perrype
Hi, I have problems trying to install ISA 2004 on a windows 2003 DC. Core components are installed but at the additional components it fails. When i check the logs it says it failed on MSDE; Attempting to install MSDE Activating MSDE installation Deleting previous MSDE installation directory <C:\Program Files\microsoft sql server\MSSQL$MSFW> Setup failed. Error returned: 0x643 MSDE Installation failed, hr=80070643 Performing rollback (uninstall) of firewall Activating setup cmdline='C:\WINDOWS\system32\msiexec.exe /qn /x {0AC95D97-1B75-4AC7-B061-F21E379FF809} REBOOT=ReallySuppress WRAPPER=1 /Lvoicewarmup+ C:\WINDOWS\TEMP\ISAFWSV_294.log ' Process completed successfully Wrapper: DoSetup failed, hr=80070643 Installation failed, error returned 0x80070643 On this server was Symantec End Point protection installed but it removed previously. I tried different things from forums to solve it but i was not able too. Hope someone here knows a solution. Here is the log from ISAMSDE_294.log. === Verbose logging started: 4-1-2013 11:33:09 Build type: SHIP UNICODE 3.01.4000.4042 Calling process: C:\WINDOWS\system32\msiexec.exe === MSI (c) (50:BC) [11:33:09:197]: Resetting cached policy values MSI (c) (50:BC) [11:33:09:197]: Machine policy value 'Debug' is 0 MSI (c) (50:BC) [11:33:09:197]: ******* RunEngine: ******* Product: C:\Program Files\Microsoft ISA Server\MSDE\Setup\SqlRun01.msi ******* Action: ******* CommandLine: ********** MSI (c) (50:BC) [11:33:09:197]: Client-side and UI is none or basic: Running entire install on the server. MSI (c) (50:BC) [11:33:09:197]: Grabbed execution mutex. MSI (c) (50:BC) [11:33:09:197]: Cloaking enabled. MSI (c) (50:BC) [11:33:09:197]: Attempting to enable all disabled priveleges before calling Install on Server MSI (c) (50:BC) [11:33:09:212]: Incrementing counter to disable shutdown. Counter after increment: 0 MSI (s) (F0:F0) [11:33:09:212]: Grabbed execution mutex. MSI (s) (F0:A8) [11:33:09:212]: Resetting cached policy values MSI (s) (F0:A8) [11:33:09:212]: Machine policy value 'Debug' is 0 MSI (s) (F0:A8) [11:33:09:212]: ******* RunEngine: ******* Product: C:\Program Files\Microsoft ISA Server\MSDE\Setup\SqlRun01.msi ******* Action: ******* CommandLine: ********** MSI (s) (F0:A8) [11:33:09:212]: Machine policy value 'DisableUserInstalls' is 0 MSI (s) (F0:A8) [11:33:09:212]: File will have security applied from OpCode. MSI (s) (F0:A8) [11:33:09:212]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files\Microsoft ISA Server\MSDE\Setup\SqlRun01.msi' against software restriction policy MSI (s) (F0:A8) [11:33:09:212]: Note: 1: 2262 2: DigitalSignature 3: -2147287038 MSI (s) (F0:A8) [11:33:09:212]: SOFTWARE RESTRICTION POLICY: C:\Program Files\Microsoft ISA Server\MSDE\Setup\SqlRun01.msi is not digitally signed MSI (s) (F0:A8) [11:33:09:212]: SOFTWARE RESTRICTION POLICY: C:\Program Files\Microsoft ISA Server\MSDE\Setup\SqlRun01.msi is permitted to run at the 'unrestricted' authorization level. MSI (s) (F0:A8) [11:33:09:212]: End dialog not enabled MSI (s) (F0:A8) [11:33:09:212]: Original package ==> C:\Program Files\Microsoft ISA Server\MSDE\Setup\SqlRun01.msi MSI (s) (F0:A8) [11:33:09:212]: Package we're running from ==> C:\WINDOWS\Installer\5bf15.msi MSI (s) (F0:A8) [11:33:09:228]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E09B48B5-E141-427A-AB0C-D3605127224A}'. MSI (s) (F0:A8) [11:33:09:228]: APPCOMPAT: no matching ProductCode found in database. MSI (s) (F0:A8) [11:33:09:228]: MSCOREE not loaded loading copy from system32 MSI (s) (F0:A8) [11:33:09:228]: Machine policy value 'TransformsSecure' is 1 MSI (s) (F0:A8) [11:33:09:228]: Note: 1: 2205 2: 3: MsiFileHash MSI (s) (F0:A8) [11:33:09:228]: Machine policy value 'DisablePatch' is 0 MSI (s) (F0:A8) [11:33:09:228]: Machine policy value 'AllowLockdownPatch' is 0 MSI (s) (F0:A8) [11:33:09:228]: Machine policy value 'DisableLUAPatching' is 0 MSI (s) (F0:A8) [11:33:09:228]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI (s) (F0:A8) [11:33:09:228]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E09B48B5-E141-427A-AB0C-D3605127224A}'. MSI (s) (F0:A8) [11:33:09:228]: APPCOMPAT: no matching ProductCode found in database. MSI (s) (F0:A8) [11:33:09:228]: Transforms are not secure. MSI (s) (F0:A8) [11:33:09:228]: Note: 1: 2262 2: Control 3: -2147287038 MSI (s) (F0:A8) [11:33:09:228]: Command Line: DISABLENETWORKPROTOCOLS=1 INSTANCENAME=MSFW SA... MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{D29DCF7A-8199-4373-BA0D-2F3635EC940C}'. MSI (s) (F0:A8) [11:33:09:228]: Product Code passed to Engine.Initialize: '' MSI (s) (F0:A8) [11:33:09:228]: Product Code from property table before transforms: '{E09B48B5-E141-427A-AB0C-D3605127224A}' MSI (s) (F0:A8) [11:33:09:228]: Product Code from property table after transforms: '{E09B48B5-E141-427A-AB0C-D3605127224A}' MSI (s) (F0:A8) [11:33:09:228]: Product not registered: beginning first-time install MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'. MSI (s) (F0:A8) [11:33:09:228]: Entering CMsiConfigurationManager::SetLastUsedSource. MSI (s) (F0:A8) [11:33:09:228]: User policy value 'SearchOrder' is 'nmu' MSI (s) (F0:A8) [11:33:09:228]: Adding new sources is allowed. MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'. MSI (s) (F0:A8) [11:33:09:228]: Package name extracted from package path: 'SqlRun01.msi' MSI (s) (F0:A8) [11:33:09:228]: Package to be registered: 'SqlRun01.msi' MSI (s) (F0:A8) [11:33:09:228]: Note: 1: 2262 2: AdminProperties 3: -2147287038 MSI (s) (F0:A8) [11:33:09:228]: Machine policy value 'DisableMsi' is 1 MSI (s) (F0:A8) [11:33:09:228]: Machine policy value 'AlwaysInstallElevated' is 0 MSI (s) (F0:A8) [11:33:09:228]: User policy value 'AlwaysInstallElevated' is 0 MSI (s) (F0:A8) [11:33:09:228]: Product installation will be elevated because user is admin and product is being installed per-machine. MSI (s) (F0:A8) [11:33:09:228]: Running product '{E09B48B5-E141-427A-AB0C-D3605127224A}' with elevated privileges: Product is assigned. MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding DISABLENETWORKPROTOCOLS property. Its value is '1'. MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding INSTANCENAME property. Its value is 'MSFW'. MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding SA... MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding ARPSYSTEMCOMPONENT property. Its value is '1'. MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'. MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'D:\CD\ISA2004'. MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'. MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '2640'. MSI (s) (F0:A8) [11:33:09:228]: TRANSFORMS property is now: MSI (s) (F0:A8) [11:33:09:228]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '110'. MSI (s) (F0:A8) [11:33:09:228]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Application Data MSI (s) (F0:A8) [11:33:09:228]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Favorites MSI (s) (F0:A8) [11:33:09:228]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\NetHood MSI (s) (F0:A8) [11:33:09:228]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\My Documents MSI (s) (F0:A8) [11:33:09:228]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\PrintHood MSI (s) (F0:A8) [11:33:09:228]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Recent MSI (s) (F0:A8) [11:33:09:228]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\SendTo MSI (s) (F0:A8) [11:33:09:228]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Templates MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Application Data MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Local Settings\Application Data MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\My Documents\My Pictures MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Startup MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Desktop MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Start Menu\Programs\Administrative Tools MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Start Menu\Programs\Startup MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Start Menu\Programs MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Start Menu MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\pperdijk\Desktop MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Templates MSI (s) (F0:A8) [11:33:09:244]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts MSI (s) (F0:A8) [11:33:09:244]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16 MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'. MSI (s) (F0:A8) [11:33:09:244]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2 MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'IT'. MSI (s) (F0:A8) [11:33:09:244]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2 MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'xxxxxxxxxx'. MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\WINDOWS\Installer\5bf15.msi'. MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files\Microsoft ISA Server\MSDE\Setup\SqlRun01.msi'. MSI (s) (F0:A8) [11:33:09:244]: Note: 1: 2262 2: PatchPackage 3: -2147287038 MSI (s) (F0:A8) [11:33:09:244]: Machine policy value 'DisableRollback' is 0 MSI (s) (F0:A8) [11:33:09:244]: User policy value 'DisableRollback' is 0 MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'. === Logging started: 4-1-2013 11:33:09 === MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'. MSI (s) (F0:A8) [11:33:09:244]: Doing action: INSTALL MSI (s) (F0:A8) [11:33:09:244]: Running ExecuteSequence MSI (s) (F0:A8) [11:33:09:244]: Doing action: ProgramFilesFolder.66CDF039_0EDE_453E_A1E5_1931046C4056 Action start 11:33:09: INSTALL. MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding ProgramFilesFolder.66CDF039_0EDE_453E_A1E5_1931046C4056 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.66CDF039_0EDE_453E_A1E5_1931046C4056. MSI (s) (F0:A8) [11:33:09:244]: Doing action: ProgramFilesFolder.ACD7EC22_4989_4067_B267_6DB5716695BC Action ended 11:33:09: ProgramFilesFolder.66CDF039_0EDE_453E_A1E5_1931046C4056. Return value 1. MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding ProgramFilesFolder.ACD7EC22_4989_4067_B267_6DB5716695BC property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.ACD7EC22_4989_4067_B267_6DB5716695BC. MSI (s) (F0:A8) [11:33:09:244]: Doing action: ProgramFilesFolder.0C7570D6_6225_4960_B951_4D16DD906838 Action ended 11:33:09: ProgramFilesFolder.ACD7EC22_4989_4067_B267_6DB5716695BC. Return value 1. MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding ProgramFilesFolder.0C7570D6_6225_4960_B951_4D16DD906838 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.0C7570D6_6225_4960_B951_4D16DD906838. MSI (s) (F0:A8) [11:33:09:244]: Doing action: ProgramFilesFolder.88C26F26_166C_4CD7_8175_38297C2276D7 Action ended 11:33:09: ProgramFilesFolder.0C7570D6_6225_4960_B951_4D16DD906838. Return value 1. MSI (s) (F0:A8) [11:33:09:244]: PROPERTY CHANGE: Adding ProgramFilesFolder.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.88C26F26_166C_4CD7_8175_38297C2276D7. MSI (s) (F0:A8) [11:33:09:244]: Doing action: ProgramFilesFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:09: ProgramFilesFolder.88C26F26_166C_4CD7_8175_38297C2276D7. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:09:259]: Doing action: StartupFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:09: ProgramFilesFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding StartupFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Documents and Settings\All Users\Start Menu\Programs\Startup\'. Action start 11:33:09: StartupFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:09:259]: Doing action: SystemFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:09: StartupFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding SystemFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\WINDOWS\system32\'. Action start 11:33:09: SystemFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 Action ended 11:33:09: SystemFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.BF65A835_E76E_4CA5_8B97_E8FD33E7C475. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.C4D32C83_C28D_4329_A829_31C4C6034F59 Action ended 11:33:09: ProgramFilesFolder.BF65A835_E76E_4CA5_8B97_E8FD33E7C475. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.C4D32C83_C28D_4329_A829_31C4C6034F59. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.EF490CFB_7BC2_4102_8395_426CE5870B18 Action ended 11:33:09: ProgramFilesFolder.C4D32C83_C28D_4329_A829_31C4C6034F59. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.EF490CFB_7BC2_4102_8395_426CE5870B18. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.DCDF3AA8_FCF8_49F6_9877_752F754DD676 Action ended 11:33:09: ProgramFilesFolder.EF490CFB_7BC2_4102_8395_426CE5870B18. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.DCDF3AA8_FCF8_49F6_9877_752F754DD676. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 Action ended 11:33:09: ProgramFilesFolder.DCDF3AA8_FCF8_49F6_9877_752F754DD676. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.185C1D8F_1545_4277_BB64_857D2622DB57 Action ended 11:33:09: ProgramFilesFolder.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.185C1D8F_1545_4277_BB64_857D2622DB57. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC Action ended 11:33:09: ProgramFilesFolder.185C1D8F_1545_4277_BB64_857D2622DB57. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF Action ended 11:33:09: ProgramFilesFolder.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 Action ended 11:33:09: ProgramFilesFolder.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 Action ended 11:33:09: ProgramFilesFolder.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.AC2DB678_071D_4330_A52D_9286D618F650 Action ended 11:33:09: ProgramFilesFolder.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.AC2DB678_071D_4330_A52D_9286D618F650 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.AC2DB678_071D_4330_A52D_9286D618F650. MSI (s) (F0:A8) [11:33:09:259]: Doing action: ProgramFilesFolder.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB Action ended 11:33:09: ProgramFilesFolder.AC2DB678_071D_4330_A52D_9286D618F650. Return value 1. MSI (s) (F0:A8) [11:33:09:259]: PROPERTY CHANGE: Adding ProgramFilesFolder.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SystemFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 Action ended 11:33:09: ProgramFilesFolder.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB. Return value 1. MSI (s) (F0:A8) [11:33:09:275]: PROPERTY CHANGE: Adding SystemFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\WINDOWS\system32\'. Action start 11:33:09: SystemFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4. MSI (s) (F0:A8) [11:33:09:275]: Doing action: ProgramFilesFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 Action ended 11:33:09: SystemFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4. Return value 1. MSI (s) (F0:A8) [11:33:09:275]: PROPERTY CHANGE: Adding ProgramFilesFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4. MSI (s) (F0:A8) [11:33:09:275]: Doing action: TempFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 Action ended 11:33:09: ProgramFilesFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4. Return value 1. MSI (s) (F0:A8) [11:33:09:275]: PROPERTY CHANGE: Adding TempFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\DOCUME~1\pperdijk\LOCALS~1\Temp\'. Action start 11:33:09: TempFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4. MSI (s) (F0:A8) [11:33:09:275]: Doing action: ProgramFilesFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:09: TempFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4. Return value 1. MSI (s) (F0:A8) [11:33:09:275]: PROPERTY CHANGE: Adding ProgramFilesFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\'. Action start 11:33:09: ProgramFilesFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:09:275]: Doing action: StartupFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:09: ProgramFilesFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:09:275]: PROPERTY CHANGE: Adding StartupFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Documents and Settings\All Users\Start Menu\Programs\Startup\'. Action start 11:33:09: StartupFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SystemFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:09: StartupFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:09:275]: PROPERTY CHANGE: Adding SystemFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\WINDOWS\system32\'. Action start 11:33:09: SystemFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetInstallDir Action ended 11:33:09: SystemFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:09: SetInstallDir. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetDataDir Action ended 11:33:09: SetInstallDir. Return value 1. Action start 11:33:09: SetDataDir. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetInstanceName Action ended 11:33:09: SetDataDir. Return value 1. MSI (s) (F0:A8) [11:33:09:275]: PROPERTY CHANGE: Adding SqlInstanceName property. Its value is 'MSFW'. Action start 11:33:09: SetInstanceName. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetCollation Action ended 11:33:09: SetInstanceName. Return value 1. Action start 11:33:09: SetCollation. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetCallback Action ended 11:33:09: SetCollation. Return value 1. Action start 11:33:09: SetCallback. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetSecurityMode Action ended 11:33:09: SetCallback. Return value 1. Action start 11:33:09: SetSecurityMode. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetUpgrade Action ended 11:33:09: SetSecurityMode. Return value 1. Action start 11:33:09: SetUpgrade. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetUpgradeUser Action ended 11:33:09: SetUpgrade. Return value 1. Action start 11:33:09: SetUpgradeUser. MSI (s) (F0:A8) [11:33:09:275]: Skipping action: SetUpgradeUserWin9x (condition is false) MSI (s) (F0:A8) [11:33:09:275]: Skipping action: SetSecurityMode9x (condition is false) MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetSaPword Action ended 11:33:09: SetUpgradeUser. Return value 1. MSI (s) (F0:A8) [11:33:09:275]: PROPERTY CHANGE: Adding SqlSa... Action start 11:33:09: SetSaPword. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetUpgradeUserPword Action ended 11:33:09: SetSaPword. Return value 1. Action start 11:33:09: SetUpgradeUserPword. MSI (s) (F0:A8) [11:33:09:275]: Doing action: SetAllowBlankSaPword Action ended 11:33:09: SetUpgradeUserPword. Return value 1. Action start 11:33:09: SetAllowBlankSaPword. MSI (s) (F0:A8) [11:33:09:291]: Skipping action: SetSqlDoUpgrade (condition is false) MSI (s) (F0:A8) [11:33:09:291]: Doing action: SetDisableAgentStartup Action ended 11:33:09: SetAllowBlankSaPword. Return value 1. Action start 11:33:09: SetDisableAgentStartup. MSI (s) (F0:A8) [11:33:09:291]: Doing action: SetAllowXDBChaining Action ended 11:33:09: SetDisableAgentStartup. Return value 1. Action start 11:33:09: SetAllowXDBChaining. MSI (s) (F0:A8) [11:33:09:291]: Doing action: DefaultProgramDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:09: SetAllowXDBChaining. Return value 1. MSI (s) (F0:A8) [11:33:09:291]: PROPERTY CHANGE: Adding SqlProgramDir property. Its value is 'C:\Program Files\Microsoft SQL Server\'. Action start 11:33:09: DefaultProgramDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:09:291]: Doing action: DefaultDataDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:09: DefaultProgramDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:09:291]: PROPERTY CHANGE: Adding SqlDataDir property. Its value is 'C:\Program Files\Microsoft SQL Server\'. Action start 11:33:09: DefaultDataDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:09:291]: Doing action: SQLVersion.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:09: DefaultDataDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:09:291]: PROPERTY CHANGE: Adding SQLVersion property. Its value is '8.00.194'. Action start 11:33:09: SQLVersion.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:09:291]: Doing action: StreamSupportFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:09: SQLVersion.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A4) [11:33:09:291]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI1E.tmp, Entrypoint: StreamSupportFiles MSI (s) (F0:B8) [11:33:09:291]: Generating random cookie. MSI (s) (F0:B8) [11:33:09:291]: Created Custom Action Server with PID 3228 (0xC9C). MSI (s) (F0:AC) [11:33:09:306]: Running as a service. MSI (s) (F0:AC) [11:33:09:306]: Hello, I'm your 32bit Impersonated custom action server. Action start 11:33:09: StreamSupportFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Creating CA Temp Directory : C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Streamed setupex.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\setupex.dll Streamed sqdedev.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqdedev.dll Streamed sqlsut.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlsut.dll Streamed sqlunirl.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlunirl.dll Streamed sqlresld.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlresld.dll Streamed sqlcaxrll.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.rll Streamed sqlstp.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlstp.dll Streamed sqlstprll.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlstp.rll Streamed sqlcax.2D02443E_7002_4C0B_ABC9_EAB2C064397B to C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll MSI (s) (F0:A8) [11:33:09:556]: Doing action: SetPropSQLMSDEInstalled.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:09: StreamSupportFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:3C) [11:33:09:556]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI1F.tmp, Entrypoint: SetPropSQLMSDEInstalled Action start 11:33:09: SetPropSQLMSDEInstalled.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action SetPropSQLMSDEInstalled FindSet for ProductCode <{E09B48B5-E141-427A-AB0C-D3605127224A}> returned 0 Unsetting SQLMSDEInstalled by MsiSetProperty returned 0 Setting SQLMSDESelected by MsiSetProperty returned 0 End SetPropSQLMSDEInstalled MSI (s) (F0:A8) [11:33:10:009]: Skipping action: RestoreSetupParams.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:10:009]: Doing action: GetInstanceName.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: SetPropSQLMSDEInstalled.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:5C) [11:33:10:009]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI20.tmp, Entrypoint: GetInstanceName2 Action start 11:33:10: GetInstanceName.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:10:150]: Doing action: GetAgentService.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: GetInstanceName.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:80) [11:33:10:166]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI21.tmp, Entrypoint: GetAgentService Action start 11:33:10: GetAgentService.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll MSI (s) (F0!74) [11:33:10:275]: PROPERTY CHANGE: Adding AgentServiceName property. Its value is 'SQLAgent$MSFW'. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:10:275]: Doing action: GetInstanceRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: GetAgentService.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:1C) [11:33:10:291]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI22.tmp, Entrypoint: GetInstanceRegKey Action start 11:33:10: GetInstanceRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll MSI (s) (F0!30) [11:33:10:400]: PROPERTY CHANGE: Adding InstanceRegKey property. Its value is 'Microsoft SQL Server\MSFW'. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:10:400]: Doing action: GetInstanceSubDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: GetInstanceRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:98) [11:33:10:400]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI23.tmp, Entrypoint: GetInstanceSubDir Action start 11:33:10: GetInstanceSubDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll MSI (s) (F0!F0) [11:33:10:525]: PROPERTY CHANGE: Adding InstanceSubDir property. Its value is 'MSSQL$MSFW'. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:10:525]: Doing action: GetPerfMonRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: GetInstanceSubDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:90) [11:33:10:525]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI24.tmp, Entrypoint: GetPerfMonRegKey Action start 11:33:10: GetPerfMonRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll MSI (s) (F0!94) [11:33:10:619]: PROPERTY CHANGE: Adding SqlPerfMonRegKey property. Its value is 'SQLCTR$MSFW'. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:10:619]: Doing action: GetPipeName.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: GetPerfMonRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:28) [11:33:10:634]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI25.tmp, Entrypoint: GetInstancePipeName Action start 11:33:10: GetPipeName.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll MSI (s) (F0!34) [11:33:10:728]: PROPERTY CHANGE: Adding PipeName property. Its value is '\\.\pipe\MSSQL$MSFW\sql\query'. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:10:728]: Doing action: GetSQLService.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: GetPipeName.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:14) [11:33:10:744]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI26.tmp, Entrypoint: GetSQLService Action start 11:33:10: GetSQLService.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll MSI (s) (F0!48) [11:33:10:822]: PROPERTY CHANGE: Adding SQLServiceName property. Its value is 'MSSQL$MSFW'. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:10:822]: Doing action: GetTcpPort.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: GetSQLService.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:68) [11:33:10:822]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI27.tmp, Entrypoint: GetInstanceTcpPort Action start 11:33:10: GetTcpPort.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll MSI (s) (F0!50) [11:33:10:947]: PROPERTY CHANGE: Adding TcpPort property. Its value is '0'. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:10:947]: Doing action: InstanceName.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: GetTcpPort.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding InstanceName.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:10:947]: Doing action: InstanceDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: InstanceName.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding InstanceDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:10:947]: Doing action: InstanceRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: InstanceDir.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding InstanceRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'Microsoft SQL Server\MSFW'. Action start 11:33:10: InstanceRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:10:947]: Skipping action: UpgSetDefaultUpgrade... MSI (s) (F0:A8) [11:33:10:947]: Doing action: DeferSaPword.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: InstanceRegKey.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding ConfigServer.2D02443E_7002_4C0B_ABC9_EAB2C064397B... Action start 11:33:10: DeferSaPword.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:10:947]: Doing action: DeferSaPword2.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: DeferSaPword.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding ReconfigServer.2D02443E_7002_4C0B_ABC9_EAB2C064397B... Action start 11:33:10: DeferSaPword2.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:10:947]: Doing action: DeferUpgPword.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: DeferSaPword2.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:10: DeferUpgPword.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:10:947]: Doing action: LaunchConditions Action ended 11:33:10: DeferUpgPword.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: Note: 1: 2262 2: LaunchCondition 3: -2147287038 Action start 11:33:10: LaunchConditions. MSI (s) (F0:A8) [11:33:10:947]: Doing action: InstanceName.24170C3F_A9E4_47C1_8DFE_FD79C2714697 Action ended 11:33:10: LaunchConditions. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding InstanceName.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.24170C3F_A9E4_47C1_8DFE_FD79C2714697. MSI (s) (F0:A8) [11:33:10:947]: Doing action: InstanceName.88C26F26_166C_4CD7_8175_38297C2276D7 Action ended 11:33:10: InstanceName.24170C3F_A9E4_47C1_8DFE_FD79C2714697. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding InstanceName.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.88C26F26_166C_4CD7_8175_38297C2276D7. MSI (s) (F0:A8) [11:33:10:947]: Doing action: InstanceDir.88C26F26_166C_4CD7_8175_38297C2276D7 Action ended 11:33:10: InstanceName.88C26F26_166C_4CD7_8175_38297C2276D7. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding InstanceDir.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.88C26F26_166C_4CD7_8175_38297C2276D7. MSI (s) (F0:A8) [11:33:10:947]: Doing action: InstanceRegKey.88C26F26_166C_4CD7_8175_38297C2276D7 Action ended 11:33:10: InstanceDir.88C26F26_166C_4CD7_8175_38297C2276D7. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding InstanceRegKey.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'Microsoft SQL Server\MSFW'. Action start 11:33:10: InstanceRegKey.88C26F26_166C_4CD7_8175_38297C2276D7. MSI (s) (F0:A8) [11:33:10:947]: Skipping action: Collation.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 (condition is false) MSI (s) (F0:A8) [11:33:10:947]: Doing action: InstanceName.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:10: InstanceRegKey.88C26F26_166C_4CD7_8175_38297C2276D7. Return value 1. MSI (s) (F0:A8) [11:33:10:947]: PROPERTY CHANGE: Adding InstanceName.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceRegKey.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:10: InstanceName.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding InstanceRegKey.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'Microsoft SQL Server\MSFW'. Action start 11:33:10: InstanceRegKey.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:10:962]: Doing action: PipeName.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:10: InstanceRegKey.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding PipeName.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is '\\.\pipe\MSSQL$MSFW\sql\query'. Action start 11:33:10: PipeName.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:10:962]: Doing action: ServiceNameAgent.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:10: PipeName.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding ServiceNameAgent.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'SQLAgent$MSFW'. Action start 11:33:10: ServiceNameAgent.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:10:962]: Doing action: ServiceNameSQL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:10: ServiceNameAgent.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding ServiceNameSQL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: ServiceNameSQL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:10:962]: Doing action: SQLVersion.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:10: ServiceNameSQL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding SQLVersion.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is '8.00.194'. Action start 11:33:10: SQLVersion.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:10:962]: Doing action: TcpPort.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:10: SQLVersion.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding TcpPort.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is '0'. Action start 11:33:10: TcpPort.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceName.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 Action ended 11:33:10: TcpPort.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding InstanceName.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.BF65A835_E76E_4CA5_8B97_E8FD33E7C475. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceDir.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 Action ended 11:33:10: InstanceName.BF65A835_E76E_4CA5_8B97_E8FD33E7C475. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding InstanceDir.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.BF65A835_E76E_4CA5_8B97_E8FD33E7C475. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceName.C4D32C83_C28D_4329_A829_31C4C6034F59 Action ended 11:33:10: InstanceDir.BF65A835_E76E_4CA5_8B97_E8FD33E7C475. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding InstanceName.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.C4D32C83_C28D_4329_A829_31C4C6034F59. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceDir.C4D32C83_C28D_4329_A829_31C4C6034F59 Action ended 11:33:10: InstanceName.C4D32C83_C28D_4329_A829_31C4C6034F59. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding InstanceDir.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.C4D32C83_C28D_4329_A829_31C4C6034F59. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceRegKey.C4D32C83_C28D_4329_A829_31C4C6034F59 Action ended 11:33:10: InstanceDir.C4D32C83_C28D_4329_A829_31C4C6034F59. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding InstanceRegKey.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'Microsoft SQL Server\MSFW'. Action start 11:33:10: InstanceRegKey.C4D32C83_C28D_4329_A829_31C4C6034F59. MSI (s) (F0:A8) [11:33:10:962]: Doing action: ServiceNameAgent.C4D32C83_C28D_4329_A829_31C4C6034F59 Action ended 11:33:10: InstanceRegKey.C4D32C83_C28D_4329_A829_31C4C6034F59. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding ServiceNameAgent.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'SQLAgent$MSFW'. Action start 11:33:10: ServiceNameAgent.C4D32C83_C28D_4329_A829_31C4C6034F59. MSI (s) (F0:A8) [11:33:10:962]: Doing action: ServiceNameSQL.C4D32C83_C28D_4329_A829_31C4C6034F59 Action ended 11:33:10: ServiceNameAgent.C4D32C83_C28D_4329_A829_31C4C6034F59. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding ServiceNameSQL.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: ServiceNameSQL.C4D32C83_C28D_4329_A829_31C4C6034F59. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceName.EF490CFB_7BC2_4102_8395_426CE5870B18 Action ended 11:33:10: ServiceNameSQL.C4D32C83_C28D_4329_A829_31C4C6034F59. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding InstanceName.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.EF490CFB_7BC2_4102_8395_426CE5870B18. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceDir.EF490CFB_7BC2_4102_8395_426CE5870B18 Action ended 11:33:10: InstanceName.EF490CFB_7BC2_4102_8395_426CE5870B18. Return value 1. MSI (s) (F0:A8) [11:33:10:962]: PROPERTY CHANGE: Adding InstanceDir.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.EF490CFB_7BC2_4102_8395_426CE5870B18. MSI (s) (F0:A8) [11:33:10:962]: Doing action: InstanceName.DCDF3AA8_FCF8_49F6_9877_752F754DD676 Action ended 11:33:10: InstanceDir.EF490CFB_7BC2_4102_8395_426CE5870B18. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceName.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.DCDF3AA8_FCF8_49F6_9877_752F754DD676. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceDir.DCDF3AA8_FCF8_49F6_9877_752F754DD676 Action ended 11:33:10: InstanceName.DCDF3AA8_FCF8_49F6_9877_752F754DD676. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceDir.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.DCDF3AA8_FCF8_49F6_9877_752F754DD676. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceName.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 Action ended 11:33:10: InstanceDir.DCDF3AA8_FCF8_49F6_9877_752F754DD676. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceName.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceDir.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 Action ended 11:33:10: InstanceName.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceDir.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceName.185C1D8F_1545_4277_BB64_857D2622DB57 Action ended 11:33:10: InstanceDir.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceName.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.185C1D8F_1545_4277_BB64_857D2622DB57. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceDir.185C1D8F_1545_4277_BB64_857D2622DB57 Action ended 11:33:10: InstanceName.185C1D8F_1545_4277_BB64_857D2622DB57. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceDir.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.185C1D8F_1545_4277_BB64_857D2622DB57. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceRegKey.185C1D8F_1545_4277_BB64_857D2622DB57 Action ended 11:33:10: InstanceDir.185C1D8F_1545_4277_BB64_857D2622DB57. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceRegKey.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'Microsoft SQL Server\MSFW'. Action start 11:33:10: InstanceRegKey.185C1D8F_1545_4277_BB64_857D2622DB57. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceName.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB Action ended 11:33:10: InstanceRegKey.185C1D8F_1545_4277_BB64_857D2622DB57. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceName.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'MSFW'. Action start 11:33:10: InstanceName.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceDir.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB Action ended 11:33:10: InstanceName.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceDir.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'MSSQL$MSFW'. Action start 11:33:10: InstanceDir.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB. MSI (s) (F0:A8) [11:33:10:978]: Doing action: InstanceRegKey.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 Action ended 11:33:10: InstanceDir.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB. Return value 1. MSI (s) (F0:A8) [11:33:10:978]: PROPERTY CHANGE: Adding InstanceRegKey.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'Microsoft SQL Server\MSFW'. Action start 11:33:10: InstanceRegKey.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4. MSI (s) (F0:A8) [11:33:10:978]: Skipping action: Collation.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:10:978]: Skipping action: ConfirmReinstall.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:10:978]: Doing action: ShutdownServiceManager.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:10: InstanceRegKey.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4. Return value 1. MSI (s) (F0:80) [11:33:10:978]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI28.tmp, Entrypoint: ShutdownServiceManager Action start 11:33:10: ShutdownServiceManager.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:11:087]: Doing action: SqlCallback.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: ShutdownServiceManager.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:11: SqlCallback.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:11:087]: Doing action: SetDefaultRefreshDisableNetworkProtocols Action ended 11:33:11: SqlCallback.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:11:087]: PROPERTY CHANGE: Adding SqlDisableNetworkProtocols property. Its value is '1'. Action start 11:33:11: SetDefaultRefreshDisableNetworkProtocols. MSI (s) (F0:A8) [11:33:11:087]: Skipping action: SetDefaultUpgradeDisableNetworkProtocols (condition is false) MSI (s) (F0:A8) [11:33:11:087]: Doing action: SetDisableNetworkProtocols Action ended 11:33:11: SetDefaultRefreshDisableNetworkProtocols. Return value 1. Action start 11:33:11: SetDisableNetworkProtocols. MSI (s) (F0:A8) [11:33:11:103]: Doing action: AppSearch Action ended 11:33:11: SetDisableNetworkProtocols. Return value 1. Action start 11:33:11: AppSearch. MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 2262 2: CompLocator 3: -2147287038 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 2262 2: IniLocator 3: -2147287038 MSI (s) (F0:A8) [11:33:11:103]: PROPERTY CHANGE: Adding APPIE.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\WINDOWS\system32\shdocvw.dll'. MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 2262 2: CompLocator 3: -2147287038 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\MSSQLServer\Setup 3: 2 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 2262 2: IniLocator 3: -2147287038 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 2262 2: CompLocator 3: -2147287038 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\MSSQLServer\Setup 3: 2 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 2262 2: IniLocator 3: -2147287038 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 2262 2: CompLocator 3: -2147287038 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\MSFW\MSSQLServer\SuperSocketNetLib 3: 2 MSI (s) (F0:A8) [11:33:11:103]: Note: 1: 2262 2: IniLocator 3: -2147287038 MSI (s) (F0:A8) [11:33:11:103]: Skipping action: ErrorCodeIE.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:103]: Skipping action: FatalErrorIE.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:103]: Doing action: GetSqlStates.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: AppSearch. Return value 1. MSI (s) (F0:54) [11:33:11:103]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI29.tmp, Entrypoint: GetSqlStates Action start 11:33:11: GetSqlStates.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0!6C) [11:33:11:259]: PROPERTY CHANGE: Adding SqlStates property. Its value is '0'. Property SqlStates: 0 (0x0) MSI (s) (F0:A8) [11:33:11:259]: Skipping action: DetectUpgrade.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:259]: Skipping action: SqlDisableNetAccessError.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:259]: Doing action: CCPSearch Action ended 11:33:11: GetSqlStates.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:11:259]: Note: 1: 2262 2: CCPSearch 3: -2147287038 Action start 11:33:11: CCPSearch. MSI (s) (F0:A8) [11:33:11:259]: Doing action: RMCCPSearch Action ended 11:33:11: CCPSearch. Return value 1. MSI (s) (F0:A8) [11:33:11:259]: Note: 1: 2262 2: CCPSearch 3: -2147287038 Action start 11:33:11: RMCCPSearch. MSI (s) (F0:A8) [11:33:11:259]: Doing action: ValidateProductID Action ended 11:33:11: RMCCPSearch. Return value 0. Action start 11:33:11: ValidateProductID. MSI (s) (F0:A8) [11:33:11:259]: Doing action: SetRefreshProtocolListRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: ValidateProductID. Return value 1. MSI (s) (F0:A8) [11:33:11:259]: PROPERTY CHANGE: Adding ProtocolListRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'tcp'. Action start 11:33:11: SetRefreshProtocolListRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:11:259]: Doing action: SetRefreshProtocolListNTRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: SetRefreshProtocolListRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:11:259]: PROPERTY CHANGE: Adding ProtocolListNTRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is ''. Action start 11:33:11: SetRefreshProtocolListNTRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:11:259]: Skipping action: SetUpgradeProtocolListRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:259]: Skipping action: SetUpgradeProtocolListNTRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:259]: Doing action: CostInitialize Action ended 11:33:11: SetRefreshProtocolListNTRegValue.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:11:259]: Machine policy value 'MaxPatchCacheSize' is 10 Action start 11:33:11: CostInitialize. MSI (s) (F0:A8) [11:33:11:259]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:259]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'. MSI (s) (F0:A8) [11:33:11:259]: Note: 1: 2262 2: Patch 3: -2147287038 MSI (s) (F0:A8) [11:33:11:259]: Note: 1: 2262 2: PatchPackage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:259]: Note: 1: 2205 2: 3: MsiPatchHeaders MSI (s) (F0:A8) [11:33:11:259]: Note: 1: 2205 2: 3: __MsiPatchFileList MSI (s) (F0:A8) [11:33:11:259]: Doing action: FileCost Action ended 11:33:11: CostInitialize. Return value 1. MSI (s) (F0:A8) [11:33:11:259]: Note: 1: 2205 2: 3: MsiAssembly MSI (s) (F0:A8) [11:33:11:275]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:11:275]: Note: 1: 2262 2: IniFile 3: -2147287038 MSI (s) (F0:A8) [11:33:11:275]: Note: 1: 2262 2: MoveFile 3: -2147287038 MSI (s) (F0:A8) [11:33:11:275]: Note: 1: 2262 2: ReserveCost 3: -2147287038 Action start 11:33:11: FileCost. MSI (s) (F0:A8) [11:33:11:275]: Doing action: IsolateComponents Action ended 11:33:11: FileCost. Return value 1. MSI (s) (F0:A8) [11:33:11:275]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:275]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:275]: Note: 1: 2728 2: Patch Action start 11:33:11: IsolateComponents. MSI (s) (F0:A8) [11:33:11:275]: Doing action: PickInstanceComponentSet.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: IsolateComponents. Return value 1. MSI (s) (F0:3C) [11:33:11:275]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI2A.tmp, Entrypoint: PickInstanceComponentSet Action start 11:33:11: PickInstanceComponentSet.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action PickInstanceComponentSet Entering Function MyMsiEvaluateCondition MsiEvaluateCondition for SQLMSDEInstalled returned FALSE End Function MyMsiEvaluateCondition MSI (s) (F0!38) [11:33:11:447]: PROPERTY CHANGE: Adding InstanceComponentSet.1 property. Its value is '1'. Locating unused component set MSI (s) (F0!38) [11:33:11:447]: PROPERTY CHANGE: Modifying SQLExitCode.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is '1603'. Its new value: '0'. Using "InstanceComponentSet.1" MSI (s) (F0:A8) [11:33:11:447]: Doing action: CostFinalize Action ended 11:33:11: PickInstanceComponentSet.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:11: CostFinalize. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'. MSI (s) (F0:A8) [11:33:11:447]: Note: 1: 2262 2: Condition 3: -2147287038 MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Data.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstance.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceLog.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its value is 'D:\MSSQL\LOG\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceJobs.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its value is 'D:\MSSQL\JOBS\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceData.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its value is 'D:\MSSQL\Data\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceInstall.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its value is 'D:\MSSQL\Install\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Redist.7EBEDD68_AA66_11D2_B980_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding MS.7EBEDD68_AA66_11D2_B980_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding System.7EBEDD68_AA66_11D2_B980_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding ANSI.7EBEDD68_AA66_11D2_B980_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Redist.7EBEDD3E_AA66_11D2_B980_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding MS.7EBEDD3E_AA66_11D2_B980_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding System.7EBEDD3E_AA66_11D2_B980_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Redist.51D569E0_8A28_11D2_B962_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding MS.51D569E0_8A28_11D2_B962_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding System.51D569E0_8A28_11D2_B962_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Redist.3CE1F932_C090_11D2_977B_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding MS.3CE1F932_C090_11D2_977B_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding System.3CE1F932_C090_11D2_977B_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Redist.51D569E2_8A28_11D2_B962_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding MS.51D569E2_8A28_11D2_B962_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding System.51D569E2_8A28_11D2_B962_006097C4DE24 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.66CDF039_0EDE_453E_A1E5_1931046C4056 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.66CDF039_0EDE_453E_A1E5_1931046C4056 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.66CDF039_0EDE_453E_A1E5_1931046C4056 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.66CDF039_0EDE_453E_A1E5_1931046C4056 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.ACD7EC22_4989_4067_B267_6DB5716695BC property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.ACD7EC22_4989_4067_B267_6DB5716695BC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.ACD7EC22_4989_4067_B267_6DB5716695BC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.ACD7EC22_4989_4067_B267_6DB5716695BC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes.ACD7EC22_4989_4067_B267_6DB5716695BC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes1033.ACD7EC22_4989_4067_B267_6DB5716695BC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.0C7570D6_6225_4960_B951_4D16DD906838 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.0C7570D6_6225_4960_B951_4D16DD906838 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.0C7570D6_6225_4960_B951_4D16DD906838 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.0C7570D6_6225_4960_B951_4D16DD906838 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceOther.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceJet.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBinRes.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'D:\MSSQL\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBinRes1033.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'D:\MSSQL\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes1033.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SystemX86.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding System.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Data.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceJobs.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\JOBS\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceLog.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\LOG\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceInstall.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\Install\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceData.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\Data\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Readme.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceOther.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceJet.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools4Dev.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsDev.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsDevLib.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsDevInclude.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerCom.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerComBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\COM\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBinRes.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'D:\MSSQL\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBinRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its value is 'D:\MSSQL\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Data.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceLog.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'D:\MSSQL\LOG\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceJobs.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'D:\MSSQL\JOBS\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerCom.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerComBin.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\COM\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBinRes.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'D:\MSSQL\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBinRes1033.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'D:\MSSQL\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes1033.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerCom.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerComBin.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\COM\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerComBinRes.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\COM\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerComBinRes1033.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Data.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstance.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstanceInstall.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'D:\MSSQL\Install\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerCom.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerComBin.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\COM\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes1033.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBinRes1033.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.AC2DB678_071D_4330_A52D_9286D618F650 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.AC2DB678_071D_4330_A52D_9286D618F650 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools4Dev.AC2DB678_071D_4330_A52D_9286D618F650 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsDev.AC2DB678_071D_4330_A52D_9286D618F650 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsDevLib.AC2DB678_071D_4330_A52D_9286D618F650 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsDevInclude.AC2DB678_071D_4330_A52D_9286D618F650 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerCom.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVerComBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'C:\Program Files\Microsoft SQL Server\80\COM\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlSetup.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlSetupTemp.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding System.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Sql.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlVer.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTools.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlToolsBin.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SystemX86.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding System.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\WINDOWS\system32\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlTarget.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceOther.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceJet.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding SqlInstanceBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\Binn\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding Data.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\'. MSI (s) (F0:A8) [11:33:11:447]: PROPERTY CHANGE: Adding DataInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding DataInstanceLog.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\LOG\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding DataInstanceJobs.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\JOBS\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding DataInstanceInstall.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\Install\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding DataInstanceData.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'D:\MSSQL\Data\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding Sql.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlVer.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlVerCom.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlVerComBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\COM\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlTools4Dev.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlToolsDev.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlToolsDevLib.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlToolsDevInclude.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlTools.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\'. MSI (s) (F0:A8) [11:33:11:462]: PROPERTY CHANGE: Adding SqlToolsBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:11:462]: Target path resolution complete. Dumping Directory table... MSI (s) (F0:A8) [11:33:11:462]: Note: target paths subject to change (via custom actions or browsing) MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: TARGETDIR , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DatabaseRepl.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: NULL MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: WindowsFolder , Object: C:\WINDOWS\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: MSDE7Shortcuts.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: NULL MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Data.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstance.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceLog.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: D:\MSSQL\LOG\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceJobs.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: D:\MSSQL\JOBS\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceData.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: D:\MSSQL\Data\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceInstall.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: D:\MSSQL\Install\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SystemFolder , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Redist.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: MS.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: System.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ANSI.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Redist.7EBEDD3E_AA66_11D2_B980_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: MS.7EBEDD3E_AA66_11D2_B980_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: System.7EBEDD3E_AA66_11D2_B980_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Redist.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: MS.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: System.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Redist.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: MS.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: System.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Redist.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: MS.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: System.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes1033.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceOther.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceJet.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBinRes.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: D:\MSSQL\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBinRes1033.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: D:\MSSQL\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes1033.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SystemFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SystemX86.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: System.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: StartupFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Data.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceJobs.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\JOBS\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceLog.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\LOG\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceInstall.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\Install\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceData.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\Data\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Readme.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceOther.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceJet.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools4Dev.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDev.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDevLib.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDevInclude.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerCom.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerComBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\COM\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBinRes.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: D:\MSSQL\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBinRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: D:\MSSQL\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Data.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceLog.