Website publish
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Website publish Page: [1]
Website publish - 16.Mar.2010 6:29:16 AM
sasif
we have a website created using oracle portal. and we want to publish it through ISA 2006. the problem we are facing is that ISA is not redirecting the actual path which i specified in the paths.
our website link is
https://servername:8251/portal/page?_pageid=374,146513&_dad=portal&_schema=PORTAL
ISA is converting it into
https://ServerName:8251/portal/page%3F_pageid%3D374,146513%26_dad%3Dportal%26_schema%3DPORTAL
i have created a web site publishing rule to listen on port 80 and redirect on Https port 8251 which is working fine the only problem is the path how can i set ISA not to change the path. it is changing ? to %3F, & to %26 and = to %3D
any suggestions on how to achieve the task?
thanks in advance.
RE: Website publish - 17.Mar.2010 4:12:13 PM
pwindell
You can't use the URL with SSL.
Publish based on the FQDN only,...not an IP#,...not a NebiosName
The cetificate for the SSL Site is tied to the FQDN.  The matching FQDN (spelling) must stay consistant through the entire process.
Publish from:  https://hostname.domainname.tld
to: https://hostname.domainname.tld
Any other redirection must be performed by the site itself.
Phillip Windell
(in reply to sasif)
