are your clients only Web Proxy clients? If so, they only will be able to use ISA as a proxy. Meanning, the only protocols handled by ISA will be HTTP/HTTPS/FTP.
Since you want ISA act like a firewall (filtering all protocols), you must configure your clients as either SecureNAT or FWC.
Regards, Paulo Oliveira.
OK, I've configured the clients as a secure NAT. But i still have the same issue, which is pop3/smtp stop responding when using "users set" instead of "all users" in the users tab of the access policy.