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: D:\MSSQL\LOG\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceJobs.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: D:\MSSQL\JOBS\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerCom.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerComBin.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft SQL Server\80\COM\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBinRes.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: D:\MSSQL\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBinRes1033.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: D:\MSSQL\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes1033.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerCom.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerComBin.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft SQL Server\80\COM\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerComBinRes.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft SQL Server\80\COM\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerComBinRes1033.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Data.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstance.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceInstall.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: D:\MSSQL\Install\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerCom.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerComBin.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft SQL Server\80\COM\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes1033.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBinRes1033.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools4Dev.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDev.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDevLib.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDevInclude.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerCom.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerComBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft SQL Server\80\COM\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: TempFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlSetup.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlSetupTemp.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SystemFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: System.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SystemFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SystemX86.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: System.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\WINDOWS\system32\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: StartupFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTarget.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceOther.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceJet.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlInstanceBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Data.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceLog.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\LOG\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceJobs.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\JOBS\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceInstall.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\Install\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: DataInstanceData.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: D:\MSSQL\Data\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: ProgramFilesFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: Sql.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVer.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerCom.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlVerComBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\COM\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools4Dev.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDev.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDevLib.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsDevInclude.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlTools.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\Tools\ MSI (s) (F0:A8) [11:33:11:462]: Dir (target): Key: SqlToolsBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\ MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2205 2: 3: MsiAssembly MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ? MSI (s) (F0:A8) [11:33:11:462]: Disallowing installation of component: {436D7A23-36BE-11D2-ACBB-0080C7FCBB84} since the same component with higher versioned keyfile exists MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Disallowing installation of component: {1CA051B0-1B70-11D2-9ADD-006097C4E452} since the same component with higher versioned keyfile exists MSI (s) (F0:A8) [11:33:11:462]: Disallowing installation of component: {FFFDF420-AFF5-11D2-9AE4-006097C4E452} since the same component with higher versioned keyfile exists MSI (s) (F0:A8) [11:33:11:462]: Disallowing installation of component: {1CA051B2-1B70-11D2-9ADD-006097C4E452} since the same component with higher versioned keyfile exists MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:462]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:478]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Doing action: DataInstance.24170C3F_A9E4_47C1_8DFE_FD79C2714697 Action ended 11:33:11: CostFinalize. Return value 1. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying DataInstance.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying DataInstanceLog.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its current value is 'D:\MSSQL\LOG\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\LOG\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying DataInstanceJobs.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its current value is 'D:\MSSQL\JOBS\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\JOBS\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying DataInstanceData.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its current value is 'D:\MSSQL\Data\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying DataInstanceInstall.24170C3F_A9E4_47C1_8DFE_FD79C2714697 property. Its current value is 'D:\MSSQL\Install\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\'. Action start 11:33:11: DataInstance.24170C3F_A9E4_47C1_8DFE_FD79C2714697. MSI (s) (F0:A8) [11:33:11:494]: Skipping action: DataInstanceUpg.24170C3F_A9E4_47C1_8DFE_FD79C2714697 (condition is false) MSI (s) (F0:A8) [11:33:11:494]: Doing action: SqlInstance.88C26F26_166C_4CD7_8175_38297C2276D7 Action ended 11:33:11: DataInstance.24170C3F_A9E4_47C1_8DFE_FD79C2714697. Return value 1. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstance.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstanceOther.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstanceJet.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstanceBin.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstanceBinRes.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its current value is 'D:\MSSQL\Binn\Resources\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstanceBinRes1033.88C26F26_166C_4CD7_8175_38297C2276D7 property. Its current value is 'D:\MSSQL\Binn\Resources\1033\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\'. Action start 11:33:11: SqlInstance.88C26F26_166C_4CD7_8175_38297C2276D7. MSI (s) (F0:A8) [11:33:11:494]: Skipping action: SqlInstanceUpg.88C26F26_166C_4CD7_8175_38297C2276D7 (condition is false) MSI (s) (F0:A8) [11:33:11:494]: Doing action: SqlInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:11: SqlInstance.88C26F26_166C_4CD7_8175_38297C2276D7. Return value 1. MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstanceOther.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:494]: PROPERTY CHANGE: Modifying SqlInstanceJet.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:494]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. Action start 11:33:11: SqlInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:11:509]: Doing action: Readme.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:11: SqlInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying Readme.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. Action start 11:33:11: Readme.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:11:509]: Doing action: DataInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 Action ended 11:33:11: Readme.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstanceJobs.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\JOBS\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\JOBS\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstanceLog.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\LOG\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\LOG\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstanceInstall.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\Install\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstanceData.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 property. Its current value is 'D:\MSSQL\Data\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\'. Action start 11:33:11: DataInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. MSI (s) (F0:A8) [11:33:11:509]: Skipping action: DataInstanceUpg.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Skipping action: ReadmeUpg.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Skipping action: SqlInstanceUpg.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Doing action: SqlInstance.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 Action ended 11:33:11: DataInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstance.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBin.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBinRes.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its current value is 'D:\MSSQL\Binn\Resources\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBinRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 property. Its current value is 'D:\MSSQL\Binn\Resources\1033\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\'. Action start 11:33:11: SqlInstance.BF65A835_E76E_4CA5_8B97_E8FD33E7C475. MSI (s) (F0:A8) [11:33:11:509]: Skipping action: SqlInstanceUpg.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Doing action: DataInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 Action ended 11:33:11: SqlInstance.BF65A835_E76E_4CA5_8B97_E8FD33E7C475. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstanceLog.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its current value is 'D:\MSSQL\LOG\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\LOG\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstanceJobs.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its current value is 'D:\MSSQL\JOBS\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\JOBS\'. Action start 11:33:11: DataInstance.C4D32C83_C28D_4329_A829_31C4C6034F59. MSI (s) (F0:A8) [11:33:11:509]: Skipping action: DataInstanceUpg.C4D32C83_C28D_4329_A829_31C4C6034F59 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Doing action: SqlInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 Action ended 11:33:11: DataInstance.C4D32C83_C28D_4329_A829_31C4C6034F59. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBin.C4D32C83_C28D_4329_A829_31C4C6034F59 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. Action start 11:33:11: SqlInstance.C4D32C83_C28D_4329_A829_31C4C6034F59. MSI (s) (F0:A8) [11:33:11:509]: Skipping action: SqlInstanceUpg.C4D32C83_C28D_4329_A829_31C4C6034F59 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Doing action: SqlInstance.EF490CFB_7BC2_4102_8395_426CE5870B18 Action ended 11:33:11: SqlInstance.C4D32C83_C28D_4329_A829_31C4C6034F59. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstance.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBin.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBinRes.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its current value is 'D:\MSSQL\Binn\Resources\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBinRes1033.EF490CFB_7BC2_4102_8395_426CE5870B18 property. Its current value is 'D:\MSSQL\Binn\Resources\1033\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\'. Action start 11:33:11: SqlInstance.EF490CFB_7BC2_4102_8395_426CE5870B18. MSI (s) (F0:A8) [11:33:11:509]: Skipping action: SqlInstanceUpg.EF490CFB_7BC2_4102_8395_426CE5870B18 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Doing action: SqlInstance.DCDF3AA8_FCF8_49F6_9877_752F754DD676 Action ended 11:33:11: SqlInstance.EF490CFB_7BC2_4102_8395_426CE5870B18. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstance.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstanceBin.DCDF3AA8_FCF8_49F6_9877_752F754DD676 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. Action start 11:33:11: SqlInstance.DCDF3AA8_FCF8_49F6_9877_752F754DD676. MSI (s) (F0:A8) [11:33:11:509]: Skipping action: SqlInstanceUpg.DCDF3AA8_FCF8_49F6_9877_752F754DD676 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Doing action: DataInstance.185C1D8F_1545_4277_BB64_857D2622DB57 Action ended 11:33:11: SqlInstance.DCDF3AA8_FCF8_49F6_9877_752F754DD676. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstance.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying DataInstanceInstall.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its current value is 'D:\MSSQL\Install\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\'. Action start 11:33:11: DataInstance.185C1D8F_1545_4277_BB64_857D2622DB57. MSI (s) (F0:A8) [11:33:11:509]: Skipping action: DataInstanceUpg.185C1D8F_1545_4277_BB64_857D2622DB57 (condition is false) MSI (s) (F0:A8) [11:33:11:509]: Doing action: SqlInstance.185C1D8F_1545_4277_BB64_857D2622DB57 Action ended 11:33:11: DataInstance.185C1D8F_1545_4277_BB64_857D2622DB57. Return value 1. MSI (s) (F0:A8) [11:33:11:509]: PROPERTY CHANGE: Modifying SqlInstance.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:509]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:525]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:525]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:525]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:525]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:525]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:11:525]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:11:525]: PROPERTY CHANGE: Modifying SqlInstanceBin.185C1D8F_1545_4277_BB64_857D2622DB57 property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. Action start 11:33:11: SqlInstance.185C1D8F_1545_4277_BB64_857D2622DB57. MSI (s) (F0:A8) [11:33:11:525]: Skipping action: SqlInstanceUpg.185C1D8F_1545_4277_BB64_857D2622DB57 (condition is false) MSI (s) (F0:A8) [11:33:11:525]: Doing action: SqlInstance.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB Action ended 11:33:11: SqlInstance.185C1D8F_1545_4277_BB64_857D2622DB57. Return value 1. MSI (s) (F0:A8) [11:33:11:525]: PROPERTY CHANGE: Modifying SqlInstance.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:525]: PROPERTY CHANGE: Modifying SqlInstanceBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. Action start 11:33:11: SqlInstance.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB. MSI (s) (F0:A8) [11:33:11:525]: Skipping action: SqlInstanceUpg.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB (condition is false) MSI (s) (F0:A8) [11:33:11:525]: Doing action: DataInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: SqlInstance.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB. Return value 1. MSI (s) (F0:A8) [11:33:11:525]: PROPERTY CHANGE: Modifying DataInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:525]: PROPERTY CHANGE: Modifying DataInstanceLog.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\LOG\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\LOG\'. MSI (s) (F0:A8) [11:33:11:525]: PROPERTY CHANGE: Modifying DataInstanceJobs.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\JOBS\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\JOBS\'. MSI (s) (F0:A8) [11:33:11:525]: PROPERTY CHANGE: Modifying DataInstanceInstall.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\Install\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\'. MSI (s) (F0:A8) [11:33:11:525]: PROPERTY CHANGE: Modifying DataInstanceData.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\Data\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\'. Action start 11:33:11: DataInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:11:525]: Skipping action: DataInstanceUpg.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:525]: Doing action: DetectInstanceClash.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: DataInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:4C) [11:33:11:525]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI2B.tmp, Entrypoint: DetectInstanceClash Action start 11:33:11: DetectInstanceClash.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action DetectInstanceClash Property SqlStates: 0 MSI (s) (F0:A8) [11:33:11:712]: Skipping action: ErrorCodeUpgrade.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:712]: Skipping action: FatalErrorUpgrade.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:712]: Doing action: GetFeatureName.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: DetectInstanceClash.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:B0) [11:33:11:712]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI2C.tmp, Entrypoint: GetFeatureName Action start 11:33:11: GetFeatureName.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action GetFeatureName MSI (s) (F0!C8) [11:33:11:853]: PROPERTY CHANGE: Adding SqlFeature property. Its value is 'SqlRun'. Setting SqlFeature=SqlRun MSI (s) (F0:A8) [11:33:11:853]: Doing action: SqlInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: GetFeatureName.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:11:853]: PROPERTY CHANGE: Modifying SqlInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\'. MSI (s) (F0:A8) [11:33:11:853]: PROPERTY CHANGE: Modifying SqlInstanceOther.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:853]: PROPERTY CHANGE: Modifying SqlInstanceJet.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. MSI (s) (F0:A8) [11:33:11:853]: PROPERTY CHANGE: Modifying SqlInstanceBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its current value is 'D:\MSSQL\Binn\'. Its new value: 'C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\'. Action start 11:33:11: SqlInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:11:853]: Skipping action: SqlInstanceUpg.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:853]: Skipping action: ValidatePatchability.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:11:853]: Doing action: PropSetLoginMode.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:11: SqlInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:4C) [11:33:11:853]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI2D.tmp, Entrypoint: PropSetLoginMode Action start 11:33:11: PropSetLoginMode.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action PropSetLoginMode MSI (s) (F0:A8) [11:33:12:025]: Doing action: DeferProductCode.1.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:12: PropSetLoginMode.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:12:025]: PROPERTY CHANGE: Adding CommitDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is '{E09B48B5-E141-427A-AB0C-D3605127224A}'. Action start 11:33:12: DeferProductCode.1.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:12:025]: Doing action: DeferProductCode.2.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:12: DeferProductCode.1.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:12:025]: PROPERTY CHANGE: Adding CommitNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B property. Its value is '{E09B48B5-E141-427A-AB0C-D3605127224A}'. Action start 11:33:12: DeferProductCode.2.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:12:025]: Skipping action: DetectBlankSaLogin.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:12:025]: Skipping action: InstallUpgradeComponents.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:12:025]: Doing action: SetODBCFolders Action ended 11:33:12: DeferProductCode.2.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:12:025]: Note: 1: 2262 2: ODBCDriver 3: -2147287038 MSI (s) (F0:A8) [11:33:12:025]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038 Action start 11:33:12: SetODBCFolders. MSI (s) (F0:A8) [11:33:12:025]: Skipping action: ReinstallGuidlessFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:12:025]: Doing action: InstallValidate Action ended 11:33:12: SetODBCFolders. Return value 1. Action start 11:33:12: InstallValidate. MSI (s) (F0:A8) [11:33:12:025]: Feature: SqlRun; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.1.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.2.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.3.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.4.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.5.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.6.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.7.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.8.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.9.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.10.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.11.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.12.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.13.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.14.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.15.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ComponentSet.16.2D02443E_7002_4C0B_ABC9_EAB2C064397B; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: CSNetInterProcess.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: CSNetSharedMemory.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: LockedFile.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: LockedFile.Win9x.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: LockedFile.WinNT.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: sqlredis.exe.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI1.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI10.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI11.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI12.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI13.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI14.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI15.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI16.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI2.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI3.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI4.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI5.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI6.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI7.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI8.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ConnectI9.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SharedCore.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SharedCoreCom.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ScmHeaders.AC2DB678_071D_4330_A52D_9286D618F650; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ScmLibraries.AC2DB678_071D_4330_A52D_9286D618F650; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SQLDMO.dll.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DMORes.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: custtask.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: dtsffile.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: dtspkg.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: dtspump.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtsRun.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtsFileRes.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtsPkgRes.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtsPumpRes.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtsRunRes.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtsTaskRes.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtsEventLog.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DISTRIB.exe.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: instdist.sql.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: mergetxt.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: rdistcom.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: REPLAGNT.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: repldist.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: REPLDP.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: repldts.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: replerrx.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: replmerg.exe.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: REPLPROV.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: REPLPROX.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: replrec.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: REPLSUB.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: replsync.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: rinitcom.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: snapshot.exe.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: spresolv.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: sqldistx.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: sqlinitx.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: sqlmergx.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ssradd.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ssravg.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ssrdown.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ssrmax.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ssrmin.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ssrpub.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ssrup.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: MSGPROX.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: repldsui.dll.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCore.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI1.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI2.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI3.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI4.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI5.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI6.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI7.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI8.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI9.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI10.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI11.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI12.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI13.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI14.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI15.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreI16.185C1D8F_1545_4277_BB64_857D2622DB57; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ReplCoreRes.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SEMCore.DCDF3AA8_FCF8_49F6_9877_752F754DD676; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SEMCoreInst.DCDF3AA8_FCF8_49F6_9877_752F754DD676; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SEMCoreRes.EF490CFB_7BC2_4102_8395_426CE5870B18; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SEMCoreResInst.EF490CFB_7BC2_4102_8395_426CE5870B18; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgent.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Profiler.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI1.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI2.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI3.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI4.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI5.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI6.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI7.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI8.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI9.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI10.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI11.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI12.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI13.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI14.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI15.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentI16.C4D32C83_C28D_4329_A829_31C4C6034F59; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SqlAgentRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ProfilerRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Readme.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ADHelper.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: axscphst.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Comnevnt.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DbData.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DbMaster.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DbModel.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: dcomscm.EXE.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Debug.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: impprov.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Jet.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMon9x.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNT.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCore.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerNetUtility.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerUtil.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServiceManager.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Setup.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Snmp.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: sqdedev.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: sqlvdi.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SSNetAppleTalk.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SSNetInterProcess.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SSNetMultiprotocol.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SSNetNamedPipe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SSNetSharedMemory.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SSNetVines.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: SSNetWinsockIPX.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ClientSettings.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ClientSettingsNT.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: MSDE7Upgrade.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI1.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI10.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI11.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI12.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI13.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI14.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI15.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI16.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI2.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI3.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI4.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI5.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI6.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI7.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI8.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonNTI9.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI1.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI10.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI11.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI12.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI13.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI14.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI15.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI16.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI2.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI3.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI4.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI5.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI6.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI7.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI8.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreI9.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI1.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI10.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI11.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI12.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI13.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI14.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI15.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI16.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI2.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI3.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI4.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI5.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI6.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI7.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI8.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreNTI9.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: SvcMngrShortcut.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ActiveScriptRes.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ADHelperRes.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreRes.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerNetUtilityRes.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServiceManagerRes.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI1.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI10.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI11.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI12.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI13.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI14.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI15.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI16.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI2.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI3.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI4.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI5.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI6.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI7.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI8.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: ServerCoreResI9.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI1.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI10.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI11.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI12.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI13.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI14.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI15.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI16.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI2.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI3.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI4.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI5.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI6.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI7.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI8.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: PerfMonResNTI9.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: MSDE7Upgrade.88C26F26_166C_4CD7_8175_38297C2276D7; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: Bcp.0C7570D6_6225_4960_B951_4D16DD906838; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: OSQL.0C7570D6_6225_4960_B951_4D16DD906838; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: BcpRes1033.ACD7EC22_4989_4067_B267_6DB5716695BC; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtcSetup.66CDF039_0EDE_453E_A1E5_1931046C4056; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: DtcReg.66CDF039_0EDE_453E_A1E5_1931046C4056; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Global_VC_MFC42ANSICore.51D569E2_8A28_11D2_B962_006097C4DE24; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: Global_VC_IRT.3CE1F932_C090_11D2_977B_006097C4DE24; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: Global_VC_CRT.51D569E0_8A28_11D2_B962_006097C4DE24; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: Global_Vba_VBStockProp.7EBEDD3E_AA66_11D2_B980_006097C4DE24; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: Global_VC_ATLANSI.7EBEDD68_AA66_11D2_B980_006097C4DE24; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: Global_VC_ATLUnicode.7EBEDD68_AA66_11D2_B980_006097C4DE24; Installed: Absent; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: UpgradeScripts.24170C3F_A9E4_47C1_8DFE_FD79C2714697; Installed: Absent; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI1.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI10.CC1A8C58_27D1_4D38_BF1B_C065; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI11.CC1A8C58_27D1_4D38_BF1B_C065; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI12.CC1A8C58_27D1_4D38_BF1B_C065; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI13.CC1A8C58_27D1_4D38_BF1B_C065; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI14.CC1A8C58_27D1_4D38_BF1B_C065; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI15.CC1A8C58_27D1_4D38_BF1B_C065; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI16.CC1A8C58_27D1_4D38_BF1B_C065; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI2.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI3.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI4.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI5.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI6.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI7.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI8.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI9.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI1.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI10.CC1A8C58_27D1_4D38_BF1B_C066; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI11.CC1A8C58_27D1_4D38_BF1B_C066; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI12.CC1A8C58_27D1_4D38_BF1B_C066; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI13.CC1A8C58_27D1_4D38_BF1B_C066; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI14.CC1A8C58_27D1_4D38_BF1B_C066; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI15.CC1A8C58_27D1_4D38_BF1B_C066; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI16.CC1A8C58_27D1_4D38_BF1B_C066; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI2.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI3.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI4.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI5.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI6.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI7.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI8.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI9.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI1.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI10.CC1A8C58_27D1_4D38_BF1B_C067; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI11.CC1A8C58_27D1_4D38_BF1B_C067; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI12.CC1A8C58_27D1_4D38_BF1B_C067; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI13.CC1A8C58_27D1_4D38_BF1B_C067; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI14.CC1A8C58_27D1_4D38_BF1B_C067; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI15.CC1A8C58_27D1_4D38_BF1B_C067; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI16.CC1A8C58_27D1_4D38_BF1B_C067; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI2.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI3.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI4.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI5.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI6.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI7.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI8.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ServerCoreI9.CC1A8C58_27D1_4D38_BF1B_C0A67; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __MSDE7Upgrade.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __MSDE7Upgrade.CC1A8C58_27D1_4D38_BF1B_C0A66; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.1.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.2.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.3.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.4.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.5.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.6.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.7.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.8.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.9.2D02443E_7002_4C0B_ABC9_E65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.10.2D02443E_7002_4C0B_ABC9_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.11.2D02443E_7002_4C0B_ABC9_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.12.2D02443E_7002_4C0B_ABC9_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.13.2D02443E_7002_4C0B_ABC9_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.14.2D02443E_7002_4C0B_ABC9_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.15.2D02443E_7002_4C0B_ABC9_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:025]: Component: __ComponentSet.16.2D02443E_7002_4C0B_ABC9_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI1.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI10.F26FFD4A_05B4_4969_A552_30C7F65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI11.F26FFD4A_05B4_4969_A552_30C7F65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI12.F26FFD4A_05B4_4969_A552_30C7F65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI13.F26FFD4A_05B4_4969_A552_30C7F65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI14.F26FFD4A_05B4_4969_A552_30C7F65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI15.F26FFD4A_05B4_4969_A552_30C7F65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI16.F26FFD4A_05B4_4969_A552_30C7F65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI2.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI3.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI4.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI5.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI6.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI7.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI8.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ConnectI9.F26FFD4A_05B4_4969_A552_30C7F965; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SQLDMO.dll.9B023A3C_3C86_4E4B_90D5_DE42F65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __dtsffile.DLL.55BCEE28_CDBF_4D7F_97C4_08265; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __dtspump.DLL.55BCEE28_CDBF_4D7F_97C4_082D65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __dtspkg.DLL.55BCEE28_CDBF_4D7F_97C4_082D665; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __custtask.DLL.55BCEE28_CDBF_4D7F_97C4_08265; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __DtsEventLog.9240E1C0_49D2_40A2_93CE_E62C65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __DtsPumpRes.9240E1C0_49D2_40A2_93CE_E62CD65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __DtsTaskRes.9240E1C0_49D2_40A2_93CE_E62CD65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI1.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI2.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI3.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI4.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI5.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI6.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI7.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI8.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI9.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI10.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI11.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI12.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI13.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI14.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI15.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ReplCoreI16.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __spresolv.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ssradd.dll.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ssravg.dll.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ssrdown.dll.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ssrmax.dll.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ssrmin.dll.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ssrpub.dll.185C1D8F_1545_4277_BB64_857D265; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ssrup.dll.185C1D8F_1545_4277_BB64_857D2665; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __mergetxt.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __rdistcom.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __repldts.dll.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __rinitcom.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __replerrx.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __repldist.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __replsync.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __repldsui.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __DISTRIB.exe.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __snapshot.exe.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __sqlmergx.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __sqlinitx.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __REPLPROX.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __REPLSUB.dll.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __replrec.dll.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __replmerg.exe.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __MSGPROX.dll.185C1D8F_1545_4277_BB64_857D65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __sqldistx.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __REPLPROV.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __REPLAGNT.dll.185C1D8F_1545_4277_BB64_85765; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI1.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI2.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI3.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI4.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI5.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI6.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI7.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI8.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI9.C4D32C83_C28D_4329_A829_31C4C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI10.C4D32C83_C28D_4329_A829_31C465; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI11.C4D32C83_C28D_4329_A829_31C465; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI12.C4D32C83_C28D_4329_A829_31C465; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI13.C4D32C83_C28D_4329_A829_31C465; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI14.C4D32C83_C28D_4329_A829_31C465; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI15.C4D32C83_C28D_4329_A829_31C465; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgentI16.C4D32C83_C28D_4329_A829_31C465; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SqlAgent.C4D32C83_C28D_4329_A829_31C4C6065; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ClientSettings.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ClientSettingsNT.CC1A8C58_27D1_4D38_BF1B65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI1.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI10.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI11.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI12.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI13.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI14.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI15.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI16.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI2.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI3.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI4.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI5.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI6.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI7.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI8.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonNTI9.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI1.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI10.CC1A8C58_27D1_4D38_BF1B_C068; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI11.CC1A8C58_27D1_4D38_BF1B_C068; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI12.CC1A8C58_27D1_4D38_BF1B_C068; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI13.CC1A8C58_27D1_4D38_BF1B_C068; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI14.CC1A8C58_27D1_4D38_BF1B_C068; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI15.CC1A8C58_27D1_4D38_BF1B_C068; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI16.CC1A8C58_27D1_4D38_BF1B_C068; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI2.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI3.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI4.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI5.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI6.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI7.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI8.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreI9.CC1A8C58_27D1_4D38_BF1B_C0A68; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI1.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI10.CC1A8C58_27D1_4D38_BF1B_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI11.CC1A8C58_27D1_4D38_BF1B_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI12.CC1A8C58_27D1_4D38_BF1B_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI13.CC1A8C58_27D1_4D38_BF1B_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI14.CC1A8C58_27D1_4D38_BF1B_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI15.CC1A8C58_27D1_4D38_BF1B_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI16.CC1A8C58_27D1_4D38_BF1B_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI2.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI3.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI4.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI5.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI6.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI7.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI8.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreNTI9.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __SvcMngrShortcut.CC1A8C58_27D1_4D38_BF1B_65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ServiceManager.CC1A8C58_27D1_4D38_BF1B_C65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCore.CC1A8C58_27D1_4D38_BF1B_C0A5C65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __axscphst.DLL.CC1A8C58_27D1_4D38_BF1B_C0A65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __impprov.dll.CC1A8C58_27D1_4D38_BF1B_C0A565; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __sqlvdi.dll.CC1A8C58_27D1_4D38_BF1B_C0A5C65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI1.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI10.88C26F26_166C_4CD7_817565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI11.88C26F26_166C_4CD7_817565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI12.88C26F26_166C_4CD7_817565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI13.88C26F26_166C_4CD7_817565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI14.88C26F26_166C_4CD7_817565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI15.88C26F26_166C_4CD7_817565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI16.88C26F26_166C_4CD7_817565; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI2.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI3.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI4.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI5.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI6.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI7.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI8.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __ServerCoreResI9.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI1.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI10.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI11.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI12.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI13.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI14.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI15.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI16.88C26F26_166C_4CD7_8175_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI2.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI3.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI4.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI5.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI6.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI7.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI8.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __PerfMonResNTI9.88C26F26_166C_4CD7_8175_365; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __DtcReg.66CDF039_0EDE_453E_A1E5_1931046C465; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __Global_Vba_VBStockProp.7EBEDD3E_AA66_11D65; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __Global_VC_ATLANSI.7EBEDD68_AA66_11D2_B9865; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __Global_VC_ATLUnicode.7EBEDD68_AA66_11D2_65; Installed: Null; Request: Local; Action: Null MSI (s) (F0:A8) [11:33:12:041]: Component: __REPLPROV.dll.185C1D8F_1545_4277_BB64_85766; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __replrec.dll.185C1D8F_1545_4277_BB64_857D66; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Component: __SvcMngrShortcut.CC1A8C58_27D1_4D38_BF1B_66; Installed: Null; Request: Local; Action: Local MSI (s) (F0:A8) [11:33:12:041]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:12:041]: Note: 1: 2262 2: PublishComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:12:041]: Note: 1: 2262 2: SelfReg 3: -2147287038 MSI (s) (F0:A8) [11:33:12:041]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:041]: Note: 1: 2262 2: Font 3: -2147287038 MSI (s) (F0:A8) [11:33:12:041]: Note: 1: 2262 2: ReserveCost 3: -2147287038 MSI (s) (F0:A8) [11:33:12:041]: Note: 1: 2205 2: 3: _RemoveFilePath MSI (s) (F0:A8) [11:33:12:041]: Note: 1: 2205 2: 3: MsiFileHash MSI (s) (F0:A8) [11:33:12:087]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:087]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:087]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:087]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:087]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:087]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:087]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:087]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:103]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:119]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2756 2: DatabaseRepl.185C1D8F_1545_4277_BB64_857D2622DB57 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2756 2: DatabaseRepl.185C1D8F_1545_4277_BB64_857D2622DB57 MSI (s) (F0:A8) [11:33:12:134]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'. MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: BindImage 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: PublishComponent 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: SelfReg 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2262 2: Font 3: -2147287038 MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2727 2: MSI (s) (F0:A8) [11:33:12:134]: Note: 1: 2727 2: MSI (s) (F0:A8) [11:33:12:134]: Skipping action: UpgDetectBlankSaLogin.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:12:134]: Skipping action: DetectBlankSaLogin2.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:12:134]: Doing action: DetectExistingData.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:12: InstallValidate. Return value 1. MSI (s) (F0:D0) [11:33:12:134]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI2E.tmp, Entrypoint: DetectExistingData Action start 11:33:12: DetectExistingData.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action DetectExistingData Ending custom action DetectExistingData MSI (s) (F0:A8) [11:33:12:275]: Doing action: InstallInitialize Action ended 11:33:12: DetectExistingData.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:12:275]: Machine policy value 'AlwaysInstallElevated' is 0 MSI (s) (F0:A8) [11:33:12:275]: User policy value 'AlwaysInstallElevated' is 0 MSI (s) (F0:A8) [11:33:12:275]: BeginTransaction: Locking Server MSI (s) (F0:A8) [11:33:12:291]: SRSetRestorePoint skipped for this transaction. MSI (s) (F0:A8) [11:33:12:291]: Server not locked: locking for product {E09B48B5-E141-427A-AB0C-D3605127224A} Action start 11:33:12: InstallInitialize. MSI (s) (F0:A8) [11:33:13:462]: Doing action: DeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: InstallInitialize. Return value 1. MSI (s) (F0:48) [11:33:13:462]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI2F.tmp, Entrypoint: DeferProperties Action start 11:33:13: DeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Start custom action DeferProperties Defer Properties returns: 0 MSI (s) (F0:A8) [11:33:13:572]: Doing action: RollbackDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: DeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:13:572]: Note: 1: 2205 2: 3: MsiPatchCertificate MSI (s) (F0:A8) [11:33:13:572]: LUA patching is disabled: missing MsiPatchCertificate table MSI (s) (F0:A8) [11:33:13:572]: Resolving source. MSI (s) (F0:A8) [11:33:13:572]: Resolving source to launched-from source. MSI (s) (F0:A8) [11:33:13:572]: Setting launched-from source as last-used. MSI (s) (F0:A8) [11:33:13:572]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Program Files\Microsoft ISA Server\MSDE\Setup\'. MSI (s) (F0:A8) [11:33:13:572]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Program Files\Microsoft ISA Server\MSDE\Setup\'. MSI (s) (F0:A8) [11:33:13:572]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{E09B48B5-E141-427A-AB0C-D3605127224A}'. MSI (s) (F0:A8) [11:33:13:572]: SOURCEDIR ==> C:\Program Files\Microsoft ISA Server\MSDE\Setup\ MSI (s) (F0:A8) [11:33:13:572]: SOURCEDIR product ==> {E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0:A8) [11:33:13:572]: Determining source type MSI (s) (F0:A8) [11:33:13:572]: Source type from package 'SqlRun01.msi': 2 Action start 11:33:13: RollbackDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:13:572]: Source path resolution complete. Dumping Directory table... MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: TARGETDIR , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DatabaseRepl.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: WindowsFolder , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: MSDE7Shortcuts.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Data.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstance.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceLog.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\LOG\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceJobs.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\JOBS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceData.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Data\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceInstall.24170C3F_A9E4_47C1_8DFE_FD79C2714697 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Install\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SystemFolder , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Redist.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: MS.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: System.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ANSI.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\System\ANSI\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Redist.7EBEDD3E_AA66_11D2_B980_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: MS.7EBEDD3E_AA66_11D2_B980_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: System.7EBEDD3E_AA66_11D2_B980_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Redist.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: MS.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: System.