do I need WPAD for web proxy client
All Forums >> [ISA 2006 Web Proxy] >> Web Proxy Client >> do I need WPAD for web proxy client Page: [1]
do I need WPAD for web proxy client - 8.Dec.2010 6:16:34 AM
mcse_696
hi all
is it require WPAD for proxy client and firewall client, or its enough to point IE to use isa as proxy ? I only have 30 clients windows, and I have slow internet when I m using isa as proxy server,
thanks in advance
< Message edited by mcse_696 -- 9.Dec.2010 3:47:02 AM >
RE: do I need WPAD for web proxy client - 9.Dec.2010 7:01:45 AM
paulo.oliveira
WPAD is not a requirement, but best practices.
About ISA slowness, could be many things, but first make sure your NICs are configured correctly.
http://blog.msfirewall.org.uk/2008/06/isa-servers-recommeded-network-card.html
Paulo Oliveira.
Microsoft MVP - Forefront
MCP - ISA Firewall 2004
(in reply to mcse_696)
RE: do I need WPAD for web proxy client - 9.Dec.2010 11:52:26 AM
IanC
Also, if you must configure your browsers manually, specify an automatic configuration script (http://fqdn:8080/array.dll?Get.Routing.Script) rather than a Proxy IP address. That way, you'll be able to control centrally (in ISA) which resources should bypass the proxy.
Ian
Ian Currie
nAppliance TMG/UAG Appliances - EMEA
www.surefront.co.uk
(in reply to paulo.oliveira)
RE: do I need WPAD for web proxy client - 9.Dec.2010 1:32:22 PM
paulo.oliveira
Great tip Ian!!
Paulo Oliveira.
(in reply to IanC)
RE: do I need WPAD for web proxy client - 16.Dec.2010 5:35:54 AM
mcse_696
I read the article My interface settings are correct on ISA i have 3 NIC, DG on external interface only and DNS on internal interface only. I tried Automatic Configuration Script same delay.
I tried INTERNET BROWSING from ISA itself got same delay,
I have other weird problems.
1- right now there is no access rule localhost to external, however I can browse internet
2- access rule I have from internal to external is all outbound protocols, when I choose select protocols HTTP,HTTPS,DNS,SMTP,POP3, internet browsing not working at all
3-I have proxy client from external can please explain
network rules
Acees Rules
Firewall Client
Proxy cleint
proxy setting on client
Firewall Client on ISA
< Message edited by mcse_696 -- 16.Dec.2010 7:47:23 AM >
RE: do I need WPAD for web proxy client - 16.Dec.2010 9:28:04 AM
paulo.oliveira
can not understand if you enabled WPAD, have you enabled it?
ISA has some pre-configured access rules. They´re called System Policies. There´s one System Policy which allows HTTP/HTTPS access.
Some thing must be wrong with your client machines... Did not see an access rule allowing access to your DNS server to make DNS queries.
Can not understand this. Can you elaborate?
Paulo Oliveira.
RE: do I need WPAD for web proxy client - 22.Dec.2010 6:19:16 AM
mcse_696
I enabled WPAD from DNS and DHCP, automatically detect settings, use automatic configuration script on ISA server ,
I monitored both client and DNS server nothing wrong with DNS query, I stoped using ISA as proxy until find the reason
I have other issue I added my servers to ip exceptions in Configure Flood Mitigation Settings, however still getting alert
ISA Server disconnected a non-TCP connection from 192.168.0.2 because the connection limit for this IP address was exceeded. Larger custom connection limits should be configured for the IP addresses of chained proxy servers and back-to-back ISA Server computers with a NAT relationship.
192.168.0.2 my DC
< Message edited by mcse_696 -- 22.Dec.2010 6:20:43 AM >
RE: do I need WPAD for web proxy client - 22.Dec.2010 9:43:24 AM
paulo.oliveira
is your DNS server Windows 2008? If so, check this: http://blogs.technet.com/b/isablog/archive/2008/02/19/windows-server-2008-dns-block-feature.aspx
Paulo Oliveira.
