Hi All, I have a proble that need help. My system network have isa 2006 and exchange 2003. I published OWA with SSL on isa server 2006. It run normally but today it have a problem. If i access OWA via internet enviroment, it get error 105 that can not resolved DNS. If i access OWA via local network, it show certificate dialog and i view certificate. On general tab, I see : issued to : *.opendns.com Issued by : Equifax secure Certificate Authority On Certification Path tab:
Hi, the problem is about the dns registration for the site or for the certificate publisher. -if the url works fine in lan (after clicking yes to certificate question)then you should reregsiter your site in one of the global dns -if the certificate question is new for you and your users then there is problem about your certificate publisher or the server can not negotiate with it, in this case you can install and run your own certificate(with windows 2003-2008 although it is less secure)
< Message edited by hadideveloper -- 19.Dec.2011 2:45:38 AM >
Hi, I am running own certificate. I think this problem is about dns (where i registration domain tkmvietnam.vn) I can nslookup tkmvietnam.vn --> my ip public. But can not nslookup mail.tkmvietnam.vn . if i am in Lan, i can nslookup mail.tkmvietnam.vn but it not same my ip public. Thanks,