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Redist.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: MS.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: System.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Redist.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: MS.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: System.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: Redist\MS\System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.66CDF039_0EDE_453E_A1E5_1931046C4056 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes1033.ACD7EC22_4989_4067_B267_6DB5716695BC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.0C7570D6_6225_4960_B951_4D16DD906838 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceOther.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Other\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceJet.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\jet\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBinRes.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBinRes1033.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes1033.88C26F26_166C_4CD7_8175_38297C2276D7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SystemFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SystemX86.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: System.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: StartupFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Data.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceJobs.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\JOBS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceLog.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\LOG\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceInstall.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Install\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceData.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Data\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Readme.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceOther.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Other\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceJet.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\jet\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools4Dev.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDev.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDevLib.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\x86lib\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDevInclude.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\Include\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerCom.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerComBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBinRes.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBinRes1033.BF65A835_E76E_4CA5_8B97_E8FD33E7C475 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Data.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceLog.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\LOG\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceJobs.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\JOBS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerCom.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerComBin.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.C4D32C83_C28D_4329_A829_31C4C6034F59 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBinRes.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBinRes1033.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes1033.EF490CFB_7BC2_4102_8395_426CE5870B18 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.DCDF3AA8_FCF8_49F6_9877_752F754DD676 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerCom.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerComBin.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerComBinRes.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerComBinRes1033.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Data.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstance.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceInstall.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Install\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerCom.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerComBin.185C1D8F_1545_4277_BB64_857D2622DB57 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes1033.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBinRes1033.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\res\1033\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools4Dev.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDev.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDevLib.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\x86lib\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDevInclude.AC2DB678_071D_4330_A52D_9286D618F650 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\Include\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerCom.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerComBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: TempFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlSetup.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlSetupTemp.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SystemFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: System.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4 , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SystemFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SystemX86.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: System.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: System\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: StartupFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTarget.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceOther.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Other\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceJet.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\jet\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlInstanceBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Data.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstance.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceLog.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\LOG\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceJobs.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\JOBS\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceInstall.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Install\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: DataInstanceData.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Data\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: ProgramFilesFolder.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: Sql.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVer.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerCom.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlVerComBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools4Dev.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDev.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDevLib.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\x86lib\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsDevInclude.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: DevTools\Include\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlTools.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Dir (source): Key: SqlToolsBin.2D02443E_7002_4C0B_ABC9_EAB2C064397B , Object: C:\Program Files\Microsoft ISA Server\MSDE\Setup\ , LongSubPath: x86\Binn\ , ShortSubPath: MSI (s) (F0:A8) [11:33:13:572]: Doing action: RollbackStreamSupportFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: RollbackDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:13: RollbackStreamSupportFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:13:572]: Skipping action: UseCurrentCollation.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:572]: Doing action: UseDefaultCollation.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: RollbackStreamSupportFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:AC) [11:33:13:587]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI31.tmp, Entrypoint: UseDefaultCollation Action start 11:33:13: UseDefaultCollation.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} MSI (s) (F0!34) [11:33:13:697]: PROPERTY CHANGE: Adding SqlCollation property. Its value is 'SQL_Latin1_General_CP1_CI_AS'. Starting custom action UseDefaultCollation MSI (s) (F0:A8) [11:33:13:697]: Doing action: AllocateRegistrySpace Action ended 11:33:13: UseDefaultCollation.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:13: AllocateRegistrySpace. MSI (s) (F0:A8) [11:33:13:697]: Doing action: ProcessComponents Action ended 11:33:13: AllocateRegistrySpace. Return value 1. Action start 11:33:13: ProcessComponents. MSI (s) (F0:A8) [11:33:13:744]: Doing action: UnpublishComponents Action ended 11:33:13: ProcessComponents. Return value 1. MSI (s) (F0:A8) [11:33:13:744]: Note: 1: 2262 2: PublishComponent 3: -2147287038 Action start 11:33:13: UnpublishComponents. MSI (s) (F0:A8) [11:33:13:744]: Doing action: UnpublishFeatures Action ended 11:33:13: UnpublishComponents. Return value 1. Action start 11:33:13: UnpublishFeatures. MSI (s) (F0:A8) [11:33:13:744]: Skipping action: PreSqlRemove.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:744]: Doing action: StopServices Action ended 11:33:13: UnpublishFeatures. Return value 1. Action start 11:33:13: StopServices. MSI (s) (F0:A8) [11:33:13:744]: Skipping action: UnInstAgentSecurity.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:744]: Skipping action: UnInstSQLAdHlp.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:744]: Skipping action: UnRegSQLWithMDAC.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:744]: Doing action: DeleteServices Action ended 11:33:13: StopServices. Return value 1. Action start 11:33:13: DeleteServices. MSI (s) (F0:A8) [11:33:13:744]: Doing action: DeleteSqlServices.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: DeleteServices. Return value 1. MSI (s) (F0:54) [11:33:13:744]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI32.tmp, Entrypoint: DeleteSqlServices Action start 11:33:13: DeleteSqlServices.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action DeleteSqlServices MSI (s) (F0:A8) [11:33:13:837]: Doing action: UnregisterComPlus Action ended 11:33:13: DeleteSqlServices.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: Complus 3: -2147287038 Action start 11:33:13: UnregisterComPlus. MSI (s) (F0:A8) [11:33:13:837]: Doing action: SelfUnregModules Action ended 11:33:13: UnregisterComPlus. Return value 1. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: SelfReg 3: -2147287038 Action start 11:33:13: SelfUnregModules. MSI (s) (F0:A8) [11:33:13:837]: Doing action: UnregisterTypeLibraries Action ended 11:33:13: SelfUnregModules. Return value 1. Action start 11:33:13: UnregisterTypeLibraries. MSI (s) (F0:A8) [11:33:13:837]: Doing action: RemoveODBC Action ended 11:33:13: UnregisterTypeLibraries. Return value 1. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: ODBCDataSource 3: -2147287038 MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: ODBCDataSource 3: -2147287038 MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038 MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038 MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: ODBCDriver 3: -2147287038 MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: ODBCDriver 3: -2147287038 MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2711 2: ODBCDriverManager Action start 11:33:13: RemoveODBC. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2711 2: ODBCDriverManager64 MSI (s) (F0:A8) [11:33:13:837]: Doing action: UnregisterFonts Action ended 11:33:13: RemoveODBC. Return value 1. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: Font 3: -2147287038 Action start 11:33:13: UnregisterFonts. MSI (s) (F0:A8) [11:33:13:837]: Skipping action: UndoDisableSqlAgent.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:837]: Doing action: RemoveRegistryValues Action ended 11:33:13: UnregisterFonts. Return value 1. Action start 11:33:13: RemoveRegistryValues. MSI (s) (F0:A8) [11:33:13:837]: Doing action: UnregisterClassInfo Action ended 11:33:13: RemoveRegistryValues. Return value 1. Action start 11:33:13: UnregisterClassInfo. MSI (s) (F0:A8) [11:33:13:837]: Doing action: UnregisterExtensionInfo Action ended 11:33:13: UnregisterClassInfo. Return value 1. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: Extension 3: -2147287038 Action start 11:33:13: UnregisterExtensionInfo. MSI (s) (F0:A8) [11:33:13:837]: Doing action: UnregisterProgIdInfo Action ended 11:33:13: UnregisterExtensionInfo. Return value 1. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: Extension 3: -2147287038 Action start 11:33:13: UnregisterProgIdInfo. MSI (s) (F0:A8) [11:33:13:837]: Doing action: UnregisterMIMEInfo Action ended 11:33:13: UnregisterProgIdInfo. Return value 1. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: MIME 3: -2147287038 MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: Extension 3: -2147287038 Action start 11:33:13: UnregisterMIMEInfo. MSI (s) (F0:A8) [11:33:13:837]: Doing action: RemoveIniValues Action ended 11:33:13: UnregisterMIMEInfo. Return value 1. MSI (s) (F0:A8) [11:33:13:837]: Note: 1: 2262 2: RemoveIniFile 3: -2147287038 Action start 11:33:13: RemoveIniValues. MSI (s) (F0:A8) [11:33:13:853]: Doing action: RemoveShortcuts Action ended 11:33:13: RemoveIniValues. Return value 1. Action start 11:33:13: RemoveShortcuts. MSI (s) (F0:A8) [11:33:13:853]: Skipping action: Path9X.0C7570D6_6225_4960_B951_4D16DD906838 (condition is false) MSI (s) (F0:A8) [11:33:13:853]: Doing action: PathNT.0C7570D6_6225_4960_B951_4D16DD906838 Action ended 11:33:13: RemoveShortcuts. Return value 1. MSI (s) (F0:A8) [11:33:13:853]: PROPERTY CHANGE: Adding Path.0C7570D6_6225_4960_B951_4D16DD906838 property. Its value is 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. Action start 11:33:13: PathNT.0C7570D6_6225_4960_B951_4D16DD906838. MSI (s) (F0:A8) [11:33:13:853]: Doing action: RemoveEnvironmentStrings Action ended 11:33:13: PathNT.0C7570D6_6225_4960_B951_4D16DD906838. Return value 1. Action start 11:33:13: RemoveEnvironmentStrings. MSI (s) (F0:A8) [11:33:13:853]: Doing action: RemoveDuplicateFiles Action ended 11:33:13: RemoveEnvironmentStrings. Return value 1. Action start 11:33:13: RemoveDuplicateFiles. MSI (s) (F0:A8) [11:33:13:853]: Doing action: Write_UninstallDataFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: RemoveDuplicateFiles. Return value 1. MSI (s) (F0:E0) [11:33:13:853]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI33.tmp, Entrypoint: Write_UninstallDataFiles Action start 11:33:13: Write_UninstallDataFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B. SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Write_UninstallDataFiles MSI (s) (F0:A8) [11:33:13:931]: Skipping action: MSDE7Shortcuts.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 (condition is false) MSI (s) (F0:A8) [11:33:13:931]: Skipping action: MSDE7DevInclude.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 (condition is false) MSI (s) (F0:A8) [11:33:13:931]: Skipping action: MSDE7DevLib.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616 (condition is false) MSI (s) (F0:A8) [11:33:13:931]: Doing action: RemoveFiles Action ended 11:33:13: Write_UninstallDataFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:13: RemoveFiles. MSI (s) (F0:A8) [11:33:13:931]: Doing action: RemoveFolders Action ended 11:33:13: RemoveFiles. Return value 1. MSI (s) (F0:A8) [11:33:13:931]: Note: 1: 2262 2: LockPermissions 3: -2147287038 Action start 11:33:13: RemoveFolders. MSI (s) (F0:A8) [11:33:13:931]: Skipping action: PostSqlRemove.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:931]: Doing action: CreateFolders Action ended 11:33:13: RemoveFolders. Return value 1. MSI (s) (F0:A8) [11:33:13:931]: Note: 1: 2262 2: LockPermissions 3: -2147287038 Action start 11:33:13: CreateFolders. MSI (s) (F0:A8) [11:33:13:931]: Doing action: MoveFiles Action ended 11:33:13: CreateFolders. Return value 1. Action start 11:33:13: MoveFiles. MSI (s) (F0:A8) [11:33:13:947]: Skipping action: UpgPreFileCopy.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:947]: Doing action: InstallFiles Action ended 11:33:13: MoveFiles. Return value 1. Action start 11:33:13: InstallFiles. MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2262 2: LockPermissions 3: -2147287038 MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2235 2: 3: StreamRef_ 4: SELECT `Patch`.`File_`, `Patch`.`Header`, `Patch`.`Attributes`, `Patch`.`Sequence`, `Patch`.`StreamRef_` FROM `Patch` WHERE `Patch`.`File_` = ? AND `Patch`.`#_MsiActive`=? ORDER BY `Patch`.`Sequence` MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2205 2: 3: MsiPatchOldAssemblyFile MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2228 2: 3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE `MsiPatchOldAssemblyFile`.`File_` = ? MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2205 2: 3: MsiSFCBypass MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2228 2: 3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ? MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2205 2: 3: MsiPatchHeaders MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2228 2: 3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ? MSI (s) (F0:A8) [11:33:13:947]: Note: 1: 2205 2: 3: MsiDigitalSignature MSI (s) (F0:A8) [11:33:13:994]: Doing action: InstallDTC.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: InstallFiles. Return value 1. Action start 11:33:13: InstallDTC.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:13:994]: Doing action: RollbackNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: InstallDTC.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:13: RollbackNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:13:994]: Doing action: NoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: RollbackNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:13: NoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:13:994]: Doing action: InstallSqlRedis.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:13: NoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:13: InstallSqlRedis.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:13:994]: Skipping action: UpgPostFileCopy.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:13:994]: Doing action: DuplicateFiles Action ended 11:33:13: InstallSqlRedis.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:13: DuplicateFiles. MSI (s) (F0:A8) [11:33:13:994]: Note: 1: 2756 2: DatabaseRepl.185C1D8F_1545_4277_BB64_857D2622DB57 MSI (s) (F0:A8) [11:33:13:994]: Note: 1: 2756 2: DatabaseRepl.185C1D8F_1545_4277_BB64_857D2622DB57 MSI (s) (F0:A8) [11:33:13:994]: Doing action: PatchFiles Action ended 11:33:13: DuplicateFiles. Return value 1. Action start 11:33:13: PatchFiles. MSI (s) (F0:A8) [11:33:13:994]: Doing action: BindImage Action ended 11:33:13: PatchFiles. Return value 1. MSI (s) (F0:A8) [11:33:13:994]: Note: 1: 2262 2: BindImage 3: -2147287038 Action start 11:33:13: BindImage. MSI (s) (F0:A8) [11:33:13:994]: Doing action: CreateShortcuts Action ended 11:33:13: BindImage. Return value 1. Action start 11:33:13: CreateShortcuts. MSI (s) (F0:A8) [11:33:13:994]: Doing action: RegisterClassInfo Action ended 11:33:13: CreateShortcuts. Return value 1. Action start 11:33:14: RegisterClassInfo. MSI (s) (F0:A8) [11:33:14:009]: Doing action: RegisterExtensionInfo Action ended 11:33:14: RegisterClassInfo. Return value 1. MSI (s) (F0:A8) [11:33:14:009]: Note: 1: 2262 2: Extension 3: -2147287038 Action start 11:33:14: RegisterExtensionInfo. MSI (s) (F0:A8) [11:33:14:009]: Doing action: RegisterProgIdInfo Action ended 11:33:14: RegisterExtensionInfo. Return value 1. MSI (s) (F0:A8) [11:33:14:009]: Note: 1: 2262 2: Extension 3: -2147287038 Action start 11:33:14: RegisterProgIdInfo. MSI (s) (F0:A8) [11:33:14:009]: Note: 1: 2262 2: Extension 3: -2147287038 MSI (s) (F0:A8) [11:33:14:009]: Doing action: RegisterMIMEInfo Action ended 11:33:14: RegisterProgIdInfo. Return value 1. MSI (s) (F0:A8) [11:33:14:009]: Note: 1: 2262 2: MIME 3: -2147287038 MSI (s) (F0:A8) [11:33:14:009]: Note: 1: 2262 2: Extension 3: -2147287038 Action start 11:33:14: RegisterMIMEInfo. MSI (s) (F0:A8) [11:33:14:009]: Doing action: WriteRegistryValues Action ended 11:33:14: RegisterMIMEInfo. Return value 1. Action start 11:33:14: WriteRegistryValues. MSI (s) (F0:A8) [11:33:14:009]: Note: 1: 2262 2: LockPermissions 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Doing action: DisableNetAccess.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: WriteRegistryValues. Return value 1. Action start 11:33:14: DisableNetAccess.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:525]: Skipping action: RollbackDisableSqlAgent.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:14:525]: Skipping action: DisableSqlAgent.2D02443E_7002_4C0B_ABC9_EAB2C064397B (condition is false) MSI (s) (F0:A8) [11:33:14:525]: Doing action: WriteIniValues Action ended 11:33:14: DisableNetAccess.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: WriteIniValues. MSI (s) (F0:A8) [11:33:14:525]: Doing action: WriteEnvironmentStrings Action ended 11:33:14: WriteIniValues. Return value 1. Action start 11:33:14: WriteEnvironmentStrings. MSI (s) (F0:A8) [11:33:14:525]: Doing action: RegisterFonts Action ended 11:33:14: WriteEnvironmentStrings. Return value 1. MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: Font 3: -2147287038 Action start 11:33:14: RegisterFonts. MSI (s) (F0:A8) [11:33:14:525]: Doing action: InstallODBC Action ended 11:33:14: RegisterFonts. Return value 1. MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2711 2: ODBCDriverManager MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2711 2: ODBCDriverManager64 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCDriver 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCAttribute 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCDriver 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCAttribute 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCDataSource 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCSourceAttribute 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCDataSource 3: -2147287038 MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: ODBCSourceAttribute 3: -2147287038 Action start 11:33:14: InstallODBC. MSI (s) (F0:A8) [11:33:14:525]: Doing action: RegisterTypeLibraries Action ended 11:33:14: InstallODBC. Return value 0. Action start 11:33:14: RegisterTypeLibraries. MSI (s) (F0:A8) [11:33:14:525]: skipping type library registration for component Global_VC_ATLANSI.7EBEDD68_AA66_11D2_B980_006097C4DE24 as it is disabled. MSI (s) (F0:A8) [11:33:14:525]: Doing action: SelfRegModules Action ended 11:33:14: RegisterTypeLibraries. Return value 1. MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: SelfReg 3: -2147287038 Action start 11:33:14: SelfRegModules. MSI (s) (F0:A8) [11:33:14:525]: Doing action: RegisterComPlus Action ended 11:33:14: SelfRegModules. Return value 1. MSI (s) (F0:A8) [11:33:14:525]: Note: 1: 2262 2: Complus 3: -2147287038 Action start 11:33:14: RegisterComPlus. MSI (s) (F0:A8) [11:33:14:525]: Doing action: InstallServices Action ended 11:33:14: RegisterComPlus. Return value 1. Action start 11:33:14: InstallServices. MSI (s) (F0:A8) [11:33:14:525]: Doing action: InstallPerfMon.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: InstallServices. Return value 1. Action start 11:33:14: InstallPerfMon.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:525]: Doing action: InstallSQLAdHlp.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: InstallPerfMon.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: InstallSQLAdHlp.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:541]: Doing action: RollbackAgentSecurity.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: InstallSQLAdHlp.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: RollbackAgentSecurity.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:541]: Doing action: InstallAgentSecurity.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: RollbackAgentSecurity.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: InstallAgentSecurity.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:541]: Doing action: SkuIt.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: InstallAgentSecurity.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: SkuIt.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:541]: Doing action: ConfigServer.2D02443E_7002_4C0B_ABC9_EAB2C064397B... Action ended 11:33:14: SkuIt.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: ConfigServer.2D02443E_7002_4C0B_ABC9_EAB2C064397B... MSI (s) (F0:A8) [11:33:14:541]: Skipping action: ReconfigServer.2D02443E_7002_4C0B_ABC9_EAB2C064397B... MSI (s) (F0:A8) [11:33:14:541]: Doing action: RegSQLWithMDAC.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: ConfigServer.2D02443E_7002_4C0B_ABC9_EAB2C064397B... Action start 11:33:14: RegSQLWithMDAC.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:541]: Doing action: SetLoginModeNT.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: RegSQLWithMDAC.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: SetLoginModeNT.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:541]: Doing action: SetFileAndRegACLs.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: SetLoginModeNT.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: SetFileAndRegACLs.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:541]: Skipping action: EnableCrossDBOwnershipChaining.2D02443E_7002_4C0B_ABC9_EAB2C064397B... MSI (s) (F0:A8) [11:33:14:541]: Doing action: StartServices Action ended 11:33:14: SetFileAndRegACLs.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: StartServices. MSI (s) (F0:A8) [11:33:14:541]: Doing action: RegisterUser Action ended 11:33:14: StartServices. Return value 1. Action start 11:33:14: RegisterUser. MSI (s) (F0:A8) [11:33:14:556]: Doing action: RegisterProduct Action ended 11:33:14: RegisterUser. Return value 1. MSI (s) (F0:A8) [11:33:14:556]: Note: 1: 2205 2: 3: MsiDigitalSignature Action start 11:33:14: RegisterProduct. MSI (s) (F0:A8) [11:33:14:556]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'. MSI (s) (F0:A8) [11:33:14:556]: Doing action: PublishComponents Action ended 11:33:14: RegisterProduct. Return value 1. MSI (s) (F0:A8) [11:33:14:556]: Note: 1: 2262 2: PublishComponent 3: -2147287038 Action start 11:33:14: PublishComponents. MSI (s) (F0:A8) [11:33:14:556]: Doing action: PublishFeatures Action ended 11:33:14: PublishComponents. Return value 1. Action start 11:33:14: PublishFeatures. MSI (s) (F0:A8) [11:33:14:556]: Doing action: PublishProduct Action ended 11:33:14: PublishFeatures. Return value 1. Action start 11:33:14: PublishProduct. MSI (s) (F0:A8) [11:33:14:556]: Doing action: CommitDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: PublishProduct. Return value 1. Action start 11:33:14: CommitDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:556]: Doing action: CommitNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B Action ended 11:33:14: CommitDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. Action start 11:33:14: CommitNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B. MSI (s) (F0:A8) [11:33:14:556]: Doing action: InstallFinalize Action ended 11:33:14: CommitNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B. Return value 1. MSI (s) (F0:A8) [11:33:14:556]: Running Script: C:\WINDOWS\Installer\MSI30.tmp MSI (s) (F0:A8) [11:33:14:556]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'. MSI (s) (F0:A8) [11:33:14:556]: Machine policy value 'DisableRollback' is 0 MSI (s) (F0:A8) [11:33:14:556]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (F0:A8) [11:33:14:556]: Executing op: Header(Signature=1397708873,Version=301,Timestamp=1109679143,LangId=1033,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1) Action start 11:33:14: InstallFinalize. MSI (s) (F0:A8) [11:33:14:556]: Executing op: ProductInfo(ProductKey={E09B48B5-E141-427A-AB0C-D3605127224A},ProductName=Microsoft SQL Server Desktop Engine,PackageName=SqlRun01.msi,Language=1033,Version=134218546,Assignment=1,ObsoleteArg=0,,,PackageCode={D29DCF7A-8199-4373-BA0D-2F3635EC940C},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: DialogInfo(Type=0,Argument=1033) MSI (s) (F0:A8) [11:33:14:572]: Executing op: DialogInfo(Type=1,Argument=Microsoft SQL Server Desktop Engine) MSI (s) (F0:A8) [11:33:14:572]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1]) MSI (s) (F0:A8) [11:33:14:572]: Executing op: SetBaseline(Baseline=0,) MSI (s) (F0:A8) [11:33:14:572]: Executing op: SetBaseline(Baseline=1,) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ActionStart(Name=RollbackDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B,,) MSI (s) (F0:A8) [11:33:14:572]: Executing op: CustomActionSchedule(Action=RollbackDeferProperties.2D02443E_7002_4C0B_ABC9_EAB2C064397B,ActionType=1281,Source=BinaryData,Target=DeferProperties,) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ActionStart(Name=RollbackStreamSupportFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B,,) MSI (s) (F0:A8) [11:33:14:572]: Executing op: CustomActionSchedule(Action=RollbackStreamSupportFiles.2D02443E_7002_4C0B_ABC9_EAB2C064397B,ActionType=1281,Source=BinaryData,Target=RemoveSupportFiles,) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ProgressTotal(Total=250,Type=1,ByteEquivalent=24000) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={8D1347B2-CCB1-4579-AB47-77517173B837},KeyPath=02:\SOFTWARE\Microsoft\Microsoft SQL Server\Component Set\InstanceComponentSet.1,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={90F630BE-3C8F-46E3-882E-523A4D35E1C6},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={586CE7CE-10C3-4871-BB52-B1A71FB75F69},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={8BCDD8F9-1CAC-4CF4-A9E7-0D8EE337D989},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={1E86B1D3-9AF0-48D1-A084-9B828D16ABF5},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={BEA3F834-7C08-4C02-8F74-644AD6F4C6B1},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={F85CC7C0-7DBF-4846-9D64-8FC2DC110F05},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={6D36DDE7-B112-45DB-A62C-B800713BA47B},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={8C669E46-2D35-47BD-90FA-C756A83ED281},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={AF87A101-EBBE-4E33-A0E2-C2AE9BFDC875},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={EB28E3F2-4957-4B0A-B0EA-649F45DFEB9D},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={9F8BD7FC-0607-4B60-BCB1-49EED4E18347},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={D41D9610-EBC1-4CBD-B853-B6C14365A1F8},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={CBED1DFB-EAD1-478C-8D68-239D1ECC5890},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={ECC34E75-E021-4F26-ABBC-8299ADE917D5},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={4AA23D25-9D64-426D-A7A5-2EFE44A9D5B9},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={47D38CD0-9117-435A-9282-4ACA000A7233},KeyPath=C:\WINDOWS\system32\DBmsLPCn.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={47D38CD0-9117-435A-9282-4ACA000A7233},KeyPath=C:\WINDOWS\system32\DBmsLPCn.dll,State=3,ProductKey={00000000-0000-0000-0000-000000000000},Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={BD99B001-77D0-4437-B934-F3C1A8BE0714},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={3D1AB80A-5686-4815-8B12-3CD53848334F},KeyPath=02:\SOFTWARE\Microsoft\Microsoft SQL Server\MSFW\Tracking\{E07FDDAD-5A21-11d2-9DAD-00C04F79D434},State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={2EEFF8B1-9EBD-4561-8339-0F7F4C358E4A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={5A221AEC-1062-448A-A277-13DDE57AD401},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={2C908661-2853-4100-8FED-5A0E5C99ACE9},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:572]: Executing op: ComponentRegister(ComponentId={43941FB1-6A16-4E2F-8424-A3C100289CC8},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={B9F1D2AF-D623-40F1-95DE-08399752D5DB},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={463FCF93-A271-4605-8321-6F4836A36CDA},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={ABB03F15-AE9B-431B-A467-1E84849B197F},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={CAF9BDFB-29B1-4BC7-9956-2D7D75C5B040},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={827192EB-19AA-4F1D-86E8-FE80D5A4BAA9},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={347BCC9D-7AC0-49C3-9925-CCEA967F320F},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={A1B52E15-4CCA-4256-AD11-7AD343B075B6},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={7EBC43C2-DA26-4A12-A4FD-288C2E446109},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={FD387E5D-746C-4C72-97D1-E8AA77C1924D},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={6C0B5B98-E141-4CA1-BA9A-BFB1E618344B},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={B4F5144A-D2B1-4A7A-A2F5-A44170BBC104},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={BD64ED37-1278-46A6-9E7B-CF740066EF7B},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlresld.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={77744099-F4DB-40F4-A65B-ACA0BA9CDE57},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\sqlresld.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={5B164AEB-B116-41B3-BA40-668ED3375CDC},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\wn95scm.h,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={6D1A2CE6-0D71-4171-B46D-4A1BB86EDEB7},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\w95scm.lib,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={D3A8A05A-7377-4C13-A44B-30523419F722},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={A4EB5979-83FC-4557-A1D7-3309158E61B1},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\SQLDMO.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={7D101C14-00BC-474C-9554-FF328BDE2149},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={7B8F4AA0-664E-4069-BB11-D4EA6049255F},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtsffile.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={0ADE3088-46B8-490E-B1E1-EB2BC6677C99},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:587]: Executing op: ComponentRegister(ComponentId={1B573FDE-9017-4263-B450-A83479F11483},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={F40E8A01-0355-4226-8E9A-12163F02A103},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\DTSRUN.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={2235A94A-C30B-4794-AA91-422F6DD39B17},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtsffile.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={0AEBBC16-8415-4581-A455-0C141865064D},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtspkg.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={4C0BE471-CF11-4059-8883-61F78DEE9B4B},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtspump.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={CEF0323B-6969-4911-B0B4-AEFE72ACCE88},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\DTSRUN.rll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={A5E401A7-4B53-4DBA-9CCE-CF3DFCBCD7DA},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\custtask.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={D4345F90-83BF-4FD1-869E-36EC49ABF12F},KeyPath=02:\SYSTEM\CurrentControlSet\Services\EventLog\Application\DataTransformationServices\EventMessageFile,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={86A5DB00-D26E-449B-9BAA-CE9C22C37071},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\DISTRIB.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={3AAB1C47-5774-45F2-B1BC-B6B567A57F6F},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instdist.sql,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={773EF45D-0398-49E3-BC5F-65047462BA4C},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\mergetxt.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={CB5D49D2-9847-476E-ADA5-00826F4E5EE6},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\rdistcom.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={7664E247-314C-4533-ACF0-D2F0703A2279},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\REPLAGNT.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={D471B580-6996-4DC1-9502-CDA01504AB53},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\repldist.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={4F59703B-A066-44BA-9D9F-C842FE7BF155},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\REPLDP.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={A9B02E17-17F1-4402-82B7-8EF2CF5AEDB7},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\repldts.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:603]: Executing op: ComponentRegister(ComponentId={5087B0B5-9220-437A-8EF6-7D3B7ACE6884},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\replerrx.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={F0BB3ADD-585F-4853-A30D-7D5B2988E0B2},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\replmerg.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={7A3109F3-91E4-45DD-B468-8A00C7623B0B},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\REPLPROV.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={4A3527F1-B3C9-4405-BF6F-C0CBF3B374DB},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\REPLPROX.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={86B03CF2-B3A1-4446-8B41-CF0CBAD6DDEA},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\replrec.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={77D94487-5564-4A80-A7A8-27B61781D61D},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\REPLSUB.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={544033B2-EB28-4E20-A277-39C6DB6EDCE5},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\replsync.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={BCA1F870-E948-49D0-8AFB-A7B8C54181EF},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\rinitcom.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={3DBF832A-0AB0-4255-B07F-DF891C688F77},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\snapshot.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={6526E066-75A5-4356-AFDB-617EE05C6FCA},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\spresolv.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={480802DB-0A60-42D1-90FE-44BFBA81459B},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\sqldistx.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={8C5E36D2-6B24-4146-993F-D36D614C0258},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\sqlinitx.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={250BA19B-D37C-4C51-B16E-2D4FB38EC86B},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={F3E4BD6E-283D-4EED-81B6-BAA2A113F311},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\ssradd.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={202CB148-2670-4620-8E4B-9F3132E1C832},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\ssravg.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={14D19296-BA13-4373-9C67-ED63D4637DA9},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\ssrdown.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:619]: Executing op: ComponentRegister(ComponentId={F63EADF1-35B0-4210-8153-AD745D3F8FC4},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\ssrmax.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={BA53298B-197D-4C75-ADC2-0EC16733FF73},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\ssrmin.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={EE07D20E-EF4E-40F7-8B5F-FF27586001C9},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\ssrpub.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={30877A0B-DDB6-4EDC-BEF0-476C61E610A7},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\ssrup.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={50D142DB-419A-4D0E-911C-9B5982FD3998},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\MSGPROX.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={F236AF11-136C-4F57-ABA6-B65664E744C0},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\repldsui.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={3137390F-786C-4D00-B389-B7E7F957055A},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xprepl.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={2759F926-C705-4149-B70A-6F4CDAC88E38},KeyPath=02:\SOFTWARE\Microsoft\Microsoft SQL Server\MSFW\Replication\IsInstalled,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={48F7D5E3-CCDC-431E-8982-29AF06E3403B},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={D56DBEE8-1B64-41BD-92E0-729C70BC99B3},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={4C572617-4F1A-4050-8B4C-4F4E9A5D8FE7},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={5FDE1CCC-544F-4463-ABD3-305B8A916DE0},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={99EF36BC-7BFD-488B-A627-89696E0338CB},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={044D083A-C279-4887-B87B-F1A86A817C65},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={BC973A16-D627-42D1-9F97-01B61C7AA6BE},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={E44A3A66-25B4-4157-A048-86170D4D0C14},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={9A7F73FF-6F70-4C5E-924E-378ACDA8FFCB},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={8FBABC54-6EB1-4021-9E12-4F726F23E15A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={896D216E-0F6D-49E8-ABD2-3EEB6EC56FB8},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={A5A017E0-6D78-4183-BE7A-2419DBA9016F},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={28E0348C-C883-43DE-B660-A564CCEF2FDB},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={07B76B6C-A267-4CC3-8F15-27F322BB7B84},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={867B6757-DC58-4B67-82D0-32A8AA31C336},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:634]: Executing op: ComponentRegister(ComponentId={F310225D-BA0A-42E8-943A-4928A48D19E1},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\REPLRES.rll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={C021693A-BD55-479E-9B09-3048959E8078},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlsvc.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={28D0022F-1C50-4192-87B5-6356E7277BCD},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlsvc.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={15BD03AE-1472-4674-8E73-73428D18BE14},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqlsvc.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={52BA863B-72A7-4020-A0CA-1A43E29FABDE},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlsvc.rll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={8F60FF69-8CC1-480D-918B-882E37C4ECB3},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlagent.EXE,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={9266EB46-0DFD-4506-B489-4A97D18803C7},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\PFCLNT80.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={15511886-F576-44BF-95F9-4EE6FFFA792D},KeyPath=02:\SOFTWARE\Microsoft\Microsoft SQL Server\MSFW\SQLServerAgent\JobHistoryMaxRowsPerJob,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={6D95A93F-E7AC-4021-B875-9708852940F2},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={1BBA0935-0FF8-4F97-B59D-33E638B8359F},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={41F5173C-3922-49C8-B7CA-ACC661B75DB0},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={CBA644CA-3B40-4C8E-92D8-957EAD1B9367},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={435CCC5D-54E6-4D77-B9F5-0F4C82CC740C},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={F414F727-2F94-4670-9451-2C9195A32C89},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={51266DA5-7168-44BC-966E-FA61CF5FED05},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={4E30E3D3-9DD1-4F8B-8263-88AC98B08DEB},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={EED20533-57C1-42D7-A09A-61FE8863CE66},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={5438D9C9-3F6E-420B-8E4F-6BAAE93CF8AF},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={A6D63B9A-CF9D-4484-B48F-E675BBC98F50},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={5C177ECC-62AA-4B4E-BA92-57A1C15431CD},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={0B64DD9B-FC58-4B6A-ACD1-339C65697830},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={4FDB5ABF-F9DF-4836-952F-D074247A107B},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={B7858308-9912-44A6-BD2C-2917D45FC797},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:650]: Executing op: ComponentRegister(ComponentId={BDF18B96-33C8-4748-AF0F-7BCC4DDFDC51},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlagent.RLL,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={511CF23A-64CE-4693-BB86-9E3E6ACDC1CC},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\PFCLNT80.RLL,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={13302171-0012-4989-877B-2674468BA9B5},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\readme.txt,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={7F3B083B-6A06-44D2-83C4-324468F564BC},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqladhlp.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={7A7299A8-AFB2-442E-BE09-A30A1A3716A7},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\axscphst.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={6073B386-E0BE-4339-B758-8B93B1874639},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\comnevnt.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={34A542B0-8561-4EDA-80F9-AB975258C97B},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\msdbdata.mdf,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={B5003415-8B6A-4CBB-A811-0B33487B91E0},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\master.mdf,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={9763D9CC-0870-434B-BCCD-52B9B755A470},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\model.mdf,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={B1335492-30A7-4BE0-9F3A-B2701EE83843},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dcomscm.EXE,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={81999F68-27F7-4747-AA69-C548A754160C},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\DBGHELP.DLL,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={259C7904-E838-4A1A-834A-B37BD698E432},KeyPath=C:\Program Files\Microsoft SQL Server\80\COM\impprov.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={C3BB8D69-8EED-4DCA-A8B4-6132A59668A1},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlsort.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={12FC83A1-5EE0-4BB9-86B0-F0C50A0BA7F2},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={74A7E3F3-39ED-4D5F-A493-CF5621FE699A},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlctr.ini,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={E7C6EB85-E576-47AA-A5A3-5458A109F4EF},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlservr.exe,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={E5A99560-C419-4141-B7ED-A7FD862E49AF},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SVRNETCN.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={07363EA0-0418-44FB-A8A0-822FF856C9E8},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\w95scm.DLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={D64421D0-4EF7-4649-8C97-3FFF95712FC2},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={11528505-0E70-4278-B355-CAEC801FC372},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cnfgsvr.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:666]: Executing op: ComponentRegister(ComponentId={BF473C2D-F601-4950-A0F4-A08A1ABE89E6},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SQLSNMP.DLL,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={F1ED61A5-4DF9-4F66-98E4-5B93B2C17A51},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqdedev.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={BBA7BDA1-1A3F-45A6-B662-0D23232F44EE},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlvdi.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={011EC960-47F3-4513-A315-CA7ADFF55FAC},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ssmsad70.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={70440188-46E6-48D6-8792-549EA86AC0E2},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsLPCn.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={B06029B5-3013-4EF4-B50D-E9B8880194AC},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsRP70.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={ECAC3B55-7473-493A-A43E-F9809409E133},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ssnmpn70.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={EA180B3F-3072-4A0B-9F97-8303946EA5C0},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsSH70.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={E70424BB-56BE-4B4C-B159-1DDCDEC18EA1},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsVI70.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={142A70F0-306D-4E34-B9D3-730E301EE219},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSnetlib.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={0E98126E-4AA3-4B2B-89DC-9AE4E5595C1E},KeyPath=02:\SOFTWARE\Microsoft\MSSQLServer\Client\SuperSocketNetLib\ProtocolOrder,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={6FD4C57A-6BC8-4F59-B0DF-7FFC72B0AFF1},KeyPath=02:\SOFTWARE\Microsoft\MSSQLServer\Client\SuperSocketNetLib\ProtocolOrder,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={5B17299B-3F25-45F8-B89D-2194B8BFF263},KeyPath=02:\SYSTEM\CurrentControlSet\Services\MSSQL$MSFW\Performance\Library,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={84CF8B84-512F-4CEE-B779-C6770C8CDB27},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={D5653DBA-49B3-4F8C-A721-B6C8E4A6D048},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={332B49E3-E4DF-46FA-A304-01768F692B26},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={E48F05BC-B7FA-4809-9CE1-04F5FF2F9A98},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={51A8E605-1F30-4A83-B2AF-F17D80707492},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={02AF37D4-50FA-475E-A961-9D6850761FAF},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={4AFA696F-4F2D-471F-A08A-D1338A00F04C},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={4588E6FD-386C-4319-9F2D-A96180AC36AF},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={BDC799DC-A8B7-48FB-A0A6-4EEADDD2F5B7},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={3259D7C9-0822-4623-B176-7825EEEA862A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={B96E9A74-F5EB-4922-A9AB-1543EBE17D0A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={B35293C1-A5C8-49FD-816D-8592CCB2208A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={F02118C6-EE5E-4E4A-BE90-02A6783CF24C},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:681]: Executing op: ComponentRegister(ComponentId={5CDBCCE6-C2CA-4ABB-887E-B3CA2B8AE40E},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={0A0089D2-7B37-431D-B4C0-0DEAE6647C7C},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={535C4859-FD57-4271-8BAA-67F3AAF84474},KeyPath=02:\SOFTWARE\Microsoft\Microsoft SQL Server\MSFW\MSSQLServer\CurrentVersion\CurrentVersion,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={FB1344DB-7543-496A-A239-D60E929E0C40},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={45032FB2-C891-4C5E-9BE8-A4B4816DED59},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={28302FB4-8801-473A-A1EC-7803EE76DC04},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={959F7BBD-4A3F-4D4B-9C85-D30CBCC6966A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={30275C4A-9A5D-4B15-812B-AB6481705571},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={93539BF4-70AF-4B50-9E61-DBD68C333F6F},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={CCC2D446-4855-4AF0-980D-1129AAE4155A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={4CB30639-8F8F-40CF-8939-6926E81F1AA4},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={9C405960-3E54-4A16-8C1F-56721DD086FC},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={92ACE36C-D89E-4360-BCCB-1E6191F79EA7},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={5C42FF73-E6CF-433B-8B30-24DCDF575EC0},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={CB15DDD7-935B-47A3-9444-78F0D63EA13A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={E18C87B8-1348-4634-8D73-ADAC3D6FF4C4},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={790BE970-5B07-4CE1-B981-5AF85BCF04FA},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={E8CE593A-55D0-4F64-A526-803B022F72BA},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={0AA668F9-7CFE-456B-83C5-B616084189B1},KeyPath=02:\SOFTWARE\Microsoft\Microsoft SQL Server\MSFW\MSSQLServer\SuperSocketNetLib\ProtocolList,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={57D5F87E-FE91-40E2-981E-81C9EB5DA7DB},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={61753930-773D-4B78-B5A3-B03287D8D831},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={1CBFC5BF-4C0F-4279-8E6B-D31B41EA99C8},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={236D3151-7754-4852-B372-8EB9921C34AE},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={A37D80F0-BEAD-43D6-B5D7-3D75A4D067F7},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={FD18E3F2-7506-4E8F-AB1F-2427F9C03981},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={B2A19C6C-778C-41F3-816D-9840E0229570},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={FF2E91A0-37DC-43FE-89B9-6F9D08E72952},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={7DC9092A-FFC6-4817-9454-41BBF8AECA4A},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={140C775E-8150-424A-868B-69518436853F},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:697]: Executing op: ComponentRegister(ComponentId={167458D4-B2FE-4B85-BEDF-981924155CCB},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={42F86302-3B25-452D-AD01-D8F665BAA6DB},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={FC9324DE-97EB-4859-A133-7BAAB0F4B75F},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={B4C5FCB8-9F93-4C96-9953-7A18E043CBC9},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={64898D61-DD7B-42B0-AD34-7EFF5A6F02F0},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={072BBB16-FE7A-405F-BBCC-54622D21CE3A},KeyPath=01:\SOFTWARE\Microsoft\Microsoft SQL Server\80\Tools\Service Manager\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={0772F2AF-E0AB-4E58-9333-2EE43D265F4E},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\axscphst.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={F92F876B-088A-473A-ADF2-0A30AFECD492},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqladevn.rll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={C3A8AC20-420B-4F91-9A82-2F790F69F1F5},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlevn70.rll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={E33C7444-03CA-4B91-B149-0FC30500A4B0},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\SVRNETCN.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={8808E85C-8A1E-40D3-A0AD-5AAC80C9E9B2},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqlmangr.RLL,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={A1275F65-4DA9-4FFA-990B-8429643B5855},KeyPath=02:\SOFTWARE\Microsoft\Microsoft SQL Server\MSFW\MSSQLServer\CurrentVersion\Language,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={03EA55EC-653A-42A6-8400-C9581EB61983},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={447EC68E-A9EF-4646-9016-4F7FB7CCABA4},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={4FD795EE-9FF8-46B5-BE1B-AFF1153B1B4B},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={EAFF54CE-0981-43FA-80D2-E15F392A9507},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={6F0FEDD2-40F4-4663-AF5E-B41EBEA6204E},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={635DBC0C-1494-4D70-8E94-AC923BF92F26},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={225B2A43-7518-4FF8-9049-76DAEEA49BC8},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={03D5EE9C-1AA5-4C20-93FC-56FECEF6D0FE},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={2D594C2C-8261-4B9B-AC4D-F288D3599D07},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={F97CC524-F874-4D81-9983-9EB4E7A23A42},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={14F50CCB-B3E9-4452-8D91-C30BDB3F7EF4},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={6268536F-6AA9-41A0-B736-1D2A15C44D2F},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:712]: Executing op: ComponentRegister(ComponentId={3848CE94-67D7-4A6B-B28F-DC5BCFD19F7B},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={6995C3CA-3BF6-4236-825F-B4EB10445949},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={7971417A-2060-456F-969D-D3C6DBFF4E13},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={274E5F9B-6EE1-474E-ADD5-876081446AE0},KeyPath=02:\SYSTEM\CurrentControlSet\Services\EventLog\Application\SQLCTR$MSFW\EventMessageFile,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={6D3EABC4-3256-48BB-8411-175BBEA21751},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={378FC92E-56A3-481B-8069-A1773B56FD63},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={999F247D-AF41-4C41-BC18-A1ADC599BC76},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={F9D364D9-A349-4975-96D5-C5F02242771C},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={4FCE347B-54BC-4777-BBE4-039C79AD3B90},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={A91854DA-EAC7-4A1E-8A69-464E8C6606CA},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={432A52DA-F034-45CD-8842-704D1790276D},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={E25DE09F-009E-4F32-8DAA-CEAC6BCD9A59},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={9CFF6A7B-F6D3-4A35-A684-AFE41AD18867},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={95CCDC0A-93CF-4E31-BC18-7AF0DF452ADA},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={64CF2854-6611-4BC6-87CE-0C0C761F95E6},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={B4D11BDE-990B-4BB9-824D-E5B25B28BECF},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={DD707876-939B-4EAD-87EA-D53C8A363E2D},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={F162EEF6-0FD9-4CF0-ABF4-B660196DC468},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={B917985B-18AE-4C52-AE49-E1EBD5697FE2},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={284C64BB-62AB-4CC3-B636-220DD0360F0C},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\bcp.