We started using wpad.dat for proxy autodiscovery.. wpad.dat is not hosted in ISA server its hosted in another server running IIS. We have webmarshal proxy installed on our isa sever. If I visit any proxy bypass site - the request still goes to ISA server (it by passes webmarshal fine) it doesnt go directly to internet..
Do i need to add these sites ( i.e. Internal Properties --> web browser --> add directly access these servers or domains) , in wpad.dat it specifies to go direct not to isa.. Does all the request go to ISA?
If I use wpad.dat do i not need to use auto discovery of ISA firewall?
Do you mean there is another path to internet? If so, then it could be a problem with your wpad.dat file.
