Certificate path not correct on ISA 2006 for OWA
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Certificate path not correct on ISA 2006 for OWA Page: [1]
Certificate path not correct on ISA 2006 for OWA - 19.Aug.2010 5:42:12 AM
sbsnwns1
Hello
I have this issue with OWA certificate on ISA 2006. We currently have OWA using ISA 2000 and I am in the process of setting up ISA 2006 to replace it. Everything is working apart from when you got to the OWA URL on ISA 2006 then the client get a certificate error. The certificate does not have a path back to the root certificate. THe same certificate on ISA 2000 works. On the ISA 2006 server looking at the certificate through MMC it shows everything in order. Within ISA 2006 publishing rule the certificate is all correct. test rule shows everything correct as well. ISA BPA shows all green ticks. But when I try to access OWA through the publishing rule on ISA 2006 I get certificate error. From the same PC if I access the OWA publishing rule on ISA 2000 I do not get a certificate error. Both ISA servers have the same certificate. Anybody know what could be causing this?
RE: Certificate path not correct on ISA 2006 for OWA - 19.Aug.2010 7:20:59 AM
You probably need to install the intermediate CA certificate from your certificate provider in the Local Computer, Intermediate Certificates store on your ISA server.
(in reply to sbsnwns1)
RE: Certificate path not correct on ISA 2006 for OWA - 19.Aug.2010 7:30:24 AM
sbsnwns1
Hello Jason
Yes that does fix it but why does the certificate works on the ISA 2000 OWA publishing without the need for installing the intermediate certificate. The certificate is the same on both ISA 2000 and ISA 2006. The issue we have is most of the users are based at schools and we do not have access to their PC to do the installation of intermediate certificate so if possible would like to get the ISA 2006 to work like the ISA 2000 published OWA.
RE: Certificate path not correct on ISA 2006 for OWA - 19.Aug.2010 7:35:13 AM
You should only need to install the intermediate cert on ISA, not each indidivual machine...ISA 2000 is ten years old and probably doesn't even validate the certificate chain!
< Message edited by Jason Jones -- 19.Aug.2010 7:36:14 AM >
RE: Certificate path not correct on ISA 2006 for OWA - 19.Aug.2010 10:40:11 AM
sbsnwns1
Hello Jason
Thank you for the swift reply. We have loaded all the intermidate certificates on the ISA 2006 server but still get the certificate path error on the client. When I try to access OWA from the ISA 2006 server it does not give any certificate error. My understanding is that the intermediate certificates should be downloaded to the client when it goes to the site but for some reason it is not happening. Any things else I can try out to see where the issue is? Could ISA stop the downloading of the intermediate certificates?
RE: Certificate path not correct on ISA 2006 for OWA - 27.Feb.2012 11:45:14 AM
wleaobras
You need import the root certificate into the ISA "Trusted Root Certification Authorities"