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={BC29A4DF-B970-40D9-A8F9-0EFDAA2A1FD6},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\OSQL.EXE,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={0126D0B9-6ED8-4FCB-93FE-0A93010EA34A},KeyPath=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\bcp.rll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={A8B1BC07-DE70-4C4A-B951-3C6C11E5F99C},KeyPath=02:\SOFTWARE\Microsoft\Microsoft SQL Server\80\Tools\Service Manager\Services,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={1CA051B2-1B70-11D2-9ADD-006097C4E452},KeyPath=C:\WINDOWS\system32\mfc42.dll,State=3,,Disk=1,SharedDllRefCount=3,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={1CA051B2-1B70-11D2-9ADD-006097C4E452},KeyPath=C:\WINDOWS\system32\mfc42.dll,State=3,ProductKey={00000000-0000-0000-0000-000000000000},Disk=1,SharedDllRefCount=3,BinaryType=0) MSI (s) (F0:A8) [11:33:14:728]: Executing op: ComponentRegister(ComponentId={FFFDF420-AFF5-11D2-9AE4-006097C4E452},KeyPath=C:\WINDOWS\system32\msvcirt.dll,State=3,,Disk=1,SharedDllRefCount=3,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={FFFDF420-AFF5-11D2-9AE4-006097C4E452},KeyPath=C:\WINDOWS\system32\msvcirt.dll,State=3,ProductKey={00000000-0000-0000-0000-000000000000},Disk=1,SharedDllRefCount=3,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={1CA051B0-1B70-11D2-9ADD-006097C4E452},KeyPath=C:\WINDOWS\system32\msvcrt.dll,State=3,,Disk=1,SharedDllRefCount=3,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={1CA051B0-1B70-11D2-9ADD-006097C4E452},KeyPath=C:\WINDOWS\system32\msvcrt.dll,State=3,ProductKey={00000000-0000-0000-0000-000000000000},Disk=1,SharedDllRefCount=3,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={10048711-2C96-11D2-9A97-006097C4E452},KeyPath=C:\WINDOWS\system32\msstkprp.dll,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={10048711-2C96-11D2-9A97-006097C4E452},KeyPath=C:\WINDOWS\system32\msstkprp.dll,State=3,ProductKey={00000000-0000-0000-0000-000000000000},Disk=1,SharedDllRefCount=1,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={436D7A21-36BE-11D2-ACBB-0080C7FCBB84},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={436D7A23-36BE-11D2-ACBB-0080C7FCBB84},KeyPath=C:\WINDOWS\system32\atl.dll,State=3,,Disk=1,SharedDllRefCount=3,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={436D7A23-36BE-11D2-ACBB-0080C7FCBB84},KeyPath=C:\WINDOWS\system32\atl.dll,State=3,ProductKey={00000000-0000-0000-0000-000000000000},Disk=1,SharedDllRefCount=3,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ComponentRegister(ComponentId={E04F76B9-43EC-46DA-A6A4-B64F2A69A438},KeyPath=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\upgrade.sql,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200) MSI (s) (F0:A8) [11:33:14:744]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs,,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTick() MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200) MSI (s) (F0:A8) [11:33:14:744]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs,,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTick() MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200) MSI (s) (F0:A8) [11:33:14:744]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs,,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTick() MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200) MSI (s) (F0:A8) [11:33:14:744]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs,,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTick() MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200) MSI (s) (F0:A8) [11:33:14:744]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs,,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTick() MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200) MSI (s) (F0:A8) [11:33:14:744]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs,,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTick() MSI (s) (F0:A8) [11:33:14:744]: Executing op: ActionStart(Name=StopServices,Description=Stopping services,Template=Service: [1]) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=1300000) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ServiceControl(,Name=SQLAgent$MSFW,Action=2,,) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ServiceControl(,Name=MSSQL$MSFW,Action=2,,) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ActionStart(Name=DeleteServices,Description=Deleting services,Template=Service: [1]) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=1300000) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ODBCDriverManager(,BinaryType=0) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ODBCDriverManager(,BinaryType=1) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1]) MSI (s) (F0:A8) [11:33:14:744]: Executing op: FolderCreate(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\,Foreign=0,) MSI (s) (F0:A8) [11:33:14:744]: Executing op: FolderCreate(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\LOG\,Foreign=0,) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1], Directory: [9], Size: [6]) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ProgressTotal(Total=72607031,Type=0,ByteEquivalent=1) MSI (s) (F0:A8) [11:33:14:744]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\system32\) MSI (s) (F0:A8) [11:33:14:744]: Executing op: SetSourceFolder(Folder=1\System\) MSI (s) (F0:A8) [11:33:14:744]: Executing op: ChangeMedia(MediaVolumeLabel=SQLServer,MediaPrompt=Please insert the disk: ,MediaCabinet=1\SqlRun.cab,BytesPerTick=32768,CopierType=1,,,SignatureRequired=0,,,IsFirstPhysicalMedia=1) MSI (s) (F0:A8) [11:33:14:744]: Executing op: FileCopy(SourceName=DBmsLPCn.dll,SourceCabKey=DBmsLPCn.dll.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4,DestName=DBmsLPCn.dll,,FileSize=33340,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.934.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:14:744]: File: C:\WINDOWS\system32\DBmsLPCn.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:14:744]: Source for file 'DBmsLPCn.dll.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4' is compressed MSI (s) (F0:A8) [11:33:14:744]: Note: 1: 2318 2: C:\WINDOWS\system32\DBmsLPCn.dll MSI (s) (F0:A8) [11:33:14:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:14:759]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:14:759]: Executing op: FileCopy(SourceName=sqlredis.exe,SourceCabKey=sqlredis.exe.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4,DestName=sqlredis.exe,,FileSize=10479520,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=5.0.2919.6304,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:14:759]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlredis.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:14:759]: Source for file 'sqlredis.exe.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4' is compressed MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlredis.exe MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:822]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:837]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:853]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:962]: Executing op: SetTargetFolder(Folder=C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\) MSI (s) (F0:A8) [11:33:14:962]: Executing op: SetSourceFolder(Folder=1\x86\System\) MSI (s) (F0:A8) [11:33:14:962]: Executing op: FileCopy(SourceName=sqlsrv32.dll,SourceCabKey=sqlsrv32.dll.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4,DestName=sqlsrv32.dll,,FileSize=385024,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.81.9031.38,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:14:962]: File: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\sqlsrv32.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:14:962]: Source for file 'sqlsrv32.dll.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4' is compressed MSI (s) (F0:A8) [11:33:14:962]: Note: 1: 2318 2: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\sqlsrv32.dll MSI (s) (F0:A8) [11:33:14:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Executing op: FileCopy(SourceName=dbmslpcn.dll,SourceCabKey=dbmslpcn.dll.1.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4,DestName=dbmslpcn.dll,,FileSize=33340,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.934.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:14:978]: File: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\dbmslpcn.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:14:978]: Source for file 'dbmslpcn.dll.1.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4' is compressed MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2318 2: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\dbmslpcn.dll MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:978]: Executing op: FileCopy(SourceName=odbcbcp.dll,SourceCabKey=odbcbcp.dll.1.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4,DestName=odbcbcp.dll,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.81.9031.38,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:14:978]: File: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\odbcbcp.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:14:978]: Source for file 'odbcbcp.dll.1.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4' is compressed MSI (s) (F0:A8) [11:33:14:978]: Note: 1: 2318 2: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\odbcbcp.dll MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Executing op: FileCopy(SourceName=dbnetlib.dll,SourceCabKey=dbnetlib.dll.1.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4,DestName=dbnetlib.dll,,FileSize=61440,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.81.9031.3,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:14:994]: File: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\dbnetlib.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:14:994]: Source for file 'dbnetlib.dll.1.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4' is compressed MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2318 2: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\dbnetlib.dll MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Executing op: FileCopy(SourceName=sqlsrv32.rll,SourceCabKey=sqlsrv32.rll.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4,DestName=sqlsrv32.rll,,FileSize=90112,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.81.9001.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:14:994]: File: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\sqlsrv32.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:14:994]: Source for file 'sqlsrv32.rll.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4' is compressed MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2318 2: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\sqlsrv32.rll MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Executing op: FileCopy(SourceName=SQLUNIRL.dll,SourceCabKey=SQLUNIRL.dll.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4,DestName=SQLUNIRL.dll,,FileSize=180800,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.728.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:14:994]: File: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\SQLUNIRL.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:14:994]: Source for file 'SQLUNIRL.dll.F26FFD4A_05B4_4969_A552_30C7F9BAB1F4' is compressed MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2318 2: C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp\SQLUNIRL.dll MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:14:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: FileCopy(SourceName=sqlresld.DLL,SourceCabKey=sqlresld.DLL.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB,DestName=sqlresld.DLL,,FileSize=29248,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:009]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlresld.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:009]: Source for file 'sqlresld.DLL.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB' is compressed MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlresld.DLL MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\COM\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetSourceFolder(Folder=1\x86\binn\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: FileCopy(SourceName=sqlresld.DLL,SourceCabKey=sqlresld.DLL.2.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB,DestName=sqlresld.DLL,,FileSize=29248,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:009]: File: C:\Program Files\Microsoft SQL Server\80\COM\sqlresld.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:009]: Source for file 'sqlresld.DLL.2.F5ABDAB8_DDBD_4D92_BEAD_A0511D9C85DB' is compressed MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\sqlresld.DLL MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetSourceFolder(Folder=1\DevTools\Include\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: FileCopy(SourceName=wn95scm.h,SourceCabKey=wn95scm.h.AC2DB678_071D_4330_A52D_9286D618F650,DestName=wn95scm.h,,FileSize=1341,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:009]: File: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\wn95scm.h; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:009]: Source for file 'wn95scm.h.AC2DB678_071D_4330_A52D_9286D618F650' is compressed MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Include\wn95scm.h MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetSourceFolder(Folder=1\DevTools\x86lib\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: FileCopy(SourceName=w95scm.lib,SourceCabKey=w95scm.lib.AC2DB678_071D_4330_A52D_9286D618F650,DestName=w95scm.lib,,FileSize=7294,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:009]: File: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\w95scm.lib; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:009]: Source for file 'w95scm.lib.AC2DB678_071D_4330_A52D_9286D618F650' is compressed MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\DevTools\Lib\w95scm.lib MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:15:009]: Executing op: FileCopy(SourceName=SQLDMO.dll,SourceCabKey=SQLDMO.dll.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7,DestName=SQLDMO.dll,,FileSize=4215360,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.818.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:009]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:009]: Source for file 'SQLDMO.dll.9B023A3C_3C86_4E4B_90D5_DE42FB9019F7' is compressed MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:087]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:15:087]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:15:087]: Executing op: FileCopy(SourceName=SQLDMO.RLL,SourceCabKey=SQLDMO.RLL.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092,DestName=SQLDMO.RLL,,FileSize=585728,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:087]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\SQLDMO.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:087]: Source for file 'SQLDMO.RLL.6496AA57_4ABB_4A5B_A0A9_E712ECFA8092' is compressed MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\SQLDMO.RLL MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:15:103]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:15:103]: Executing op: FileCopy(SourceName=custtask.DLL,SourceCabKey=custtask.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF,DestName=custtask.DLL,,FileSize=315968,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:103]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:103]: Source for file 'custtask.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF' is compressed MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:103]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:119]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:119]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:119]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:119]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:119]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:119]: Executing op: FileCopy(SourceName=dtsffile.DLL,SourceCabKey=dtsffile.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF,DestName=dtsffile.DLL,,FileSize=119360,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:119]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtsffile.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:119]: Source for file 'dtsffile.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF' is compressed MSI (s) (F0:A8) [11:33:15:119]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtsffile.DLL MSI (s) (F0:A8) [11:33:15:134]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:134]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:134]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:134]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:134]: Executing op: FileCopy(SourceName=dtspkg.DLL,SourceCabKey=dtspkg.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF,DestName=dtspkg.DLL,,FileSize=1905216,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:134]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:134]: Source for file 'dtspkg.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF' is compressed MSI (s) (F0:A8) [11:33:15:134]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL MSI (s) (F0:A8) [11:33:15:134]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:134]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:150]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:166]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:181]: Executing op: FileCopy(SourceName=dtspump.DLL,SourceCabKey=dtspump.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF,DestName=dtspump.DLL,,FileSize=528960,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:181]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:181]: Source for file 'dtspump.DLL.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF' is compressed MSI (s) (F0:A8) [11:33:15:181]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Executing op: FileCopy(SourceName=DTSRUN.exe,SourceCabKey=DTSRUN.exe.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF,DestName=DTSRUN.exe,,FileSize=41536,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.534.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:212]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\DTSRUN.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:212]: Source for file 'DTSRUN.exe.55BCEE28_CDBF_4D7F_97C4_082D6B58B9FF' is compressed MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\DTSRUN.exe MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:15:212]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:15:212]: Executing op: FileCopy(SourceName=dtsffile.RLL,SourceCabKey=dtsffile.RLL.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC,DestName=dtsffile.RLL,,FileSize=28672,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:212]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtsffile.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:212]: Source for file 'dtsffile.RLL.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC' is compressed MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtsffile.RLL MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:212]: Executing op: FileCopy(SourceName=dtspkg.RLL,SourceCabKey=dtspkg.RLL.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC,DestName=dtspkg.RLL,,FileSize=208896,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:212]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtspkg.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:212]: Source for file 'dtspkg.RLL.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC' is compressed MSI (s) (F0:A8) [11:33:15:212]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtspkg.RLL MSI (s) (F0:A8) [11:33:15:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:228]: Executing op: FileCopy(SourceName=dtspump.RLL,SourceCabKey=dtspump.RLL.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC,DestName=dtspump.RLL,,FileSize=102400,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:228]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtspump.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:228]: Source for file 'dtspump.RLL.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC' is compressed MSI (s) (F0:A8) [11:33:15:228]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\dtspump.RLL MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:244]: Executing op: FileCopy(SourceName=DTSRUN.rll,SourceCabKey=DTSRUN.rll.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC,DestName=DTSRUN.rll,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:244]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\DTSRUN.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:244]: Source for file 'DTSRUN.rll.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC' is compressed MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\DTSRUN.rll MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:244]: Executing op: FileCopy(SourceName=custtask.RLL,SourceCabKey=custtask.RLL.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC,DestName=custtask.RLL,,FileSize=65536,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:244]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\custtask.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:244]: Source for file 'custtask.RLL.9240E1C0_49D2_40A2_93CE_E62CD8B48DDC' is compressed MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\custtask.RLL MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:244]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\COM\) MSI (s) (F0:A8) [11:33:15:244]: Executing op: SetSourceFolder(Folder=1\x86\binn\) MSI (s) (F0:A8) [11:33:15:244]: Executing op: FileCopy(SourceName=DISTRIB.exe,SourceCabKey=DISTRIB.exe.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=DISTRIB.exe,,FileSize=53832,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:244]: File: C:\Program Files\Microsoft SQL Server\80\COM\DISTRIB.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:244]: Source for file 'DISTRIB.exe.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\DISTRIB.exe MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:244]: Executing op: FileCopy(SourceName=mergetxt.dll,SourceCabKey=mergetxt.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=mergetxt.dll,,FileSize=40096,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:244]: File: C:\Program Files\Microsoft SQL Server\80\COM\mergetxt.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:244]: Source for file 'mergetxt.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:244]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\mergetxt.dll MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:275]: Executing op: FileCopy(SourceName=rdistcom.dll,SourceCabKey=rdistcom.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=rdistcom.dll,,FileSize=410184,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:275]: File: C:\Program Files\Microsoft SQL Server\80\COM\rdistcom.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:275]: Source for file 'rdistcom.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\rdistcom.dll MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:275]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Executing op: FileCopy(SourceName=REPLAGNT.dll,SourceCabKey=REPLAGNT.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=REPLAGNT.dll,,FileSize=29256,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:291]: File: C:\Program Files\Microsoft SQL Server\80\COM\REPLAGNT.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:291]: Source for file 'REPLAGNT.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\REPLAGNT.dll MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Executing op: FileCopy(SourceName=repldsui.dll,SourceCabKey=repldsui.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=repldsui.dll,,FileSize=33352,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:291]: File: C:\Program Files\Microsoft SQL Server\80\COM\repldsui.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:291]: Source for file 'repldsui.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\repldsui.dll MSI (s) (F0:A8) [11:33:15:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:291]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:15:291]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:15:291]: Executing op: FileCopy(SourceName=xpqueue.dll,SourceCabKey=xpqueue.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=xpqueue.dll,,FileSize=57924,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:291]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xpqueue.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:291]: Source for file 'xpqueue.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:306]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xpqueue.dll MSI (s) (F0:A8) [11:33:15:306]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:306]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:306]: Executing op: FileCopy(SourceName=xprepl.dll,SourceCabKey=xprepl.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=xprepl.dll,,FileSize=156228,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:306]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xprepl.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:306]: Source for file 'xprepl.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:306]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xprepl.dll MSI (s) (F0:A8) [11:33:15:306]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:306]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:306]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:306]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:322]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\COM\) MSI (s) (F0:A8) [11:33:15:322]: Executing op: SetSourceFolder(Folder=1\x86\binn\) MSI (s) (F0:A8) [11:33:15:322]: Executing op: FileCopy(SourceName=repldist.dll,SourceCabKey=repldist.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=repldist.dll,,FileSize=70216,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:322]: File: C:\Program Files\Microsoft SQL Server\80\COM\repldist.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:322]: Source for file 'repldist.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:322]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\repldist.dll MSI (s) (F0:A8) [11:33:15:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:337]: Executing op: FileCopy(SourceName=REPLDP.dll,SourceCabKey=REPLDP.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=REPLDP.dll,,FileSize=90692,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:337]: File: C:\Program Files\Microsoft SQL Server\80\COM\REPLDP.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:337]: Source for file 'REPLDP.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\REPLDP.dll MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Executing op: FileCopy(SourceName=repldts.dll,SourceCabKey=repldts.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=repldts.dll,,FileSize=98888,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:353]: File: C:\Program Files\Microsoft SQL Server\80\COM\repldts.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:353]: Source for file 'repldts.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\repldts.dll MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Executing op: FileCopy(SourceName=replerrx.dll,SourceCabKey=replerrx.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=replerrx.dll,,FileSize=93352,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:353]: File: C:\Program Files\Microsoft SQL Server\80\COM\replerrx.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:353]: Source for file 'replerrx.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\replerrx.dll MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Executing op: FileCopy(SourceName=replmerg.exe,SourceCabKey=replmerg.exe.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=replmerg.exe,,FileSize=152136,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:353]: File: C:\Program Files\Microsoft SQL Server\80\COM\replmerg.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:353]: Source for file 'replmerg.exe.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\replmerg.exe MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:369]: Executing op: FileCopy(SourceName=REPLPROV.dll,SourceCabKey=REPLPROV.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=REPLPROV.dll,,FileSize=221768,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.798.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:369]: File: C:\Program Files\Microsoft SQL Server\80\COM\REPLPROV.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:369]: Source for file 'REPLPROV.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:369]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\REPLPROV.dll MSI (s) (F0:A8) [11:33:15:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Executing op: FileCopy(SourceName=REPLPROX.dll,SourceCabKey=REPLPROX.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=REPLPROX.dll,,FileSize=189000,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:384]: File: C:\Program Files\Microsoft SQL Server\80\COM\REPLPROX.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:384]: Source for file 'REPLPROX.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\REPLPROX.dll MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Executing op: FileCopy(SourceName=replrec.dll,SourceCabKey=replrec.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=replrec.dll,,FileSize=307784,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.765.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:384]: File: C:\Program Files\Microsoft SQL Server\80\COM\replrec.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:384]: Source for file 'replrec.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\replrec.dll MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:384]: Executing op: FileCopy(SourceName=REPLSUB.dll,SourceCabKey=REPLSUB.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=REPLSUB.dll,,FileSize=262724,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:384]: File: C:\Program Files\Microsoft SQL Server\80\COM\REPLSUB.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:384]: Source for file 'REPLSUB.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\REPLSUB.dll MSI (s) (F0:A8) [11:33:15:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Executing op: FileCopy(SourceName=replsync.dll,SourceCabKey=replsync.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=replsync.dll,,FileSize=94792,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:400]: File: C:\Program Files\Microsoft SQL Server\80\COM\replsync.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:400]: Source for file 'replsync.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\replsync.dll MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Executing op: FileCopy(SourceName=rinitcom.dll,SourceCabKey=rinitcom.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=rinitcom.dll,,FileSize=287304,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:400]: File: C:\Program Files\Microsoft SQL Server\80\COM\rinitcom.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:400]: Source for file 'rinitcom.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\rinitcom.dll MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Executing op: FileCopy(SourceName=snapshot.exe,SourceCabKey=snapshot.exe.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=snapshot.exe,,FileSize=53832,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:416]: File: C:\Program Files\Microsoft SQL Server\80\COM\snapshot.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:416]: Source for file 'snapshot.exe.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\snapshot.exe MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Executing op: FileCopy(SourceName=spresolv.dll,SourceCabKey=spresolv.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=spresolv.dll,,FileSize=60608,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:416]: File: C:\Program Files\Microsoft SQL Server\80\COM\spresolv.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:416]: Source for file 'spresolv.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\spresolv.dll MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Executing op: FileCopy(SourceName=sqldistx.dll,SourceCabKey=sqldistx.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sqldistx.dll,,FileSize=158896,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:416]: File: C:\Program Files\Microsoft SQL Server\80\COM\sqldistx.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:416]: Source for file 'sqldistx.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\sqldistx.dll MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:416]: Executing op: FileCopy(SourceName=sqlinitx.dll,SourceCabKey=sqlinitx.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sqlinitx.dll,,FileSize=130216,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:416]: File: C:\Program Files\Microsoft SQL Server\80\COM\sqlinitx.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:416]: Source for file 'sqlinitx.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:416]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\sqlinitx.dll MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Executing op: FileCopy(SourceName=sqlmergx.dll,SourceCabKey=sqlmergx.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sqlmergx.dll,,FileSize=158880,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:431]: File: C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:431]: Source for file 'sqlmergx.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:431]: Executing op: FileCopy(SourceName=ssradd.dll,SourceCabKey=ssradd.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=ssradd.dll,,FileSize=44200,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:431]: File: C:\Program Files\Microsoft SQL Server\80\COM\ssradd.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:431]: Source for file 'ssradd.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\ssradd.dll MSI (s) (F0:A8) [11:33:15:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:447]: Executing op: FileCopy(SourceName=ssravg.dll,SourceCabKey=ssravg.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=ssravg.dll,,FileSize=44216,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:447]: File: C:\Program Files\Microsoft SQL Server\80\COM\ssravg.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:447]: Source for file 'ssravg.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\ssravg.dll MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:447]: Executing op: FileCopy(SourceName=ssrdown.dll,SourceCabKey=ssrdown.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=ssrdown.dll,,FileSize=36024,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:447]: File: C:\Program Files\Microsoft SQL Server\80\COM\ssrdown.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:447]: Source for file 'ssrdown.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\ssrdown.dll MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:447]: Executing op: FileCopy(SourceName=ssrmax.dll,SourceCabKey=ssrmax.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=ssrmax.dll,,FileSize=40120,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:447]: File: C:\Program Files\Microsoft SQL Server\80\COM\ssrmax.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:447]: Source for file 'ssrmax.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\ssrmax.dll MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:447]: Executing op: FileCopy(SourceName=ssrmin.dll,SourceCabKey=ssrmin.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=ssrmin.dll,,FileSize=40120,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:447]: File: C:\Program Files\Microsoft SQL Server\80\COM\ssrmin.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:447]: Source for file 'ssrmin.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\ssrmin.dll MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:447]: Executing op: FileCopy(SourceName=ssrpub.dll,SourceCabKey=ssrpub.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=ssrpub.dll,,FileSize=36024,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:447]: File: C:\Program Files\Microsoft SQL Server\80\COM\ssrpub.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:447]: Source for file 'ssrpub.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:447]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\ssrpub.dll MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Executing op: FileCopy(SourceName=ssrup.dll,SourceCabKey=ssrup.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=ssrup.dll,,FileSize=36008,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:462]: File: C:\Program Files\Microsoft SQL Server\80\COM\ssrup.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:462]: Source for file 'ssrup.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\ssrup.dll MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Executing op: FileCopy(SourceName=MSGPROX.dll,SourceCabKey=MSGPROX.dll.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=MSGPROX.dll,,FileSize=90692,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.765.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:462]: File: C:\Program Files\Microsoft SQL Server\80\COM\MSGPROX.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:462]: Source for file 'MSGPROX.dll.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\MSGPROX.dll MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\) MSI (s) (F0:A8) [11:33:15:462]: Executing op: SetSourceFolder(Folder=1\x86\Install\) MSI (s) (F0:A8) [11:33:15:462]: Executing op: FileCopy(SourceName=instdist.sql,SourceCabKey=instdist.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=instdist.sql,,FileSize=747927,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:462]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instdist.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:462]: Source for file 'instdist.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instdist.sql MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:478]: Executing op: FileCopy(SourceName=80sp1-~1.sql|80sp1-tools.sql,SourceCabKey=sp1Tools80.sql.B1EA9824_A6BB_4729_9176_90F7D8D6EC7A,DestName=80sp1-tools.sql,,FileSize=72550,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:478]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\80sp1-tools.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:478]: Source for file 'sp1Tools80.sql.B1EA9824_A6BB_4729_9176_90F7D8D6EC7A' is compressed MSI (s) (F0:A8) [11:33:15:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\80sp1-tools.sql MSI (s) (F0:A8) [11:33:15:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:494]: Executing op: FileCopy(SourceName=sp1_repl.sql,SourceCabKey=sp1Repl.sql.6F5175EB_2F88_4C71_A4C6_1454BC518EC4,DestName=sp1_repl.sql,,FileSize=1742437,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:494]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp1_repl.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:494]: Source for file 'sp1Repl.sql.6F5175EB_2F88_4C71_A4C6_1454BC518EC4' is compressed MSI (s) (F0:A8) [11:33:15:494]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp1_repl.sql MSI (s) (F0:A8) [11:33:15:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Executing op: FileCopy(SourceName=sp1_se~1.sql|sp1_serv_uni.sql,SourceCabKey=sp1ServUni.sql.6EAD8B17_4094_442C_BF0E_93C639158E73,DestName=sp1_serv_uni.sql,,FileSize=140748,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:525]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp1_serv_uni.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:525]: Source for file 'sp1ServUni.sql.6EAD8B17_4094_442C_BF0E_93C639158E73' is compressed MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp1_serv_uni.sql MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:525]: Executing op: FileCopy(SourceName=80sp2-~1.sql|80sp2-tools.sql,SourceCabKey=sp2Tools80.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=80sp2-tools.sql,,FileSize=1639,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:525]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\80sp2-tools.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:525]: Source for file 'sp2Tools80.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:525]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\80sp2-tools.sql MSI (s) (F0:A8) [11:33:15:666]: Executing op: FileCopy(SourceName=sp2_repl.sql,SourceCabKey=sp2Repl.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sp2_repl.sql,,FileSize=674264,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:666]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp2_repl.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:666]: Source for file 'sp2Repl.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp2_repl.sql MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Executing op: FileCopy(SourceName=sp2_se~1.sql|sp2_serv_uni.sql,SourceCabKey=sp2ServUni.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sp2_serv_uni.sql,,FileSize=15622,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:681]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp2_serv_uni.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:681]: Source for file 'sp2ServUni.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp2_serv_uni.sql MSI (s) (F0:A8) [11:33:15:681]: Executing op: FileCopy(SourceName=80sp3-~1.sql|80sp3-tools.sql,SourceCabKey=sp3Tools80.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=80sp3-tools.sql,,FileSize=141004,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:681]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\80sp3-tools.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:681]: Source for file 'sp3Tools80.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\80sp3-tools.sql MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Executing op: FileCopy(SourceName=sp3_repl.sql,SourceCabKey=sp3Repl.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sp3_repl.sql,,FileSize=557890,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:681]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_repl.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:681]: Source for file 'sp3Repl.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_repl.sql MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:681]: Executing op: FileCopy(SourceName=sp3_se~1.sql|sp3_serv_uni.sql,SourceCabKey=sp3ServUni.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sp3_serv_uni.sql,,FileSize=115944,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:681]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_serv_uni.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:681]: Source for file 'sp3ServUni.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:681]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_serv_uni.sql MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Executing op: FileCopy(SourceName=sp3_re~1.sql|sp3_replcom.sql,SourceCabKey=sp3replcom.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sp3_replcom.sql,,FileSize=449531,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:697]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_replcom.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:697]: Source for file 'sp3replcom.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_replcom.sql MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:697]: Executing op: FileCopy(SourceName=sp3_re~2.sql|sp3_replmerg.sql,SourceCabKey=sp3replmerg.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sp3_replmerg.sql,,FileSize=1083467,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:697]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_replmerg.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:697]: Source for file 'sp3replmerg.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:697]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_replmerg.sql MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Executing op: FileCopy(SourceName=sp3_re~3.sql|sp3_replsys.sql,SourceCabKey=sp3replsys.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sp3_replsys.sql,,FileSize=1085874,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:728]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_replsys.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:728]: Source for file 'sp3replsys.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_replsys.sql MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:728]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Executing op: FileCopy(SourceName=sp3_re~4.sql|sp3_repltran.sql,SourceCabKey=sp3repltran.sql.185C1D8F_1545_4277_BB64_857D2622DB57,DestName=sp3_repltran.sql,,FileSize=983404,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:744]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_repltran.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:744]: Source for file 'sp3repltran.sql.185C1D8F_1545_4277_BB64_857D2622DB57' is compressed MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sp3_repltran.sql MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:744]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\) MSI (s) (F0:A8) [11:33:15:759]: Executing op: SetSourceFolder(Folder=1\x86\binn\res\1033\) MSI (s) (F0:A8) [11:33:15:759]: Executing op: FileCopy(SourceName=REPLRES.rll,SourceCabKey=REPLRES.rll.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128,DestName=REPLRES.rll,,FileSize=159813,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:759]: File: C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\REPLRES.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:759]: Source for file 'REPLRES.rll.D9BC9C10_2DCD_44D3_AACC_9C58CAF76128' is compressed MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\REPLRES.rll MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:759]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:15:759]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:15:759]: Executing op: FileCopy(SourceName=semmap.DLL,SourceCabKey=semmap.DLL.DCDF3AA8_FCF8_49F6_9877_752F754DD676,DestName=semmap.DLL,,FileSize=66112,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:759]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\semmap.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:759]: Source for file 'semmap.DLL.DCDF3AA8_FCF8_49F6_9877_752F754DD676' is compressed MSI (s) (F0:A8) [11:33:15:759]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\semmap.DLL MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:791]: Executing op: FileCopy(SourceName=SEMNT.dll,SourceCabKey=SEMNT.dll.DCDF3AA8_FCF8_49F6_9877_752F754DD676,DestName=SEMNT.dll,,FileSize=57916,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:791]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SEMNT.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:791]: Source for file 'SEMNT.dll.DCDF3AA8_FCF8_49F6_9877_752F754DD676' is compressed MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SEMNT.dll MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:791]: Executing op: FileCopy(SourceName=sqlsvc.DLL,SourceCabKey=sqlsvc.DLL.DCDF3AA8_FCF8_49F6_9877_752F754DD676,DestName=sqlsvc.DLL,,FileSize=94784,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:791]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlsvc.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:791]: Source for file 'sqlsvc.DLL.DCDF3AA8_FCF8_49F6_9877_752F754DD676' is compressed MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlsvc.DLL MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:791]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:15:791]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:15:791]: Executing op: FileCopy(SourceName=sqlsvc.dll,SourceCabKey=sqlsvc.DLL.9D087405_CE6A_41B7_8591_33A021D36A77,DestName=sqlsvc.dll,,FileSize=94784,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:791]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlsvc.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:791]: Source for file 'sqlsvc.DLL.9D087405_CE6A_41B7_8591_33A021D36A77' is compressed MSI (s) (F0:A8) [11:33:15:791]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlsvc.dll MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:806]: Executing op: FileCopy(SourceName=SEMNT.dll,SourceCabKey=SEMNT.dll.88235E32_07A8_402A_99A0_0D2DC6EA7C5B,DestName=SEMNT.dll,,FileSize=57916,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:806]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SEMNT.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:806]: Source for file 'SEMNT.dll.88235E32_07A8_402A_99A0_0D2DC6EA7C5B' is compressed MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SEMNT.dll MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:806]: Executing op: FileCopy(SourceName=semmap.DLL,SourceCabKey=semmap.DLL.1FDA19CB_EEE5_487E_8D88_2E090B8B3EED,DestName=semmap.DLL,,FileSize=66112,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:806]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\semmap.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:806]: Source for file 'semmap.DLL.1FDA19CB_EEE5_487E_8D88_2E090B8B3EED' is compressed MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\semmap.DLL MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:806]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:15:806]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:15:806]: Executing op: FileCopy(SourceName=semmap.RLL,SourceCabKey=semmap.RLL.EF490CFB_7BC2_4102_8395_426CE5870B18,DestName=semmap.RLL,,FileSize=32768,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:806]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\semmap.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:806]: Source for file 'semmap.RLL.EF490CFB_7BC2_4102_8395_426CE5870B18' is compressed MSI (s) (F0:A8) [11:33:15:806]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\semmap.RLL MSI (s) (F0:A8) [11:33:15:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:900]: Executing op: FileCopy(SourceName=SEMNT.RLL,SourceCabKey=SEMNT.RLL.EF490CFB_7BC2_4102_8395_426CE5870B18,DestName=SEMNT.RLL,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:900]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\SEMNT.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:900]: Source for file 'SEMNT.RLL.EF490CFB_7BC2_4102_8395_426CE5870B18' is compressed MSI (s) (F0:A8) [11:33:15:900]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\SEMNT.RLL MSI (s) (F0:A8) [11:33:15:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:931]: Executing op: FileCopy(SourceName=sqlsvc.RLL,SourceCabKey=sqlsvc.RLL.EF490CFB_7BC2_4102_8395_426CE5870B18,DestName=sqlsvc.RLL,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:931]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqlsvc.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:931]: Source for file 'sqlsvc.RLL.EF490CFB_7BC2_4102_8395_426CE5870B18' is compressed MSI (s) (F0:A8) [11:33:15:931]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqlsvc.RLL MSI (s) (F0:A8) [11:33:15:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:931]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:15:931]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:15:931]: Executing op: FileCopy(SourceName=sqlsvc.rll,SourceCabKey=sqlsvc.RLL.0F0BBBEF_B79A_4EE4_A6A3_9A1929CF1B3F,DestName=sqlsvc.rll,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:931]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlsvc.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:931]: Source for file 'sqlsvc.RLL.0F0BBBEF_B79A_4EE4_A6A3_9A1929CF1B3F' is compressed MSI (s) (F0:A8) [11:33:15:994]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlsvc.rll MSI (s) (F0:A8) [11:33:15:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:994]: Executing op: FileCopy(SourceName=SEMNT.RLL,SourceCabKey=SEMNT.RLL.0F0BBBEF_B79A_4EE4_A6A3_9A1929CF1B3F,DestName=SEMNT.RLL,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:994]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\SEMNT.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:994]: Source for file 'SEMNT.RLL.0F0BBBEF_B79A_4EE4_A6A3_9A1929CF1B3F' is compressed MSI (s) (F0:A8) [11:33:15:994]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\SEMNT.RLL MSI (s) (F0:A8) [11:33:15:994]: Executing op: FileCopy(SourceName=semmap.RLL,SourceCabKey=semmap.RLL.0F0BBBEF_B79A_4EE4_A6A3_9A1929CF1B3F,DestName=semmap.RLL,,FileSize=32768,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:994]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\semmap.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:994]: Source for file 'semmap.RLL.0F0BBBEF_B79A_4EE4_A6A3_9A1929CF1B3F' is compressed MSI (s) (F0:A8) [11:33:15:994]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\semmap.RLL MSI (s) (F0:A8) [11:33:15:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:15:994]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:15:994]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:15:994]: Executing op: FileCopy(SourceName=sqlagent.EXE,SourceCabKey=sqlagent.EXE.C4D32C83_C28D_4329_A829_31C4C6034F59,DestName=sqlagent.EXE,,FileSize=311872,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:15:994]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlagent.EXE; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:15:994]: Source for file 'sqlagent.EXE.C4D32C83_C28D_4329_A829_31C4C6034F59' is compressed MSI (s) (F0:A8) [11:33:15:994]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlagent.EXE MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Executing op: FileCopy(SourceName=SQLAGENT.dll,SourceCabKey=SQLAGENT.dll.C4D32C83_C28D_4329_A829_31C4C6034F59,DestName=SQLAGENT.dll,,FileSize=28672,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:025]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SQLAGENT.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:025]: Source for file 'SQLAGENT.dll.C4D32C83_C28D_4329_A829_31C4C6034F59' is compressed MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SQLAGENT.dll MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Executing op: FileCopy(SourceName=sqlatxss.DLL,SourceCabKey=sqlatxss.DLL.C4D32C83_C28D_4329_A829_31C4C6034F59,DestName=sqlatxss.DLL,,FileSize=49728,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:025]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlatxss.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:025]: Source for file 'sqlatxss.DLL.C4D32C83_C28D_4329_A829_31C4C6034F59' is compressed MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlatxss.DLL MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Executing op: FileCopy(SourceName=sqlcmdss.DLL,SourceCabKey=sqlcmdss.DLL.C4D32C83_C28D_4329_A829_31C4C6034F59,DestName=sqlcmdss.DLL,,FileSize=53824,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:025]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlcmdss.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:025]: Source for file 'sqlcmdss.DLL.C4D32C83_C28D_4329_A829_31C4C6034F59' is compressed MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlcmdss.DLL MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:025]: Executing op: FileCopy(SourceName=sqlrepss.DLL,SourceCabKey=sqlrepss.DLL.C4D32C83_C28D_4329_A829_31C4C6034F59,DestName=sqlrepss.DLL,,FileSize=57920,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.765.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:025]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlrepss.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:025]: Source for file 'sqlrepss.DLL.C4D32C83_C28D_4329_A829_31C4C6034F59' is compressed MSI (s) (F0:A8) [11:33:16:025]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlrepss.DLL MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:16:056]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:16:056]: Executing op: FileCopy(SourceName=PFCLNT80.dll,SourceCabKey=PFCLNT80.dll.C4D32C83_C28D_4329_A829_31C4C6034F59,DestName=PFCLNT80.dll,,FileSize=414272,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:056]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\PFCLNT80.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:056]: Source for file 'PFCLNT80.dll.C4D32C83_C28D_4329_A829_31C4C6034F59' is compressed MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\PFCLNT80.dll MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:16:056]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:16:056]: Executing op: FileCopy(SourceName=sqlagent.RLL,SourceCabKey=sqlagent.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475,DestName=sqlagent.RLL,,FileSize=53248,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:056]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlagent.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:056]: Source for file 'sqlagent.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475' is compressed MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlagent.RLL MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:056]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:072]: Executing op: FileCopy(SourceName=sqlatxss.RLL,SourceCabKey=sqlatxss.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475,DestName=sqlatxss.RLL,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:072]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlatxss.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:072]: Source for file 'sqlatxss.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475' is compressed MSI (s) (F0:A8) [11:33:16:072]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlatxss.RLL MSI (s) (F0:A8) [11:33:16:072]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:072]: Executing op: FileCopy(SourceName=sqlcmdss.RLL,SourceCabKey=sqlcmdss.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475,DestName=sqlcmdss.RLL,,FileSize=12288,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:072]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlcmdss.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:072]: Source for file 'sqlcmdss.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475' is compressed MSI (s) (F0:A8) [11:33:16:072]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlcmdss.RLL MSI (s) (F0:A8) [11:33:16:072]: Executing op: FileCopy(SourceName=sqlrepss.RLL,SourceCabKey=sqlrepss.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475,DestName=sqlrepss.RLL,,FileSize=12288,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:072]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlrepss.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:072]: Source for file 'sqlrepss.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475' is compressed MSI (s) (F0:A8) [11:33:16:072]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlrepss.RLL MSI (s) (F0:A8) [11:33:16:228]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:16:228]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:16:228]: Executing op: FileCopy(SourceName=PFCLNT80.RLL,SourceCabKey=PFCLNT80.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475,DestName=PFCLNT80.RLL,,FileSize=28672,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:228]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\PFCLNT80.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:228]: Source for file 'PFCLNT80.RLL.BF65A835_E76E_4CA5_8B97_E8FD33E7C475' is compressed MSI (s) (F0:A8) [11:33:16:228]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\PFCLNT80.RLL MSI (s) (F0:A8) [11:33:16:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:228]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:16:228]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:16:228]: Executing op: FileCopy(SourceName=axscphst.DLL,SourceCabKey=axscphst.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=axscphst.DLL,,FileSize=57924,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:228]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\axscphst.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:228]: Source for file 'axscphst.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:228]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\axscphst.DLL MSI (s) (F0:A8) [11:33:16:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:228]: Executing op: FileCopy(SourceName=dcomscm.EXE,SourceCabKey=dcomscm.EXE.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=dcomscm.EXE,,FileSize=21060,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:228]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dcomscm.EXE; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:228]: Source for file 'dcomscm.EXE.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:228]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dcomscm.EXE MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:244]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:16:244]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:16:244]: Executing op: FileCopy(SourceName=DBGHELP.DLL,SourceCabKey=DBGHELP.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=DBGHELP.DLL,,FileSize=719360,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=6.0.17.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:244]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\DBGHELP.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:244]: Source for file 'DBGHELP.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\DBGHELP.DLL MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Executing op: FileCopy(SourceName=MSDBI.DLL,SourceCabKey=MSDBI.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=MSDBI.DLL,,FileSize=102672,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=6.10.8226.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:259]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\MSDBI.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:259]: Source for file 'MSDBI.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\MSDBI.DLL MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Executing op: FileCopy(SourceName=sqlimage.dll,SourceCabKey=sqlimage.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqlimage.dll,,FileSize=36112,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=5.0.2031.1,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:259]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlimage.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:259]: Source for file 'sqlimage.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlimage.dll MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:259]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\) MSI (s) (F0:A8) [11:33:16:259]: Executing op: SetSourceFolder(Folder=1\) MSI (s) (F0:A8) [11:33:16:259]: Executing op: FileCopy(SourceName=readme.txt,SourceCabKey=readme.txt.