FPCPolicyRule - ftp upload blocked by default?
All Forums >> [ISA 2006 Misc.] >> ISA 2006 Programming >> FPCPolicyRule - ftp upload blocked by default? Page: [1]
FPCPolicyRule - ftp upload blocked by default? - 8.Dec.2010 10:47:35 AM
FlushNorris
Hey,
I've got a project where FPCPolicyRule's is being created with .net(C#) through FPCLib, now i've become aware of an additional setting which is only able to be altered when the rule has been saved e.g. FTP regarding uploads is being blocked by default, that may be good for some rules. But how do i find/change that setting api-wise?
I became aware of the additional setting on...
http://www.elmajdal.net/isaserver/Allowing_FTP_Uploads_Through_ISA_Server_2004_2006.aspx
There is also additional settings for HTTP and RDP, which also would be nice to know where they are stored.
Regards
Nikolaj Strauss
RE: FPCPolicyRule - ftp upload blocked by default? - 14.Dec.2010 7:05:27 AM
parseint
I've got the exact same problem, I'm using vbscript, didn't know there was a c# lib. Where can I find this lib?
(in reply to FlushNorris)
RE: FPCPolicyRule - ftp upload blocked by default? - 14.Dec.2010 7:31:57 AM
parseint
Hi, I figured it out, take a look at:
http://msdn.microsoft.com/en-us/library/ff823963(VS.85).aspx
RE: FPCPolicyRule - ftp upload blocked by default? - 14.Dec.2010 8:18:24 AM
parseint
Was a little hassle to figure this one out code-wise, but here's how to disable the read-only mode:
const FTPFilterGUID = "{680A928F-22B3-11D1-B026-0000F87750CB}"
const RuleName = "Some rule"
Set fso = CreateObject("Scripting.FileSystemObject")
Set rule = GetPolicyRule(RuleName)
Set vpSets = rule.VendorParametersSets
Set vpSet = vpSets.Item(FTPFilterGUID)
vpSet.Value("BOOL_VALUE") = "FALSE"
vpSet.Save
function GetPolicyRule(ruleName)
Dim root
Dim rules
Dim errorCode, errorDescript
Set root = WScript.CreateObject("FPC.Root")
Set rules = root.GetContainingArray.ArrayPolicy.PolicyRules
On Error Resume Next
Set GetPolicyRule = rules(ruleName)
Select case err.Number
case Error_FileNotFound:
WScript.Echo "The policy rule " & ruleName & " could not be found."
WScript.Quit
case 0:
' OK
case Else
err.Raise err.Number,, err.Description
End Select
On Error GoTo 0
End Function
< Message edited by parseint -- 14.Dec.2010 9:07:27 AM >
(in reply to parseint)
RE: FPCPolicyRule - ftp upload blocked by default? - 14.Dec.2010 9:05:48 AM
parseint
I forgot to add the vendor set if it doesn't exist, here's the code for doing that:
sub AddVendorSet(ruleN, guid)
'Define the constants needed.
Const Error_FileNotFound = &H80070002
Dim rule, vpSets, vpSet
set rule = GetPolicyRule(ruleN)
' Try to retrieve the required vendor parameters set.
' If it does not exist, create it.
Set vpSet = vpSets.Item(guid)
If Err.Number = Error_FileNotFound Then
Err.Clear
WScript.Echo "Creating the required vendor parameters set..."
Set vpSet = vpSets.Add(guid)
If Err.Number <> 0 Then
WScript.Echo "An error occurred: 0x" & Hex(Err.Number) & " " & Err.Description
WScript.Quit
End If
Else
WScript.Echo "The vendor required parameters set already exists."
End If
Err.Clear
On Error GoTo 0
' Set the value of the parameter.
vpSet.Save
WScript.Echo "Done adding vendor set!"
End Sub
< Message edited by parseint -- 14.Dec.2010 9:06:59 AM >
