Windows Live Essentials 2011...messenger
All Forums >> [Threat Management Gateway (TMG) 2010] >> General >> Windows Live Essentials 2011...messenger Page: [1] 2   next >   >>
Windows Live Essentials 2011...messenger - 1.Oct.2010 1:43:18 PM
kingbuzzo
Hi Fellas:
I recently upgraded to the new Windows Live Essentials suite that came out yesterday and now I cannot login to save my life...
I checked my Firewall Policy and Messenger is enabled for port 1863 and when I launch the client's built-in troubleshooter I get all green lights (good).
However, when I login it throws the Error code: 80048439
I looked in my logs and this is the first error I see:
Forefront TMG requires authorization to fulfill the request:  Access to the Web Proxy filter is denied.
anonymous  Internal External
http://www.sqm.microsoft.com/sqm/messenger/sqmserver.dll
Is something from MS trying to come back thru TMG and getting blocked?  I don't get it...
Note:   I have SP1 installed, W7/IE8 with the TMG Firewall Client enabled...
It was working fine until I upgraded my client.
Thanks.
RE: Windows Live Essentials 2011...messenger - 1.Oct.2010 2:45:23 PM
Hi King,
You might need to configure the client as a web proxy client or Firewall (TMG) client.
Is your Access Rule requireing authentication?
(in reply to kingbuzzo)
RE: Windows Live Essentials 2011...messenger - 1.Oct.2010 4:19:44 PM
kingbuzzo
Yes, my workstation is an authenticated (AD) TMG client.
Yes, my access rule requires authentication.
I was reading another post that explained how to create a rule so that link could be accessed without authentication (which I did).
I got a little further in the login process but then it threw another error message.
I went thru the logs and it was trying to access several more links without using authentication which I added to my new rule but it is still failing for me.
On a side note, the Live Mail application is also failing with similar symptoms.
Either I'm an early adopter or nobody uses TMG because this is a very popular application!
Has anyone had similar issues with the Beta and TMG?
RE: Windows Live Essentials 2011...messenger - 4.Oct.2010 3:50:50 AM
illum1na
I'm in (almost) the same situation.
Windows Live Essentials 2011, which was released..
ISA Server 2006
Eventually the login process fails with error 81000306, ISA logging does not show denied access from my client, only Allowed messages..
RE: Windows Live Essentials 2011...messenger - 4.Oct.2010 8:24:30 AM
burnhp
hi!
same problem here.
windows live essentials 2011.
Messenger login fails with error 81000303 behind proxy in isa server 2006.
working fine before upgrade.
(in reply to illum1na)
RE: Windows Live Essentials 2011...messenger - 4.Oct.2010 9:51:09 AM
kingbuzzo
ha ha, you would think someone in Redmond would have tested the thing with their own proxy!
i guess i will go crawling back to the old version until i find a fix - critical app!
(in reply to burnhp)
RE: Windows Live Essentials 2011...messenger - 4.Oct.2010 9:54:54 AM
I've been using the beta of LiveEssentials and haven't had any problems from behind TMG. However, I'm not requiring authentication. What happens when you do that?
RE: Windows Live Essentials 2011...messenger - 4.Oct.2010 10:19:57 AM
burnhp
keep getting errors in isa server 2006.
443 HTTPS Denied Connection MSN 0x800733f5 WSA_RWS_ERROR_ACCESS_DENIED
but msn 2009, build 14.0 works fine in the same network, including this same machine updated to 2011.
RE: Windows Live Essentials 2011...messenger - 5.Oct.2010 12:29:47 PM
kingbuzzo
no authentication isn't really an option for me...did you upgrade from the beta?
RE: Windows Live Essentials 2011...messenger - 6.Oct.2010 3:23:11 PM
kingbuzzo
Windows Live Mail doesn't work either...throws:  0x80048820 with similar symptoms...
RE: Windows Live Essentials 2011...messenger - 7.Oct.2010 5:24:49 AM
Hazem_Salaita
i'm using the full version Windows Live Messenger 2011 15.4.3502.0922
and had problem with signing in ...
Using ISA Server 2004
Error Code:8004840a
when i check the troubleshooter it gaves me that my default gateway is offline
can someone help me to fix it
RE: Windows Live Essentials 2011...messenger - 7.Oct.2010 9:45:15 AM
kingbuzzo
I wish I could help you but I'm in the same boat.
I guess that this confirms that the same issue exists in all supported version of ISA/TMG.
Maybe a genius will chime in...
(in reply to Hazem_Salaita)
RE: Windows Live Essentials 2011...messenger - 7.Oct.2010 12:38:21 PM
ORIGINAL: kingbuzzo
Hi King,
I haven't upgraded from beta - is this a problem with the final version?
RE: Windows Live Essentials 2011...messenger - 7.Oct.2010 12:41:18 PM
ORIGINAL: kingbuzzo
Are your browsers configured with the web proxy client configuration?
RE: Windows Live Essentials 2011...messenger - 7.Oct.2010 12:57:48 PM
burnhp
yes, they are with webproxy.
RE: Windows Live Essentials 2011...messenger - 7.Oct.2010 2:18:23 PM
kingbuzzo
Yesh, Windows Live Essentials 2011 went gold last week:
http://explore.live.com/windows-live-essentials?os=winxp
It was working with the previous version (never tried beta)...
RE: Windows Live Essentials 2011...messenger - 7.Oct.2010 2:19:21 PM
kingbuzzo
I have tried both configs, proxy client and firewall client with no dice...
Incidentally, it doesn't seem to work with Asstaro or BordumbMangler either!
RE: Windows Live Essentials 2011...messenger - 15.Oct.2010 2:58:38 PM
kingbuzzo
RE: Windows Live Essentials 2011...messenger - 15.Oct.2010 3:17:29 PM
burnhp
same here, the programs of the live suite dont connect :/
Post #: 19
RE: Windows Live Essentials 2011...messenger - 15.Oct.2010 3:42:59 PM
Is this with both ISA Server and TMG ???
Windows Expert - IT Pro MVP
Post #: 20