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=readme.txt,,FileSize=42412,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:259]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\readme.txt; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:259]: Source for file 'readme.txt.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:259]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\readme.txt MSI (s) (F0:A8) [11:33:16:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:291]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:16:291]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:16:291]: Executing op: FileCopy(SourceName=cmdwrap.exe,SourceCabKey=cmdwrap.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=cmdwrap.exe,,FileSize=21056,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:291]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\cmdwrap.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:291]: Source for file 'cmdwrap.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:291]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\cmdwrap.exe MSI (s) (F0:A8) [11:33:16:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:291]: Executing op: FileCopy(SourceName=ODSOLE70.dll,SourceCabKey=ODSOLE70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=ODSOLE70.dll,,FileSize=62024,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.800.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:291]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ODSOLE70.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:291]: Source for file 'ODSOLE70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:291]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ODSOLE70.dll MSI (s) (F0:A8) [11:33:16:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:291]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:291]: Executing op: FileCopy(SourceName=opends60.dll,SourceCabKey=opends60.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=opends60.dll,,FileSize=25152,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:291]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\opends60.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:291]: Source for file 'opends60.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:291]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\opends60.dll MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Executing op: FileCopy(SourceName=sqlservr.exe,SourceCabKey=sqlservr.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqlservr.exe,,FileSize=7544916,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.818.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:322]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlservr.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:322]: Source for file 'sqlservr.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlservr.exe MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:431]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Executing op: FileCopy(SourceName=ums.dll,SourceCabKey=ums.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=ums.dll,,FileSize=45132,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.816.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:634]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ums.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:634]: Source for file 'ums.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ums.dll MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Executing op: FileCopy(SourceName=xplog70.dll,SourceCabKey=xplog70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=xplog70.dll,,FileSize=70208,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:634]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xplog70.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:634]: Source for file 'xplog70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xplog70.dll MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Executing op: FileCopy(SourceName=xpsqlbot.dll,SourceCabKey=xpsqlbot.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=xpsqlbot.dll,,FileSize=25152,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:634]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xpsqlbot.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:634]: Source for file 'xpsqlbot.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xpsqlbot.dll MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Executing op: FileCopy(SourceName=xpstar.DLL,SourceCabKey=xpstar.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=xpstar.DLL,,FileSize=287296,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:634]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xpstar.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:634]: Source for file 'xpstar.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\xpstar.DLL MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:16:634]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:16:634]: Executing op: FileCopy(SourceName=SVRNETCN.dll,SourceCabKey=SVRNETCN.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SVRNETCN.dll,,FileSize=158240,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.818.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:634]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SVRNETCN.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:634]: Source for file 'SVRNETCN.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SVRNETCN.dll MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:634]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Executing op: FileCopy(SourceName=SVRNETCN.exe,SourceCabKey=SVRNETCN.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SVRNETCN.exe,,FileSize=76416,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.818.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:650]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SVRNETCN.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:650]: Source for file 'SVRNETCN.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SVRNETCN.exe MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Executing op: FileCopy(SourceName=scm.exe,SourceCabKey=scm.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=scm.exe,,FileSize=90680,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.534.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:650]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\scm.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:650]: Source for file 'scm.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\scm.exe MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Executing op: FileCopy(SourceName=w95scm.DLL,SourceCabKey=w95scm.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=w95scm.DLL,,FileSize=49728,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:650]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\w95scm.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:650]: Source for file 'w95scm.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\w95scm.DLL MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Executing op: FileCopy(SourceName=sqlmangr.exe,SourceCabKey=sqlmangr.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqlmangr.exe,,FileSize=74308,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:650]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:650]: Source for file 'sqlmangr.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Executing op: FileCopy(SourceName=cnfgsvr.exe,SourceCabKey=cnfgsvr.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=cnfgsvr.exe,,FileSize=62012,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:650]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cnfgsvr.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:650]: Source for file 'cnfgsvr.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cnfgsvr.exe MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:16:650]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:16:650]: Executing op: FileCopy(SourceName=SQLBOOT.dll,SourceCabKey=SQLBOOT.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SQLBOOT.dll,,FileSize=33340,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:650]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SQLBOOT.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:650]: Source for file 'SQLBOOT.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SQLBOOT.dll MSI (s) (F0:A8) [11:33:16:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:650]: Executing op: FileCopy(SourceName=mssql.mib,SourceCabKey=mssql.mib.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=mssql.mib,,FileSize=26740,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:650]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\mssql.mib; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:650]: Source for file 'mssql.mib.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:666]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\mssql.mib MSI (s) (F0:A8) [11:33:16:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Executing op: FileCopy(SourceName=SQLSNMP.DLL,SourceCabKey=SQLSNMP.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SQLSNMP.DLL,,FileSize=61440,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:775]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SQLSNMP.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:775]: Source for file 'SQLSNMP.DLL.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SQLSNMP.DLL MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Executing op: FileCopy(SourceName=ssmsad70.dll,SourceCabKey=ssmsad70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=ssmsad70.dll,,FileSize=33336,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:775]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ssmsad70.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:775]: Source for file 'ssmsad70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ssmsad70.dll MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Executing op: FileCopy(SourceName=SSmsLPCn.dll,SourceCabKey=SSmsLPCn.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SSmsLPCn.dll,,FileSize=33340,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.934.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:775]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsLPCn.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:775]: Source for file 'SSmsLPCn.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsLPCn.dll MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Executing op: FileCopy(SourceName=SSmsRP70.dll,SourceCabKey=SSmsRP70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SSmsRP70.dll,,FileSize=33332,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:775]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsRP70.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:775]: Source for file 'SSmsRP70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsRP70.dll MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Executing op: FileCopy(SourceName=ssnmpn70.dll,SourceCabKey=ssnmpn70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=ssnmpn70.dll,,FileSize=25148,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.818.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:775]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ssnmpn70.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:775]: Source for file 'ssnmpn70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\ssnmpn70.dll MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Executing op: FileCopy(SourceName=SSmsSH70.dll,SourceCabKey=SSmsSH70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SSmsSH70.dll,,FileSize=33344,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:775]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsSH70.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:775]: Source for file 'SSmsSH70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsSH70.dll MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Executing op: FileCopy(SourceName=SSmsVI70.dll,SourceCabKey=SSmsVI70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SSmsVI70.dll,,FileSize=33336,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:775]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsVI70.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:775]: Source for file 'SSmsVI70.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSmsVI70.dll MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:775]: Executing op: FileCopy(SourceName=SSnetlib.dll,SourceCabKey=SSnetlib.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=SSnetlib.dll,,FileSize=82492,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.818.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:775]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSnetlib.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:775]: Source for file 'SSnetlib.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:775]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\SSnetlib.dll MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:16:791]: Executing op: SetSourceFolder(Folder=1\x86\jet\) MSI (s) (F0:A8) [11:33:16:791]: Executing op: FileCopy(SourceName=sqlsort.dll,SourceCabKey=sqlsort.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqlsort.dll,,FileSize=590396,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:791]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlsort.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:791]: Source for file 'sqlsort.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlsort.dll MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Executing op: FileCopy(SourceName=sqldata.dll,SourceCabKey=sqldata.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqldata.dll,,FileSize=815676,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=0,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:791]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqldata.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:791]: Source for file 'sqldata.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqldata.dll MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:791]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:806]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:884]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\) MSI (s) (F0:A8) [11:33:16:900]: Executing op: SetSourceFolder(Folder=1\x86\Data\) MSI (s) (F0:A8) [11:33:16:900]: Executing op: FileCopy(SourceName=master.mdf,SourceCabKey=master.mdf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=master.mdf,,FileSize=12779520,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:16:900]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\master.mdf; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:16:900]: Source for file 'master.mdf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\master.mdf MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:900]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:916]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:931]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:947]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:962]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:978]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:16:994]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:009]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:025]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:041]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:181]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:197]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:212]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:228]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:244]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Executing op: FileCopy(SourceName=mastlog.ldf,SourceCabKey=mastlog.ldf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=mastlog.ldf,,FileSize=524288,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:322]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\mastlog.ldf; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:322]: Source for file 'mastlog.ldf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\mastlog.ldf MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Executing op: FileCopy(SourceName=model.mdf,SourceCabKey=model.mdf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=model.mdf,,FileSize=655360,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:322]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\model.mdf; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:322]: Source for file 'model.mdf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\model.mdf MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:322]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Executing op: FileCopy(SourceName=modellog.ldf,SourceCabKey=modellog.ldf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=modellog.ldf,,FileSize=524288,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:337]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\modellog.ldf; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:337]: Source for file 'modellog.ldf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\modellog.ldf MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:17:337]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:17:337]: Executing op: FileCopy(SourceName=comnevnt.dll,SourceCabKey=comnevnt.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=comnevnt.dll,,FileSize=319488,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:337]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\comnevnt.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:337]: Source for file 'comnevnt.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\comnevnt.dll MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:337]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:17:353]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:17:353]: Executing op: FileCopy(SourceName=sqdedev.dll,SourceCabKey=sqdedev.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqdedev.dll,,FileSize=127548,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:353]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqdedev.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:353]: Source for file 'sqdedev.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqdedev.dll MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\) MSI (s) (F0:A8) [11:33:17:353]: Executing op: SetSourceFolder(Folder=1\x86\Data\) MSI (s) (F0:A8) [11:33:17:353]: Executing op: FileCopy(SourceName=msdbdata.mdf,SourceCabKey=msdbdata.mdf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=msdbdata.mdf,,FileSize=3145728,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:353]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\msdbdata.mdf; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:353]: Source for file 'msdbdata.mdf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\msdbdata.mdf MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:353]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:369]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:384]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Executing op: FileCopy(SourceName=msdblog.ldf,SourceCabKey=msdblog.ldf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=msdblog.ldf,,FileSize=524288,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:400]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\msdblog.ldf; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:400]: Source for file 'msdblog.ldf.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Data\msdblog.ldf MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:400]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:416]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:17:416]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:17:416]: Executing op: FileCopy(SourceName=sqlctr.ini,SourceCabKey=sqlctr.ini.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqlctr.ini,,FileSize=19984,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:416]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlctr.ini; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:416]: Source for file 'sqlctr.ini.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:416]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlctr.ini MSI (s) (F0:A8) [11:33:17:416]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:416]: Executing op: FileCopy(SourceName=sqlctr.h,SourceCabKey=sqlctr.h.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqlctr.h,,FileSize=4516,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:416]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlctr.h; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:416]: Source for file 'sqlctr.h.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:416]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlctr.h MSI (s) (F0:A8) [11:33:17:447]: Executing op: FileCopy(SourceName=sqlctr80.dll,SourceCabKey=sqlctr80.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqlctr80.dll,,FileSize=33336,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.534.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:447]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlctr80.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:447]: Source for file 'sqlctr80.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:447]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlctr80.dll MSI (s) (F0:A8) [11:33:17:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:447]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\COM\) MSI (s) (F0:A8) [11:33:17:447]: Executing op: SetSourceFolder(Folder=1\x86\binn\) MSI (s) (F0:A8) [11:33:17:447]: Executing op: FileCopy(SourceName=impprov.dll,SourceCabKey=impprov.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=impprov.dll,,FileSize=102992,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:447]: File: C:\Program Files\Microsoft SQL Server\80\COM\impprov.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:447]: Source for file 'impprov.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:447]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\COM\impprov.dll MSI (s) (F0:A8) [11:33:17:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:447]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:447]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:17:447]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:17:447]: Executing op: FileCopy(SourceName=sqlvdi.dll,SourceCabKey=sqlvdi.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqlvdi.dll,,FileSize=45644,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.765.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:447]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlvdi.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:447]: Source for file 'sqlvdi.dll.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:447]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlvdi.dll MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Executing op: FileCopy(SourceName=sqladhlp.exe,SourceCabKey=sqladhlp.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616,DestName=sqladhlp.exe,,FileSize=66112,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:462]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqladhlp.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:462]: Source for file 'sqladhlp.exe.CC1A8C58_27D1_4D38_BF1B_C0A5CBB90616' is compressed MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqladhlp.exe MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:17:462]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:17:462]: Executing op: FileCopy(SourceName=sqlmaint.exe,SourceCabKey=sqlmaint.exe.32EDCB9E_F17F_4831_A493_A4A1BF81F665,DestName=sqlmaint.exe,,FileSize=156224,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:462]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlmaint.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:462]: Source for file 'sqlmaint.exe.32EDCB9E_F17F_4831_A493_A4A1BF81F665' is compressed MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlmaint.exe MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Executing op: FileCopy(SourceName=sqlresld.dll,SourceCabKey=sqlresld.DLL.38D1180E_7B73_4D00_BAA6_DBD3312CFDA8,DestName=sqlresld.dll,,FileSize=29248,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:462]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlresld.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:462]: Source for file 'sqlresld.DLL.38D1180E_7B73_4D00_BAA6_DBD3312CFDA8' is compressed MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\sqlresld.dll MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:17:462]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:17:462]: Executing op: FileCopy(SourceName=axscphst.RLL,SourceCabKey=axscphst.RLL.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=axscphst.RLL,,FileSize=28672,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:462]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\axscphst.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:462]: Source for file 'axscphst.RLL.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\axscphst.RLL MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:17:462]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:17:462]: Executing op: FileCopy(SourceName=sqlevn70.rll,SourceCabKey=sqlevn70.rll.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=sqlevn70.rll,,FileSize=28672,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.789.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:462]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlevn70.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:462]: Source for file 'sqlevn70.rll.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlevn70.rll MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:462]: Executing op: FileCopy(SourceName=odsole70.rll,SourceCabKey=odsole70.rll.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=odsole70.rll,,FileSize=20480,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:462]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\odsole70.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:462]: Source for file 'odsole70.rll.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\odsole70.rll MSI (s) (F0:A8) [11:33:17:462]: Executing op: FileCopy(SourceName=xplog70.rll,SourceCabKey=xplog70.rll.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=xplog70.rll,,FileSize=16453,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:462]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\xplog70.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:462]: Source for file 'xplog70.rll.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\xplog70.rll MSI (s) (F0:A8) [11:33:17:462]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Executing op: FileCopy(SourceName=xpstar.RLL,SourceCabKey=xpstar.RLL.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=xpstar.RLL,,FileSize=36864,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:478]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\xpstar.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:478]: Source for file 'xpstar.RLL.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\xpstar.RLL MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:17:478]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:17:478]: Executing op: FileCopy(SourceName=SVRNETCN.RLL,SourceCabKey=SVRNETCN.RLL.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=SVRNETCN.RLL,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:478]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\SVRNETCN.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:478]: Source for file 'SVRNETCN.RLL.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\SVRNETCN.RLL MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Executing op: FileCopy(SourceName=sqlmangr.RLL,SourceCabKey=sqlmangr.RLL.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=sqlmangr.RLL,,FileSize=98304,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:478]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqlmangr.RLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:478]: Source for file 'sqlmangr.RLL.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqlmangr.RLL MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Executing op: FileCopy(SourceName=sqladevn.rll,SourceCabKey=sqladevn.rll.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=sqladevn.rll,,FileSize=24576,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:478]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqladevn.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:478]: Source for file 'sqladevn.rll.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\sqladevn.rll MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:17:478]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:17:478]: Executing op: FileCopy(SourceName=sqlmaint.rll,SourceCabKey=sqlmaint.rll.88C26F26_166C_4CD7_8175_38297C2276D7,DestName=sqlmaint.rll,,FileSize=32768,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:478]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlmaint.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:478]: Source for file 'sqlmaint.rll.88C26F26_166C_4CD7_8175_38297C2276D7' is compressed MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\Resources\1033\sqlmaint.rll MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:17:478]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:17:478]: Executing op: FileCopy(SourceName=bcp.exe,SourceCabKey=bcp.exe.0C7570D6_6225_4960_B951_4D16DD906838,DestName=bcp.exe,,FileSize=94208,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:478]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\bcp.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:478]: Source for file 'bcp.exe.0C7570D6_6225_4960_B951_4D16DD906838' is compressed MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\bcp.exe MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Executing op: FileCopy(SourceName=OSQL.EXE,SourceCabKey=OSQL.EXE.0C7570D6_6225_4960_B951_4D16DD906838,DestName=OSQL.EXE,,FileSize=57904,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.796.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:478]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\OSQL.EXE; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:478]: Source for file 'OSQL.EXE.0C7570D6_6225_4960_B951_4D16DD906838' is compressed MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\OSQL.EXE MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:478]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\) MSI (s) (F0:A8) [11:33:17:478]: Executing op: SetSourceFolder(Folder=1\x86\Binn\res\1033\) MSI (s) (F0:A8) [11:33:17:478]: Executing op: FileCopy(SourceName=bcp.rll,SourceCabKey=bcp.rll.ACD7EC22_4989_4067_B267_6DB5716695BC,DestName=bcp.rll,,FileSize=16384,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.382.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:478]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\bcp.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:478]: Source for file 'bcp.rll.ACD7EC22_4989_4067_B267_6DB5716695BC' is compressed MSI (s) (F0:A8) [11:33:17:478]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\bcp.rll MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:17:494]: Executing op: SetSourceFolder(Folder=1\x86\Binn\) MSI (s) (F0:A8) [11:33:17:494]: Executing op: FileCopy(SourceName=cldtcstp.exe,SourceCabKey=cldtcstp.exe.66CDF039_0EDE_453E_A1E5_1931046C4056,DestName=cldtcstp.exe,,FileSize=82492,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:494]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cldtcstp.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:494]: Source for file 'cldtcstp.exe.66CDF039_0EDE_453E_A1E5_1931046C4056' is compressed MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cldtcstp.exe MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Executing op: FileCopy(SourceName=cnvsvc.exe,SourceCabKey=cnvsvc.exe.66CDF039_0EDE_453E_A1E5_1931046C4056,DestName=cnvsvc.exe,,FileSize=74296,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:494]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cnvsvc.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:494]: Source for file 'cnvsvc.exe.66CDF039_0EDE_453E_A1E5_1931046C4056' is compressed MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cnvsvc.exe MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Executing op: FileCopy(SourceName=cnvrem.dll,SourceCabKey=cnvrem.dll.66CDF039_0EDE_453E_A1E5_1931046C4056,DestName=cnvrem.dll,,FileSize=98872,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:494]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cnvrem.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:494]: Source for file 'cnvrem.dll.66CDF039_0EDE_453E_A1E5_1931046C4056' is compressed MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cnvrem.dll MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Executing op: FileCopy(SourceName=cldtcstp.rll,SourceCabKey=cldtcstp.rll.66CDF039_0EDE_453E_A1E5_1931046C4056,DestName=cldtcstp.rll,,FileSize=28672,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=2000.80.194.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:494]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cldtcstp.rll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:494]: Source for file 'cldtcstp.rll.66CDF039_0EDE_453E_A1E5_1931046C4056' is compressed MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cldtcstp.rll MSI (s) (F0:A8) [11:33:17:494]: Executing op: FileCopy(SourceName=dtcsetup.exe,SourceCabKey=dtcsetup.exe.66CDF039_0EDE_453E_A1E5_1931046C4056,DestName=dtcsetup.exe,,FileSize=584416,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=4.71.1015.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:494]: File: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtcsetup.exe; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:494]: Source for file 'dtcsetup.exe.66CDF039_0EDE_453E_A1E5_1931046C4056' is compressed MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtcsetup.exe MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:494]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\system32\) MSI (s) (F0:A8) [11:33:17:509]: Executing op: SetSourceFolder(Folder=1\Redist\MS\System\) MSI (s) (F0:A8) [11:33:17:509]: Executing op: FileCopy(SourceName=msstkprp.dll,SourceCabKey=Global_Vba_VBStockProp_f0.7EBEDD3E_AA66_11D2_B980_006097C4DE24,DestName=msstkprp.dll,Attributes=0,FileSize=94208,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=6.0.81.69,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:509]: File: C:\WINDOWS\system32\msstkprp.dll; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:509]: Source for file 'Global_Vba_VBStockProp_f0.7EBEDD3E_AA66_11D2_B980_006097C4DE24' is compressed MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2318 2: C:\WINDOWS\system32\msstkprp.dll MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\) MSI (s) (F0:A8) [11:33:17:509]: Executing op: SetSourceFolder(Folder=1\x86\Install\) MSI (s) (F0:A8) [11:33:17:509]: Executing op: FileCopy(SourceName=ansiview.sql,SourceCabKey=ansiview.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=ansiview.sql,,FileSize=33853,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:509]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\ansiview.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:509]: Source for file 'ansiview.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\ansiview.sql MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Executing op: FileCopy(SourceName=instcat.sql,SourceCabKey=instcat.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=instcat.sql,,FileSize=768067,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:509]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instcat.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:509]: Source for file 'instcat.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instcat.sql MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:509]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Executing op: FileCopy(SourceName=instlang.sql,SourceCabKey=instlang.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=instlang.sql,,FileSize=36298,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:525]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instlang.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:525]: Source for file 'instlang.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instlang.sql MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Executing op: FileCopy(SourceName=instls.sql,SourceCabKey=instls.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=instls.sql,,FileSize=52628,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:525]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instls.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:525]: Source for file 'instls.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instls.sql MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Executing op: FileCopy(SourceName=instmsdb.sql,SourceCabKey=instmsdb.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=instmsdb.sql,,FileSize=745961,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:525]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instmsdb.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:525]: Source for file 'instmsdb.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\instmsdb.sql MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:525]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Executing op: FileCopy(SourceName=messages.sql,SourceCabKey=messages.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=messages.sql,,FileSize=727572,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:541]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\messages.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:541]: Source for file 'messages.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\messages.sql MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:541]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Executing op: FileCopy(SourceName=odsole.sql,SourceCabKey=odsole.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=odsole.sql,,FileSize=1873,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:556]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\odsole.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:556]: Source for file 'odsole.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\odsole.sql MSI (s) (F0:A8) [11:33:17:556]: Executing op: FileCopy(SourceName=oledbsch.sql,SourceCabKey=oledbsch.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=oledbsch.sql,,FileSize=10190,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:556]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\oledbsch.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:556]: Source for file 'oledbsch.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\oledbsch.sql MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Executing op: FileCopy(SourceName=procsyst.sql,SourceCabKey=procsyst.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=procsyst.sql,,FileSize=550032,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:556]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\procsyst.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:556]: Source for file 'procsyst.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\procsyst.sql MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:556]: Executing op: FileCopy(SourceName=replcom.sql,SourceCabKey=replcom.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=replcom.sql,,FileSize=449531,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:556]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\replcom.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:556]: Source for file 'replcom.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\replcom.sql MSI (s) (F0:A8) [11:33:17:556]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Executing op: FileCopy(SourceName=replmerg.sql,SourceCabKey=replmerg.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=replmerg.sql,,FileSize=1083467,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:572]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\replmerg.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:572]: Source for file 'replmerg.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\replmerg.sql MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:572]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:587]: Executing op: FileCopy(SourceName=replsys.sql,SourceCabKey=replsys.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=replsys.sql,,FileSize=1085874,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:587]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\replsys.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:587]: Source for file 'replsys.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:587]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\replsys.sql MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:650]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Executing op: FileCopy(SourceName=repltran.sql,SourceCabKey=repltran.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=repltran.sql,,FileSize=983404,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:666]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\repltran.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:666]: Source for file 'repltran.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\repltran.sql MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:666]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Executing op: FileCopy(SourceName=servmsgs.sql,SourceCabKey=servmsgs.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=servmsgs.sql,,FileSize=58772,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:681]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\servmsgs.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:681]: Source for file 'servmsgs.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\servmsgs.sql MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Executing op: FileCopy(SourceName=sqldmo.sql,SourceCabKey=sqldmo.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=sqldmo.sql,,FileSize=186471,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:681]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sqldmo.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:681]: Source for file 'sqldmo.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sqldmo.sql MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:681]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Executing op: FileCopy(SourceName=u_tables.sql,SourceCabKey=u_tables.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=u_tables.sql,,FileSize=55354,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:697]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\u_tables.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:697]: Source for file 'u_tables.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\u_tables.sql MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Executing op: FileCopy(SourceName=upgrade.sql,SourceCabKey=upgrade.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=upgrade.sql,,FileSize=387627,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:697]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\upgrade.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:697]: Source for file 'upgrade.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\upgrade.sql MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Executing op: FileCopy(SourceName=web.sql,SourceCabKey=web.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=web.sql,,FileSize=16324,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:697]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\web.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:697]: Source for file 'web.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\web.sql MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Executing op: FileCopy(SourceName=xpstar.sql,SourceCabKey=xpstar.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=xpstar.sql,,FileSize=73647,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:697]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\xpstar.sql; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:697]: Source for file 'xpstar.sql.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\xpstar.sql MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:697]: Executing op: FileCopy(SourceName=sysmes~1.sym|sysmessages.sym,SourceCabKey=sysmessages.sym.24170C3F_A9E4_47C1_8DFE_FD79C2714697,DestName=sysmessages.sym,,FileSize=727132,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,) MSI (s) (F0:A8) [11:33:17:697]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sysmessages.sym; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:17:697]: Source for file 'sysmessages.sym.24170C3F_A9E4_47C1_8DFE_FD79C2714697' is compressed MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Install\sysmessages.sym MSI (s) (F0:A8) [11:33:17:697]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Note: 1: 2360 MSI (s) (F0:A8) [11:33:17:712]: Executing op: CacheSizeFlush(,) MSI (s) (F0:A8) [11:33:17:712]: Executing op: InstallProtectedFiles(AllowUI=0) MSI (s) (F0:A8) [11:33:17:712]: Executing op: ActionStart(Name=InstallDTC.2D02443E_7002_4C0B_ABC9_EAB2C064397B,,) MSI (s) (F0:A8) [11:33:17:712]: Executing op: CustomActionSchedule(Action=InstallDTC.2D02443E_7002_4C0B_ABC9_EAB2C064397B,ActionType=1025,Source=BinaryData,Target=InstallDTC,) MSI (s) (F0:88) [11:33:17:712]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI35.tmp, Entrypoint: InstallDTC SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action InstallDTC MSI (s) (F0:A8) [11:33:19:822]: Executing op: ActionStart(Name=RollbackNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B,,) Executing "C:\Program Files\Microsoft SQL Server\80\Tools\Binn\cldtcstp.exe -SupportDir "C:\Program Files\Microsoft SQL Server\80\Tools\Binn\" -DTCPkg "C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtcsetup.exe" -Silent 1" MSI (s) (F0:A8) [11:33:19:822]: Executing op: CustomActionSchedule(Action=RollbackNoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B,ActionType=1281,Source=BinaryData,Target=NoRebootReplace,) MSI (s) (F0:A8) [11:33:19:822]: Executing op: ActionStart(Name=NoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B,,) MSI (s) (F0:A8) [11:33:19:822]: Executing op: CustomActionSchedule(Action=NoRebootReplace.2D02443E_7002_4C0B_ABC9_EAB2C064397B,ActionType=1025,Source=BinaryData,Target=NoRebootReplace,) MSI (s) (F0:A4) [11:33:19:822]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI36.tmp, Entrypoint: NoRebootReplace SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action NoRebootReplace TempFolder Property is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\ Source Dir Property is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\SqlSetup\Temp MSI (s) (F0:A8) [11:33:20:134]: Executing op: ActionStart(Name=InstallSqlRedis.2D02443E_7002_4C0B_ABC9_EAB2C064397B,,) NoRebootConnectRepl returned: 0 MSI (s) (F0:A8) [11:33:20:134]: Executing op: CustomActionSchedule(Action=InstallSqlRedis.2D02443E_7002_4C0B_ABC9_EAB2C064397B,ActionType=1025,Source=BinaryData,Target=InstallSqlRedis,) MSI (s) (F0:AC) [11:33:20:134]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI37.tmp, Entrypoint: InstallSqlRedis SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} TempFolder is C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\ Loading extended custom action library C:\DOCUME~1\pperdijk\LOCALS~1\Temp\{E09B48B5-E141-427A-AB0C-D3605127224A}\sqlcax.dll SOFTWARE\Microsoft\Microsoft SQL Server Setup.{E09B48B5-E141-427A-AB0C-D3605127224A} Starting custom action InstallSqlRedis MSI (s) (F0:A8) [11:33:26:541]: Executing op: ActionStart(Name=DuplicateFiles,Description=Creating duplicate files,Template=File: [1], Directory: [9], Size: [6]) Executing "C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlredis.exe /q:a" MSI (s) (F0:A8) [11:33:26:541]: Executing op: ProgressTotal(Total=739093,Type=0,ByteEquivalent=1) MSI (s) (F0:A8) [11:33:26:541]: Executing op: SetSourceFolder(Folder=C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\) MSI (s) (F0:A8) [11:33:26:541]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\) MSI (s) (F0:A8) [11:33:26:541]: Executing op: FileCopy(SourceName=REPLRES.rll,,DestName=REPLRES.rll,,FileSize=159813,PerTick=0,IsCompressed=0,VerifyMedia=0,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=262144,,,,,,,) MSI (s) (F0:A8) [11:33:26:541]: File: C:\Program Files\Microsoft SQL Server\80\COM\Resources\1033\REPLRES.rll; Won't Overwrite; Won't patch; Existing file is of an equal version MSI (s) (F0:A8) [11:33:26:541]: Executing op: SetSourceFolder(Folder=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\) MSI (s) (F0:A8) [11:33:26:541]: Executing op: SetTargetFolder(Folder=C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\) MSI (s) (F0:A8) [11:33:26:541]: Executing op: FileCopy(SourceName=w95scm.DLL,,DestName=w95scm.DLL,,FileSize=49728,PerTick=0,IsCompressed=0,VerifyMedia=0,,,,,CheckCRC=0,Version=2000.80.760.0,Language=1033,InstallMode=262144,,,,,,,) MSI (s) (F0:A8) [11:33:26:541]: File: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\w95scm.DLL; To be installed; Won't patch; No existing file MSI (s) (F0:A8) [11:33:26:541]: Source for file 'w95scm.DLL' is uncompressed, at 'C:\Program Files\Microsoft SQL Server\80\Tools\Binn\'. MSI (s) (F0:A8) [11:33:26:541]: Note: 1: 2318 2: C:\Program Files\Microsoft SQL Server\MSSQL$MSFW\Binn\w95scm.DLL MSI (s) (F0:A8) [11:33:26:541]: Executing op: ActionStart(Name=CreateShortcuts,Description=Creating shortcuts,Template=Shortcut: [1]) MSI (s) (F0:A8) [11:33:26:541]: Executing op: SetTargetFolder(Folder=24) MSI (s) (F0:A8) [11:33:26:541]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Startup MSI (s) (F0:A8) [11:33:26:541]: Executing op: ShortcutCreate(Name=SvcMngr|Service Manager,,,FileName=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe,Arguments=/n,,Icon=SvcMangrIco_4BFD7B59_97C9_4908_8AF4_4CB073038239,IconIndex=0,,ShowCmd=1,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: ActionStart(Name=RegisterClassInfo,Description=Registering Class servers,Template=Class Id: [1]) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegClassInfoRegister(Feature=SqlRun,Component={10048711-2C96-11D2-9A97-006097C4E452}[~]2,FileName=C:\WINDOWS\system32\msstkprp.dll,ClsId={7EBDAAE1-8120-11CF-899F-00AA00688B10},,,Description=MS Stock Color Property Page Object,Context=InprocServer32,,,,,,,,,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegClassInfoRegister(Feature=SqlRun,Component={10048711-2C96-11D2-9A97-006097C4E452}[~]2,FileName=C:\WINDOWS\system32\msstkprp.dll,ClsId={7EBDAAE0-8120-11CF-899F-00AA00688B10},,,Description=MS Stock Font Property Page Object,Context=InprocServer32,,,,,,,,,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegClassInfoRegister(Feature=SqlRun,Component={10048711-2C96-11D2-9A97-006097C4E452}[~]2,FileName=C:\WINDOWS\system32\msstkprp.dll,ClsId={7EBDAAE2-8120-11CF-899F-00AA00688B10},,,Description=MS Stock Picture Property Page Object,Context=InprocServer32,,,,,,,,,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegClassInfoRegister(Feature=SqlRun,Component={436D7A23-36BE-11D2-ACBB-0080C7FCBB84}[~]2,,ClsId={44EC053A-400F-11D0-9DCD-00A0C90391D3},ProgId=ATL.Registrar,,Description=ATL.Registrar,Context=InprocServer32,,,,,IconIndex=0,,,,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: ActionStart(Name=RegisterProgIdInfo,Description=Unregistering program identifiers,Template=ProgId: [1]) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegProgIdInfoRegister(ProgId=ATL.Registrar,ClsId={44EC053A-400F-11D0-9DCD-00A0C90391D3},,Description=Registrar Class,,IconIndex=0,,,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: ActionStart(Name=WriteRegistryValues,Description=Writing system registry values,Template=Key: [1], Name: [2], Value: [3]) MSI (s) (F0:A8) [11:33:26:572]: Executing op: ProgressTotal(Total=1905,Type=1,ByteEquivalent=13200) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegOpenKey(,Key=SQLDMO.Application,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegAddValue(,Value=SQLDMO Application,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegOpenKey(,Key=SQLDMO.Application\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegAddValue(,Value={10020100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegOpenKey(,Key=SQLDMO.Application.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegAddValue(,Value=SQLDMO Application,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegOpenKey(,Key=SQLDMO.Application.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegAddValue(,Value={10020100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegOpenKey(,Key=CLSID\{10020100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegAddValue(,Value=SQLDMO Application,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegOpenKey(,Key=CLSID\{10020100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegAddValue(,Value=SQLDMO.Application.8.0,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegOpenKey(,Key=CLSID\{10020100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegAddValue(,Value=SQLDMO.Application,) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegOpenKey(,Key=CLSID\{10020100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:572]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{10020100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.SQLServer,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO Server,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.SQLServer\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value={10020200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.SQLServer.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO Server,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.SQLServer.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value={10020200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{10020200-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO Server,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{10020200-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO.SQLServer.8.0,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{10020200-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO.SQLServer,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{10020200-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{10020200-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.SQLServer2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO Server,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.SQLServer2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value={100202C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.SQLServer2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO Server,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.SQLServer2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value={100202C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{100202C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO Server,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{100202C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO.SQLServer2.8.0,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{100202C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO.SQLServer2,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{100202C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=CLSID\{100202C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegOpenKey(,Key=SQLDMO.Database,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:587]: Executing op: RegAddValue(,Value=SQLDMO Database,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Database\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value={10020300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Database.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO Database,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Database.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value={10020300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{10020300-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO Database,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{10020300-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO.Database.8.0,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{10020300-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO.Database,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{10020300-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{10020300-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Database2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO Database,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Database2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value={100203C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Database2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO Database,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Database2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value={100203C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{100203C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO Database,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{100203C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO.Database2.8.0,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{100203C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO.Database2,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{100203C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=CLSID\{100203C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Table,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO Table,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Table\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value={10020400-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Table.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value=SQLDMO Table,) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegOpenKey(,Key=SQLDMO.Table.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:603]: Executing op: RegAddValue(,Value={10020400-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{10020400-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO Table,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{10020400-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO.Table.8.0,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{10020400-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO.Table,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{10020400-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{10020400-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=SQLDMO.Table2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO Table,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=SQLDMO.Table2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value={100204C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=SQLDMO.Table2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO Table,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=SQLDMO.Table2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value={100204C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{100204C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO Table,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{100204C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO.Table2.8.0,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{100204C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO.Table2,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{100204C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{100204C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=SQLDMO.Column,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO Column,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=SQLDMO.Column\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value={10020500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=SQLDMO.Column.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO Column,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=SQLDMO.Column.