Single Public IP Address
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Single Public IP Address Page: [1]
Single Public IP Address - 10.Jan.2013 3:14:15 AM
johnrthompson
I hope you can help.
We only have 1 public IP address which is currently being used by our Cisco firewall's external interface. We would like to publish Exchange OWA/OA. At present I cannot NAT HTTPS on the public ip to our TMG box which is installed as a back firewall.
To get around this; my plan is to replace the Cisco firewall with the TMG as the Edge server. This would use the public ip address on the TMG external interface. I would then create a publishing rule for exchange and create DNS entries that direct external users to the single public IP on the TMG? Does this sound feasible or would I still hit the same problem of trying to NAT the external TMG interface? And do I require an additional public IP address as a minimum? As usual I am looking to avoid the heavy cost of another IP address!
All help gratefully appreciated,
John
RE: Single Public IP Address - 11.Jan.2013 4:06:34 PM
pwindell
There is nothing stopping you from doing it as it is now. The Cisco NATs from the External Interface of the Cisco to the External Interface of the ISA/TMG. The ISA/TMG than publishes it from there to the Exchange machine.
Phillip Windell
(in reply to johnrthompson)
RE: Single Public IP Address - 13.Jan.2013 10:03:53 AM
johnrthompson
Hi Phillip,
Thanks for your response much appreciated.
Firstly I wasn't sure that if the TMG server had two private IP addresses it would actually work. However you are suggesting the Cisco can have the public IP and the TMG can sit behind it and publish when it has private IP's?
In my first attempt to get it working I had developed some configuration from digging around on the internet.
Configure NAT
object network Forefront TMG
nat (inside,outside) static interface service tcp https https
Add ACL
access-list outside-acl permit tcp any host 'external private IP TMG' eq 443
access-group outside-acl in int outside
However the ACL just dropped the traffic. I struggled with troubleshooting it so any pointers on the configuration would be fantastic.
John
(in reply to pwindell)
RE: Single Public IP Address - 14.Jan.2013 8:43:50 AM
pwindell
If the ISA/TMG has and internal and an external interface (operating as the "back" firewall of a back-to-back DMZ design) then you should be able to get it done. It would have RFC private IPs on both sides of it however they would still be different subnets [networks] from each other and that is all that matters
Phillip Windell
RE: Single Public IP Address - 24.Oct.2015 12:27:06 AM
akashsharma
True Phillip Windell and John i have a some different option for you. you can use local server for your work.
I Think this is another option for you..
Akash
we are tour operator.
http://www.visittnt.com/rajasthan-travel/
http://www.visittnt.com/rajasthan-travel/rajasthan-tourist-attractions.html
http://www.visittnt.com/jaisalmer-tour/
