Routed HTTP does not cache
All Forums >> [ISA Server 2004 Cache] >> General >> Routed HTTP does not cache Page: [1]
Routed HTTP does not cache - 14.Feb.2011 12:33:22 PM
Rogerga
Hello
I have a Routed Internal Network (ISA behind ISA) so that clients behind the ISA accessing internal webservers(outside the ISA) connect directly with their client IP.
The traffic mainly is HTTP - so I have a Custom protocol called MYHTTP configured for port 80 through which the traffic passes and I have denied the same traffic on HTTP which has webproxy bound.
Everything works fine as expected however I am unable to cache this HTTP aka MTHTTP traffic on the ISA - how do i get around this . I do not want to use the webproxyfilter because it NATs on the ISA's Ip.
Roger
RE: Routed HTTP does not cache - 14.Feb.2011 1:59:01 PM
paulo.oliveira
Hi Roger,
without using web proxy filter, you canīt benefit from cache.
Paulo Oliveira.
(in reply to Rogerga)
RE: Routed HTTP does not cache - 14.Feb.2011 2:01:56 PM
paulo.oliveira
if this is intended to access a restricted set of websites, you can create a cache rule for caching the contents,
Paulo Oliveira.
(in reply to paulo.oliveira)
RE: Routed HTTP does not cache - 14.Feb.2011 2:40:48 PM
Rogerga
Thanks Paul
I did try ur suggestion already i.e Traffic allowed thru MYHTTP without webproxy and set a cache rule explicitly to the internal site
The logs show the connections being successful thru the firewall service but the cache status is always 0x0 . From what i decipher - the cache will work only thru the webproxy filter ...but I was hoping there was a workaround for this.
Would you by any chance know if the latest TMG behave similarly or different given the same circumstance ?
Thanks a bunch
Roger
RE: Routed HTTP does not cache - 14.Feb.2011 3:08:22 PM
paulo.oliveira
Hi Roger,
I guess TMG behaviour is the same.
Paulo Oliveira.