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value={10020500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{10020500-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO Column,) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegOpenKey(,Key=CLSID\{10020500-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:619]: Executing op: RegAddValue(,Value=SQLDMO.Column.8.0,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{10020500-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO.Column,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{10020500-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{10020500-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=SQLDMO.Column2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO Column,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=SQLDMO.Column2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value={100205C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=SQLDMO.Column2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO Column,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=SQLDMO.Column2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value={100205C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{100205C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO Column,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{100205C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO.Column2.8.0,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{100205C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO.Column2,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{100205C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{100205C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=SQLDMO.View,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO View,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=SQLDMO.View\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value={10020700-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=SQLDMO.View.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO View,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=SQLDMO.View.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value={10020700-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{10020700-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO View,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{10020700-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO.View.8.0,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{10020700-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=SQLDMO.View,) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegOpenKey(,Key=CLSID\{10020700-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:634]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{10020700-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.View2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO View,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.View2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value={100207C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.View2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO View,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.View2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value={100207C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{100207C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO View,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{100207C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO.View2.8.0,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{100207C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO.View2,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{100207C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{100207C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedDatatype,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedDatatype,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedDatatype\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value={10020800-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedDatatype.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedDatatype,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedDatatype.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value={10020800-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{10020800-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedDatatype,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{10020800-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO.UserDefinedDatatype.8.0,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{10020800-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO.UserDefinedDatatype,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{10020800-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=CLSID\{10020800-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedDatatype2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:650]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedDatatype,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedDatatype2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value={100208C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedDatatype2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedDatatype,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedDatatype2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value={100208C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{100208C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedDatatype,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{100208C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO.UserDefinedDatatype2.8.0,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{100208C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO.UserDefinedDatatype2,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{100208C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{100208C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.Default,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO Default,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.Default\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value={10020900-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.Default.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO Default,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.Default.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value={10020900-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{10020900-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO Default,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{10020900-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO.Default.8.0,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{10020900-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO.Default,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{10020900-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=CLSID\{10020900-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.Default2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO Default,) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.Default2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value={100209C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegOpenKey(,Key=SQLDMO.Default2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:666]: Executing op: RegAddValue(,Value=SQLDMO Default,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Default2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value={100209C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{100209C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO Default,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{100209C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO.Default2.8.0,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{100209C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO.Default2,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{100209C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{100209C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Rule,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO Rule,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Rule\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value={10020A00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Rule.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO Rule,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Rule.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value={10020A00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{10020A00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO Rule,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{10020A00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO.Rule.8.0,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{10020A00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO.Rule,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{10020A00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{10020A00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Rule2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO Rule,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Rule2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value={10020AC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Rule2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO Rule,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=SQLDMO.Rule2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value={10020AC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{10020AC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO Rule,) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegOpenKey(,Key=CLSID\{10020AC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:681]: Executing op: RegAddValue(,Value=SQLDMO.Rule2.8.0,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020AC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO.Rule2,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020AC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020AC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=SQLDMO.User,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO User,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=SQLDMO.User\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value={10020B00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=SQLDMO.User.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO User,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=SQLDMO.User.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value={10020B00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020B00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO User,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020B00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO.User.8.0,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020B00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO.User,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020B00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020B00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=SQLDMO.User2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO User,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=SQLDMO.User2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value={10020BC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=SQLDMO.User2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO User,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=SQLDMO.User2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value={10020BC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020BC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO User,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020BC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO.User2.8.0,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020BC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=SQLDMO.User2,) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegOpenKey(,Key=CLSID\{10020BC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:697]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020BC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.Group,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO Group,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.Group\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value={10020C00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.Group.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO Group,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.Group.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value={10020C00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020C00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO Group,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020C00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO.Group.8.0,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020C00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO.Group,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020C00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020C00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.StoredProcedure,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO StoredProcedure,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.StoredProcedure\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value={10020D00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.StoredProcedure.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO StoredProcedure,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.StoredProcedure.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value={10020D00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020D00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO StoredProcedure,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020D00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO.StoredProcedure.8.0,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020D00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO.StoredProcedure,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020D00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=CLSID\{10020D00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegOpenKey(,Key=SQLDMO.StoredProcedure2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:712]: Executing op: RegAddValue(,Value=SQLDMO StoredProcedure,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.StoredProcedure2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value={10020DC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.StoredProcedure2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO StoredProcedure,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.StoredProcedure2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value={10020DC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020DC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO StoredProcedure,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020DC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO.StoredProcedure2.8.0,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020DC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO.StoredProcedure2,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020DC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020DC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.Index,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO Index,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.Index\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value={10020E00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.Index.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO Index,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.Index.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value={10020E00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020E00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO Index,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020E00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO.Index.8.0,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020E00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO.Index,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020E00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=CLSID\{10020E00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.Index2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO Index,) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.Index2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value={10020EC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegOpenKey(,Key=SQLDMO.Index2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:728]: Executing op: RegAddValue(,Value=SQLDMO Index,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Index2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value={10020EC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020EC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO Index,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020EC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO.Index2.8.0,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020EC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO.Index2,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020EC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020EC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Key,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO DRI Key,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Key\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value={10020F00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Key.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO DRI Key,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Key.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value={10020F00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020F00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO DRI Key,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020F00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO.Key.8.0,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020F00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO.Key,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020F00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10020F00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Trigger,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO Trigger,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Trigger\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value={10021000-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Trigger.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO Trigger,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=SQLDMO.Trigger.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value={10021000-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10021000-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO Trigger,) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegOpenKey(,Key=CLSID\{10021000-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:744]: Executing op: RegAddValue(,Value=SQLDMO.Trigger.8.0,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{10021000-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO.Trigger,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{10021000-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{10021000-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=SQLDMO.Trigger2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO Trigger,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=SQLDMO.Trigger2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value={100210C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=SQLDMO.Trigger2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO Trigger,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=SQLDMO.Trigger2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value={100210C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{100210C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO Trigger,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{100210C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO.Trigger2.8.0,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{100210C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO.Trigger2,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{100210C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{100210C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=SQLDMO.BackupDevice,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO BackupDevice,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=SQLDMO.BackupDevice\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value={10021100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=SQLDMO.BackupDevice.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO BackupDevice,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=SQLDMO.BackupDevice.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value={10021100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{10021100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO BackupDevice,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{10021100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO.BackupDevice.8.0,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{10021100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=SQLDMO.BackupDevice,) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegOpenKey(,Key=CLSID\{10021100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:759]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{10021100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=SQLDMO.Login,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO Login,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=SQLDMO.Login\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value={10021300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=SQLDMO.Login.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO Login,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=SQLDMO.Login.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value={10021300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{10021300-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO Login,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{10021300-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO.Login.8.0,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{10021300-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO.Login,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{10021300-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{10021300-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=SQLDMO.Login2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO Login,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=SQLDMO.Login2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value={100213C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=SQLDMO.Login2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO Login,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=SQLDMO.Login2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value={100213C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{100213C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO Login,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{100213C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO.Login2.8.0,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{100213C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=SQLDMO.Login2,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{100213C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegOpenKey(,Key=CLSID\{100213C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:775]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.Language,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO Language,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.Language\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value={10021400-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.Language.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO Language,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.Language.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value={10021400-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021400-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO Language,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021400-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO.Language.8.0,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021400-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO.Language,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021400-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021400-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteServer,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO RemoteServer,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteServer\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value={10021500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteServer.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO RemoteServer,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteServer.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value={10021500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021500-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO RemoteServer,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021500-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO.RemoteServer.8.0,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021500-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO.RemoteServer,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021500-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=CLSID\{10021500-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteServer2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO RemoteServer,) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteServer2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value={100215C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteServer2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:791]: Executing op: RegAddValue(,Value=SQLDMO RemoteServer,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteServer2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value={100215C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{100215C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO RemoteServer,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{100215C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO.RemoteServer2.8.0,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{100215C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO.RemoteServer2,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{100215C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{100215C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteLogin,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO RemoteLogin,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteLogin\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value={10021600-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteLogin.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO RemoteLogin,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.RemoteLogin.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value={10021600-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{10021600-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO RemoteLogin,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{10021600-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO.RemoteLogin.8.0,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{10021600-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO.RemoteLogin,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{10021600-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{10021600-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.Check,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO DRI Check,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.Check\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value={10021700-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.Check.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO DRI Check,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=SQLDMO.Check.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value={10021700-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{10021700-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO DRI Check,) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegOpenKey(,Key=CLSID\{10021700-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:806]: Executing op: RegAddValue(,Value=SQLDMO.Check.8.0,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021700-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO.Check,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021700-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021700-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=SQLDMO.ServerGroup,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO Server Group,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=SQLDMO.ServerGroup\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value={10021800-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=SQLDMO.ServerGroup.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO Server Group,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=SQLDMO.ServerGroup.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value={10021800-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021800-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO Server Group,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021800-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO.ServerGroup.8.0,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021800-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO.ServerGroup,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021800-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021800-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=SQLDMO.RegisteredServer,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO Registered Server,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=SQLDMO.RegisteredServer\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value={10021900-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=SQLDMO.RegisteredServer.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO Registered Server,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=SQLDMO.RegisteredServer.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value={10021900-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021900-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO Registered Server,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021900-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO.RegisteredServer.8.0,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021900-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=SQLDMO.RegisteredServer,) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegOpenKey(,Key=CLSID\{10021900-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:822]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021900-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=SQLDMO.Transfer,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO DB Transfer,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=SQLDMO.Transfer\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value={10021E00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=SQLDMO.Transfer.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO DB Transfer,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=SQLDMO.Transfer.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value={10021E00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021E00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO DB Transfer,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021E00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO.Transfer.8.0,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021E00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO.Transfer,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021E00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021E00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=SQLDMO.Transfer2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO DB Transfer,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=SQLDMO.Transfer2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value={10021EC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=SQLDMO.Transfer2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO DB Transfer,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=SQLDMO.Transfer2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value={10021EC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021EC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO DB Transfer,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021EC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO.Transfer2.8.0,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021EC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=SQLDMO.Transfer2,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021EC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegOpenKey(,Key=CLSID\{10021EC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:837]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.Backup,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO DB Backup,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.Backup\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value={10021F00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.Backup.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO DB Backup,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.Backup.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value={10021F00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021F00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO DB Backup,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021F00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO.Backup.8.0,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021F00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO.Backup,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021F00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021F00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.Backup2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO DB Backup,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.Backup2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value={10021FC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.Backup2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO DB Backup,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.Backup2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value={10021FC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021FC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO DB Backup,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021FC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO.Backup2.8.0,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021FC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO.Backup2,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021FC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=CLSID\{10021FC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.BulkCopy,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO BulkCopy,) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.BulkCopy\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value={10021C00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegOpenKey(,Key=SQLDMO.BulkCopy.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:853]: Executing op: RegAddValue(,Value=SQLDMO BulkCopy,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.BulkCopy.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value={10021C00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021C00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO BulkCopy,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021C00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO.BulkCopy.8.0,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021C00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO.BulkCopy,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021C00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021C00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.BulkCopy2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO BulkCopy,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.BulkCopy2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value={10021CC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.BulkCopy2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO BulkCopy,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.BulkCopy2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value={10021CC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021CC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO BulkCopy,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021CC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO.BulkCopy2.8.0,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021CC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO.BulkCopy2,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021CC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10021CC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.FileGroup,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO File Group,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.FileGroup\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value={10022C00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.FileGroup.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO File Group,) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=SQLDMO.FileGroup.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value={10022C00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegOpenKey(,Key=CLSID\{10022C00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:869]: Executing op: RegAddValue(,Value=SQLDMO File Group,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022C00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO.FileGroup.8.0,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022C00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO.FileGroup,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022C00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022C00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=SQLDMO.FileGroup2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO File Group,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=SQLDMO.FileGroup2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value={10022CC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=SQLDMO.FileGroup2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO File Group,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=SQLDMO.FileGroup2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value={10022CC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022CC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO File Group,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022CC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO.FileGroup2.8.0,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022CC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO.FileGroup2,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022CC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022CC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=SQLDMO.DBFile,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO DB File,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=SQLDMO.DBFile\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value={10022D00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=SQLDMO.DBFile.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO DB File,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=SQLDMO.DBFile.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value={10022D00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022D00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO DB File,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022D00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO.DBFile.8.0,) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegOpenKey(,Key=CLSID\{10022D00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:884]: Executing op: RegAddValue(,Value=SQLDMO.DBFile,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022D00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022D00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=SQLDMO.LogFile,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO Log File,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=SQLDMO.LogFile\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value={10022E00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=SQLDMO.LogFile.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO Log File,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=SQLDMO.LogFile.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value={10022E00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022E00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO Log File,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022E00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO.LogFile.8.0,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022E00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO.LogFile,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022E00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022E00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=SQLDMO.LogFile2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO Log File,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=SQLDMO.LogFile2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value={10022EC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=SQLDMO.LogFile2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO Log File,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=SQLDMO.LogFile2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value={10022EC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022EC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO Log File,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022EC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO.LogFile2.8.0,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022EC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=SQLDMO.LogFile2,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022EC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegOpenKey(,Key=CLSID\{10022EC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:900]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.ServerRole,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO Server Role,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.ServerRole\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value={10022F00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.ServerRole.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO Server Role,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.ServerRole.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value={10022F00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10022F00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO Server Role,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10022F00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO.ServerRole.8.0,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10022F00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO.ServerRole,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10022F00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10022F00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.DatabaseRole,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO Database Role,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.DatabaseRole\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value={10023100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.DatabaseRole.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO Database Role,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.DatabaseRole.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value={10023100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10023100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO Database Role,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10023100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO.DatabaseRole.8.0,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10023100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO.DatabaseRole,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10023100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=CLSID\{10023100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegOpenKey(,Key=SQLDMO.DatabaseRole2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:916]: Executing op: RegAddValue(,Value=SQLDMO Database Role,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.DatabaseRole2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value={100231C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.DatabaseRole2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO Database Role,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.DatabaseRole2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value={100231C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{100231C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO Database Role,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{100231C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO.DatabaseRole2.8.0,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{100231C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO.DatabaseRole2,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{100231C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{100231C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.Restore,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO DB Restore,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.Restore\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value={10023200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.Restore.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO DB Restore,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.Restore.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value={10023200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{10023200-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO DB Restore,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{10023200-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO.Restore.8.0,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{10023200-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO.Restore,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{10023200-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=CLSID\{10023200-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.Restore2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO DB Restore,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.Restore2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value={100232C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.Restore2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value=SQLDMO DB Restore,) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegOpenKey(,Key=SQLDMO.Restore2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:931]: Executing op: RegAddValue(,Value={100232C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100232C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO DB Restore,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100232C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO.Restore2.8.0,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100232C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO.Restore2,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100232C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100232C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServer,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO LinkedServer,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServer\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value={10023300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServer.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO LinkedServer,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServer.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value={10023300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{10023300-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO LinkedServer,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{10023300-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO.LinkedServer.8.0,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{10023300-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO.LinkedServer,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{10023300-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{10023300-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServer2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO LinkedServer,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServer2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value={100233C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServer2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO LinkedServer,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServer2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value={100233C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100233C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO LinkedServer,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100233C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO.LinkedServer2.8.0,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100233C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=SQLDMO.LinkedServer2,) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegOpenKey(,Key=CLSID\{100233C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:947]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{100233C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServerLogin,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO LinkedServerLogin,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServerLogin\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value={10023400-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServerLogin.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO LinkedServerLogin,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.LinkedServerLogin.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value={10023400-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023400-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO LinkedServerLogin,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023400-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO.LinkedServerLogin.8.0,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023400-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO.LinkedServerLogin,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023400-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023400-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.FullTextCatalog,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO FullText Catalog,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.FullTextCatalog\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value={10023500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.FullTextCatalog.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO FullText Catalog,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.FullTextCatalog.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value={10023500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023500-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO FullText Catalog,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023500-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO.FullTextCatalog.8.0,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023500-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO.FullTextCatalog,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023500-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=CLSID\{10023500-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.FullTextCatalog2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value=SQLDMO FullText Catalog,) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegOpenKey(,Key=SQLDMO.FullTextCatalog2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:962]: Executing op: RegAddValue(,Value={100235C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.FullTextCatalog2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO FullText Catalog,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.FullTextCatalog2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value={100235C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{100235C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO FullText Catalog,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{100235C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO.FullTextCatalog2.8.0,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{100235C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO.FullTextCatalog2,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{100235C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{100235C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedFunction,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedFunction,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedFunction\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value={10023700-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedFunction.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedFunction,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.UserDefinedFunction.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value={10023700-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{10023700-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO UserDefinedFunction,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{10023700-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO.UserDefinedFunction.8.0,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{10023700-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO.UserDefinedFunction,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{10023700-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{10023700-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.Replication,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO Replication,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.Replication\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value={10031000-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.Replication.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO Replication,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=SQLDMO.Replication.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value={10031000-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{10031000-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO Replication,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{10031000-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO.Replication.8.0,) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegOpenKey(,Key=CLSID\{10031000-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:978]: Executing op: RegAddValue(,Value=SQLDMO.Replication,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{10031000-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{10031000-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.Replication2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO Replication,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.Replication2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value={100310C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.Replication2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO Replication,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.Replication2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value={100310C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{100310C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO Replication,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{100310C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO.Replication2.8.0,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{100310C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO.Replication2,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{100310C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{100310C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublisher,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublisher,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublisher\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value={10030700-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublisher.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublisher,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublisher.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value={10030700-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{10030700-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublisher,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{10030700-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO.DistributionPublisher.8.0,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{10030700-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO.DistributionPublisher,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{10030700-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=CLSID\{10030700-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublisher2,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublisher,) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublisher2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:26:994]: Executing op: RegAddValue(,Value={100307C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublisher2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublisher,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublisher2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value={100307C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{100307C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublisher,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{100307C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO.DistributionPublisher2.8.0,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{100307C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO.DistributionPublisher2,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{100307C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{100307C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionDatabase,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO DistributionDatabase,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionDatabase\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value={10031300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionDatabase.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO DistributionDatabase,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionDatabase.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value={10031300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{10031300-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO DistributionDatabase,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{10031300-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO.DistributionDatabase.8.0,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{10031300-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO.DistributionDatabase,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{10031300-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{10031300-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionDatabase2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO DistributionDatabase,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionDatabase2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value={100313C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionDatabase2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO DistributionDatabase,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionDatabase2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value={100313C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{100313C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO DistributionDatabase,) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegOpenKey(,Key=CLSID\{100313C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:009]: Executing op: RegAddValue(,Value=SQLDMO.DistributionDatabase2.8.0,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{100313C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO.DistributionDatabase2,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{100313C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{100313C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=SQLDMO.RegisteredSubscriber,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO RegisteredSubscriber,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=SQLDMO.RegisteredSubscriber\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value={10030900-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=SQLDMO.RegisteredSubscriber.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO RegisteredSubscriber,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=SQLDMO.RegisteredSubscriber.