properties.
Steve
www.isaserver.bm
RE: Why can't I do this?? - 19.Feb.2010 1:24:16 PM
sduffey
So let's say this is in production and I am trying to grant access to resources on our network to a network over the WAN (not ours, another department), you are saying the proper way to do this with ISA is to add that subnet to the Internal network?
Here is the test network I made for the 192.168.31.0 network called "Outside"
http://dl.dropbox.com/u/2357341/1.jpg
And here is the rule where I was trying to allow the Outside network to ping resources on Internal
http://dl.dropbox.com/u/2357341/2.jpg
RE: Why can't I do this?? - 19.Feb.2010 1:40:13 PM
SteveMoffat
no, then you would use a publishing rule.
Steve
www.isaserver.bm
