how to avoid Websense filtering for some machines
All Forums >> [ISA 2006 Firewall] >> HTTP Filtering >> how to avoid Websense filtering for some machines Page: [1]
how to avoid Websense filtering for some machines - 15.Apr.2010 10:37:02 AM
apur32
We are having Websense licensing issues ( We are short of it ). Is there any way that for certain machines (IPs) can pass through ISA directly rather than passing to Websense for filtering to save licenses.
These are servers which we do not want to filter at all because there is no browsing going on these servers.
Apur
RE: how to avoid Websense filtering for some machines - 15.Apr.2010 11:34:17 AM
richardhicks
Absolutely. On each ISA firewall, create a file called ignore.txt and place it in the \windows\system32 folder. Add the machine names in all CAPS (don't ask why!) to the file and save it. Restart the Websense services and you're done.
Richard Hicks - Forefront MVP
(in reply to apur32)
RE: how to avoid Websense filtering for some machines - 15.Apr.2010 12:46:45 PM
ORIGINAL: richardhicks
Nice, LSNED
(in reply to richardhicks)
RE: how to avoid Websense filtering for some machines - 16.Apr.2010 5:05:03 AM
apur32
Hi Richard,
Thanks for the prompt replay.
I have done the same as you advised but it did not work.
I included the machine names in the ignore.txt file on ISA server & placed it in \windows\system32 folder & restart the Websense filter service but it is still filtering the servers & some other machines which I don't want to filter in order to save licenses.
Apur
RE: how to avoid Websense filtering for some machines - 16.Apr.2010 4:33:03 PM
richardhicks
Looking at the Websense documentation, their recommendation is to 'restart the server' after making changes to ignore.txt. It appears that simply recycling the filtering service isn't enough. Give that a shot and let me know what happens.
RE: how to avoid Websense filtering for some machines - 20.Apr.2010 4:01:29 AM
apur32
Hi Richards,
I have restarted the server but it is still filtering the servers. I have contacted the Websense and they told me that there is another file in Windows\system32 folders
isa_ignore.txt
through which I can ignore URL, HOSTNAME and USERNAMES only. I have used it to ignore the URL and still testing it. But initially it looks to me that it is not working.
I will keep you posted on it.
Thanks for your help.
Apur
RE: how to avoid Websense filtering for some machines - 20.Apr.2010 5:43:42 PM
richardhicks
It was my understanding that isa_ignore.txt was only for intra-array communication, but if Websense support says otherwise, I'll take their word for it.
RE: how to avoid Websense filtering for some machines - 29.Apr.2010 7:40:49 AM
apur32
Just a quick update.....
Websense Support personnel remote to our system and try to fix the problem with
isa_ignore.txt
but the problem is still there.
I will keep you updated ....
RE: how to avoid Websense filtering for some machines - 17.May2010 8:28:54 AM
apur32
Websense Support closed the call after trying different method which did not work. They said at the end that anything which goes out of the network to internet will be filtered with Websense.
This is pretty tricky situation now for us. We have to buy more licenses if we can not solve this issue.
Is there any other way we can solve it?
RE: how to avoid Websense filtering for some machines - 18.May2010 10:22:45 AM
pierreasdf
Maybe something like this could work: If possible for you, you could deploy a second ISA server, without the Websense plug-in installed, and point these machines to this new ISA server (if they are secure NAT clients, you can change the default route to this ISA; if they are FW ou Web proxy clients, reconfigure them accordingly).
< Message edited by pierreasdf -- 18.May2010 10:23:45 AM >
RE: how to avoid Websense filtering for some machines - 6.Aug.2011 4:44:24 AM
wangyin
Looking in the Websense documentation, their advice can be to 'restart the server' ideal after producing modifications to ignore.txt. It appears that merely recycling the filtering organization isn't enough. Give that the shot and allow me know what happens.
Cheap Gucci Shoes|Cheap Gucci Boots|Gucci Designer Shoes
(in reply to pierreasdf)