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value={10030900-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030900-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO RegisteredSubscriber,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030900-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO.RegisteredSubscriber.8.0,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030900-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO.RegisteredSubscriber,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030900-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030900-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=SQLDMO.TransPublication,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO TransPublication,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=SQLDMO.TransPublication\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value={10030100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=SQLDMO.TransPublication.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO TransPublication,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=SQLDMO.TransPublication.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value={10030100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO TransPublication,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO.TransPublication.8.0,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=SQLDMO.TransPublication,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegOpenKey(,Key=CLSID\{10030100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:025]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransPublication2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransPublication,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransPublication2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value={100301C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransPublication2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransPublication,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransPublication2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value={100301C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{100301C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransPublication,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{100301C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO.TransPublication2.8.0,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{100301C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO.TransPublication2,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{100301C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{100301C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransArticle,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransArticle,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransArticle\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value={10030200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransArticle.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransArticle,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransArticle.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value={10030200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{10030200-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransArticle,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{10030200-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO.TransArticle.8.0,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{10030200-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO.TransArticle,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{10030200-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{10030200-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransArticle2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransArticle,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransArticle2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value={100302C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransArticle2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransArticle,) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=SQLDMO.TransArticle2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value={100302C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegOpenKey(,Key=CLSID\{100302C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:041]: Executing op: RegAddValue(,Value=SQLDMO TransArticle,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{100302C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO.TransArticle2.8.0,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{100302C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO.TransArticle2,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{100302C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{100302C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=SQLDMO.TransSubscription,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO TransSubscription,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=SQLDMO.TransSubscription\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value={10030300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=SQLDMO.TransSubscription.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO TransSubscription,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=SQLDMO.TransSubscription.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value={10030300-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{10030300-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO TransSubscription,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{10030300-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO.TransSubscription.8.0,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{10030300-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO.TransSubscription,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{10030300-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{10030300-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=SQLDMO.TransSubscription2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO TransSubscription,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=SQLDMO.TransSubscription2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value={100303C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=SQLDMO.TransSubscription2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO TransSubscription,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=SQLDMO.TransSubscription2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value={100303C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{100303C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO TransSubscription,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{100303C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO.TransSubscription2.8.0,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{100303C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=SQLDMO.TransSubscription2,) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegOpenKey(,Key=CLSID\{100303C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:056]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{100303C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.TransPullSubscription,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO TransPullSubscription,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.TransPullSubscription\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value={10030B00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.TransPullSubscription.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO TransPullSubscription,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.TransPullSubscription.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value={10030B00-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030B00-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO TransPullSubscription,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030B00-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO.TransPullSubscription.8.0,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030B00-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO.TransPullSubscription,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030B00-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030B00-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.TransPullSubscription2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO TransPullSubscription,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.TransPullSubscription2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value={10030BC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.TransPullSubscription2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO TransPullSubscription,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.TransPullSubscription2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value={10030BC1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030BC1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO TransPullSubscription,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030BC1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO.TransPullSubscription2.8.0,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030BC1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO.TransPullSubscription2,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030BC1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=CLSID\{10030BC1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.MergePublication,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegAddValue(,Value=SQLDMO MergePublication,) MSI (s) (F0:A8) [11:33:27:072]: Executing op: RegOpenKey(,Key=SQLDMO.MergePublication\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value={10030400-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergePublication.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO MergePublication,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergePublication.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value={10030400-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{10030400-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO MergePublication,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{10030400-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO.MergePublication.8.0,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{10030400-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO.MergePublication,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{10030400-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{10030400-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergePublication2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO MergePublication,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergePublication2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value={100304C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergePublication2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO MergePublication,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergePublication2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value={100304C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{100304C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO MergePublication,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{100304C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO.MergePublication2.8.0,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{100304C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO.MergePublication2,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{100304C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{100304C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergeArticle,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO MergeArticle,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergeArticle\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value={10030500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergeArticle.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO MergeArticle,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=SQLDMO.MergeArticle.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value={10030500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{10030500-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO MergeArticle,) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegOpenKey(,Key=CLSID\{10030500-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:087]: Executing op: RegAddValue(,Value=SQLDMO.MergeArticle.8.0,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{10030500-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO.MergeArticle,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{10030500-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{10030500-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeArticle2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO MergeArticle,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeArticle2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value={100305C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeArticle2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO MergeArticle,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeArticle2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value={100305C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{100305C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO MergeArticle,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{100305C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO.MergeArticle2.8.0,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{100305C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO.MergeArticle2,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{100305C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{100305C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubscription,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO MergeSubscription,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubscription\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value={10030600-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubscription.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO MergeSubscription,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubscription.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value={10030600-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{10030600-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO MergeSubscription,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{10030600-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO.MergeSubscription.8.0,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{10030600-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=SQLDMO.MergeSubscription,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{10030600-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=CLSID\{10030600-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:103]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubscription2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergeSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubscription2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value={100306C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubscription2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergeSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubscription2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value={100306C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{100306C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergeSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{100306C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO.MergeSubscription2.8.0,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{100306C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO.MergeSubscription2,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{100306C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{100306C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergePullSubscription,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergePullSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergePullSubscription\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value={10031100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergePullSubscription.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergePullSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergePullSubscription.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value={10031100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{10031100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergePullSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{10031100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO.MergePullSubscription.8.0,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{10031100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO.MergePullSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{10031100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{10031100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergePullSubscription2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergePullSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergePullSubscription2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value={100311C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergePullSubscription2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergePullSubscription,) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=SQLDMO.MergePullSubscription2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value={100311C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegOpenKey(,Key=CLSID\{100311C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:119]: Executing op: RegAddValue(,Value=SQLDMO MergePullSubscription,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{100311C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO.MergePullSubscription2.8.0,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{100311C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO.MergePullSubscription2,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{100311C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{100311C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubsetFilter,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO MergeSubsetFilter,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubsetFilter\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value={10035100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubsetFilter.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO MergeSubsetFilter,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=SQLDMO.MergeSubsetFilter.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value={10035100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10035100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO MergeSubsetFilter,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10035100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO.MergeSubsetFilter.8.0,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10035100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO.MergeSubsetFilter,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10035100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10035100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=SQLDMO.ReplicationSecurity,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO ReplicationSecurity,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=SQLDMO.ReplicationSecurity\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value={10031200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=SQLDMO.ReplicationSecurity.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO ReplicationSecurity,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=SQLDMO.ReplicationSecurity.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value={10031200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10031200-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO ReplicationSecurity,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10031200-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO.ReplicationSecurity.8.0,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10031200-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=SQLDMO.ReplicationSecurity,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10031200-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegOpenKey(,Key=CLSID\{10031200-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:134]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublication,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublication,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublication\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value={10032100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublication.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublication,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublication.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value={10032100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{10032100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublication,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{10032100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO.DistributionPublication.8.0,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{10032100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO.DistributionPublication,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{10032100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{10032100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublication2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublication,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublication2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value={100321C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublication2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublication,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionPublication2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value={100321C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{100321C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO DistributionPublication,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{100321C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO.DistributionPublication2.8.0,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{100321C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO.DistributionPublication2,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{100321C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=CLSID\{100321C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionArticle,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO DistributionArticle,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionArticle\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value={10033100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionArticle.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value=SQLDMO DistributionArticle,) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionArticle.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:150]: Executing op: RegAddValue(,Value={10033100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:166]: Executing op: RegOpenKey(,Key=CLSID\{10033100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:166]: Executing op: RegAddValue(,Value=SQLDMO DistributionArticle,) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegOpenKey(,Key=CLSID\{10033100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegAddValue(,Value=SQLDMO.DistributionArticle.8.0,) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegOpenKey(,Key=CLSID\{10033100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegAddValue(,Value=SQLDMO.DistributionArticle,) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegOpenKey(,Key=CLSID\{10033100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegOpenKey(,Key=CLSID\{10033100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionArticle2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:384]: Executing op: RegAddValue(,Value=SQLDMO DistributionArticle,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionArticle2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value={100331C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionArticle2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO DistributionArticle,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionArticle2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value={100331C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{100331C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO DistributionArticle,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{100331C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO.DistributionArticle2.8.0,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{100331C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO.DistributionArticle2,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{100331C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{100331C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionSubscription,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO DistributionSubscription,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionSubscription\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value={10034100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionSubscription.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO DistributionSubscription,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionSubscription.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value={10034100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{10034100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO DistributionSubscription,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{10034100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO.DistributionSubscription.8.0,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{10034100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO.DistributionSubscription,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{10034100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{10034100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionSubscription2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO DistributionSubscription,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionSubscription2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value={100341C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionSubscription2.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO DistributionSubscription,) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=SQLDMO.DistributionSubscription2.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value={100341C1-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegOpenKey(,Key=CLSID\{100341C1-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:400]: Executing op: RegAddValue(,Value=SQLDMO DistributionSubscription,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{100341C1-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO.DistributionSubscription2.8.0,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{100341C1-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO.DistributionSubscription2,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{100341C1-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{100341C1-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=SQLDMO.MergeDynamicSnapshotJob,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO MergeDynamicSnapshotJob,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=SQLDMO.MergeDynamicSnapshotJob\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value={10036100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=SQLDMO.MergeDynamicSnapshotJob.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO MergeDynamicSnapshotJob,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=SQLDMO.MergeDynamicSnapshotJob.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value={10036100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10036100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO MergeDynamicSnapshotJob,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10036100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO.MergeDynamicSnapshotJob.8.0,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10036100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO.MergeDynamicSnapshotJob,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10036100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10036100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=SQLDMO.Alert,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO Alert,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=SQLDMO.Alert\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value={10040600-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=SQLDMO.Alert.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO Alert,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=SQLDMO.Alert.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value={10040600-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10040600-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO Alert,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10040600-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO.Alert.8.0,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10040600-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=SQLDMO.Alert,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10040600-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:416]: Executing op: RegOpenKey(,Key=CLSID\{10040600-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.Operator,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO Operator,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.Operator\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value={10040200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.Operator.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO Operator,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.Operator.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value={10040200-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040200-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO Operator,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040200-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO.Operator.8.0,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040200-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO.Operator,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040200-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040200-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.Job,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO Job,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.Job\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value={10040800-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.Job.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO Job,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.Job.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value={10040800-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040800-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO Job,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040800-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO.Job.8.0,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040800-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO.Job,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040800-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=CLSID\{10040800-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.TargetServer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO TargetServer,) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.TargetServer\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value={10041000-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegOpenKey(,Key=SQLDMO.TargetServer.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:431]: Executing op: RegAddValue(,Value=SQLDMO TargetServer,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.TargetServer.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value={10041000-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041000-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO TargetServer,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041000-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO.TargetServer.8.0,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041000-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO.TargetServer,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041000-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041000-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.TargetServerGroup,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO TargetServerGroup,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.TargetServerGroup\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value={10041100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.TargetServerGroup.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO TargetServerGroup,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.TargetServerGroup.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value={10041100-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041100-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO TargetServerGroup,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041100-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO.TargetServerGroup.8.0,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041100-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO.TargetServerGroup,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041100-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041100-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.Category,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO Category,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.Category\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value={10041500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.Category.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO Category,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=SQLDMO.Category.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value={10041500-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041500-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO Category,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041500-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO.Category.8.0,) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegOpenKey(,Key=CLSID\{10041500-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:447]: Executing op: RegAddValue(,Value=SQLDMO.Category,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10041500-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10041500-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=SQLDMO.JobStep,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO JobStep,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=SQLDMO.JobStep\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value={10040900-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=SQLDMO.JobStep.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO JobStep,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=SQLDMO.JobStep.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value={10040900-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10040900-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO JobStep,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10040900-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO.JobStep.8.0,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10040900-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO.JobStep,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10040900-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10040900-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=SQLDMO.JobSchedule,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO JobSchedule,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=SQLDMO.JobSchedule\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value={10041600-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=SQLDMO.JobSchedule.8.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO JobSchedule,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=SQLDMO.JobSchedule.8.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value={10041600-E260-11CF-AE68-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10041600-E260-11CF-AE68-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO JobSchedule,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10041600-E260-11CF-AE68-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO.JobSchedule.8.0,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10041600-E260-11CF-AE68-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=SQLDMO.JobSchedule,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10041600-E260-11CF-AE68-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=CLSID\{10041600-E260-11CF-AE68-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SQLDMO.dll,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=DTSFlatFile,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value=DTS Package Flatfile provider,) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegOpenKey(,Key=DTSFlatFile\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:462]: Executing op: RegAddValue(,Value={10010100-0224-11D1-B7B8-00C04FB6EFD5},) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSFlatFile.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=DTS Package Flatfile provider,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSFlatFile.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value={10010100-0224-11D1-B7B8-00C04FB6EFD5},) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010100-0224-11D1-B7B8-00C04FB6EFD5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=DTS Package Flatfile provider,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010100-0224-11D1-B7B8-00C04FB6EFD5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=DTSFlatFile.1,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010100-0224-11D1-B7B8-00C04FB6EFD5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=DTSFlatFile,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010100-0224-11D1-B7B8-00C04FB6EFD5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtsffile.DLL,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformScript,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=ActiveX Script,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformScript\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value={10010501-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformScript.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=ActiveX Script,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformScript.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value={10010501-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010501-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=ActiveX Script,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010501-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformScript.2.0,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010501-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformScript,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010501-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010501-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformMidString,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=Middle of String,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformMidString\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value={10010901-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformMidString.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=Middle of String,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformMidString.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value={10010901-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010901-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=Middle of String,) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegOpenKey(,Key=CLSID\{10010901-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:478]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformMidString.2.0,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010901-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformMidString,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010901-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010901-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformTrimString,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=Trim String,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformTrimString\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value={10010D01-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformTrimString.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=Trim String,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformTrimString.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value={10010D01-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010D01-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=Trim String,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010D01-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformTrimString.2.0,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010D01-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformTrimString,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010D01-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010D01-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformReadFile,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=Read File,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformReadFile\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value={10010A01-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformReadFile.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=Read File,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformReadFile.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value={10010A01-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010A01-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=Read File,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010A01-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformReadFile.2.0,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010A01-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformReadFile,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010A01-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegOpenKey(,Key=CLSID\{10010A01-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:494]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformWriteFile,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=Write File,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformWriteFile\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value={10010C01-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformWriteFile.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=Write File,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformWriteFile.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value={10010C01-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010C01-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=Write File,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010C01-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformWriteFile.2.0,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010C01-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformWriteFile,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010C01-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010C01-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformDateTimeString,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=DateTime String,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformDateTimeString\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value={10010B01-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformDateTimeString.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=DateTime String,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformDateTimeString.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value={10010B01-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010B01-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=DateTime String,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010B01-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformDateTimeString.2.0,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010B01-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformDateTimeString,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010B01-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=CLSID\{10010B01-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformCopy,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=Copy Column,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformCopy\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value={10010400-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformCopy.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value=Copy Column,) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformCopy.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:509]: Executing op: RegAddValue(,Value={10010400-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010400-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=Copy Column,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010400-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformCopy.2.0,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010400-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformCopy,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010400-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010400-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformUpperString,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=Uppercase String,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformUpperString\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value={10010701-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformUpperString.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=Uppercase String,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformUpperString.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value={10010701-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010701-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=Uppercase String,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010701-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformUpperString.2.0,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010701-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformUpperString,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010701-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010701-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformLowerString,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=Lowercase String,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformLowerString\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value={10010801-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformLowerString.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=Lowercase String,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=DTSPump.DataPumpTransformLowerString.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value={10010801-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010801-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=Lowercase String,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010801-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformLowerString.2.0,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010801-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=DTSPump.DataPumpTransformLowerString,) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegOpenKey(,Key=CLSID\{10010801-740B-11D0-AE7B-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:525]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010801-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=Component Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(Name=409,Value=Custom Transformation Objects for Microsoft Data Transformation Services,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value=Data Transformation Services Data Pump Server,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010100-740B-11D0-AE7B-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value=DTS.DataPump.2,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010100-740B-11D0-AE7B-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value=DTS.DataPump,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010100-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010400-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010501-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010701-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010801-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010901-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010a01-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010b01-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010c01-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010d01-740B-11D0-AE7B-00AA004A34D5}\Implemented Categories\{10010100-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010103-740B-11D0-AE7B-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value=DTS.DataConvert,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=CLSID\{10010103-740B-11D0-AE7B-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspump.DLL,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=DTS.DataPumpTransformCopy,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value=Copy Column,) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=DTS.DataPumpTransformCopy\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegAddValue(,Value={10010400-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:541]: Executing op: RegOpenKey(,Key=DTS.DataPumpTransformCopy.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=Copy Column,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.DataPumpTransformCopy.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value={10010400-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.DataPumpTransformScript,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=ActiveX Script,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.DataPumpTransformScript\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value={10010501-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.DataPumpTransformScript.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=ActiveX Script,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.DataPumpTransformScript.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value={10010501-740B-11D0-AE7B-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.Package,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=Data Transformation Services Package Object,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.Package\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value={10020200-EB1C-11CF-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.Package.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=Data Transformation Services Package Object,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.Package.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value={10020200-EB1C-11CF-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=Data Transformation Services Package Object,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020200-EB1C-11CF-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=DTS.Package.2.0,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020200-EB1C-11CF-AE6E-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=DTS.Package,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020200-EB1C-11CF-AE6E-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020200-EB1C-11CF-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.Package2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=Data Transformation Services Package Object,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.Package2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value={10020202-EB1C-11CF-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.Package2.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=Data Transformation Services Package Object,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=DTS.Package2.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value={10020202-EB1C-11CF-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020202-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=Data Transformation Services Package Object,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020202-EB1C-11CF-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=DTS.Package2.2.0,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020202-EB1C-11CF-AE6E-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=DTS.Package2,) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegOpenKey(,Key=CLSID\{10020202-EB1C-11CF-AE6E-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:556]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10020202-EB1C-11CF-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTS.PropertiesProvider,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=Default provider of 'Properties' collection for DTS Objects,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTS.PropertiesProvider\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value={10020201-EB1C-11CF-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTS.PropertiesProvider.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=Default provider of 'Properties' collection for DTS Objects,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTS.PropertiesProvider.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value={10020201-EB1C-11CF-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10020201-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=Default provider of 'Properties' collection for DTS Objects,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10020201-EB1C-11CF-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=DTS.PropertiesProvider.2.0,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10020201-EB1C-11CF-AE6E-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=DTS.PropertiesProvider,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10020201-EB1C-11CF-AE6E-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10020201-EB1C-11CF-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTS.Application,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=Data Transformation Services Application Object,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTS.Application\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value={10030000-EB1C-11CF-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTS.Application.2.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=Data Transformation Services Application Object,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTS.Application.2.0\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value={10030000-EB1C-11CF-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10030000-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=Data Transformation Services Application Object,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10030000-EB1C-11CF-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=DTS.Application.2.0,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10030000-EB1C-11CF-AE6E-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=DTS.Application,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10030000-EB1C-11CF-AE6E-00AA004A34D5}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=CLSID\{10030000-EB1C-11CF-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=Component Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(Name=409,Value=Custom Task Objects for Microsoft Data Transformation Services,) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegOpenKey(,Key=DTSActiveScriptTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:572]: Executing op: RegAddValue(,Value=DTSActiveScriptTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=DTSActiveScriptTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value={10020907-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020907-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSActiveScriptTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020907-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSActiveScriptTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020907-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020907-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=DTSDataPumpTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSDataPumpTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=DTSDataPumpTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value={10020908-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020908-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSDataPumpTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020908-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSDataPumpTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020908-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020908-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=DTSCreateProcessTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSCreateProcessTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=DTSCreateProcessTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value={10020909-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020909-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSCreateProcessTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020909-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSCreateProcessTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020909-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{10020909-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=DTSExecuteSQLTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSExecuteSQLTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=DTSExecuteSQLTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value={1002090C-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{1002090C-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSExecuteSQLTask,) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegOpenKey(,Key=CLSID\{1002090C-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:587]: Executing op: RegAddValue(,Value=DTSExecuteSQLTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090C-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090C-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=DTSDataDrivenQueryTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSDataDrivenQueryTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=DTSDataDrivenQueryTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value={1002090D-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090D-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSDataDrivenQueryTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090D-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSDataDrivenQueryTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090D-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090D-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=DTSTransferObjectsTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSTransferObjectsTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=DTSTransferObjectsTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value={1002090E-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090E-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSTransferObjectsTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090E-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSTransferObjectsTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090E-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090E-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=DTSSendMailTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSSendMailTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=DTSSendMailTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value={1002090F-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090F-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSSendMailTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090F-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=DTSSendMailTask,) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegOpenKey(,Key=CLSID\{1002090F-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:603]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{1002090F-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=DTSBulkInsertTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSBulkInsertTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=DTSBulkInsertTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value={10020910-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020910-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSBulkInsertTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020910-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSBulkInsertTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020910-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020910-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=DTSExecutePackageTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSExecutePackageTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=DTSExecutePackageTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value={10020912-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020912-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSExecutePackageTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020912-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSExecutePackageTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020912-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020912-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=DTSParallelDataPumpTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSParallelDataPumpTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=DTSParallelDataPumpTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value={10020911-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020911-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSParallelDataPumpTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020911-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=DTSParallelDataPumpTask,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020911-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegOpenKey(,Key=CLSID\{10020911-EB1C-11cf-AE6E-00AA004A34D5}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:619]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=DTSPackageDSO,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=Microsoft OLE DB Provider for DTS Packages,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=DTSPackageDSO\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value={10010031-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=DTSPackageDSO.2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=Microsoft OLE DB Provider for DTS Packages,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=DTSPackageDSO.2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value={10010031-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010031-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=DTSPackageDSO,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010031-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=DTSPackageDSO.2,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010031-EB1C-11cf-AE6E-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=DTSPackageDSO,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010031-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010031-EB1C-11cf-AE6E-00AA004A34D5}\OLE DB Provider,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=Microsoft OLE DB Provider for DTS Packages,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=DTSRowQueue\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value={10010032-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=DTSRowQueue.2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value={10010032-EB1C-11cf-AE6E-00AA004A34D5},) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010032-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=DTSRowQueue,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010032-EB1C-11cf-AE6E-00AA004A34D5}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=DTSRowQueue.2,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010032-EB1C-11cf-AE6E-00AA004A34D5}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=DTSRowQueue,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10010032-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{1001000A-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=DTSRunPackage,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{1001000A-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10020103-EB1C-11cf-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=DTSRepositoryManager,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegOpenKey(,Key=CLSID\{10020103-EB1C-11cf-AE6E-00AA004A34D5}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtspkg.DLL,) MSI (s) (F0:A8) [11:33:27:634]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSDynamicPropertiesTask.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSDynamicPropertiesTask Class,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSDynamicPropertiesTask.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value={CF1988D3-E143-11D2-AB67-00C04F79EE8C},) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSDynamicPropertiesTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSDynamicPropertiesTask Class,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSDynamicPropertiesTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value={CF1988D3-E143-11D2-AB67-00C04F79EE8C},) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSDynamicPropertiesTask\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSDynamicPropertiesTask.1,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=CLSID\{CF1988D3-E143-11D2-AB67-00C04F79EE8C},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSDynamicPropertiesTask Class,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(Name=DTSIconFile,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(Name=DTSIconIndex,Value=#0,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(Name=DTSTaskDescription,Value=Dynamic Properties Task,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=CLSID\{CF1988D3-E143-11D2-AB67-00C04F79EE8C}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSDynamicPropertiesTask,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=CLSID\{CF1988D3-E143-11D2-AB67-00C04F79EE8C}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSDynamicPropertiesTask,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=CLSID\{CF1988D3-E143-11D2-AB67-00C04F79EE8C}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=CLSID\{CF1988D3-E143-11D2-AB67-00C04F79EE8C}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=CLSID\{CF1988D3-E143-11D2-AB67-00C04F79EE8C}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value={CF1988C5-E143-11D2-AB67-00C04F79EE8C},) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=CLSID\{CF1988D3-E143-11D2-AB67-00C04F79EE8C}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSFTPTask.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSFTPTask Class,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSFTPTask.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value={0E090A39-E613-11D2-ACED-00C04F689068},) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSFTPTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSFTPTask Class,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSFTPTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value={0E090A39-E613-11D2-ACED-00C04F689068},) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=DTSFTPTask\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSFTPTask.1,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegOpenKey(,Key=CLSID\{0E090A39-E613-11D2-ACED-00C04F689068},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(,Value=DTSFTPTask Class,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(Name=DTSIconFile,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL,) MSI (s) (F0:A8) [11:33:27:650]: Executing op: RegAddValue(Name=DTSIconIndex,Value=#1,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(Name=DTSTaskDescription,Value=File Transfer Protocol Task,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{0E090A39-E613-11D2-ACED-00C04F689068}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=DTSFTPTask,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{0E090A39-E613-11D2-ACED-00C04F689068}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=DTSFTPTask,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{0E090A39-E613-11D2-ACED-00C04F689068}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{0E090A39-E613-11D2-ACED-00C04F689068}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{0E090A39-E613-11D2-ACED-00C04F689068}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value={96501C1E-E633-11D2-ACED-00C04F689068},) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{0E090A39-E613-11D2-ACED-00C04F689068}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=DTSMessageQueueTask.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=DTSMessageQueueTask Class,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=DTSMessageQueueTask.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value={4C237FFF-FC07-11D2-ACF5-00C04F689068},) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=DTSMessageQueueTask,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=DTSMessageQueueTask Class,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=DTSMessageQueueTask\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value={4C237FFF-FC07-11D2-ACF5-00C04F689068},) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=DTSMessageQueueTask\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=DTSMessageQueueTask.1,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{4C237FFF-FC07-11D2-ACF5-00C04F689068},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=DTSMessageQueueTask Class,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(Name=DTSIconFile,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(Name=DTSIconIndex,Value=#2,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(Name=DTSTaskDescription,Value=Message Queue Task,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{4C237FFF-FC07-11D2-ACF5-00C04F689068}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=DTSMessageQueueTask,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{4C237FFF-FC07-11D2-ACF5-00C04F689068}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=DTSMessageQueueTask,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{4C237FFF-FC07-11D2-ACF5-00C04F689068}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{4C237FFF-FC07-11D2-ACF5-00C04F689068}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\custtask.DLL,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegOpenKey(,Key=CLSID\{4C237FFF-FC07-11D2-ACF5-00C04F689068}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:666]: Executing op: RegAddValue(,Value={4C237FF2-FC07-11D2-ACF5-00C04F689068},) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{4C237FFF-FC07-11D2-ACF5-00C04F689068}\Implemented Categories\{10020200-EB1C-11CF-AE6E-00AA004A34D5},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010400-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=Copy Column,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010501-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=ActiveX Script,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010701-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=Uppercase String,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010801-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=Lowercase String,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010901-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=Middle of String,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010a01-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=Read File,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010b01-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=DateTime String,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010c01-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=Write File,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{10010d01-740B-11D0-AE7B-00AA004A34D5}\DTSTransform\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTransformDescription,Value=Trim String,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{CF1988D3-E143-11D2-AB67-00C04F79EE8C}\DTSTask\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSIconFile,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\custtask.RLL,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSIconIndex,Value=#0,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTaskDescription,Value=Dynamic Properties Task,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{0E090A39-E613-11D2-ACED-00C04F689068}\DTSTask\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSIconFile,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\custtask.RLL,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSIconIndex,Value=#1,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTaskDescription,Value=File Transfer Protocol Task,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{4C237FFF-FC07-11D2-ACF5-00C04F689068}\DTSTask\1033,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSIconFile,Value=C:\Program Files\Microsoft SQL Server\80\Tools\Binn\Resources\1033\custtask.RLL,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSIconIndex,Value=#2,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DTSTaskDescription,Value=Message Queue Task,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2D6-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(,Value=Microsoft SQLServer Stored Procedure Resolver,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(Name=DescriptiveString,Value=none,) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2D6-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:681]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\spresolv.dll,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2D6-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=Component Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=409,Value=SQL Server Conflict Resolvers,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DB-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,Value=Microsoft SQL Server Additive Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=DescriptiveString,Value=none,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DB-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\ssradd.dll,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DB-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DC-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,Value=Microsoft SQL Server Averaging Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DC-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\ssravg.dll,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DC-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DD-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,Value=Microsoft SQL Server Download Only Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=DescriptiveString,Value=none,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DD-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\ssrdown.dll,) MSI (s) (F0:A8) [11:33:27:697]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DD-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DE-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,Value=Microsoft SQL Server Maximum Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=DescriptiveString,Value=none,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DE-3FB3-11D3-A4DE-00C04F610189}\Aliases,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=Microsoft SQL Server DATETIME (Later Wins) Conflict Resolver,Value=Microsoft SQL Server DATETIME (Later Wins) Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=Microsoft SQL Server Priority Column Resolver,Value=Microsoft SQL Server Priority Column Resolver,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DE-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\ssrmax.dll,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DE-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DF-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,Value=Microsoft SQL Server Minimum Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=DescriptiveString,Value=none,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DF-3FB3-11D3-A4DE-00C04F610189}\Aliases,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=Microsoft SQL Server DATETIME (Earlier Wins) Conflict Resolver,Value=Microsoft SQL Server DATETIME (Earlier Wins) Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DF-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\ssrmin.dll,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2DF-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E0-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,Value=Microsoft SQL Server Subscriber Always Wins Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=DescriptiveString,Value=none,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E0-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\ssrpub.dll,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E0-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E2-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,Value=Microsoft SQL Server Upload Only Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(Name=DescriptiveString,Value=none,) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E2-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:712]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\ssrup.dll,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E2-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E1-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=Microsoft SQL Server Merge Text Columns Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(Name=DescriptiveString,Value=none,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E1-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\mergetxt.dll,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2E1-3FB3-11D3-A4DE-00C04F610189}\Implemented Categories\{AEF21081-CD22-11D2-A8E8-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=Microsoft SQL Replication Distributor,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distributor,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=Microsoft SQL Replication Distributor\Clsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value={08b0b2e3-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e3-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distributor,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e3-3fb3-11d3-a4de-00c04f610189}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distributor,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e3-3fb3-11d3-a4de-00c04f610189}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distributor,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e3-3fb3-11d3-a4de-00c04f610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\rdistcom.dll,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e3-3fb3-11d3-a4de-00c04f610189}\ThreadingModel,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=Both,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=SQLReplication.OLEDB\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value={10010100-D8C9-11D2-B67C-00C04F688F5E},) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=SQLReplication.OLEDB.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value={10010100-D8C9-11D2-B67C-00C04F688F5E},) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{10010100-D8C9-11D2-B67C-00C04F688F5E},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=SQLReplication.OLEDB,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{10010100-D8C9-11D2-B67C-00C04F688F5E}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=SQLReplication.OLEDB.1,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{10010100-D8C9-11D2-B67C-00C04F688F5E}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=SQLReplication.OLEDB,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{10010100-D8C9-11D2-B67C-00C04F688F5E}\InprocHandler32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=ole32.dll,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{10010100-D8C9-11D2-B67C-00C04F688F5E}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\repldts.dll,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegOpenKey(,Key=CLSID\{10010100-D8C9-11D2-B67C-00C04F688F5E}\OLE DB Provider,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:728]: Executing op: RegAddValue(,Value=SQL Server Replication OLE DB Provider for DTS,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{10010100-D8C9-11D2-B67C-00C04F688F5E}\ThreadingModel,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Both,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=Microsoft SQL Replication Snapshot,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Snapshot,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=Microsoft SQL Replication Snapshot\Clsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value={6bc1ccf6-bf94-11d2-b6db-00c04f688e8f},) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{6bc1ccf6-bf94-11d2-b6db-00c04f688e8f},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Snapshot,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{6bc1ccf6-bf94-11d2-b6db-00c04f688e8f}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Snapshot,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{6bc1ccf6-bf94-11d2-b6db-00c04f688e8f}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Snapshot,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{6bc1ccf6-bf94-11d2-b6db-00c04f688e8f}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\rinitcom.dll,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{6bc1ccf6-bf94-11d2-b6db-00c04f688e8f}\ThreadingModel,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Both,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=SQLReplErrors.SQLReplErrors.2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Errors Collection,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=SQLReplErrors.SQLReplErrors.2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value={08b0b2ea-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=SQLReplErrors.SQLReplErrors,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Errors Collection,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=SQLReplErrors.SQLReplErrors\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=SQLReplErrors.SQLReplErrors.2,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Errors Collection,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=SQLReplErrors.SQLReplErrors.2,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=SQLReplErrors.SQLReplErrors,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\replerrx.dll,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\Control,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\Insertable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\ToolboxBitmap32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\replerrx.dll, 202,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\MiscStatus,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=0,) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\MiscStatus\1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:744]: Executing op: RegAddValue(,Value=132497,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={08b0b2e9-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2ea-3fb3-11d3-a4de-00c04f610189}\Version,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=1.0,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=TypeLib\{08B0B2E9-3FB3-11D3-A4DE-00C04F610189}\1.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Errors 8.0,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=TypeLib\{08B0B2E9-3FB3-11D3-A4DE-00C04F610189}\1.0\0\Win32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\replerrx.dll,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=TypeLib\{08B0B2E9-3FB3-11D3-A4DE-00C04F610189}\1.0\FLAGS,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=0,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=TypeLib\{08B0B2E9-3FB3-11D3-A4DE-00C04F610189}\1.0\HELPDIR,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=installdir,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Interface\{35CE087B-2E4E-11D2-B6D4-00C04FB93D6B},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=ISQLReplErrors,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=ISQLReplErrors,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Interface\{35CE087B-2E4E-11D2-B6D4-00C04FB93D6B}\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Interface\{35CE087B-2E4E-11D2-B6D4-00C04FB93D6B}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Interface\{35CE087B-2E4E-11D2-B6D4-00C04FB93D6B}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={E02C121D-C12A-11D2-B6DB-00C04F688E8F},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={E02C121D-C12A-11D2-B6DB-00C04F688E8F},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Interface\{2A744FF0-EEB0-11D2-A002-0080C7FDD26E},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=_ReplErrorEvents,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Interface\{2A744FF0-EEB0-11D2-A002-0080C7FDD26E}\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={00020420-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Interface\{2A744FF0-EEB0-11D2-A002-0080C7FDD26E}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={00020420-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Interface\{2A744FF0-EEB0-11D2-A002-0080C7FDD26E}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={08B0B2E9-3FB3-11D3-A4DE-00C04F610189},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Microsoft SQL Replication Distribution Provider,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distribution Provider,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=Microsoft SQL Replication Distribution Provider\Clsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value={16D9A8E2-C326-11d0-94E9-00C04FC2DB9C},) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=CLSID\{16D9A8E2-C326-11d0-94E9-00C04FC2DB9C},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distribution Provider,) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegOpenKey(,Key=CLSID\{16D9A8E2-C326-11d0-94E9-00C04FC2DB9C}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:759]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distribution Provider,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{16D9A8E2-C326-11d0-94E9-00C04FC2DB9C}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distribution Provider,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{16D9A8E2-C326-11d0-94E9-00C04FC2DB9C}\ExtendedErrors,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Distribution Error lookup,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{16D9A8E2-C326-11d0-94E9-00C04FC2DB9C}\ExtendedErrors\{246CBC55-F3E8-11d0-9AEB-00C04FB6B6EF},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Error Lookup Service for Microsoft SQL Replication Distribution Provider,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{16D9A8E2-C326-11d0-94E9-00C04FC2DB9C}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\repldist.dll,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{16D9A8E2-C326-11d0-94E9-00C04FC2DB9C}\ThreadingModel,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{246CBC55-F3E8-11d0-9AEB-00C04FB6B6EF},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distribution Provider-Error Lookup,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{246CBC55-F3E8-11d0-9AEB-00C04FB6B6EF}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distribution Provider-Error Lookup,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{246CBC55-F3E8-11d0-9AEB-00C04FB6B6EF}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Distribution Provider-Error Lookup,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{246CBC55-F3E8-11d0-9AEB-00C04FB6B6EF}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\repldist.dll,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{246CBC55-F3E8-11d0-9AEB-00C04FB6B6EF}\ThreadingModel,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d5-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication SyncMgr Handler Version 8.0,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d5-3fb3-11d3-a4de-00c04f610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\replsync.dll,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{710B8A11-38A4-11d3-AE35-00C04F688E96},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Server DS Client UI Handler,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{710B8A11-38A4-11d3-AE35-00C04F688E96}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\repldsui.dll,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{8A23E65E-31C2-11D0-891C-00A024AB2DBB}\Forms\{710B8A11-38A4-11d3-AE35-00C04F688E96},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value={710B8A11-38A4-11d3-AE35-00C04F688E96},) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(Name=CLSID,Value={710B8A11-38A4-11d3-AE35-00C04F688E96},) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=ReplAgent.Distribution.2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Distribution Agent 8.0,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=ReplAgent.Distribution.2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value={08b0b2d7-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=ReplAgent.Distribution,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Distribution Agent,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=ReplAgent.Distribution\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=ReplAgent.Distribution.2,) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d7-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:775]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Distribution Agent 8.0,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(Name=AppID,Value={08b0b2d7-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d7-3fb3-11d3-a4de-00c04f610189}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=ReplAgent.Distribution.2,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d7-3fb3-11d3-a4de-00c04f610189}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=ReplAgent.Distribution,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d7-3fb3-11d3-a4de-00c04f610189}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d7-3fb3-11d3-a4de-00c04f610189}\LocalServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value="C:\Program Files\Microsoft SQL Server\80\COM\DISTRIB.exe",) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=AppID\{08b0b2d7-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Distribution Agent 8.0,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=ReplAgent.RemoteDistribution.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Remote Dist Agent 8.0,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=ReplAgent.RemoteDistribution.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value={B36EA3B4-9927-11d2-96EC-00C04F8EEDE6},) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=ReplAgent.RemoteDistribution,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Remote Dist Agent,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=ReplAgent.RemoteDistribution\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=ReplAgent.RemoteDistribution.1,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{B36EA3B4-9927-11d2-96EC-00C04F8EEDE6},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Remote Distribution Agent 8.0,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(Name=AppID,Value={B36EA3B4-9927-11d2-96EC-00C04F8EEDE6},) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{B36EA3B4-9927-11d2-96EC-00C04F8EEDE6}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=ReplAgent.RemoteDistribution.1,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{B36EA3B4-9927-11d2-96EC-00C04F8EEDE6}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=ReplAgent.RemoteDistribution,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{B36EA3B4-9927-11d2-96EC-00C04F8EEDE6}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{B36EA3B4-9927-11d2-96EC-00C04F8EEDE6}\LocalServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value="C:\Program Files\Microsoft SQL Server\80\COM\DISTRIB.exe",) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=AppID\{B36EA3B4-9927-11d2-96EC-00C04F8EEDE6},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Remote Dist Agent 8.0,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=ReplAgent.Snapshot.2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Snapshot Agent 8.0,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=ReplAgent.Snapshot.2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value={08b0b2d9-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=ReplAgent.Snapshot,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Snapshot Agent,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=ReplAgent.Snapshot\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=ReplAgent.Snapshot.2,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d9-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Snapshot Agent 8.0,) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(Name=AppID,Value={08b0b2d9-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d9-3fb3-11d3-a4de-00c04f610189}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:791]: Executing op: RegAddValue(,Value=ReplAgent.Snapshot.2,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d9-3fb3-11d3-a4de-00c04f610189}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=ReplAgent.Snapshot,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d9-3fb3-11d3-a4de-00c04f610189}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d9-3fb3-11d3-a4de-00c04f610189}\LocalServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value="C:\Program Files\Microsoft SQL Server\80\COM\snapshot.exe",) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=AppID\{08b0b2d9-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Snapshot Agent 8.0,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=SQLMerge.SQLMerge.2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=Microsoft SQL Merge,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=SQLMerge.SQLMerge.2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={08b0b2e8-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=SQLMerge.SQLMerge,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=Microsoft SQL Merge,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=SQLMerge.SQLMerge\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=SQLMerge.SQLMerge.2,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartner.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=AlternateSyncPartner Class,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=AlternateSyncPartner Class,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartner.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={0A98450E-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={0A98450E-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartner,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=AlternateSyncPartner Class,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=AlternateSyncPartner Class,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartner\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={0A98450E-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={0A98450E-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartner\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartner.1,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartner.1,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartners.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=AlternateSyncPartners Class,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=AlternateSyncPartners Class,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartners.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={0A984510-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={0A984510-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartners,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=AlternateSyncPartners Class,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=AlternateSyncPartners Class,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartners\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={0A984510-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value={0A984510-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegOpenKey(,Key=PolyHub.AlternateSyncPartners\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartners.1,) MSI (s) (F0:A8) [11:33:27:806]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartners.1,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=Microsoft SQL Merge,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=SQLMerge.SQLMerge.1,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=SQLMerge.SQLMerge,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\Control,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\Insertable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\ToolboxBitmap32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll, 201,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\Implemented Categories\{7DD95802-9882-11CF-9FA9-00AA006C42C4},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\MiscStatus,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=0,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\MiscStatus\1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=131473,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value={08b0b2e7-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e8-3fb3-11d3-a4de-00c04f610189}\Version,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=1.0,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{0A98450E-04A9-11D3-A8FB-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=AlternateSyncPartner Class,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=AlternateSyncPartner Class,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{0A98450E-04A9-11D3-A8FB-00C04F9FC436}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartner.1,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartner.1,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{0A98450E-04A9-11D3-A8FB-00C04F9FC436}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartner,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartner,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{0A98450E-04A9-11D3-A8FB-00C04F9FC436}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegOpenKey(,Key=CLSID\{0A98450E-04A9-11D3-A8FB-00C04F9FC436}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll,) MSI (s) (F0:A8) [11:33:27:822]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=CLSID\{0A98450E-04A9-11D3-A8FB-00C04F9FC436}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={0A984501-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={0A984501-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=CLSID\{0A984510-04A9-11D3-A8FB-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=AlternateSyncPartners Class,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=AlternateSyncPartners Class,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=CLSID\{0A984510-04A9-11D3-A8FB-00C04F9FC436}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartners.1,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartners.1,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=CLSID\{0A984510-04A9-11D3-A8FB-00C04F9FC436}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartners,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=PolyHub.AlternateSyncPartners,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=CLSID\{0A984510-04A9-11D3-A8FB-00C04F9FC436}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=CLSID\{0A984510-04A9-11D3-A8FB-00C04F9FC436}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=CLSID\{0A984510-04A9-11D3-A8FB-00C04F9FC436}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={0A984501-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={0A984501-04A9-11D3-A8FB-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Component Categories\{7DD95801-9882-11CF-9FA9-00AA006C42C4},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=409,Value=Controls that are safely scriptable,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=409,Value=Controls that are safely scriptable,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=409,Value=Controls that are safely scriptable,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Component Categories\{7DD95802-9882-11CF-9FA9-00AA006C42C4},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=409,Value=Controls safely initializable from persistent data,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=409,Value=Controls safely initializable from persistent data,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=409,Value=Controls safely initializable from persistent data,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Interface\{84923188-F94B-11d0-A8E8-00C04FC2DEB3},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=ISQLMerge,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Interface\{84923188-F94B-11d0-A8E8-00C04FC2DEB3}\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Interface\{84923188-F94B-11d0-A8E8-00C04FC2DEB3}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Interface\{84923188-F94B-11d0-A8E8-00C04FC2DEB3}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={08b0b2e7-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Interface\{84923186-F94B-11d0-A8E8-00C04FC2DEB3},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value=_SQLMergeEvents,) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Interface\{84923186-F94B-11d0-A8E8-00C04FC2DEB3}\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={00020420-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegOpenKey(,Key=Interface\{84923186-F94B-11d0-A8E8-00C04FC2DEB3}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:837]: Executing op: RegAddValue(,Value={00020420-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{84923186-F94B-11d0-A8E8-00C04FC2DEB3}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value={08b0b2e7-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{0A98450D-04A9-11D3-A8FB-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=IAlternateSyncPartner,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{0A98450D-04A9-11D3-A8FB-00C04F9FC436}\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{0A98450D-04A9-11D3-A8FB-00C04F9FC436}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{0A98450D-04A9-11D3-A8FB-00C04F9FC436}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value={08b0b2e7-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{0A98450F-04A9-11D3-A8FB-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=IAlternateSyncPartners,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{0A98450F-04A9-11D3-A8FB-00C04F9FC436}\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{0A98450F-04A9-11D3-A8FB-00C04F9FC436}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=Interface\{0A98450F-04A9-11D3-A8FB-00C04F9FC436}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value={08b0b2e7-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=TypeLib\{08b0b2e7-3fb3-11d3-a4de-00c04f610189}\1.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=Microsoft SQL Merge Control 8.0,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=TypeLib\{08b0b2e7-3fb3-11d3-a4de-00c04f610189}\1.0\0\Win32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlmergx.dll,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=TypeLib\{08b0b2e7-3fb3-11d3-a4de-00c04f610189}\1.0\FLAGS,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=0,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=TypeLib\{08b0b2e7-3fb3-11d3-a4de-00c04f610189}\1.0\HELPDIR,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=installdir,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=SQLSnapshot.SQLSnapshot.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=Microsoft SQL Snapshot,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=SQLSnapshot.SQLSnapshot.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value={E02C121F-C12A-11d2-B6DB-00C04F688E8F},) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=SQLSnapshot.SQLSnapshot,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=Microsoft SQL Snapshot,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=SQLSnapshot.SQLSnapshot\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=SQLSnapshot.SQLSnapshot.1,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=Microsoft SQL Snapshot,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=SQLSnapshot.SQLSnapshot.1,) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:853]: Executing op: RegAddValue(,Value=SQLSnapshot.SQLSnapshot,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlinitx.dll,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\Implemented Categories\{7DD95802-9882-11CF-9FA9-00AA006C42C4},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\Control,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\Insertable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\ToolboxBitmap32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlinitx.dll, 201,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\MiscStatus,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=0,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\MiscStatus\1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=131473,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value={E02C121D-C12A-11d2-B6DB-00C04F688E8F},) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=CLSID\{E02C121F-C12A-11d2-B6DB-00C04F688E8F}\Version,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=1.0,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=Interface\{E02C121C-C12A-11d2-B6DB-00C04F688E8F},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=ISQLSnapshot,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=Interface\{E02C121C-C12A-11d2-B6DB-00C04F688E8F}\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=Interface\{E02C121C-C12A-11d2-B6DB-00C04F688E8F}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=Interface\{E02C121C-C12A-11d2-B6DB-00C04F688E8F}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value={E02C121D-C12A-11d2-B6DB-00C04F688E8F},) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=Interface\E02C121E-C12A-11d2-B6DB-00C04F688E8F,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=_SQLSnapshotEvents,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=Interface\E02C121E-C12A-11d2-B6DB-00C04F688E8F\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value={00020420-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=Interface\E02C121E-C12A-11d2-B6DB-00C04F688E8F\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value={00020420-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=Interface\E02C121E-C12A-11d2-B6DB-00C04F688E8F\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value={E02C121D-C12A-11d2-B6DB-00C04F688E8F},) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=TypeLib\{E02C121D-C12A-11d2-B6DB-00C04F688E8F}\1.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=Microsoft SQL Snapshot Control 8.0,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=TypeLib\{E02C121D-C12A-11d2-B6DB-00C04F688E8F}\1.0\0\Win32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqlinitx.dll,) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegOpenKey(,Key=TypeLib\{E02C121D-C12A-11d2-B6DB-00C04F688E8F}\1.0\FLAGS,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:869]: Executing op: RegAddValue(,Value=0,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=TypeLib\{E02C121D-C12A-11d2-B6DB-00C04F688E8F}\1.0\HELPDIR,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=installdir,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{BB6AEB42-AA4B-11D2-AE19-00C04F688E96},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=Microsoft SQLServer Proxy Subscriber Replication Provider,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{BB6AEB42-AA4B-11D2-AE19-00C04F688E96}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\REPLPROX.dll,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2EC-3FB3-11D3-A4DE-00C04F610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=Subscriber Replication Component,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{08B0B2EC-3FB3-11D3-A4DE-00C04F610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\REPLSUB.dll,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{f3f59b02-752e-11d3-b734-00c04f688e8f},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=Replication Schema Translation Component,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{f3f59b02-752e-11d3-b734-00c04f688e8f}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\REPLSUB.dll,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=SQL.Replication.Conflict.Resolver.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=Microsoft SQL Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=SQL.Replication.Conflict.Resolver.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value={16469B61-92F0-11d2-A8DC-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=SQL.Replication.Conflict.Resolver,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=Microsoft SQL Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=SQL.Replication.Conflict.Resolver\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value={16469B61-92F0-11d2-A8DC-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{2FAD19D0-E309-11D2-B6E5-00C04F688E8F},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=Microsoft SQLServer Database Reconciler,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{2FAD19D0-E309-11D2-B6E5-00C04F688E8F}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\replrec.dll,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{37E95A52-1CA3-11D0-A11B-00AA003E4672},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=PSFactoryBuffer,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{37E95A52-1CA3-11D0-A11B-00AA003E4672}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\replrec.dll,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{16469B61-92F0-11d2-A8DC-00C04F9FC436},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=Microsoft SQL Conflict Resolver,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{16469B61-92F0-11d2-A8DC-00C04F9FC436}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=SQL.Replication.Conflict.Resolver.1,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{16469B61-92F0-11d2-A8DC-00C04F9FC436}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,Value=SQL.Replication.Conflict.Resolver,) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegOpenKey(,Key=CLSID\{16469B61-92F0-11d2-A8DC-00C04F9FC436}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:884]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=CLSID\{16469B61-92F0-11d2-A8DC-00C04F9FC436}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\replrec.dll,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=CLSID\{16469B61-92F0-11d2-A8DC-00C04F9FC436}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value={16469B60-92F0-11d2-A8DC-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{37E95A52-1CA3-11D0-A11B-00AA003E4672},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=IConnectionInfo,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{37E95A52-1CA3-11D0-A11B-00AA003E4672}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value={37E95A52-1CA3-11D0-A11B-00AA003E4672},) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{37E95A52-1CA3-11D0-A11B-00AA003E4672}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value={16469B60-92F0-11d2-A8DC-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(Name=Version,Value=7.0,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{FC2F91C1-1CA2-11D0-A11B-00AA003E4672},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=ICustomResolver,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{FC2F91C1-1CA2-11D0-A11B-00AA003E4672}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value={37E95A52-1CA3-11D0-A11B-00AA003E4672},) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{FC2F91C1-1CA2-11D0-A11B-00AA003E4672}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value={16469B60-92F0-11d2-A8DC-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(Name=Version,Value=7.0,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{FC2F91C2-1CA2-11D0-A11B-00AA003E4672},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=IReplRowChange,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{FC2F91C2-1CA2-11D0-A11B-00AA003E4672}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value={37E95A52-1CA3-11D0-A11B-00AA003E4672},) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=Interface\{FC2F91C2-1CA2-11D0-A11B-00AA003E4672}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value={16469B60-92F0-11d2-A8DC-00C04F9FC436},) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(Name=Version,Value=7.0,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=TypeLib\{16469B60-92F0-11d2-A8DC-00C04F9FC436}\7.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=Microsoft SQL Replication Conflict Resolver Library,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=TypeLib\{16469B60-92F0-11d2-A8DC-00C04F9FC436}\7.0\0\Win32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\replrec.dll,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=TypeLib\{16469B60-92F0-11d2-A8DC-00C04F9FC436}\7.0\FLAGS,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=0,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=ReplAgent.Merge.2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Merge Agent 8.0,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=ReplAgent.Merge.2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value={08b0b2d8-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=ReplAgent.Merge,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Merge Agent,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=ReplAgent.Merge\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=ReplAgent.Merge.2,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d8-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Merge Agent 8.0,) MSI (s) (F0:A8) [11:33:27:900]: Executing op: RegAddValue(Name=AppID,Value={08b0b2d8-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d8-3fb3-11d3-a4de-00c04f610189}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=ReplAgent.Merge.2,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d8-3fb3-11d3-a4de-00c04f610189}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=ReplAgent.Merge,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d8-3fb3-11d3-a4de-00c04f610189}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2d8-3fb3-11d3-a4de-00c04f610189}\LocalServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value="C:\Program Files\Microsoft SQL Server\80\COM\replmerg.exe",) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=AppID\{08b0b2d8-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Merge Agent 8.0,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=ReplAgent.RemoteMerge.1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Remote Merge Agent 8.0,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=ReplAgent.RemoteMerge.1\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value={183141A8-992D-11d2-96EC-00C04F8EEDE6},) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=ReplAgent.RemoteMerge,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Remote Merge Agent,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=ReplAgent.RemoteMerge\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=ReplAgent.RemoteMerge.1,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{183141A8-992D-11d2-96EC-00C04F8EEDE6},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Remote Merge Agent 8.0,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(Name=AppID,Value={183141A8-992D-11d2-96EC-00C04F8EEDE6},) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{183141A8-992D-11d2-96EC-00C04F8EEDE6}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=ReplAgent.RemoteMerge.1,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{183141A8-992D-11d2-96EC-00C04F8EEDE6}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=ReplAgent.RemoteMerge,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{183141A8-992D-11d2-96EC-00C04F8EEDE6}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{183141A8-992D-11d2-96EC-00C04F8EEDE6}\LocalServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value="C:\Program Files\Microsoft SQL Server\80\COM\replmerg.exe",) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=AppID\{183141A8-992D-11d2-96EC-00C04F8EEDE6},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQL Server Replication Remote Merge Agent 8.0,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{EF43EC5A-7699-11D3-AE49-00C04F688E96},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQLServer Proxy Message Replication Provider,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{EF43EC5A-7699-11D3-AE49-00C04F688E96}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\MSGPROX.dll,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=SQLDistribution.SQLDistribution.2,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQL Distribution,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=SQLDistribution.SQLDistribution.2\CLSID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value={08b0b2e6-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=SQLDistribution.SQLDistribution,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQL Distribution,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=SQLDistribution.SQLDistribution\CurVer,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=SQLDistribution.SQLDistribution.2,) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:916]: Executing op: RegAddValue(,Value=Microsoft SQL Distribution,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\ProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=SQLDistribution.SQLDistribution.2,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\VersionIndependentProgID,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=SQLDistribution.SQLDistribution,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\Programmable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\InprocServer32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqldistx.dll,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\Control,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\Insertable,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\ToolboxBitmap32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=C:\Program Files\Microsoft SQL Server\80\COM\sqldistx.dll, 201,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\Implemented Categories\{7DD95802-9882-11CF-9FA9-00AA006C42C4},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\MiscStatus,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=0,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\MiscStatus\1,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=131473,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value={08b0b2e5-3fb3-11d3-a4de-00c04f610189},) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=CLSID\{08b0b2e6-3fb3-11d3-a4de-00c04f610189}\Version,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=1.0,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=Interface\{9BD37E1C-BB55-11D0-94E7-00C04FC2DB9C},,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=ISQLDistribution,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=Interface\{9BD37E1C-BB55-11D0-94E7-00C04FC2DB9C}\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=Interface\{9BD37E1C-BB55-11D0-94E7-00C04FC2DB9C}\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value={00020424-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=Interface\{9BD37E1C-BB55-11D0-94E7-00C04FC2DB9C}\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value={08B0B2E5-3FB3-11D3-A4DE-00C04F610189},) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=Interface\05E219F6-BB55-11D0-94E7-00C04FC2DB9C,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=_SQLDistributionEvents,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=Interface\05E219F6-BB55-11D0-94E7-00C04FC2DB9C\ProxyStubClsid,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value={00020420-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=Interface\05E219F6-BB55-11D0-94E7-00C04FC2DB9C\ProxyStubClsid32,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value={00020420-0000-0000-C000-000000000046},) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=Interface\05E219F6-BB55-11D0-94E7-00C04FC2DB9C\TypeLib,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value={08B0B2E5-3FB3-11D3-A4DE-00C04F610189},) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(Name=Version,Value=1.0,) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegOpenKey(,Key=TypeLib\{08B0B2E5-3FB3-11D3-A4DE-00C04F610189}\1.0,,BinaryType=0) MSI (s) (F0:A8) [11:33:27:931]: Executing op: RegAddValue(,Value=Microsoft SQL Distribution Control 8.0,) MSI (s) (F0:A8) [11:33:27:947]: Executing op: RegOpenKey(,Key=TypeLib\{0 |
